Like Tree91Likes
 Old 06-29-2016, 01:58 PM   #81
Moar teasing.
mxlplx71 (06-29-2016), Yatta (06-29-2016)
 Old 06-29-2016, 02:02 PM   #82
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Strange. Shows up in all 3 of my browsers. Just a link to the fb post. I took out the 's' in the HTTPS since some browsers have issue with it.
AwAfrican likes this.
 Old 06-29-2016, 02:02 PM   #83
Noticed that as well... maybe the page will be up tomorrow? hah
i saw it. it was a post on their facebook. maybe it got removed or something.
 Old 06-29-2016, 07:14 PM   #84
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Porn doesnt last long on FB...
WetzMS3 likes this.
The Following 3 Users Say Thank You to JSmith For This Useful Post:
KiwiFlavor (07-11-2016), WetzMS3 (06-29-2016), Yatta (06-30-2016)
 Old 06-30-2016, 09:01 AM   #85
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
well?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
WetzMS3 (06-30-2016)
 Old 06-30-2016, 10:01 AM   #86
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
Weight info, for those who are interested in shedding a tiny bit.
ST Mani: 3.6 lb
DM Adapter: 1.7 lb
I don't have a stock manifold weight, only one that has VTCS removed with mild porting. It weighed 7.7lb, so I'm guessing a totally stock mani is around 8.5lb.
Approximate savings: 3.2 lb
vtcs couldn't have been more than 1lb, by the feel of it .
Helpful post Phate !
ericrapp0507@gmail.com is offline   Reply With Quote
 Old 06-30-2016, 08:36 PM   #87
broda's Avatar
Posts: 375   (View Stats)
https://damondmotorsports.com/produc...nt=21148829956
There you go for you lazies
The Following User Says Thank You to broda For This Useful Post:
ericrapp0507@gmail.com (07-04-2016)
 Old 07-06-2016, 05:51 AM   #88
Atomic41's Avatar
Posts: 1,174   (View Stats)
@Farhan@DM;
When we all have news if this part will be compatible with TMIC ???
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
 Old 07-09-2016, 04:22 AM   #89
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
Originally Posted by Atomic41 View Post
@Farhan@DM;
I highly doubt it will be, there is no where for the the TMIC to mount to the Manifold.
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
 Old 07-09-2016, 06:30 AM   #90
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
It will more likely be something custom like meth pump/tank mounting. Once people get the first few batches and fux with them something will emerge. Im getting mine today.
MECP
2012 BM
Rfinkle tune in progress
 Old 07-09-2016, 06:33 AM   #91
mxlplx71's Avatar
Groans: 128
anyone could make this work, fmic or tmic, if you cant figure that out go buy a Hyundai veloster
WetzMS3 likes this.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
rob ms6gt (07-10-2016), WetzMS3 (07-09-2016)
 Old 07-09-2016, 08:22 AM   #92
broda's Avatar
Yeah, it's just a plastic, $60 manifold so there's no reason you should feel opposed to messing with it. You could tap into the runners, use a long stud and then add brackets. Done.
 Old 07-10-2016, 06:33 PM   #93
Groans: 74
Well..... it seems the tmic cold pipe rests on the manifold so it's going to be much more complex then i originally thought as usawal. I removed my tmic shroud for clearance while testing.
Maby with a modified CS scoop it may work. Piping will fit but the cold pipe imo is the major issue.
MECP
2012 BM
The Following 4 Users Say Thank You to 5doorsoffury For This Useful Post:
broda (07-10-2016), JSmith (07-10-2016), MS3Shadow (07-10-2016), nindoja (07-10-2016)
 Old 07-10-2016, 10:06 PM   #94
nindoja's Avatar
Posts: 2,395   (View Stats)
@5doorsoffury; is that with the spacer or without? You may gain/lose some clearance with that spacer. Additionally, which part of the cold pipe is hitting?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 07-11-2016, 04:35 AM   #95
Groans: 74
That is with the spacer. It is hitting the rear of the cold pipe as it starts to bend. It makes contact with the rib of runner 4 . I may be able to get more clearance by sliding the intercooler forward. I am going to revisit it after work today.
MECP
2012 BM
 Old 07-11-2016, 06:10 PM   #96
Groans: 74
Progress!
I was able to shift it forward. Not gunna lie i was looking hard at fmic's but it is not time for that yet. Ill keep screwing with it until this weekend where i will be going out of town for 3 weeks with the ms3. So i will put it back to stock mani for the trip. After that it will be permenent mod time.
New post needed for rear directly in front of the old one. Front pass bracket needs realignment/shapeing. Driver side st engine cover ball needs to be chopped off. Turbo elbow needs to be spun and trimmed. I still need a dr side bracket.
Edit: i have a 3.25" tmic so it is harder for me to get the room then someone with a thinner intercooler.
