Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Like Tree115Likes
 Old 10-17-2012, 06:03 PM   #1
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Default The FAIL formerly known as "Dano's Drop-in Build"
So I guess I'll throw something together to chronicle my process on a drop in build. Not sure ATM how detailed I'll get or how informative this will end up being so stay tuned and we'll see what happens together.
So I knew I would approach a "build" like this for some time. I am not going for major HP or fame just want to keep my motor together for DD duties at 400-450WHP. Keeping it fun and on the edge of a true DD which mine currently is. I would like to thank Tom @MS3-a(sore)ASS-rex, for even giving me the idea to do something like this. I haven't put a motor together since my 302 back ...well in the early 80's for god sake...lol
Also want to thank a couple of the MSF pioneers in this area @chimmike and @Tomas for their contribution to this type of build. I suspect it will become extremely common for those wanting a lil insurance by adding some forged internals to their DD and I know a few other drop-ins are under way or in the planning stages like this one. Only time will tell how successful this will be but of course other platforms have been doing it for ages so how hard can it be cough subie cough 99.5 drop ins for example..some of those guys don't even measure the bores for god sake...I call it poke and hope.
I wasn't in any particular hurry and thought my tune would keep things together but recently my motor had other plans and is likely an outlier as to how it decided to..well perform less than optimally. Long story short, I believe I have lost a ringland in the #3 cylinder with the details being discussed here:
How bad is this-Oil everywhere
So I already knew some of what I would need and so had a small list compiled of the following:
Wiseco pistons and their brother's K1 rods
I am also running OE VVT from 07 so I will replace all the timing stuff..including washers and bolts for cams and crank.
ARP head studs
the rest is all Mazda OEM stuff and I will compile and entire list as I go.
a shout out to @silvapain for his spreadsheet of OE parts and @phate for linking me to it.
I have access to quite a bit of cool measuring equip from my rat scoobie buddy who is about to build his motor such as a bore gauge, digital calipers, mic, fixed hones, etc. so I should be prepared.
I do plan to measure the bores and crank pins and if things are too far out...well depending on how far, I will pull the motor, send my Wiseco's back and maybe get some angry HCR pistons just b/c my motor hates me...gotta get even right?
anyway...that's all for now I'll update as things progress.
oh I did get these today complements of @eric@edgeautosport
cheap scale but they all weigh the same...pistons, pins and clips
they are not near as cool as Dan and Clints huh?
Build Tolerance Specs: Updated as the build progresses
Wiseco OE spec piston: PWC .0025 [I will target .0025 but if it gets out to .0030 I will live with it]
K1 Rod w ARP 2000: Torque to 25ft/lbs + 55*
Specialty Tools: Updated as the build progresses
Cam timing tools - Silvapain
Torque wrench [inch & ft lbs] - owned
Angle Gauge - Amazon Search
87.5mm ARP ring compressor ARP 901-8750 ARP Ring Compressors
Flex-Hone 89mm 320 grit - Amazon Search
Plateau Brush 3" - 3-1/2" Plateau Brush Explanation: Plateau Cylinder Bore Finishes
Lubes and Fluids:
Lucas assembly lube 4oz Lucas Oil 10152 Lucas Oil Assembly Lube
Lucas 30wt Break-in Oil 5qt Lucas Oil 10631 Lucas Oil High Zinc Engine Break-In Oils
+ 1qt of any 30wt dino oil
ATF for cylinder honing and wall cleaning/lubing for fast breakin
10/20/12 Update:
so before I was forced down the road of a build I wanted to find out just how much oil pressure there is at our turbo feed outlet in the block. I wanted to be able to measure pressure in 3 different configurations.
1) restricted to turbo and guage
2) unrestricted to turbo and gauge
3) unrestricted to gauge and restricted to turbo.
This allows me to monitor oil pressure for the experiment and keep a gauge connected afterward. I realize this may not be the best source of a pressure reading but as long as I have a baseline of now and after the motor is built I don't think it matters much.
Anyway, I put together a list of what I would need to accomplish this with some help from @Celestspeed3
Edit: 10/31/12 Updated graphic to include hose length modifications and additional fittings.
