Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Like Tree19Likes
 Old 10-06-2015, 03:19 PM   #41
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Can you double the head gaskets up?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-19-2015, 06:21 PM   #42
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
So I am using this head gasket on a motor I am building for a local, long story short he went with +1 exhaust valves and didn't get the top of the valve shaved down to fit his buckets. So I had to pull the head off and this is how hard this gasket bites.
excuse the potato camera
Realgib3 likes this.
2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller
HOCKEYNUBE is offline   Reply With Quote
The Following 5 Users Say Thank You to HOCKEYNUBE For This Useful Post:
Code Monkey (10-19-2015), impossible (02-05-2017), ItsNox (11-28-2015), Mauro_Penguin (10-20-2015), Mazdazilla6 (10-19-2015)
 Old 10-19-2015, 08:06 PM   #43
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
So, it dented the block?
 Old 10-19-2015, 08:12 PM   #44
HOCKEYNUBE's Avatar
No it did not dent the block, that is the the gasket material that was left behind because of how tight the seal is to the block after the head has been torqued down
The Following 3 Users Say Thank You to HOCKEYNUBE For This Useful Post:
Enki (10-19-2015), impossible (02-05-2017), Mauro_Penguin (10-20-2015)
 Old 11-27-2015, 09:46 PM   #45
SNOW_QN's Avatar
Posts: 384   (View Stats)
@HOCKEYNUBE; Did you get my pm?
Has anyone else been able to pick up one of these head gaskets? Would like to pick one of these up.
 Old 01-02-2016, 04:00 PM   #46
Elrodd's Avatar
Posts: 274   (View Stats)
Elrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond reputeElrodd has a reputation beyond repute
I'm also trying to get answers on this as well, I'm needing to make up quite a bit of lost material.
2006 Mazdaspeed6 GT #3352 137k mi.
Nav deleted for Galaxy Tab 2 mod because it was shithouse and an Auzmod to keep my sat and such (like a bawss)
GenPu engine:
Poor Man's EBCS ($20, can't beat it)
HTP 3.5
CP-E Fuel injector seals
Custom TR8 FMIC, Mazo catless DP in to 3 IN Corksport exhaust, TMM inserts
Relentless P&P Intake Manifold
Damond EGR delete, OCC, PCV Plate
Autotech HPFP
JBR RMM,weight and Shift knob
Ralco Short Throw shifter
ACT Stage 3 Clutch
H&R Springs
EVO VIII Wheels
SP63 PTO caps
Purple Drank e30 tuned
Soon to come: Gen 2 gear swap, rear diff mounts, PMM, Holset HX35 and focus log mani with EWG
Elrodd is offline   Reply With Quote
 Old 01-02-2016, 04:08 PM   #47
SNOW_QN's Avatar
This head gasket is only 0.034" thick(stock is 0.030). Depending on how much material was removed, you may need something with a little more meat.
Edge and RPM sell cometic head gaskets that are 0.051" and 0.075" if you need a thicker one
Cometic Head Gasket Mazdaspeed 3 6 MS3 MS6 MZR 2.3L
Cometic Head Gasket for Mazdaspeed 3 / 6 / CX-7 #C4481 - Revolution Performance Motorsports!
Elrodd likes this.
The Following User Says Thank You to SNOW_QN For This Useful Post:
Elrodd (01-02-2016)
 Old 01-02-2016, 07:28 PM   #48
Elrodd's Avatar
Thank you for the links. I keep hearing from many people that cometics are a no go, but that seems to be my only option at this point. Wish me luck! Hopefully with both the head and block milled to 50 RA, it holds.
SNOW_QN likes this.
GenPu engine:
HTP 3.5
Autotech HPFP
ACT Stage 3 Clutch
H&R Springs
EVO VIII Wheels
SP63 PTO caps
 Old 01-02-2016, 07:36 PM   #49
LumberJack's Avatar
Groans: 57
@mazdafreak;
10.36@148 Fastest Gen 2
 Old 01-02-2016, 08:01 PM   #50
SNOW_QN's Avatar
Wish I could help ya there, but I don't know enough about surface roughness to say it will be good or not. Hopefully someone else chimes in on that.
 Old 01-04-2016, 08:42 AM   #51
Realgib3's Avatar
Posts: 2,443   (View Stats)
50 RA is quite rough, but may hold alright, at least for a while.
Also, shelf cometics are worse than OEM and are completely different than this. Lastly, you do not want to go with a thick ass gasket to make up for the amount machined off. It's all bad news when you do that, mostly because you become more knock prone.
