Damond Motorsports PCV plate We're happy to announce that we're coming out with a PCV plate soon. Along with a whole mess of OCC and dual OCC options, so you can crank your case til there's no oil left. Key features: -Main thing with our PCV plate is that it can use an OEM PCV valve. We designed the PCV valve port to the exact dimensions of the OEM PCV box, allowing for a perfect fitment of the factory PCV valve and o-ring. The main reason to use a PCV valve is to meter the amount of air pulled from the crankcase under vacuum, keeping it as a sustained level, especially under WOT to closed throttle transitions and engine braking, where manifold vacuum is at its highest. -OEM Gasket, you can reuse yours, or opt to have one included -Two 3/8" NPT ports for fittings, plugs, checkvalves -Anodized with engraved DM logo Price is TBA, but it won't break the bank. And there will be options, to add a PCV valve or use the one you have, plugs, fittings, gaskets, checkvalves, whatevs. I'm going to be working on a full blog/forum post on different PCV and OCC configurations, and updating the ones I have, so keep an eye out for that. We're getting them anodized, and we'd like to hear y'all's opinion on what color you'd prefer or feel looks best. Hence the poll. http://i797.photobucket.com/albums/y...psiwekaztv.jpg http://i797.photobucket.com/albums/y...psyw3n9sdc.jpg |
Ginger Red. It'll be sexy in any color man! |
Gold or Blue would be nice. I was looking into a dual OCC from you. sent from my HTC One M9 |
I'm so glad I've not bought a perm plate yet. tapatalk, it sucks |
As long as it's cheaper than the damn perm plate. I'm glad you're going to be able to put to use all the data you've gathered on the PCV system over the years. You haven't found any problems with the PCV valve binding or getting stuck while being sideways? |
Quote:
Can't not offer gold. |
This is how I'm planning on running the plate I have now. http://i.imgur.com/SSqTHrp.jpg How would one utilize a 3rd port on the new plate? |
How do you plan on preventing the intake leak that will happen then you route the hose from intake to vta can? |
Quote:
Black please! Sent from my SM-G900V using Tapatalk |
I think black is the obvious choice, but using the same gold as the mounts would be nice, if you're going to offer options. |
Quote:
PINK!!! |
Black. Looking forward to seeing the occ setups you have in the works Sent from my ONE A2005 using Tapatalk |
HEY. You answer my question right meow. |
Quote:
Quote:
We consider the stock PCV valve as a way to meter air, in addition to it's function as a check valve. We generally don't like a wide open path from the crankcase to an IM under relatively high vacuum. Therefore, the recommendation would be to utilize the normal function of the PCV valve and system, and use an additional port for added venting. You've then effectively addressed crankcase venting issues in boost, and in vacuum. There do exist the minority for whom that isn't enough venting. They will see benefit from a third port. You don't need a valve cover breather, a new hole in the valve cover, or any other added port. It's already there. If desired, put a check valve on it, and run a hose to wherever you want to vent it. Of course, for those who prefer the PCV valve left out, the plate can be the normal, dual vent plate. All the options, fittings, etc. will be available with this. |
Quote:
Remember that some/most/all drag strips will frown on what might result from that. |
| All times are GMT -7. The time now is 01:46 AM. |