Parts links
4 An to M12x1 5 Straight Adapter Saab Volvo TD04L 1 5mm Oil Restrictor | eBay
Earl's 921104 Earl's Specialty Fittings
P.T.F.E.-Lined Stainless Steel Hose
JEGS Performance Products 100531 JEGS Fuel Pressure Gauge In-Line Adapter Fittings
Earl's 924104 Earl's Specialty Fittings
I may drill this 1.5mm fitting out so there is zero restriction. This way is cheaper than getting a $19 ATP open bolt.
Turbo Oil Feed Banjo Bolt Kit Garrett T25 T28 TB25 TB28 Journal Bearing | eBay
1mm restrictor banjo which is ~.040 - not quite as small as an ATP .035 but this is not rocket science.
Turbo Oil Feed Banjo Bolt Kit Garrett GT2871R GT2876R GT3071R Ball Bearing | eBay
I am going to get under the car today and get measurements to confirm my gestimates on SS line length and will update if necessary.
Pulled my belt tensioner off and inspected the area and everything should work as designed.
10/26/12 Update
More parts and tools acquired today:
11/21/12 Update
Job costing spreadsheet uploaded.
The Following 55 Users Say Thank You to Dano For This Useful Post:
802MS3 (10-17-2012), 86AmishMs3 (10-21-2012), ASHMS3 (10-17-2012), atvfreek (10-17-2012), BlueStreak (10-17-2012), breakfasteatre (01-09-2013), btstarcher (10-18-2012), charlesfist (10-18-2012), Chimmike (10-17-2012), Ckmazdaspeed3 (03-30-2013), darkstar5440 (08-02-2014), djuosnteisn (10-17-2012), Downmented (10-17-2012), Easter Bunny (10-18-2012), EdgeAutosport.com (10-18-2012), eljefe62 (01-09-2013), El_Diablo (12-13-2013), fredricktsang (10-18-2012), helmetface (10-17-2012), IshiKage (10-21-2012), Jay@posifab.com (10-25-2012), jman46 (10-17-2012), jracer (10-18-2012), JTMS3 (11-07-2012), kylec_2003 (11-08-2012), leon78 (10-18-2012), Lex (10-26-2012), magicka (12-07-2012), Micha (02-07-2013), Monotonous ONE (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), Neverlift (10-18-2012), NJSPEED3 (10-18-2012), phate (10-17-2012), Pointless (10-17-2012), rfinkle2 (10-18-2012), rghispanic88 (10-17-2012), RichieRichness (10-19-2012), robry (11-06-2012), Roddiy (10-26-2012), silvapain (10-18-2012), SilverDemon (10-17-2012), snailD (11-10-2012), Snyeed (10-17-2012), speed14 (10-17-2012), speedms6 (10-17-2012), speed_freak91 (10-18-2012), statesm (10-23-2012), TiGraySpeed6 (10-17-2012), Tokay444 (10-17-2012), Tomas (10-17-2012), torquemaniac (11-09-2015), uncorked11 (10-19-2012), WetzMS3 (01-12-2015), Ziggo (01-23-2013)
 Old 10-17-2012, 06:19 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Glad to see that you have access to the proper measuring equipment. That' my biggest fear with drop in builds, I think you'll be fine.
I used those same Wiseco's on the gray 6 and it runs like a champ.
I'll be following along
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (10-17-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 06:22 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
<- raging boner
Dano (10-17-2012)
 Old 10-17-2012, 06:28 PM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
my time is coming...
"Exclusivity" - CP-enis
Demodded.
The Seals
Dano (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012)
 Old 10-17-2012, 06:33 PM   #5
Trail of Fail
Dano's Avatar
<- raging boner
hahah you're a young guy right...dick gets hard when the wind blows...ah...those days...lol
j/k man...I can't wait until my rods get here...<------see what I did there?
...says Mr. Consumption...Mr Oil Consumption...
atvfreek and helmetface like this.
