Like Tree31Likes
 Old 01-13-2016, 05:29 PM   #1
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Neutral  +1 score
Default MS6 Oil Drain Line Flange
Matt, and I have a lot of history with the MS6, and a whole lot more love. I've been paying attention to the MS6 struggles here. It's taken too long, and this "check back in 4 weeks" nonsense to get a part machined puts it over the top. Long story short, I'm going to do try to solve this issue.
Code, I might get in touch with you soon about test fitting for me.
The Following 18 Users Say Thank You to Farhan@DM For This Useful Post:
batmsp3 (02-02-2016), Code Monkey (01-13-2016), Easter Bunny (01-14-2016), ESA (02-04-2016), Fonsi (01-13-2016), Hargarbl (01-13-2016), Mauro_Penguin (01-14-2016), Mazdazilla6 (01-14-2016), MD1032 (01-27-2016), Micha (01-17-2016), ms6mil (01-27-2016), nindoja (01-20-2016), PhillyCheese (01-13-2016), SamiChicago (02-02-2016), SofaKingAwesome (01-27-2016), speed23 (01-13-2016), Stryker125 (01-26-2016), WetzMS3 (01-14-2016)
 Old 01-13-2016, 05:36 PM   #2
I just got the Treadstone fittings today, will stop by the shop tomorrow and do some test fitting to see which angle works, will report back.
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
Easter Bunny (01-14-2016), ESA (02-04-2016), Farhan@DM (01-13-2016), Mazdazilla6 (01-14-2016), Poohster (01-14-2016), WetzMS3 (01-14-2016)
 Old 01-13-2016, 06:55 PM   #3
Omega's Avatar
Posts: 441   (View Stats)
Thanks for actually looking for a solution for us and to all those that have helped this cause! I'm looking to go BT sometime in the future (not anytime soon) and cannot express how awesome it is that a MSF vendor is stepping up to help.
I just wanted to express my interest in this if it helps a solution come to market for the 6. If this is a one-off run item more like a group buy rather than a continuing item, please announce I will buy sooner than later to support this if needed.
2006 Super Clean BCM MS6
 Old 01-13-2016, 09:38 PM   #4
speed23's Avatar
Posts: 1,480   (View Stats)
THANK-YOU!!!
The Following User Says Thank You to speed23 For This Useful Post:
Farhan@DM (01-14-2016)
 Old 01-14-2016, 09:41 AM   #5
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
In for results! Drain line is one of the last things I need to buy for my swap. If this doesn't work out I've got something in mind (and my amazon wish list) that should work.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 01-14-2016, 09:51 AM   #6
BrownBear
Farhan@DM's Avatar
Need input from everyone actually needing this.
Does this NEED to be adjustable/swivel? I'm not familiar with all the turbo options out there. Can one angle, assuming it's made to accept whatever fitting you need, work for everybody?
Likely a one run, unless someone makes a group that's interested in the future. Already expecting to not make money on this, I'd rather not tie up space on a shelf in addition.
It will work out.
Mazdazilla6 likes this.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
Mazdazilla6 (01-14-2016), WetzMS3 (01-14-2016)
 Old 01-14-2016, 10:05 AM   #7
IMO yes it should be adjustable/swivel because people who run top mount setups will need a different angle I believe.
I was planning on using this fitting for the block side, it allows for adjustability
Amazon.com: Fragola 499110-BL Black Size (-10) x 1/2 MPT 90° Swivel Adapter: AutomotiveAmazon.com: Fragola 499110-BL Black Size (-10) x 1/2 MPT 90° Swivel Adapter: Automotive
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Code Monkey (01-19-2016), SofaKingAwesome (01-27-2016)
 Old 01-14-2016, 10:12 AM   #8
BrownBear
Farhan@DM's Avatar
Why wouldn't they be able to put a different AN/JIC37 fitting on it to point it a different direction? If you have pictures showing any of what they might need, it would help.
That fitting won't work. Too tall.
