| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score Our RMMs are in stock, ready to go! To place an order, please visit our site: Rear Motor Mount: Mazdaspeed3 (All Years) | Damond Motorsports Last edited by Matt@DamondMotorsports; 08-20-2014 at 12:15 PM. |
| The Following 5 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | breakfstincluded (07-18-2014), Chuthor (07-18-2014), himurax13 (07-18-2014), MichaelGear (07-18-2014), [R]usty (07-18-2014) |
![]() Join Date: Sep 2012 Location: Downers Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,033
| Not Ranked : 0 score Get em while they're hot! I love mine! Sent from my XT1060 using Tapatalk
__________________ 2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC |
| The Following 2 Users Say Thank You to Chuthor For This Useful Post: | Matt@DamondMotorsports (07-18-2014), MichaelGear (07-18-2014) |
![]() Join Date: Mar 2013 Location: Rural Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
| Not Ranked : 0 score Agreed, while I don't have a lot of experience with different RMMs, this was a significant improvement to the overall feel of the car. Best of all, it cured my difficulty getting from second to third while playing on the back-roads. Thanks again for an excellent product MDM! |
| The Following User Says Thank You to MichaelGear For This Useful Post: | xfeejayx (07-18-2014) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Where is the speed6 love @Matt@DamondMotorsports;???
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | dagrimey1 (11-11-2014) |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
__________________ | |
| The Following User Says Thank You to Farhan@DM For This Useful Post: | Easter Bunny (07-24-2014) |
| Not Ranked : 0 score Farhan - for real. I need an RMM for the 6. I realize it won't be the same design, but I'm all for DM parts on my car. Make it happen.
| Not Ranked : 0 score I'm listening. Unfortunately it gets priority behind the 3 stuff, putting even my car on hold.
| The Following User Says Thank You to Farhan@DM For This Useful Post: | nindoja (07-28-2014) |
| Not Ranked : 0 score I'll be patiently waiting on 6 parts. And 3 parts too, but I already have a lot of those.
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score I need OTS bilstien coilover conversion, cause i am lazy. GO MAKE IT RIGHT NOW!!!!
__________________ Damond Built Speed 6 |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Gold and red is the only color combo to get. Badass mount.
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following User Says Thank You to macdiesel For This Useful Post: | Farhan@DM (07-28-2014) |
Rep Power: 235 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score I have this installed and it's been great so far. I took off my JBR TMM and CPe Stage-1 RMM, and I feel like my engine moves LESS with just this mount. The solid connection to the underframe with the vertical bushings are really where it's at. Well done DM. |
![]() Join Date: Nov 2010 Location: Bear, DE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Definitely pick one up, you won't be sorry.
__________________ Installed: Cobb AP v2 // Autotech Internals // Corksport Stage II SRI // CX Racing FMIC // ATP Catless Downpipe // DM RMM // Corksport SSP // JBR TBG & Collant Bypass // SU Shift Bushings // JBR Armor Mud Flaps On The Bench (pending install): Grimspeed EBCS Coming Soon (in no particular order): JBR Intake TIG // HTP 3.5" Intake System // DM PMM // DM v1 Oil Catch Can // Corksport BPV // (?) Short Shifter // (?) Catted Downpipe |
| The Following 2 Users Say Thank You to morbiddk For This Useful Post: | Farhan@DM (07-30-2014), Matt@DamondMotorsports (07-30-2014) |
| Not Ranked : 0 score Sounds like you're happy with yours?
| Not Ranked : 0 score Very happy once the new washers arrived and were installed.
| The Following User Says Thank You to morbiddk For This Useful Post: | Farhan@DM (08-20-2014) |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score Sounds like this mount has some happy customers, has anyone had experience/seat time with both this RMM and the CP-E Stage 2? How do they compare?
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
(Thread Starter) | Not Ranked : 0 score New lower pricing! Order now for only $145 shipped in the US! We've optimized our manufacturing process to lower costs, and we'll be passing on savings to you! Now only $145 shipped anywhere in the US! To our previous customers that have paid a higher price on the mount in the past 2 weeks, you will receive a refund for the difference. |
| The Following 5 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | Chuthor (08-20-2014), Deldran (08-23-2014), Easter Bunny (08-25-2014), SarcasticOne (08-20-2014), Snip (08-20-2014) |
| Not Ranked : 0 score Way to pass the savings along MDM. Sent from my iPhone using sausage fingers
| The Following 2 Users Say Thank You to macdiesel For This Useful Post: | Easter Bunny (08-25-2014), SarcasticOne (08-23-2014) |
![]() Join Date: Dec 2011 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 966
Groans: 127
Groaned at 24 Times in 17 Posts
| Not Ranked : 0 score i keep trying to order one for my car but it doesn't seem available... not sure why but lets fix that @Farhan@DM; @Matt@DamondMotorsports;
__________________ 2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna FreekTuned ![]() |
| The Following 3 Users Say Thank You to blackmicamps6 For This Useful Post: |
| The Following User Says Thank You to Farhan@DM For This Useful Post: | blackmicamps6 (08-23-2014) |
(Thread Starter) | Not Ranked : 0 score He has a MS6. lol I'll tell you about what I have in mind for a 6 RMM at the meet today. |
| The Following 3 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: |
Groans: 127
| Not Ranked : 0 score grumble.... still got 12 hours left at work here.
