Mazdaspeed Forums
-   Damond Motorsports (http://www.mazdaspeedforum.org/forum/forum/f661/)
-   -   Damond Motorsports TB Meth Injection spacer (http://www.mazdaspeedforum.org/forum/forum/f661/damond-motorsports-tb-meth-injection-spacer-177745/)
Farhan@DM 09-25-2014 08:21 AM
1 Attachment(s)
Need a nice clean setup to inject additional fluid into your air stream? Don't want to tap pipes on your car? Look no further.
The Damond Motorsports Throttle Body Spacer has 6 1/8" NPT ports to hook up whatever you want to inject right before the intake manifold. It sandwiches between your throttle body and intake manifold and allows you to thread in multiple nozzles, lines, or injectors for as much as 800 hp of fuel! The spacer comes with all the hardware you need for an easy install, including bolts, washers, and all the plugs you'll need.
Pricing:
$69 no gaskets
$79 1 OEM TB gasket
$94 2 OEM TB gaskets
USPS Priority shipping is included in the USA 48.
http://damondmotorsports.com/product...-ports-pre-buy
This spacer uses a stock throttle body gasket on each side, so you need 2 total. Please select the option you need for additional gaskets. Supplied gaskets will be OEM gaskets.
Will work with stock TMIC on Mazdaspeed 3 2007-2013 and Mazdaspeed 6 2007. You will need to trim the cold side boost tube 16mm.
Will NOT work with Mazdaspeed6 stock cold pipe.
Injectors and/or nozzles are not included.
Shown with Coolingmist injection nozzles (not included).
http://cdn.shopify.com/s/files/1/042...G?v=1414175370
lnumbp 09-25-2014 10:11 AM
Way cool! Is there a rubber o-ring gasket on both sides of the spacer?
Farhan@DM 09-25-2014 10:17 AM
Quote:
There is not. The stock gasket is used on both sides. One will be provided with the kit for under $80 total.
Sebs6 09-25-2014 10:30 AM
Any time frame?? Around went is gonna be released.
Farhan@DM 09-25-2014 11:52 AM
Quote:
Best case, shipping in 1-2 weeks.
If beta testers find problems, that moves out. We will not release a product that we and our beta testers are not happy with, so please be patient if it comes to that. We're confident in an October release even with a redesign, if needed.
Novej 09-25-2014 12:04 PM
Can you get it with a single nozzle?
Farhan@DM 09-25-2014 12:09 PM
Quote:
Nozzles are not included. You can run 1 to 4 nozzles of your choosing. Plugs will be provided for the other ports you don't use.
rfinkle2 09-25-2014 12:15 PM
:approve:
[R]usty 09-25-2014 12:29 PM
I think I speak for everyone when i say...
http://cdn.niketalk.com/d/d2/d2ee22b...ectoplasm.jpeg
WetzMS3 09-25-2014 12:42 PM
Quote:
Originally Posted by rfinkle2 (Post 2711371)
:approve:
:beerchug:
Novej 09-25-2014 03:56 PM
Quote:
Sorry I didn't mean nozzles I meant the pre drilled holes for the nozzles. Nevertheless you answered my question so thank you :) If its not too early go a head and put me down for the first batch when we can order them!..............I'm serious!
kbz0129 09-25-2014 04:55 PM
Damn, 4 nozzles!:approve:
cciepunk 09-25-2014 07:15 PM
Just another product I need to buy from DM.
chapdawg 09-25-2014 07:33 PM
i need to get on this beta tester list… its nice to see companies breathing life back into the platform:You_Rock_Emoticon:
Alpha 09-25-2014 08:21 PM
Mmmm.... This + EFR + Aquamist = :firedevil:
LatinKraze 09-25-2014 09:51 PM
Make this spacer for Bosch injectors
sidekick 09-25-2014 10:43 PM
Would this work with a TMIC? Or is it designed to be used with a FMIC?
WetzMS3 09-27-2014 08:11 AM
Quote:
This fits on the stock manifold and easily works with TMIC.