The Following User Says Thank You to Farhan@DM For This Useful Post:
qtrmile beast (02-12-2016)
 Old 01-14-2016, 10:17 AM   #9
I suppose they could use another fitting to change the angle, unfortunately I don't have any pictures showing this but most top mount manifolds move the turbo towards the passenger side from what I've seen.
I'm pretty sure it'll work, I've seen some people on FB use it with success. What do you think it is going to contact from being too tall?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-14-2016, 05:29 PM   #10
@Farhan@DM; check my update -- I am going to order another banjo fitting, if the threads are the same (they should be) I could mail you guys the useless banjo fitting so you can design a flange around it.
 Old 01-14-2016, 05:47 PM   #11
BrownBear
Farhan@DM's Avatar
I advise holding off on ordering another fitting. I won't even ask for 2 weeks, just give me 1 to get things figured out. I think you'll be happy.
Won't need the banjo fitting.
Code Monkey and Mazdazilla6 like this.
The Following 5 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (01-14-2016), maddocx240 (01-14-2016), Mazdazilla6 (01-14-2016), Omega (01-14-2016), SofaKingAwesome (01-27-2016)
 Old 01-14-2016, 06:31 PM   #12
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
I had a leaky turbo drain line on my car for the past two years since I got it back from SP63. It's leaked the entire time, at times from certain area's. Not sure if it works for every turbo but the below links worked together to build a non-leaky one for mine.
10AN Aluminum Turbo Oil Return Drain Flange Garrett GT25 GT28 GT30 Ball Bearing | eBay
10AN Push-On Hose End - 30 Degree- TREADSTONE PERFORMANCE
Hi Temp Turbo Rubber Silicone Oil Drain Hose 5 8" 10 An Fast Shipping | eBay
200110BL Fragola 10AN Black Push Lock Straight Race Hose Ends | eBay
Turbo Oil Return Drain Flange 38mm Garrett GT15 GT17 GT20 GT22 | eBay
999160 Fragola 10AN Push Lock Clamps Pair | eBay
DEI 010419 HEAT SHEATH ALUMINIZED SLEEVING 1 | eBay
The Following 4 Users Say Thank You to Jh8909 For This Useful Post:
Code Monkey (01-14-2016), Mazdazilla6 (01-14-2016), qtrmile beast (02-12-2016), rob ms6gt (01-14-2016)
 Old 01-14-2016, 07:42 PM   #13
rob ms6gt's Avatar
Posts: 416   (View Stats)
To be universal I think it does need to swivel. The actual hose portion is so short that the fittings on both the block and turbo need to be damn near pointing right at one another to avoid kinking with a hose fat enough to provide adequate flow. Then on the turbo side there are different sized chra's that the line is attached to and different sized exhaust housings that the line needs to steer around. Both of these things affect this angle.
That's just one angle though. It still needs to come back towards the firewall as well.
That is the best I can explain it. It's hard to actually understand quite what you're dealing with until you've had to fab a line on a 6 for yourself.
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
The Following User Says Thank You to rob ms6gt For This Useful Post:
 Old 01-20-2016, 06:33 PM   #14
BrownBear
Farhan@DM's Avatar
Teaser. Details tomorrow. Already anticipating round 2, and that should be all it takes.
The Following 10 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (01-20-2016), DingoDave (01-25-2016), Easter Bunny (01-24-2016), ESA (02-04-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), neganox (01-20-2016), qtrmile beast (02-12-2016), rob ms6gt (01-21-2016), WetzMS3 (01-21-2016)
 Old 01-20-2016, 06:42 PM   #15
nindoja's Avatar
Posts: 2,395   (View Stats)
and this is why you are awesome @Farhan@DM;. It's a shame I won't ever be pulling my drain line on the 6, otherwise I'd want one of these. Or maybe I should buy one in case I decided to go bigger turbo...
