Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Like Tree287Likes
 Old 08-02-2011, 01:37 PM   #81
conso's Avatar
Posts: 186   (View Stats)
conso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the world
anyone hav a clutch and flywheel they want to giv me cause iv been waiting bout a month for mine now, figured i post and say that im still alive, car is still a go but this is the last piece i need to finish this thing but on a better note i did buy some 15x9s for the miata WIN
07 speed3, vivid has my car under house arrest
03 miata, top down
conso is offline   Reply With Quote
The Following User Says Thank You to conso For This Useful Post:
802MS3 (08-02-2011)
 Old 08-02-2011, 05:45 PM   #82
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
Originally Posted by JMEngineer View Post
... did you have to supply a head on top of that or does that include a core charge?
and will you still be using stock cams?
you have to supply your head take about 4 to 5 weeks to get done and you can use the stock cams. I will be using custom cams
I'll be on my honeymoon for the first half of October so I'll be looking forward to some results when I get back!
Its it should be done I just have to get my girl's baby shower out the way first lol..
SPEED6 KILLAH is offline   Reply With Quote
 Old 08-02-2011, 05:59 PM   #83
okay i just got the motor put together just waiting on a few things.... I am currently working on the fuel system problem now.. I figured it out and I just recevied my additional injector controller that I will be using.. It has two independent maps can control up to four inJectors. Map A can drive two low or high impedance injectors. Map B can drive two high impedance injectors. I will be having it working with the map sensor which is 3 1/2 bars. The way it will work will be in two different ways, one on high boost and one on low boost. Currently looking for the high impedance injectors and I'm about to send out the intake manifold. Here are some pix of the controller .. I am currently looking for people who are interested in helping me tune it.
The Following 9 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
Alpha (08-03-2011), djuosnteisn (08-03-2011), doubleflusher (08-02-2011), dougefresh_ (08-03-2011), i8urgti (08-06-2011), ms3blackmica (05-18-2013), rfinkle2 (05-18-2013), SpeedSixxx (10-14-2011), topher3134 (08-02-2011)
 Old 08-02-2011, 07:01 PM   #84
@djuosnteisn
lol
your using an AP right?
HES ALIVE!!!!
Last edited by superskaterxes; 08-02-2011 at 07:01 PM. Reason: MSF Database - Automerged Doublepost
djuosnteisn (08-03-2011), SpeedSixxx (10-14-2011)
 Old 08-02-2011, 07:19 PM   #85
[QUOTE=superskaterxes;968260]@djuosnteisn
lol
Yeah..
 Old 08-02-2011, 07:20 PM   #86
ok just making sure you werent headed for fail before u even started......
Alpha (08-03-2011)
 Old 08-02-2011, 08:06 PM   #87
Yeah I know what you mean..
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
superskaterxes (08-02-2011)
 Old 08-03-2011, 07:55 AM   #88
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
not to side track OP's thread.. but hows the speed3 ? conso ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 08-03-2011, 11:01 AM   #89
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Looks promising. Love the weld on injector holders, i've been looking at some of those too. They should work for what your going for. What kind of mandrel are you going to use to feed the inj's?
I think i'm gonna rig up an actual fuel rail on my setup. Don't think it'll be tooooo complicated.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 08-03-2011, 01:44 PM   #90
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
This thread is so much win...
Fatguy729 is offline   Reply With Quote
The Following User Says Thank You to Fatguy729 For This Useful Post:
BobtailedSnail (11-09-2011)
 Old 08-03-2011, 02:31 PM   #91
Thanks man. That good if you go with it. Not to complicated its the cost of getting everthing togther.. Well snice I decided to go with the port injection system at the top of the intake manifold have to go back to the drawing board. For how i am going to run the fuel off of the high pressure or run a sparate fuel tank.. I have to see what is going to be more efficiency and try to keep the cost down...
The Following 4 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
djuosnteisn (08-03-2011), dougefresh_ (08-03-2011), jracer (08-03-2011), SpeedSixxx (10-14-2011)
 Old 08-04-2011, 08:48 PM   #92
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
if i may ask what system is this that you are using?
track weight 3220
street weight 3370
 Old 08-04-2011, 09:20 PM   #93
split second..
 Old 08-08-2011, 07:19 PM   #94
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
I hate when people clog up a good thread with stupid fucking posts with no value other than to subscribe to the thread...
Go to thread tools and subscribe the right way. I don't know about anyone else, but I'd appreciate it if a mod would delete all the "subbed" posts.
Keep this shit clean
The Following 4 Users Say Thank You to jwilkins88 For This Useful Post:
Alpha (12-01-2011), Dano (08-09-2011), harryclay (08-09-2011), sleepyspeed6 (08-10-2011)
 Old 08-08-2011, 07:29 PM   #95
done!
Dano (08-09-2011), harryclay (08-09-2011), jwilkins88 (08-08-2011), NJSPEED3 (08-09-2011)
 Old 08-24-2011, 05:20 PM   #96
Here is the intake manifold that is almost completed. It has the port injectors on it the fuel rail that i am going to use...