Last edited by Dano; 10-17-2012 at 06:33 PM. Reason: MSF Database - Automerged Doublepost
helmetface (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012), Tokay444 (10-17-2012)
 Old 10-17-2012, 06:36 PM   #6
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Dope, im glad to see more of these popping up. Subbd for results. Good luck
Sent from my GT-P3113 using Tapatalk 2
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
Dano (10-17-2012)
 Old 10-17-2012, 06:37 PM   #7
Tokay444's Avatar
Groans: 793
yup. don't want to face it, but there is no choice.
i may as well go bnr while i'm at it.
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
Celestspeed3 (10-19-2012), Dano (10-17-2012), helmetface (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 06:38 PM   #8
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Do it to it! Mine's still running great!
Sent from my iPhone your mom's face
07 MS3
The original Genpoo Hater
The Following 4 Users Say Thank You to Chimmike For This Useful Post:
atvfreek (10-17-2012), Dano (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 06:47 PM   #9
Trail of Fail
Dano's Avatar
BTW. talked to Andy at Wiseco today and he says the PWC is already built into their drop-in pistons and indicated I only needed a .0025 PWC measured at the skirt for turbo induction...that sounds tight to me. I do know Manley and Wiseco's for the scoobies at 99.5 call for .0035
what say the experts?
@phate
@silvapain
@Tomas
@djuosnteisn
@SPEED6 KILLAH
djuosnteisn (10-18-2012), phate (10-18-2012), Tomas (10-17-2012)
 Old 10-17-2012, 06:50 PM   #10
Eth Fiend
phate's Avatar
BTW. talked to Andy at Wiseco today and he says the PWC is already built into their drop-in pistons and indicated I only needed a .0025 PWC measured at the skirt for turbo induction...that sounds tight to me. I do know Manley and Wiseco's for the scoobies at 99.5 ask for .0035-.0040.
@phate
@silvapain
@Tomas
@djuosnteisn
@SPEED6 KILLAH
Seems tight to me. My pistons spec is .0035" PWC.
-06 MS6
Dano (10-17-2012), djuosnteisn (10-18-2012)
 Old 10-17-2012, 06:53 PM   #11
Trail of Fail
Dano's Avatar
I thought as much. no sheet came with the pistons.
 Old 10-17-2012, 06:57 PM   #12
Eth Fiend
phate's Avatar
So I was thinking about my new pistons when I said .0035....I think I still have the sheet for those same pistons you have, let me go check.
-06 MS6
 Old 10-17-2012, 07:00 PM   #13
Trail of Fail
Dano's Avatar
the sheet that came with Pablo's pistons, in silvapain's thread, say .0035
Stated at the top of the piston pic
I think ring gaps will be different with the HCR pistons but I can't believe the PWC would be.
 Old 10-17-2012, 07:01 PM   #14
Eth Fiend
phate's Avatar
This sheet is the spec for standard bore pistons exactly like yours Dano. They're what I used in the gray 6's engine.
.0030" PWC
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
atvfreek (10-17-2012), charlesfist (10-18-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 07:03 PM   #15
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Good luck Mr. Dano, I see something like this in my future.
Defiantly keep this thread updated.
417whp 428tq 12.037@117.2mph
The Following 2 Users Say Thank You to Snyeed For This Useful Post:
Dano (10-17-2012), sleepyspeed6 (10-18-2012)
 Old 10-17-2012, 07:06 PM   #16
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
@phate
@silvapain
@Tomas
@djuosnteisn
@SPEED6 KILLAH
Dood. I don't think that 0.001" difference is really that critical. I'd go for 0.0035 for safety but I wouldn't sweat it if after a hone you only get 0.0025.
If I had to choose between honing the liners a further 0.001" afer a light hone to bring the PWC from 0.0025 to 0.0035 and leaving it a 0.0025 I would leave it. Honing that 0.02mm by hand with a drill or whatever won't be very accurate. Better just leave it alone before you fuck up something. That's just my opinion. Picking up that 0.02mm difference in the bore is already hard enough with gauges going only 2 metric decimals.