You can pick up a used head for cheap if you're past the service limit from cutting it too much and that would be a better way to go in the long run.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
Mauro_Penguin (01-04-2016), pmartz16 (01-04-2016)
 Old 02-19-2016, 10:58 AM   #52
HOCKEYNUBE's Avatar
sorry for not replying to earlier comments, I wasn't getting notifications for them. like the guy above me said you shouldn't go that thick on a head gasket but this gasket can be made in almost any thickness but it'll have to be special ordered.
But the main reason I came back to this thread was to provide a little update to how mine is doing, I ended the year last year at 32 psi and making somewhere between 500 and 550 WHP (never took it to a real dyno) and I have 210 psi compression across the bored in my cylinders. I don't want to jinx myself so I wont say what I want to about it. I'm putting a 6266 on this year and swapping the meth for a 6th port so well see how she holds up to more power this year, ill keep coming back if anyone is curious.
Mauro_Penguin and jtday like this.
The Following 7 Users Say Thank You to HOCKEYNUBE For This Useful Post:
ButtholeRedMS3 (02-19-2016), Code Monkey (02-19-2016), Enki (02-19-2016), Mauro_Penguin (02-20-2016), Mazdazilla6 (02-19-2016), Realgib3 (02-23-2016), SpeedRebirth (02-20-2016)
 Old 09-27-2016, 10:21 PM   #53
Billy626's Avatar
Posts: 16   (View Stats)
Billy626 has a spectacular aura aboutBilly626 has a spectacular aura aboutBilly626 has a spectacular aura about
@HOCKEYNUBE;
I am getting ready to put my engine together and had contacted cometic a while back about your gaskets. I was told I could order them but it would be a couple days before they would send out since they were custom. I went to see how to order them yesterday and now they say I need you in order to order the head gasket. I am looking to get the head gasket in a 0.040" thickness and standard head stud size and the same 88mm bore size you mentioned. I need this gasket pretty soon. Can you help me get one?
Billy626 is offline   Reply With Quote
 Old 09-27-2016, 10:28 PM   #54
Enki's Avatar
Groans: 189
Better yet call them up and tell them that these are fair game for all so you don't have to be brought in to authorize them to make it every time.
Mauro_Penguin (09-28-2016)
 Old 09-28-2016, 01:31 PM   #55
Billy626's Avatar
Any body know how to get a hold of hockeynube? I still cant pm im still a nube!!!
 Old 09-28-2016, 01:53 PM   #56
wes3id's Avatar
Posts: 611   (View Stats)
Kevin (hockeynube) does not really frequent the site much anymore. i will give a text and let him know, there are a few people interested in getting gaskets. FYI... he works nights and is in the middle of a move, so it may take a couple days to get a reply.
wes3id is offline   Reply With Quote
The Following 2 Users Say Thank You to wes3id For This Useful Post:
Billy626 (09-30-2016), Code Monkey (09-28-2016)
 Old 09-28-2016, 02:49 PM   #57
Billy626's Avatar
Sounds good thank you so much!!!
 Old 09-28-2016, 07:33 PM   #58
SpeedyTurd's Avatar
Posts: 35   (View Stats)
SpeedyTurd has a spectacular aura aboutSpeedyTurd has a spectacular aura aboutSpeedyTurd has a spectacular aura about
Looks like it's a solid product. I'm interested as well!
SpeedyTurd is offline   Reply With Quote
 Old 09-28-2016, 07:37 PM   #59
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
A couple days ago I heard @EdgeAutosport.com; was looking into getting these for us.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 09-28-2016, 10:39 PM   #60
Billy626's Avatar
I dont understand why cometic doesnt just offer them. The first email I got back from them I thought I would just be able to order it. Then they said I would have to get it from their customer since it is a custom design by him. Maybe its just who i talked to or something? I thought someone had said they got one with no problem? Anyone have the secret code word you have to use to order this?
 Old 09-29-2016, 04:58 PM   #61
wes3id's Avatar
@EdgeAutosport.com; does in fact have them listed on their website in multiple thicknesses.
 Old 09-29-2016, 05:05 PM   #62
wes3id's Avatar
Bad news for you guys looking to purchase custom gaskets from @HOCKEYNUBE; he is swamped with work and a move right now, and does not have the time to get in any orders for custom gaskets. Sorry guys, i tried to help you out.
