Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Like Tree64Likes
 Old 10-25-2012, 05:57 AM   #41
LLIo6oH's Avatar
Posts: 17   (View Stats)
LLIo6oH has a spectacular aura aboutLLIo6oH has a spectacular aura aboutLLIo6oH has a spectacular aura about
thank you. this is what I need!!
sarm1084 likes this.
CorkSport SRI
Custom Short Shifter
Hankook RS3
Eibach Pro Kit
LLIo6oH is offline   Reply With Quote
The Following User Says Thank You to LLIo6oH For This Useful Post:
sarm1084 (12-22-2018)
 Old 02-23-2013, 03:59 PM   #42
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
Great write up, thanks!
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline   Reply With Quote
The Following 2 Users Say Thank You to soccerballz For This Useful Post:
Manny (02-23-2013), sarm1084 (12-22-2018)
 Old 11-22-2013, 07:32 AM   #43
BZiggy10's Avatar
Posts: 725   (View Stats)
BZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the world
Really this makes things to easy. You may as well have come to my house and built my motor. Thanks though. I will have a build diary thread soon enough.
BZiggy10 is offline   Reply With Quote
The Following User Says Thank You to BZiggy10 For This Useful Post:
 Old 11-22-2013, 09:31 AM   #44
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
Thanks so much for this thread! It has really cleared up the confusion that I had recently. Good job and keep it up
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
The Following User Says Thank You to GARRETHEXTREME For This Useful Post:
 Old 02-27-2014, 12:27 PM   #45
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
Great write up! I think I have some cracked ringlands so this write up helped me know what I need to get!
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
The Following 2 Users Say Thank You to meelo88 For This Useful Post:
sarm1084 (12-22-2018), TWOptSL0W (02-27-2014)
 Old 07-31-2015, 07:59 PM   #46
Darthspeed3's Avatar
Posts: 292   (View Stats)
Darthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the world
Thanks to the OP for an awesome and very informative thread!! I've been playing around with the idea of buying a spare short block and making it a long winded workshop project to tackle (hopefully) before my stock block decides it's time to leave this life. I'm sure when I get into all the additional tools and bs, I'll be back at saving for a sp63 pop & drop; BUT....it's great to see the end from different angles.
Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI.
Darthspeed3 is offline   Reply With Quote
The Following User Says Thank You to Darthspeed3 For This Useful Post:
 Old 05-24-2016, 01:57 PM   #47
Sleepin6's Avatar
Posts: 99   (View Stats)
Sleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to behold
Default Who balances flywheels?
The machine shop I'm guessing? Never got one balanced before.
MS6 GT...REBUILD IN PROGRESS
BOLTED AND BOOST PROVIDED BY...
SPEED1/CORKSPORT...
Sleepin6 is offline   Reply With Quote
The Following User Says Thank You to Sleepin6 For This Useful Post:
 Old 06-01-2016, 03:37 PM   #48
Sleepin6's Avatar
SPEED1/CORKSPORT...
 Old 06-01-2016, 03:41 PM   #49
btstarcher's Avatar
Posts: 4,852   (View Stats)
Sent from my HTC6535LVW using Tapatalk
SnailTune in progress
 Old 06-01-2016, 04:25 PM   #50
Sleepin6's Avatar
Did anyone ever have it done and by who? Thanks.
SPEED1/CORKSPORT...
 Old 06-01-2016, 04:37 PM   #51
btstarcher's Avatar
Have what done?
 Old 06-01-2016, 07:12 PM   #52
Sleepin6's Avatar
Have what done?
Balancing the flywheel.
SPEED1/CORKSPORT...
 Old 06-01-2016, 07:13 PM   #53
btstarcher's Avatar
Never done it. I think the OEM flywheel is shit anyway. Replace it.
 Old 06-01-2016, 07:26 PM   #54
Sleepin6's Avatar
Thanks I'm going with a south bend. Do you think I need to worry about balancing it if the crank will be balanced.
SPEED1/CORKSPORT...
 Old 06-01-2016, 07:26 PM   #55
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Most machine shops will be able to balance a flywheel, and some can do pressure plates. Most of the aftermarket units with billet aluminum flywheels will be balanced in process, so nothing to worry about.
My Clutchmasters aluminum flywheel was checked and did not need balanced. My steel ACT flywheel was checked and did need balanced.
btstarcher, sarm1084 and Sleepin6 like this.