The Following 6 Users Say Thank You to Tomas For This Useful Post:
charlesfist (10-18-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), Easter Bunny (10-18-2012), silvapain (10-18-2012), Tokay444 (10-17-2012)
 Old 10-17-2012, 07:08 PM   #17
atvfreek's Avatar
Posts: 7,787   (View Stats)
Love it! I will be tuned in as well.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
 Old 10-17-2012, 07:15 PM   #18
Trail of Fail
Dano's Avatar
If I had to choose between honing the liners 0.001" to bring the PWC from 0.0025 to 0.0035 and leaving it a 0.0025 I would leave it. Honing that 0.02mm by hand with a drill or whatever won't be very accurate. Better just leave it alone before you fuck up something. That's just my opinion. Picking up that 0.02mm difference in the bore is already hard enough with gauges going only 2 metric decimals.
totally agree...been there done that with my buddy's EJ25...a 240 grit hone will leave the walls rough enough to make .001x worth of variance in the measurements. only when you get to 500 grit can you really begin to measure down to .000x
he does have a super fly adjustable fixed hone but I wouldn't even consider doing that with a drop in. to much lubricant pouring over the crank for a clean install.
.0030" PWC
cool...so I will hope for a .0030 PWC but won't cry if its as much as .0035. does that sound good?
BTW did any of the drop in guys even measure what the PWC is on a motor with wear? I am thinking it would be on the big side but really have no idea.
Edit:
oh and @Tomas...me an my buddy ruined his case halves...lol went too far with the honing trying to remove taper and out of roundness...like you say...it is a bitch with hand held tools.
here's the hone.
Last edited by Dano; 10-17-2012 at 07:25 PM. Reason: MSF Database - Automerged Doublepost
djuosnteisn (10-18-2012), NJSPEED3 (11-11-2012), silvapain (10-18-2012), Tomas (10-17-2012)
 Old 10-17-2012, 07:23 PM   #19
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
Which piston are you running custom?
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
Dano (10-17-2012)
 Old 10-17-2012, 07:26 PM   #20
Trail of Fail
Dano's Avatar
nah...just OE 9.5.1 std bore K640M875
 Old 10-17-2012, 07:30 PM   #21
Okay I'll go with .0025 nice and tight there a reason behind it..
The Following 4 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
atvfreek (10-17-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), Easter Bunny (10-18-2012)
 Old 10-17-2012, 07:40 PM   #22
Trail of Fail
Dano's Avatar
interesting...that's what the Wiseco guy said...care to share that reason with the rest of the class?
skirt coating will wear off ?
atvfreek (10-17-2012), djuosnteisn (10-18-2012), phate (10-17-2012)
 Old 10-17-2012, 07:49 PM   #23
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
good luck with the build!
I'm looking forward to watching this one
340hp / 371tq
Dano (10-17-2012)
 Old 10-17-2012, 09:10 PM   #24
Bob Ross Fanclub
Tomas's Avatar
Because you don't want that shit to feel like you are throwing a hot dog down the hallway?
I know all about that.
No. The skirt coating is not supposed to wear off.
And that hone you posted earlier, it's heavy enough to bend the shit out of the oil squirters. Make sure you put some masking tape on the shaft to mark how deep you can go before colliding with the tubes.
Edit: hmmm. I think you are gonna have to bend the oil squirters anyway but that does not mean you should do it by slamming the honing stones on them. lol
charlesfist (10-18-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), phate (10-17-2012), rfinkle2 (10-18-2012), Tokay444 (10-18-2012)
 Old 10-17-2012, 09:37 PM   #25
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Good luck with the build @Dano. Would you mind linking the referenced spreadsheet here for the rest of us? Thanks!!!
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
phate (10-17-2012), Voltwings (10-19-2012)
 Old 10-17-2012, 11:31 PM   #26
Trail of Fail
Dano's Avatar
word on the squinter bending method, but reading fail for u...I will NOT use that hone in my block...it is the exact hone my buddy used to ruin his ej25 case halves...lol
not that it is a bad hone...it will def take some material off quickly but you have to pay attention and step down to the clearance you want. I now think of it more like a hand held boring tool
kinda like Wiseco says...