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
Farhan@DM (01-20-2016)
 Old 01-20-2016, 06:50 PM   #16
In for drainage epicness! I've been holding off on getting a drain line to see how this pans out.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-20-2016, 06:51 PM   #17
Make it 1.75" just in case..... Not sure if one can fit an Allen key on the lower bolt with the TC on but it is worth a shot.
 Old 01-20-2016, 06:54 PM   #18
Cut allen key shorter. Solved.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-20-2016, 07:14 PM   #19
BrownBear
Farhan@DM's Avatar
Going for 1.72". Stay tuned for round 2. I'll contact you tomorrow.
Code Monkey likes this.
The Following 6 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (01-20-2016), Easter Bunny (01-24-2016), ESA (02-04-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), WetzMS3 (01-21-2016)
 Old 01-20-2016, 07:18 PM   #20
Easter Bunny (01-24-2016), JSmith (01-26-2016), Mauro_Penguin (01-25-2016), qtrmile beast (02-12-2016), rob ms6gt (01-21-2016), WetzMS3 (01-21-2016)
 Old 01-21-2016, 08:56 AM   #21
Omega's Avatar
Much love @Farhan@DM; this is definitely a great looking solution! Thank you guys for continuing to support the community when other vendors have given up.
Farhan@DM (01-21-2016)
 Old 01-21-2016, 09:32 AM   #22
I still think the top of the flange (only around the fitting) should be a bit thicker than the bottom, about 10 percent thicker will give you a nice 5-degree angle which should be good enough for relieving some of the stress on the line and the flange.
Easter Bunny (01-24-2016), rob ms6gt (01-23-2016)
 Old 01-21-2016, 12:51 PM   #23
robander3's Avatar
Posts: 143   (View Stats)
robander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant future
I'm interested if this goes into production
08 MS3 DD (Sold)
06 Dodge Dakota, V6, 6 speed, 4x4
07 MS6 w/engine block VTA mod (currently going built block, etc)
robander3 is offline   Reply With Quote
 Old 01-24-2016, 03:27 PM   #24
Any update @Farhan@DM;? I'm itching to see how this turns out.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Farhan@DM (01-25-2016)
 Old 01-24-2016, 04:01 PM   #25
2 weeks.
Farhan@DM (01-25-2016), WetzMS3 (01-25-2016)
 Old 01-25-2016, 06:59 AM   #26
BrownBear
Farhan@DM's Avatar
I was going to send code monkey one of the prototype I took pictures of, but decided against it. It will work with some modification, but no sense sending him something that isn't the final piece.
Round 2 has been designed, and is off for machining. It will not have the angle away from the block that some have requested. It would significantly increase the cost, and I don't think you need it.
2 weeks.
Don't you know better by now?
The Following 4 Users Say Thank You to Farhan@DM For This Useful Post:
ItsNox (01-29-2016), Mazdazilla6 (01-25-2016), Micha (01-29-2016), WetzMS3 (01-25-2016)
 Old 01-25-2016, 07:59 AM   #27
Ballpark on price? Is it going to be similar to the one that comes in the atmosphere kits?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Code Monkey (01-25-2016), SpeedRebirth (01-25-2016)
 Old 01-25-2016, 08:00 AM   #28
Well its been two weeks on those Mazda 5 caliper brackets
Plus all vendors are to treated with equal disdain......
 Old 01-25-2016, 09:36 AM   #29
BrownBear
Farhan@DM's Avatar
I asked if it NEEDED to be a swivel. The feedback was yes, swivel. So it will not be that type of flange.
Can't comment on price, yet. The fitting will probably cost more than the flange, to be honest.
Fair point.
...I never signed up for the caliper brackets.
Easter Bunny (01-25-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-25-2016), Micha (01-29-2016), rob ms6gt (01-25-2016)
 Old 01-26-2016, 07:53 PM   #30
BrownBear
Farhan@DM's Avatar
ORB swivel fittings get longer as they are rotated/swivel. Sizes are min, and max you might see with a new stock gasket.
It does not tilt out, as that would be expensive, and, I think, unnecessary.
It requires a specific XRP fitting. Cheapest I've seen it is $55.
