Other Platforms
> Ford Focus ST Ecoboost - Engine, Transmission & Driveline
  • 2 Post By SPEED6 KILLAH
 Old 01-17-2013, 08:36 PM   #1
WPaDave_ST's Avatar
Posts: 7   (View Stats)
WPaDave_ST has a spectacular aura aboutWPaDave_ST has a spectacular aura aboutWPaDave_ST has a spectacular aura about
Default Alternate Cylinder Heads for EcoBoost 2.0L
I have been trying to confirm if there is more than one Ford cylinder head for the 2.0L Ford EcoBoost engine.
I'm fairly certain the 2013 ST uses the cylinder head with the integral exhaust manifold. This is shown in the manual which has been posted. There are pics of a version of the engine shown in 2011 showing an external exhaust manifold. I'm not sure if this is only a prototype.
I have also read in other forums the cylinder head is different depending on the car model.
The integral exhaust manifold makes it difficult for porting and designing a custom exhaust manifold for larger turbos.
Any information is appreciated.
2013 PB Focus ST2
WPaDave_ST is offline   Reply With Quote
 Old 01-17-2013, 10:15 PM   #2
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
I have been working on a different cylinder head that will work and have bigger valves but haven't really release any info on it yet so stay tune
Here is a picture a picture of a nice manifold made
from fully race.
Raider and kritz like this.
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
Raider (01-18-2013)
 Old 01-18-2013, 08:09 AM   #3
WPaDave_ST's Avatar
Default Cylinder Head
Thanks, I'll be patient.
I'm not sure I understand Ford's thinking with the stock cylinder head and the integrated exhaust manifold. The way I understand the theory the exhaust gas energy should try and be conserved between the exhaust valve and the turbo inlet. This means keeping the velocity and temperature optimum. The integrated head rejects heat into the cooling system.
There are other discussions about the ST turbo having a special coating to withstand higher temps and then the head design appears to go in a different direction. I'd think the exhaust manifold should be insullated to reduce heat loss. I thought the manifold on the prototype motor looked neat because it appeared to be modular and possibly insullated.
Ford spent a lot of money making this motor efficient, I must be missing something!
2013 PB Focus ST2
 Old 01-18-2013, 10:23 AM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I think we're missing the requisite, "donate brownie faggot" in this thread.
A turbo as small as the st's is already a flame thrower for your 20 seconds of over boost.
Keeping the exhaust gasses as cool as possible, for it, is essential to it's longevity.
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 01-18-2013 at 10:23 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-19-2013, 11:58 AM   #5
WPaDave_ST's Avatar
Speed6 Killah,
For some reason your attached pic did not load when I looked at the thread at work.
Your exhaust manifold is a work of art, looks great.
Thanks,
Dave
2013 PB Focus ST2
 Old 01-19-2013, 12:39 PM   #6
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
My parts counter guys already left for the day. I'll try to remember to check with them on Monday.
 Old 01-19-2013, 02:33 PM   #7
Swapping heads is quite the bolt on upgrade - there's something in between there still using the OEM head and bolting on a larger turbo. A 2871 would be ideal.
ecoboost cylinder SPEED6 KILLAH Ford Focus ST Ecoboost - General Discussion 21 09-16-2012 10:14 PM
Euro-Fords first to get four-cylinder EcoBoost this summer Haltech Automotive News 0 03-01-2010 09:50 AM
Ford all but confirms four-cylinder Ecoboost for next Explorer Haltech Automotive News 0 01-10-2010 09:30 AM
Ford officially confirms four-cylinder Ecoboost Haltech Automotive News 0 07-21-2009 12:10 PM
Ford considering four-cylinder EcoBoost for F150 Haltech Automotive News 0 07-13-2008 11:50 PM
Page generated in 0.29736 seconds with 25 queries
