Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
 Old 05-28-2019, 06:30 PM   #1
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Default Several questions along my build
Hey Guys,
1. Receiving my engine block back from the machinist I noticed a part that I don't remember taking out. Take a look at the little coin shaped part in the pictures. Closest thing I can find to that is part of the balance shaft delete units, but I never had one before.
2. There seems to be a lot of casting flash in the block, looks like oil drain paths, have you guys taken a grinder to those areas or just left them?
3. The engine manual shows a gasket for the oil pump, but im not seeing other sources show this as true. Is there a gasket between the oil pump and the block?
Thanks!
Phil.
The_big_dill is offline   Reply With Quote
 Old 05-29-2019, 07:53 AM   #2
Posts: 2,233   (View Stats)
Have you replaced the VVT ? Not sure but the VVT has a blocking pin looking like this on the exterior....and this is the waek part of it that fall off and destroy the timing or more...
I never saw a gasket between bloc and oil pump but i did see gasket kit giving some, i asked myself if i should use one or not and decided to put it aside...
I did soften some of the casting where a chip could fall of or on the outside where i could cut my skin working around it but i did it prior to send it to machine shop to make sure any metal dust would be cleaned.
 Old 06-03-2019, 10:01 AM   #3
A+ reply, thank you!
The previous owner replaced the VVT, looks like he did it after it failed.
On a side note, my machinist says that the main bearings can be standard but I'm seeing a clearance of 0.0025" on the original bearings. Spec is 0.0007-0.0013".
Should I go 1 size under to get to the spec or just get replacements at standard size?
Thanks,
Phil.
Questions/Help w/BT Build CajunBud876 MazdaSpeed 3/6 - Big Turbo Builds 5 03-09-2015 03:05 AM
MS6 Engine Build Questions RogerH MazdaSpeed 6 - Engine, Transmission & Driveline 3 05-23-2013 06:28 PM
questions about my build SlickDevil 2010 MS3 - Engine, Transmission & Driveline 19 04-26-2012 08:04 PM
Stupid questions about BT build I am considering. dsmluck MazdaSpeed 3/6 - Turbo Induction 198 08-09-2011 11:33 AM
A few build questions....... jracer MazdaSpeed 3/6 - Big Turbo Builds 11 02-21-2011 02:04 PM
Page generated in 0.24142 seconds with 22 queries