The Following 17 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
802MS3 (08-24-2011), 86AmishMs3 (11-27-2011), BlueStreak (09-07-2011), BobtailedSnail (11-09-2011), Dano (08-25-2011), djuosnteisn (08-26-2011), doubleflusher (08-24-2011), essejkcamraw (08-27-2011), Fatguy729 (08-24-2011), Fobio (08-24-2011), I Love Brownies (08-25-2011), NJSPEED3 (08-26-2011), SpeedSixxx (10-14-2011), super_pablo_ (10-29-2011), taf0422 (10-29-2011), Tokay444 (08-25-2011), wette460 (11-11-2011)
 Old 08-24-2011, 05:45 PM   #97
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
Use some 3/8th quick disconnect fittings and hook up to the factory feed line from the intank fuel pump, Id suggest running a return style system, with an inline pump otherwise youll find out very quickly how week the factory pump is without some additional help.
You could always modify the factory fuel basket for a bigger fuel pump, but that is a pain in the ass to keep the stock fuel level indicator and bigger pump. Best to just keep everything outside the tank. That and the stock regulator isn't equipt to run more than 50-60PSI so you have a set fuel pressure and when you go into boost this fuel pressure will drop anything more than 15-25psi of boost and you could start to see eratic fuel spray patterns and loss of atomization of the fuel. You need some form of rising rate fuel pressure regulator.
pinkcheese is offline   Reply With Quote
 Old 08-24-2011, 05:53 PM   #98
Fatguy729's Avatar
Groans: 82
MOAR POWAH AND CLEAN INTAKE VALVES FTMFW!
 Old 08-24-2011, 07:51 PM   #99
will i am definitely upgrade in the fuel pump and the regulator is equipt to run more then 50 -60 psi ... stock 60—71...
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
djuosnteisn (08-26-2011), SpeedSixxx (10-14-2011)
 Old 08-24-2011, 08:20 PM   #100
whats the rail from? the injectors line up pretty good. how r you going to mount the rail? or is that not needed
 Old 08-24-2011, 08:46 PM   #101
The rail is from the regular 4 clyinder port injection mazda 6 .... He is going to weld a bracket on the manifold.. .
The Following 6 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
Black Metal (08-25-2011), djuosnteisn (08-26-2011), I Love Brownies (08-25-2011), qtrmile beast (08-27-2011), SpeedSixxx (10-14-2011), superskaterxes (08-25-2011)
 Old 08-26-2011, 10:02 AM   #102
Captain
Looks sweet man. Good job!
www.permtuning.com
qtrmile beast (08-27-2011), SPEED6 KILLAH (08-26-2011), SpeedSixxx (10-14-2011)
 Old 08-26-2011, 06:27 PM   #103
pinkcheese's Avatar
You should reconsider that fuel rail. If you plan to run high boost the rail isn't equipt to handle all that pressure. I had one bubble out and another which created a small leak after bubbling out with about 100 fuel PSI or so. The rails are made of stainless. But the material is very thin, Best option for something going to be pushing quite a bit of pressure it to get one of those universal rails and make one out of that to ensure proper safety.
That and the quick disconnect fittings for that rail are prone to leaking/breaking the design was never meant to handle all that pressure. Trust me I would know, hit 150psi of fuel one day on a road coarse and the line burst off during the back sweeper. Was able to maintain idle fuel pressure so I had to coast into the pit. Was not pleased.
 Old 08-26-2011, 07:19 PM   #104
Well sounds very interesting. I'm basically trying to run probably like between 90 to 100 psi's nothing over that.. I seen a couple of ppl who ran about 150 psi with fuel rail with no problems. It sounds like the bubble situation as caused your problem but I understand what you mean and I will take it under consideration but like I said before, I've seen ppl ran these fuel rails with no problem.
 Old 08-26-2011, 07:59 PM   #105
pinkcheese's Avatar
Aeromotive fittings will be your only salvation in keeping things safe then. The russell performance ones or similar designs while cheaper will not hold that type of pressure. The aeromotive fittings twice the price, have a higher pressure range from my expierence as they incorperate a diffferent design, and stronger plastic locking clip.
 Old 08-26-2011, 08:38 PM   #106
wtf would u want to run 100psi on a PI rail for? isent like 75ish considered pretty aggressive?
 Old 08-26-2011, 09:05 PM   #107
pinkcheese's Avatar
You run higher pressure to increase injector size.
 Old 08-26-2011, 09:48 PM   #108
bmylez's Avatar
Posts: 3,197   (View Stats)
Obviously this is a totally different setup, however, I know that on a typical PI car, FP at idle is about 43.5psi (at least on a Focus) and most guys running a return fuel setup would command a 1 psi increase in FP with every 1psi increase in boost. So someone running 30psi would still only need maybe 75psi. This was on injectors as large as 80 lbs/min, which would be more than enough as a secondary fuel system, since that setup can support 500whp by itself.