-06 MS6
-Corn fed 07 MS3 - Sold
btstarcher (06-01-2016), sarm1084 (12-22-2018), Sleepin6 (06-01-2016)
 Old 02-07-2018, 05:18 PM   #56
Losymis's Avatar
Posts: 12   (View Stats)
Losymis will become famous soon enough
nice work
Losymis is offline   Reply With Quote
The Following User Says Thank You to Losymis For This Useful Post:
 Old 02-07-2018, 05:44 PM   #57
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Originally Posted by Losymis View Post
nice work
What did you add to this thread necro? Are you retarded?
crapatalk it sucks for free
Dolfius (03-14-2018), JSmith (02-07-2018)
 Old 02-07-2018, 06:44 PM   #58
kTaLgsTo's Avatar
Posts: 566   (View Stats)
The answer is yes
The Following User Says Thank You to kTaLgsTo For This Useful Post:
monkey.bones.007 (02-07-2018)
 Old 02-07-2018, 07:05 PM   #59
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Indeed
The Following User Says Thank You to Db09ms3 For This Useful Post:
 Old 03-14-2018, 12:45 PM   #60
Losymis's Avatar
Are u talkin to me my child
Stock except for CAI and downpipe...
The Following 2 Users Say NO Thank You to Losymis For This Un-useful Post:
Db09ms3 (03-14-2018), JSmith (04-13-2018)
 Old 03-14-2018, 01:00 PM   #61
No, you're not worth it.
Tapatalk, it sucks for free!
thrisnospork likes this.
Db09ms3 (03-14-2018), thrisnospork (03-15-2018)
 Old 03-27-2018, 07:12 AM   #62
Losymis's Avatar
Thats what I gave your momma
 Old 03-27-2018, 08:17 AM   #63
She does love sausage, just like you.
 Old 03-27-2018, 09:57 PM   #64
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
what else did you give her? cheetos crumbs in her urethra?
btstarcher likes this.
94 M
MS6
IS350
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
btstarcher (03-28-2018), Db09ms3 (03-29-2018), monkey.bones.007 (03-28-2018)
 Old 03-28-2018, 05:03 AM   #65
Losymis's Avatar
Mind your fuckin business
The Following User Says NO Thank You to Losymis For This Un-useful Post:
 Old 03-28-2018, 05:38 AM   #66
btstarcher's Avatar
In for pics of Losymis's mom.
Sent from my SM-G955U using Tapatalk
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
 Old 03-28-2018, 05:44 AM   #67
Losymis's Avatar
[QUOTE=btstarcher;3141724]In for pics of my moms black dick in her ass
Yea me too...lmao
 Old 03-28-2018, 09:39 PM   #68
In for pics of @Losymis; I bet he's got huge beef curtains.
 Old 06-03-2019, 07:33 PM   #69
liamsms6's Avatar
Posts: 4   (View Stats)
liamsms6 has a little shameless behaviour in the past
Question Balance shaft and crankshaft severe damage
Recently I noticed a loud knock that started very settle followed by grinding. After taking to a mechanic they were clueless to what was wrong, so I started ripping my engine bay apart.
once the engine was out I took off the oil pan to discover this...
Will the crank need to be replaced? (im 18 finishing high school and can't really afford it with out going into debt)
liamsms6 is offline   Reply With Quote
 Old 06-04-2019, 07:14 AM   #70
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
Attachment 237714
Attachment 237715
Attachment 237716
I'd say its time for a BSD. but maybe someone else who knows the inner workings of the motors will chime in and not rip into you to hard for posting on this thread instead of starting your own. gotta wonder where all that metal went too....
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 06-04-2019, 09:08 AM   #71
liamsms6's Avatar
I know I should have started my own thread. Thanks for not tearing into me. I ordered a BSD few days ago, had a mechanic look at it too. The crank is fine to leave with the chipped gears with a BSD.
danb likes this.
 Old 06-05-2019, 08:03 AM   #72
danb's Avatar
Did you have the crank bearings checked out? I'd be worried about the metal from the gears working it's way thru the motor too
2011 mazda 6
 Old 07-26-2019, 03:48 PM   #73
carb4time's Avatar
Posts: 1   (View Stats)
carb4time is an unknown quantity at this point
Default New Member...Troubleshooting a Speed6
Hi New member, working with my son on a recently purchased and now blown up Speed6 (2006). Head is now off, seeing both exhaust burned up (chunks gone) on cylinder #1 . Next question is what is root cause, and do I rebuild or buy a new (rebuilt) head?
carb4time is offline   Reply With Quote
 Old 07-26-2019, 03:57 PM   #74
Db09ms3's Avatar
Groans: 105
Burnt valve is from heat.
Stockish
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f658/what-you-need-know-build-motor-106962/
2008 speed3 sedan - Page 9 This thread Refback 11-28-2013 06:48 PM
speed6 believe it spun a rod bearing. - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-28-2013 11:00 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
Motor build parts list ? jracer MazdaSpeed 3/6 - Big Turbo Builds 6 12-25-2010 06:20 PM
everything neded to build motor? ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-04-2009 11:14 PM
Page generated in 0.55635 seconds with 37 queries