• Install and torque main bearing caps
• Use torque plates. This simulates the distortion that occurs when the
cylinder head is mounted to the block. (hint: After boring and honing, leave
the torque plates in place and fit/gap the piston rings to their respective
cylinders.)
• Allow for a minimum of .003" excess material for use as honing stock.
• Intermediate hone to within .0005" of finished size with #220-#280 grit
stones. (With diamond stones use #280-#400 grit.)
• Finish hone with #400 grit stone or higher. (Use #600 grit diamond stone.
If using hand operated equipment, set drill speed between 200-450 rpm.)
• Finish with an appropriate stone or tool to achieve desired plateau finish
(see below).
I will use a brush hone and put an exact 20-25* cross hatch in that bitch.
...or at least that is my plan for now and I am all ears to any better ideas.
Fallopian tubes..ok never thought about that....
Last edited by Dano; 10-17-2012 at 11:32 PM. Reason: MSF Database - Automerged Doublepost
BrianB6 (10-23-2012), djuosnteisn (10-18-2012), Tomas (10-18-2012)
 Old 10-18-2012, 04:56 AM   #27
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Good luck Dano. I can't wait for another one of these swaps to be successful!
I've been trying to start my own build but my car has been very uncooperative.
NATOR PA
The Following 4 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
atvfreek (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 08:54 AM   #28
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Same here. 0.0035" PWC on my sheet. My machinist said my new block was dead-on with the PWC clearance, and he didn't have to hone/bore it at all. Wiseco knew my block was brand new when they made the pistons.
The Following 6 Users Say Thank You to silvapain For This Useful Post:
atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 09:01 AM   #29
silvapain's Avatar
Groans: 136
@Dano, when you time the engine, be sure to double-check #1 TDC; don't trust the crank locking pin stuck in the side of the block. I don't know if you saw the MCY degree wheel in my build thread, and how far the pin was off TDC (~7°).
The Following 5 Users Say Thank You to silvapain For This Useful Post:
charlesfist (10-18-2012), Dano (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), NJSPEED3 (11-11-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 09:03 AM   #30
Over my head, but rootin' for you nonetheless.
You are going to run the 3071 with this fresh engine?
Dano (10-18-2012)
 Old 10-18-2012, 09:10 AM   #31
Trail of Fail
Dano's Avatar
lol I did see your cock wheel but have no idea how to use one of those...nor do I know how to use a degree wheel but I suppose I could read up.
yessir...the GT28 is cursed
I mean it will make a great turbo for someone else just not me....that chapter is closed.
Last edited by Dano; 10-18-2012 at 09:10 AM. Reason: MSF Database - Automerged Doublepost
NJSPEED3 (11-11-2012), rfinkle2 (10-18-2012), TiGraySpeed6 (10-18-2012)
 Old 10-18-2012, 09:18 AM   #32
Trail of Fail
Dano's Avatar
.0030" PWC
hahah this is why this project will be fun. Ask 3 guys what the PWC should be and get 3 different answers...lol
Wiseco and Pablo both state .0025 for the OE spec pistons
Phate's sheet from Wiseco states .0030 for the OE spec pistons
SilvaPain is running HCR pistons which could generate more heat and so they are speced at .0035
my plan will be to target .0025 and if it is as big as .0030 I will live with it. Some piston slap, if it would even occur, never killed anyone.
OP updated with this information.
The Following 7 Users Say Thank You to Dano For This Useful Post:
atvfreek (10-18-2012), djuosnteisn (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), NJSPEED3 (11-11-2012), phate (10-18-2012), silvapain (10-18-2012), SPEED6 KILLAH (10-18-2012)
 Old 10-18-2012, 09:38 AM   #33
Eth Fiend
phate's Avatar
It's really easy, lol. I now have a real degree wheel and TDC stop if you would like to borrow it.
-06 MS6
charlesfist (10-18-2012), Dano (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012), silvapain (10-18-2012)
 Old 10-18-2012, 09:42 AM   #34
silvapain's Avatar
Groans: 136
Clint was the one who knew his shit on the degree wheel.