Ask me how I know
Poohster 09-27-2014 08:57 AM
I guess that all hardware includes longer bolts for installation? Just asking. Great product!
Easter Bunny 09-27-2014 09:04 AM
Quote:
Ask me how I know
How do you know?
WetzMS3 09-27-2014 10:00 AM
5 Attachment(s)
Quote:
Originally Posted by Easter Bunny (Post 2712719)
How do you know?
:banana:
Farhan@DM 09-27-2014 03:09 PM
1 Attachment(s)
Update.
With stock manifold and tmic, you're able to use the two ports facing down, or at least one port facing up depending on your nozzle setup. It was evident that bottom or top + side ports couldn't be used with stock mating parts. So we're doing the sensible thing and adding 2 more ports on a third side. You'll be able to get 2 down + 1 or 2 up on stock mating parts, and the side if you have aftermarket manifold (and the TB rotated).
We're sticking with the price we committed to.
Poohster 09-27-2014 03:38 PM
I have a MS6 2006 cold pipe that wraps to the TB. How is the fitment? I can't be certain, but the space between the TB and the cold pipe may not be much. Thanks.
Farhan@DM 09-27-2014 03:42 PM
Quote:
Sorry, you'll need a new cold pipe and boost tube.
Farhan@DM 09-27-2014 04:17 PM
Prebuy is on! Come get some.
Mazdaspeed 3/6 TB spacer with injection ports PRE-BUY | Damond Motorsports
ms6mil 09-27-2014 04:28 PM
paypal sent can't wait.
Putin 2.3T 09-28-2014 03:13 PM
Ordered. :) Can't wait for release.
rfinkle2 09-28-2014 06:22 PM
:You_Rock_Emoticon:
maisonvi 09-28-2014 06:55 PM
damn, 6 ports? Just curious, why so many?
WetzMS3 09-28-2014 06:59 PM
Quote:
Because all of the meths!!! Right @rfinkle2;???
Mostly for mounting options and flexibility depending on the setup
shane5747 09-29-2014 12:09 AM
Pre-Order placed. I've been waiting for something like this. I really did not want to drill in to my cobb coldpipe, or add a tap in the silicone.
tegxsi 10-06-2014 08:56 PM
I was wondering if something like this existed... looks good!
ms6mil 10-08-2014 06:16 PM
@Farhan@DM; Any word on a ship date yet? the suspense is killing me!!!
http://i.imgur.com/pQHYMJ1.png
Farhan@DM 10-08-2014 06:33 PM
All I'm promising is by month end, but realistically will probably be around the 24th. I want to make sure the function is solid as well as the form.
SpeedRebirth 10-08-2014 06:40 PM
I'll be buying one even though i don't have a WMI system :P Getting this spacer will push me to actually buy one ;)
Farhan@DM 10-08-2014 06:46 PM
Quote:
You and me both.
Get your order in soon. Hopefully we'll guess right at how many extra we should get, but no guarantees if you don't preorder.
jack_hammer 10-08-2014 09:00 PM
Quote:
Originally Posted by Farhan@DM (Post 2721686)
You and me both.
Is this a one time order for you guys? Or just saying you'll probably sell out and have to wait for the next order to be cut?
tikous360 10-08-2014 09:47 PM
there's any gain on use this without WMI, just as a TB spacer?
mr.speedy3 10-08-2014 10:37 PM
I can't see the original picture for some reason, but is there any chance you'd be selling it with a TB TIG? Seems like a good opportunity for people to install a TB tig since the TB has to come out.
tapatalkin
Matt@DamondMotorsports 10-08-2014 10:43 PM
Quote:
The later, more or less. We do plan on always stocking them though.
Quote:
TB spacers on carbureted and TBI cars can help to mix the air and fuel mixture. On a EFI port or, in our cases, direct injected engine, they have no real effect. It adds a little bit of plenum volume, but it's so small it's insignificant.
It'll add to the butt dyno though, so in that sense, you should buy one :booty:
Page generated in 0.20957 seconds with 11 queries