| Not Ranked : 0 score I wanna know too! My 6 desperately needs more DM love.
![]() Join Date: Jun 2011 Location: Parkville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Got one last week and the discount post-purchase as well, thanks Matt! Can't wait to put it in and see how much better it feels than my TRZ dogbone. |
![]() | | #24 | ![]() |
Enjoy the mount.
![]() | | #25 | ![]() |
| Not Ranked : 0 score lol, sorry Farhan, thanks for making the mount! |
| The Following User Says Thank You to frequencysurfer For This Useful Post: | Farhan@DM (10-20-2014) |
![]() | | #26 | ![]() |
![]() Join Date: Apr 2014 Location: Westland, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score New washers? @morbiddk |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score For anyone looking to purchase a Damond Motorsports RMM and PMM when the PMMs are ready to go, we will be offering a package deal. Also to show our support for customer's who've already purchased a RMM and want to get our PMM upon release, we will be offering the same, if not better, discount. Don't wait, and order your DM RMM today! MPS RMM, Mazda MPS rear mount, rear motor mount - Damond Motorsports | Damond Motorsports |
| The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | goHAMM (10-27-2014), naoandlater (10-27-2014) |
![]() | | #28 | ![]() |
I installed my RMM about 600 miles ago. Very impressed with how the car finally feels "one". Two questions I have is one, I get more of a vibe while under deceleration from 3200 down to about 2800 rather than cruising at say 2500. It seems normal but not sure if it is or not? And two, will the RMM cause any more stress to the other mounts causing them fail sooner than usual? | |
![]() | | #29 | ![]() |
![]() Join Date: May 2014
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Gonna install mine today! can't wait!
__________________ 2008.5 mazdaspeed 3. AEM SRI, NGK iridium plugs, RA flaps, Turbosmart Dual Port BOV, AP V3, CS HPFP, CS TIP, M2 test pipe, Muffler Delete and Gen 2 rims. Stage 2 Freektune OTS+ Map. |
| The Following User Says Thank You to MarcAndreGauthier For This Useful Post: | Farhan@DM (11-04-2014) |
![]() | | #30 | ![]() |
![]() Join Date: Sep 2012 Location: Montreal, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score Just out of curiosity, what's the durometer of the bushing? I cant find the info here / on your website. Thanks! |
![]() | | #31 | ![]() |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score Eleventy three. BTW you should ask the durometer of their OCC too.
![]() | | #32 | ![]() |
| Not Ranked : 0 score 90+
![]() | | #33 | ![]() |
| Not Ranked : 0 score Whoa that was fast! Thanks! We'll be placing my order along with OCC tomorrow
__________________ Cheap, fast, reliable. Pick two. |
| The Following User Says Thank You to reko For This Useful Post: | Farhan@DM (04-15-2015) |
![]() | | #34 | ![]() |
![]() Join Date: Apr 2016 Location: SoCal
Rep Power: 0 ![]() Thanks: 4
| Not Ranked : 0 score are the prices on the website shipped? Send me a PM please |
![]() | | #35 | ![]() |
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Damond includes US Priority shipping on all parts on his site, assuming you live in the US. Listed in the description of each item!
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks |
| The Following 2 Users Say Thank You to Carskick For This Useful Post: | Matt@DamondMotorsports (06-08-2017), t3chnique (06-08-2017) |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes.. for the most part. Smaller items go First Class, and some larger shipments go FedEx. |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Gotya, thank you for the correction. All the ones I checked were Priority. All of your prices are all inclusive , IIRC.
| Introducing the all new Damond Motorsports OCC | Matt@DamondMotorsports | Damond Motorsports | 85 | 08-10-2015 07:24 PM |
| Damond Motorsports OCC V1 review | Justus | Damond Motorsports | 5 | 10-15-2013 07:02 PM |
| Welcome Damond Motorsports | Haltech | Damond Motorsports | 46 | 08-25-2013 09:56 AM |