@Realgib3; are you able to get the custom gaskets from cometic? or is Kevin the only true contact?
The Following User Says Thank You to wes3id For This Useful Post:
 Old 09-29-2016, 05:28 PM   #63
I was referring to these custom ones.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 09-29-2016, 09:27 PM   #64
Billy626's Avatar
@wes3id; thanks for trying. I guess he couldnt just call them and tell them to let us order them directly from them could he? Anybody got any recommendations on a good head gasket if I cant get this custom one?
 Old 09-29-2016, 09:54 PM   #65
Plenty of power has been made on the stock gasket.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
WetzMS3 (09-30-2016)
 Old 09-30-2016, 07:03 AM   #66
wes3id's Avatar
^^^^This is true. You only really need one if you are looking to push some crazy power and/or using larger head studs.
 Old 09-30-2016, 08:54 AM   #67
Tokay444's Avatar
Groans: 793
I need the .071" thick one...
Demodded.
The Seals
 Old 09-30-2016, 11:09 AM   #68
Billy626's Avatar
So do they make the oem head gasket in different sizes?
 Old 09-30-2016, 11:12 AM   #69
wes3id's Avatar
Here.
 Old 09-30-2016, 11:48 AM   #70
Billy626's Avatar
So just got off the phone with cometic. Ordered the timing cover gasket. And having them make a head gasket to match my new bore size 88mm and going with .04 thickness. Thank you everyone for your help
The Following User Says Thank You to Billy626 For This Useful Post:
 Old 06-22-2017, 09:18 AM   #71
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Just ordered the timing cover gasket as well.
For anyone else interested the part number is EC1948018AFM.
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
Code Monkey (06-22-2017), JSmith (06-22-2017)
 Old 06-22-2017, 10:43 AM   #72
Billy626's Avatar
I used some high tack gasket sealer from loctite to hold it in place. Worked like a charm!!!
 Old 06-23-2017, 05:31 AM   #73
HOCKEYNUBE's Avatar
Jesus Christ you guys I just got the first email saying someone replied to this thread, I am so terribly sorry... I sold my car and don't really have a reason to come on the forums anymore... my name is Kevin kubec find me on Facebook and shoot me a message if you ever need help with these... I've told them before that anyone can buy it from them cuz I didn't care. I'm pretty sure multiple people have called them and got it before.
Again I'm super sorry about not getting back to you guys, this forum is trash with notifying.
The Following User Says Thank You to HOCKEYNUBE For This Useful Post:
Code Monkey (06-23-2017)
 Old 06-27-2017, 10:04 AM   #74
Posts: 2,237   (View Stats)
Let us know how good does it seal And if it make the job easier to put back the timing cover ?
 Old 06-28-2017, 04:08 PM   #75
Groans: 60
Still have no tracking number or gasket, and the pending charge has disappeared...
Looks like I'm going to call Cometic tomorrow.
Jeff23spl (06-29-2017)
 Old 06-29-2017, 08:39 AM   #76
ok if you finally get it and use it, i'm interested to know how it goes...
I used the grey silicone stuff at first for my cover, it was leaking a lot, i re-did it with right stuff and had a hard time putting it back there in the car. An hardened gasket should make that step a lot easier.....The solid one won't get broken if you touch anything while putting back the cover...
 Old 10-23-2017, 04:25 PM   #77
eroler1's Avatar
Posts: 133   (View Stats)
eroler1 is just really niceeroler1 is just really niceeroler1 is just really niceeroler1 is just really nice
Sorry to revive this old thread but anybody else have a way to get this headgasket? I really don't want to bother kevin kubec but also I don't have Facebook to contact him, or any info I need when I call cometic? Or should I say his name and they would know?
eroler1 is offline   Reply With Quote
 Old 10-23-2017, 05:16 PM   #78
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
You've tried the part number I hope?
"For anyone else interested the part number is EC1948018AFM."
 Old 10-23-2017, 05:23 PM   #79
Billy626's Avatar
You can try. I ended up having them match my bore size and got the timing cover gasket.
 Old 10-23-2017, 05:36 PM   #80
eroler1's Avatar
Yeah the part number is for the timing cover, it's being sold by summit racing but for the head gasket kinda hard,
What did you told them? To get the head gasket
Did you mention Kevin kubec design?
Last edited by eroler1; 10-23-2017 at 05:52 PM. Reason: MSF Database - Automerged Doublepost
Page generated in 0.58365 seconds with 34 queries