2007 CTS-V - Trying to sell
 Old 08-26-2011, 09:55 PM   #109
this is exactly what i was thinking in my head lol
 Old 08-27-2011, 03:05 PM   #110
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
or go with and EVO rail. There are only like 50 different options out there and they are already for boosted applications.
IIRC the injector spacing is about the same as our IM. I know you already have things welded up and ready to go but this could be a plan B if things don't work out.
 Old 08-27-2011, 05:55 PM   #111
Yeah I know.. I was looking into one of them before I decided to use the rail I have now to keep cost down..
 Old 08-27-2011, 07:06 PM   #112
you can use a fuel rail off the for probe, 626 turbo and mx6 turbo.. i can get one if you need one i just have to measure the length of it to make sure it is long enough.
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
SPEED6 KILLAH (08-27-2011)
 Old 08-27-2011, 07:47 PM   #113
Thanks I'll let you know.. I am just wait on couple thing before I start put it together ..
 Old 08-29-2011, 12:56 PM   #114
jonlax's Avatar
Posts: 312   (View Stats)
jonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the world
Let me start of by saying it took me time and research...
CUSTOM DARTON DRY SLEEVE WITH OUT NO FLANGE... Hold up well over 30 psi..
APR MAIN STUD
APR HEAD STUD
CP PISTON 8:5.1 & 20 OVER
CARRILLO FORGED CONNECTING RODS
CODING CRANK BEARING, ROD BEARING FROM "CALICO COATINGS"
FULLY BUILT CYLINDER HEAD FROM "COMPTECH RACING"
PORT & POLISH INTAKE/EXHAUST SIDE
UPGRANDED FERREA INTAKE VALVES AND CUSTOM FERREA EXHAUST VALVES
M-6 VALVE GUIDE
COSWORTH RACE VALVE SPRING ...
PORT AND POLISH INTAKE MANIFOLD..
I was wondering your opinion of the coatings calico did? In 2004 i had them, threw rotorsports do a full coating of my 1991 RX7 build i did. I though the thing was nuke proof which it turned out to be untill i left for the army. While i was gone i asked my mother to start the car once a week. Well long story short she let my brother do it and he though it was a good idea to red line it. Now noted i did have a 10k redline with my set up. The engine lasted for a full year of that but shortly after i returned home for leave it blew under low boost at 4k partial throttle. Strong shit if you ask me!
Anyway what coatings did you get done?
jonlax is offline   Reply With Quote
 Old 08-29-2011, 06:56 PM   #115
CT-1 for the engine bearing
CT-3 psiton skirts
 Old 09-06-2011, 09:30 PM   #116
Default update
Got everthing put together just waiting on the exhaust manifold from @steedspeed and the turbo that should be in tomorrow. Here are some update pic...
The Following 15 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
bewsted (09-07-2011), BlueStreak (09-07-2011), Brian MP5T (09-07-2011), Broxer (09-07-2011), cld12pk2go (09-07-2011), Dano (09-07-2011), Dash08 (10-04-2011), DingoDave (11-16-2011), djuosnteisn (09-07-2011), doubleflusher (10-04-2011), JacksonMS30 (09-07-2011), NJSPEED3 (09-07-2011), predapio (09-07-2011), SpeedSixxx (10-14-2011), zpele (09-08-2011)
 Old 09-07-2011, 06:53 AM   #117
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Brian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the world
Awesome, I love these types of threads...
Brian MP5T is offline   Reply With Quote
The Following User Says Thank You to Brian MP5T For This Useful Post:
SPEED6 KILLAH (09-07-2011)
 Old 09-07-2011, 08:59 AM   #118
Captain
You sure the hood will shut?
www.permtuning.com
 Old 09-07-2011, 09:00 AM   #119
jwilkins88's Avatar
Groans: 126
So you might have to cut a strip out of the hood... Big fucking deal
The Following 3 Users Say Thank You to jwilkins88 For This Useful Post:
ccspeedsix (09-07-2011), Dano (09-07-2011), djuosnteisn (09-07-2011)
The Following User Says NO Thank You to jwilkins88 For This Un-useful Post:
 Old 09-07-2011, 09:11 AM   #120
It will close...
djuosnteisn (09-07-2011), SpeedSixxx (10-14-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f658/all-out-mzr-engine-build-86131/
speedperf6rmanc3 - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-19-2014 04:48 PM
Engine build josh0408 MazdaSpeed 3/6 - Big Turbo Builds 5 12-28-2010 07:15 PM
Researching Engine (re)Build hnda etr MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-16-2010 09:40 PM
My Forged Engine Build JumpingJackson MazdaSpeed 6 - Engine, Transmission & Driveline 156 03-06-2010 04:26 PM
DCR Engine build FTW !!!! flyrevs2 MazdaSpeed 3 - Engine, Transmission & Driveline 28 10-11-2009 10:20 AM
Page generated in 0.59117 seconds with 33 queries
