Like Tree91Likes
 Old 10-01-2016, 09:56 AM   #121
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
this exactly with my setup. Even in summer 95* outside the 1st 2-3 minutes of driving you can't hold the throttle just off idle without it stumbling. you have to really give it some gas (=more airflow) to get past it. Its all in the tumble, or lack thereof. I've often thought about PNPing an OEM intake and reinstalling the VTCS system. but meh it's an (almost) daily driven racecar so not worth the effort.
I would imagine any ST IM will be the same.
Tomas (10-01-2016)
 Old 10-01-2016, 05:40 PM   #122
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Most of the time i remote start my car so it can warm up a bit before i drive. This way i never have to worry about it's affects while driving (That and i fucking love a warm car in winter). When i dont have time for that i just blip the throttle while cranking to bypass cold start.
You dont have to wait for the motor to catch for the bypass to work so there is no worry of revving it up cold.
The cold start stumble can also cause a p300 misfire pending code if you always start it from a cold state.
I think the only reason it stumbles is because the ecu is expecting the behavior of the VTCS system. The FOST dosent have one so the ecu isn't coded for a VTCS start up so no stumble. It probably runs pig rich to get the cats up to temp like most cars.
MECP
2012 BM
Rfinkle tune in progress
 Old 10-01-2016, 07:47 PM   #123
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Its all in the tumble.
IT'S ALL IN THE MOTHERFUCKING TUMBLE
macdiesel likes this.
Dano (10-02-2016), WetzMS3 (10-03-2016)
 Old 10-02-2016, 08:27 AM   #124
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
My car doesn't stumble on cold start when it's warm out. Usually give it a minute or two to warm up when it's cooler out.
I'd imagine you can tune out the stumble with some of the cold start tables.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 10-02-2016, 11:16 AM   #125
Trail of Fail
Dano's Avatar
Just to clarify, and like Tomas said, it has no problems starting or idling. Cold start logic runs as expected. It starts and idles just like a car with VTCS. It's only when you start moving (apply load to the motor) - opening the throttle plate slightly - that the stumble occurs. hard to explain I guess. Just crack the TP and the roughness occurs, just a cunt hair past that all is good again. I haven't tried tuning it out due to the difficulty in doing so since the car only does it for literally 2 minutes lol.
If I lived in a cold climate it would probably be too much to deal with and I'd just let the car idle for 5 minutes before driving it.
anyway I guess this is OT but wanted to clarify.
Tappin
Mauro_Penguin (10-02-2016), Tomas (10-02-2016)
 Old 10-07-2016, 01:59 PM   #126
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Is there a kit for the TMICs yet? I reckon it's only some tubing required to replace the silicone elbow between the coldpipe and TB when in its normal position with a longer tube and about the same elbow but lower in the engine bay. Or it's more difficult than that?
Nitro likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 10-07-2016, 02:33 PM   #127
aviator79's Avatar
Posts: 3,934   (View Stats)
I live in a cold climate but on a back road where I can just drive slow as it warms up. I dont like to let car sit to warm up so I just start and go.
Still want to install my ST mani but cant afford the $300 price for the kit. Need job.
 Old 10-07-2016, 04:10 PM   #128
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
I second Mituc....what is happening with the TMIC version??
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 10-07-2016, 06:12 PM   #129
Groans: 74
More like what is happening with the PI version??
MECP
2012 BM
The Following User Says Thank You to 5doorsoffury For This Useful Post:
AwAfrican (10-08-2016)
 Old 10-23-2016, 10:23 PM   #130
mituc's Avatar
Groans: 111
So did anyone with a TMIC fitted the FOST IM with this kit?
@Farhan@DM, any plans for adding a TMIC kit to the existing kit?
 Old 11-04-2016, 08:48 PM   #131
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Don't have a timeline for a TMIC version. However, I think 5doors might have figured it out for you.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
AwAfrican (11-05-2016), WetzMS3 (11-05-2016)
 Old 05-01-2017, 12:03 PM   #132
Atomic41's Avatar
Posts: 1,174   (View Stats)
What I need for the cold pipe section if I go with JBR UnderRouting Pipe + TR8 Core ... and Damond ST Intake Manifold
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
 Old 05-01-2017, 12:16 PM   #133
nindoja's Avatar
Posts: 2,395   (View Stats)
siliconeintakes.com get you a 180-pipe, a BOV adapter coupler (or pipe if your BOV works with the ones they offer), some lengths of the straight pipe, a 90-degree coupler, some 2.5" straight couplers to tie it all together, and one of the 2.5-2.76" couplers for the TB.
I can get a specific list later, but that's roughly what you'll need.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 05-01-2017, 12:36 PM   #134
Atomic41's Avatar
yes if you can for the specific list it will be nice
thanks
 Old 05-02-2017, 06:38 AM   #135
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
- 2.75" to 2.5" silicone reducer: Tube Reducer
- 1' 90* aluminum bend: Aluminum Pipe
- Mishimoto silicone tap for methanol: https://www.mishimoto.com/2-5-silico...-npt-bung.html
- 1' straight pipe: Aluminum Pipe
- BPV T-in silicone joiner: Silicone BOV T
- 90* silicone bend: Silicone 90
- Coupler joiner: DIY Intercooler Piping
- 2.5" bump coupler: Turbo Coupler
You can sub out the meth tap for a straight silicone section or another hump coupler. This list also assumes your BPV/BOV has a 1" or 1.25" pipe style fitting? for the T-in silicone section, not a normal mazdaspeed flange.
This list is in order from throttle body to cold side of the intercooler. Provided you have a gen2, you'll have zero rubbing.
AwAfrican (05-02-2017)
 Old 05-02-2017, 06:49 AM   #136
Atomic41's Avatar
I have a Turbosmart BPV
 Old 05-02-2017, 10:31 AM   #137
Feline Führer
neganox's Avatar
I know JBR can sell you a BPV adapter if you're stuck with a mazdaspeed flange. I believe they'll fit the 1.25" T-in coupler, but you'll need to double check with them for sizing.
 Old 08-05-2017, 12:19 PM   #138
Nitro's Avatar
Has there been any progress on a TMIC version?
Sent from my SM-N910W8 using Tapatalk
MD1032 and macdiesel like this.
Stratified Tune
Volkswagen teasing plug-in hybrid SUV concept for Beijing Haltech Automotive News 0 04-18-2016 10:10 AM
Subaru teasing STI surprise for NYC show? Haltech Automotive News 0 04-14-2014 12:30 PM
Video: Is BMW teasing an X6 M diesel? Haltech Automotive News 0 12-04-2011 06:20 PM
2011 Ford Explorer teasing continues - My, what big pillars you have Haltech Automotive News 0 06-18-2010 11:40 AM
BMW teasing 2011 X3 well in advance Haltech Automotive News 0 05-24-2010 08:50 AM
Page generated in 0.39950 seconds with 31 queries