MECP
2012 BM
The Following 5 Users Say Thank You to 5doorsoffury For This Useful Post:
ericrapp0507@gmail.com (07-12-2016), Gerbilo (07-12-2016), JSmith (07-15-2016), MD1032 (07-12-2016), WetzMS3 (07-12-2016)
 Old 07-11-2016, 06:18 PM   #97
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Damn looks like it will require a lot of work to make it fit with TMIC
2012 NASA Spaceship Gray MS3
 Old 07-16-2016, 07:08 PM   #98
JSmith's Avatar
Groans: 106
Are we deleting posts in here now?
"$449 for titanium adapter plate."?
 Old 07-16-2016, 10:22 PM   #99
aviator79's Avatar
Posts: 3,934   (View Stats)
I deleted it myself...it does convey how I feel but decided no point of posting it here so deleted.
JSmith (07-17-2016)
 Old 07-17-2016, 06:16 AM   #100
Groans: 74
Well this is how i think of it. You always could buy a jmf..... for almost double. 449 for a plate, manifold that has been modified and a plug n play extention harness. This gets you a manifold that almost flows as good as a jmf and resists heat soak. This is not something for some one who wants a bolt on and done solution it takes some modification.
But so does suspension setups, meth kits, turbo lines and about half the stuff you do to your car.
The tmic i beleive will just be 2 brackets and some pipe. I wont stop until i get it to work.
MECP
2012 BM
The Following 2 Users Say Thank You to 5doorsoffury For This Useful Post:
ericrapp0507@gmail.com (07-17-2016), KiwiFlavor (07-17-2016)
 Old 07-17-2016, 08:13 AM   #101
aviator79's Avatar
I already bought mani a few months ago cause I was bored but havent had time to mess with it. I did not realize the options were default selected to YES as I thought $449 was just flange. $299 for flange is better. Will look into it more when I get time.
The Following 2 Users Say Thank You to aviator79 For This Useful Post:
5doorsoffury (07-17-2016), zjnspeed3 (07-17-2016)
 Old 07-17-2016, 12:00 PM   #102
I have a JMF manifold. Had it for a couple years. First run i think.
But just recently installed the latest rebuild.
Nothing against it.
But if this option was available at the time, the ST mani with adaptor plate would have been my choice. ST manifold looks awful but function wins
File Type: jpg mazdaspeed intake and charge pipe mock up.JPG (3.56 MB, 114 views)
The Following 3 Users Say Thank You to ericrapp0507@gmail.com For This Useful Post:
5doorsoffury (07-17-2016), AwAfrican (07-17-2016), Farhan@DM (07-19-2016)
 Old 09-12-2016, 11:07 AM   #103
Atomic41's Avatar
Can someone ... who install it on his SPEED3.
Can put a review here please ???
Any change on your SPEED3 ...
Thanks
 Old 09-12-2016, 11:09 AM   #104
Thanks
I have had it on my SPEED3 for nearly a year. What would you like to know? Flow data is here, I'm not sure what else could help your decision making process more.
 Old 09-12-2016, 11:14 AM   #105
maybe he wants to know if anything changed when you installed it on your SPEED3 and a review of that as well?
 Old 09-12-2016, 11:14 AM   #106
KiwiFlavor's Avatar
maybe he wants to know if anything changed when you installed it on your SPEED3 ?
dat SPEED3 doe
 Old 09-12-2016, 11:17 AM   #107
Airflow increased, imbalance across cylinders was reduced when installed on my SPEED3.
KiwiFlavor (09-12-2016)
 Old 09-12-2016, 11:42 AM   #108
Atomic41's Avatar
is it worth it for the price ???
 Old 09-12-2016, 11:47 AM   #109
Full disclosure: I have not looked at what price DM has decided to sell this for. I helped develop it over the last year, but do not work for DM.
The answer to that depends on your goals really. If you need to flow as much air as a JMF manifold, but prefer a better balance across cylinders, this manifold is definitely worth the cost. If you'd like more flow than an OEM manifold, and like balance across cylinders, it may even be worth the cost difference between a PnP manifold and this.
It's a tough question to answer individually. I have no idea what your goals are or what is currently on your car.
 Old 09-12-2016, 05:59 PM   #110
Groans: 74
It give you direct port meth with a lot of flow. It would be mainly for balanced flow on a ko4 since the turbo can be maxed out very easily. When the PI version comes out it will be that much better.
MECP
2012 BM
 Old 09-13-2016, 07:01 AM   #111
Atomic41's Avatar
the better balance across cylinder give a smoother power delivery on better response time when you push accelerator ??? do you see any change between stock IM and DM IM or we just know by spec sheet it will be better but no change in everyday feeling ???