Once you have the head on and bolted down, get an long M14 x 1.25 bolt and thread it down into the #1 plug well. No need to torque it down; just thread it in by hand. Put the degree wheel on a use a coat hanger or welding wire to be a pointer for the wheel; we used a coat hanger wrapped around the bolts for the alternator. Then rotate the crank very slowly until the piston just touches the bolt, and mark the wheel. Then rotate the crank in the opposite direction until the piston just touches the bolt again, and mark that point. You will end up with to markings at different places on the wheel. Then split the angle between the two in half, and that's TDC. Take the bolt out and rotate the crank until the pointer hits the TDC line, and you're at TDC for piston #1 .
P.S. You let me know when you want to sell me that GT28
kritz likes this.
The Following 8 Users Say Thank You to silvapain For This Useful Post:
atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), kritz (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), phate (10-18-2012), rfinkle2 (10-18-2012), TiGraySpeed6 (10-18-2012)
 Old 10-18-2012, 09:53 AM   #35
I want to come down to Ill. and learn how to build an engine for chrissake.
All of this TDC pin talk and degree wheels has me feeling a dunce.
I'm half tempted to blow my own shit up so I have to learn to build a motor.
TiGraySpeed6 and skeurton like this.
The Following 14 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), jracer (10-18-2012), kritz (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), ms3blackmica (11-04-2012), NJSPEED3 (11-11-2012), phate (10-18-2012), skeurton (10-18-2012), taf0422 (10-19-2012), TiGraySpeed6 (10-18-2012), Tokay444 (10-18-2012), uncorked11 (10-19-2012)
 Old 10-18-2012, 09:56 AM   #36
silvapain's Avatar
Groans: 136
You come down here and help me vinyl wrap my car and we have a deal.
The Following 10 Users Say Thank You to silvapain For This Useful Post:
atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), Easter Bunny (10-18-2012), jracer (10-18-2012), kritz (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), NJSPEED3 (11-11-2012), rfinkle2 (10-18-2012), SofaKingAwesome (11-08-2012)
 Old 10-18-2012, 10:00 AM   #37
Trail of Fail
Dano's Avatar
Um a hell to the yes is my answer if timing works out so that you don't need it for a week. I also need to source the timing plate as well. Maybe u have that too?
DJ has one too so I should be able to get one somewhere on here.
Maybe I'll just buy one IDK.
Tappin
djuosnteisn (10-18-2012), phate (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 10:01 AM   #38
silvapain's Avatar
Groans: 136
Tappin
I have a full timing tool kit I can mail down to you. I just need it back in time for Clint's engine build.
charlesfist (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012), SPEED6 KILLAH (10-18-2012)
 Old 10-18-2012, 10:04 AM   #39
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Gold?
Damond Built Speed 6
 Old 10-18-2012, 10:05 AM   #40
Groans: 224
I will gladly trade engines with you if you're really feeling that intrigued....lol
NATOR PA
The Following 10 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
amoosenamedhank (10-18-2012), atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), Easter Bunny (10-18-2012), rfinkle2 (10-18-2012), silvapain (10-18-2012), SofaKingAwesome (11-08-2012), SPEED6 KILLAH (10-18-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f658/fail-formerly-known-dano-s-drop-build-127709/
The Antique Outboard Motor Club Forums - 1960 evinrude 10hp parts swap? This thread Refback 11-01-2013 05:11 AM
Tuoreimmat viestit This thread Refback 12-09-2012 11:00 AM
Mazda 3 MPS This thread Refback 12-09-2012 10:46 AM
Dano's Koni FSD install Dano MazdaSpeed 3 - How-To's 64 03-03-2015 12:49 PM
My Pop 'n drop build Chimmike Mazda MZR DISI Engine Builds (2006-2013) 381 11-10-2013 06:51 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning 1512 09-20-2012 06:47 AM
2010 MS3 Build, please drop your 2 cents in! randino69 2010 MS3 - Build Diaries 17 03-26-2012 10:19 PM
Dano's SS Exmani install Dano MazdaSpeed 3 - How-To's 18 11-12-2010 10:38 PM
Page generated in 0.68033 seconds with 36 queries