 Old 09-13-2016, 07:39 AM   #112
Previous to testing this kit I had a Relentless Customs PnP manifold with VTCS delete. I did not notice a change in acceleration pedal feel or response at all, either way under low load conditions. The 3076 on my car does seem to spool a tad bit faster. I did see an increase in airflow, as well as power when switching manifolds.
 Old 09-13-2016, 07:44 AM   #113
Yatta's Avatar
Posts: 1,862   (View Stats)
Relentless might have done a good job on balancing (intentional or not) the runners; it would be very interesting to do per cylinder measurements on the exhaust side after switching to this manifold.
WetzMS3 (09-13-2016)
 Old 09-30-2016, 08:23 AM   #114
Atomic41's Avatar
so PnP our stock manifold vs this DM IM option ... which seem to be the best option for a Stage 2+ SPEED3 ?
So if I understand ... not really a big upgrade vs our OEM IM if it's just airflow balance and this don't bring power.
It's for a healthy motor that's it ???
 Old 09-30-2016, 08:32 AM   #115
I have no idea what a "Stage 2+ SPEED3" is.
The ST manifold flows more air and is better balanced than a PnP manifold, as has been shown in this thread.
If you need more air to make more power, than this is better than a PnP manifold. If a PnP manifold flows enough air for your goals, then the reason to upgrade would be better balance.
There really is a lot of information in this thread, I suggest you read through the whole thread. Is the upgrade worth it on a k04 car not chasing a ton of power, probably not. Will some do it anyway for better balance, probably.
blackms3_71 likes this.
Gerbilo (09-30-2016), KiwiFlavor (10-01-2016), Nliiitend1 (09-30-2016), Tomas (09-30-2016)
 Old 09-30-2016, 05:18 PM   #116
Atomic41's Avatar
Ok !!!
So I wish they go out with a TMIC compatible DM IM soon ...
Thanks for your time sir
 Old 09-30-2016, 07:41 PM   #117
Groans: 74
I was able to make it work. It's a pita with fat pipes and couplers. It could be done easier if i used smaller pipe and could weld/bend it into 1 or 2 pieces. I am not done still have some brackets to remake in steel and i want to see if my install rubs or does anthing after driving on it for a while.
I don't have any turbo lag and the car is just as reaponsive as before. My cold start stumble did get a bit more severe but no fucks given. No logs.
For a ko4 there is about as much gain as a jmf. It will be marginal at best. Other then some bnr s3 people on a tmic the majority of cars that can take advantage of the extra flow will most likely be useing a fmic. The manifold works the best with a passenger side hookup to the fmic due to the oil filter getting in the way. I did it because it was a challenge and i wanted to have it on the car instead of messing around with it for the first time when it comes to build time. I wish they would come out with a pi version already since i cant imagine where the 6th port coupler would go.
MECP
2012 BM
KiwiFlavor (10-01-2016), Tomas (09-30-2016)
 Old 09-30-2016, 09:03 PM   #118
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
My tumble flapper delete IM makes cold starts a total stumble fuck fest. Main reason I wouldn't go with this. That shit just annoys the fuck out of me. Going back to fully functioning stock tumble flaperoo IM.
macdiesel likes this.
MD1032 (10-06-2016), WetzMS3 (10-03-2016)
 Old 09-30-2016, 10:11 PM   #119
JSmith's Avatar
Groans: 106
You can change the cold start idle via the tune to mitigate. Makes it manageable if the temps are 60 deg F or above.
Edit: You've probably seen this thread but here it is anyways. Possible cold start fix
The Following User Says Thank You to JSmith For This Useful Post:
Tomas (09-30-2016)
 Old 09-30-2016, 10:36 PM   #120
Bob Ross Fanclub
Tomas's Avatar
I should have worded it differently.
I do not have a problem with a cold start high idle or problems getting the car to start.
Up to coolant operating temp the engine will stumble when you drive. Or hesitate on throttle input. Or slightly choke. Many ways to describe it. Reason being there isnt enough swirl in the combustion chamber when cold. That's the whole reason of the variable tumble mathingey. How the Focus ST gets around this I have no idea but it could be a different combustion chamber design.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
5doorsoffury (10-01-2016), Dano (10-01-2016), MD1032 (10-06-2016), WetzMS3 (10-03-2016)
Volkswagen teasing plug-in hybrid SUV concept for Beijing Haltech Automotive News 0 04-18-2016 10:10 AM
Subaru teasing STI surprise for NYC show? Haltech Automotive News 0 04-14-2014 12:30 PM
Video: Is BMW teasing an X6 M diesel? Haltech Automotive News 0 12-04-2011 06:20 PM
2011 Ford Explorer teasing continues - My, what big pillars you have Haltech Automotive News 0 06-18-2010 11:40 AM
BMW teasing 2011 X3 well in advance Haltech Automotive News 0 05-24-2010 08:50 AM
Page generated in 0.60055 seconds with 35 queries