The captive washer on the fitting needs to be reduced in diameter; I did it with a dremel in 5 minutes.
I'll likely send this to @Code Monkey; to get his nod. Then we'll let @Matt@DamondMotorsports; take care of you guys.
The Following 8 Users Say Thank You to Farhan@DM For This Useful Post:
ItsNox (01-29-2016), Mauro_Penguin (01-27-2016), Mazdazilla6 (01-26-2016), Micha (01-29-2016), ms6mil (01-26-2016), qtrmile beast (02-12-2016), rob ms6gt (01-27-2016), WetzMS3 (01-27-2016)
 Old 01-26-2016, 08:43 PM   #31
Looks pretty sweet! Do you have a picture of the block side of the flange? Just wondering how big the hole opening is and how much material is left on the edges.
The XRP fitting you speak of is, I assume, an XRP push-on hose end, page 11 of this catalog? If so, it is possible that a 30-degree or a 60-degree end could work (assuming they swivel).
 Old 01-26-2016, 09:06 PM   #32
BrownBear
Farhan@DM's Avatar
Plenty of material. You need the shallow 10 orb/an adapter. Can put whatever 10 an fitting on the other side.
The Following 7 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (01-26-2016), Easter Bunny (01-27-2016), ItsNox (01-29-2016), Mauro_Penguin (01-27-2016), Micha (01-29-2016), rob ms6gt (01-27-2016), WetzMS3 (01-27-2016)
 Old 01-26-2016, 09:29 PM   #33
Stryker125's Avatar
Posts: 386   (View Stats)
Stryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the world
Perfect timing! I was planning on using the oem return in the next month or so when my gtx3071 goes it. Sounds like this may make my life easier!
-2006 Speed6-
PTE5862 Tial 44mm ewg
Cpe exhaust mani, Relentless PnP Intake mani
Fmic w/ tr8
+All the things
Tuned by: Will Dawson @Purple Drank
Stryker125 is offline   Reply With Quote
 Old 01-26-2016, 09:30 PM   #34
@Farhan@DM; Looks awesome! So the flange uses ORB threads? I'm not familiar with that thread type. Why was that chosen over NPT or AN?
Edit: Are you using the part # 989110?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-27-2016, 06:42 AM   #35
BrownBear
Farhan@DM's Avatar
Yes, 989110
ORB/o-ring port/SAE straight thread/SAE J514 o-ring fittings are all the same. The thread is the same as the AN/JIC 37 fittings you see everywhere, just that there is an o-ring port machined in. Code Monkey's banjo fitting is an ORB.
Not an AN fitting because they're a metal-metal seal. They go loose with the smallest bit of rotation. I think that's a bad idea when your hose might actually be rotating the fitting out. They also give you a smaller opening for a fitting size. The XRP 989110 is a JIC37 on the other end, but you'll see it opens up at the angle.
Not NPT because I've seen too many leaks at this interface. The fitting would be cheaper with NPT, but may also leak a month later.
Mazdazilla6 and Mauro_Penguin like this.
Easter Bunny (01-27-2016), Mauro_Penguin (01-27-2016), Mazdazilla6 (01-27-2016), Micha (01-29-2016), torquemaniac (01-28-2016), WetzMS3 (01-27-2016)
 Old 01-27-2016, 08:57 AM   #36
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Interested in at least 2 of these.
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 2 Users Say Thank You to Lakespeed6 For This Useful Post:
Easter Bunny (01-27-2016), Farhan@DM (01-27-2016)
 Old 01-27-2016, 09:39 AM   #37
Farhan, is there anyway Matt would be able to include the fitting with the flange to help on price a bit or is it too low run of a part where that's not possible?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-27-2016, 09:42 AM   #38
I still do not know which fitting it is, @Farhan@DM; do you have the part number?
 Old 01-27-2016, 12:44 PM   #39
BrownBear
Farhan@DM's Avatar
XRP 989110 -10 Flare to -10 ORB 90 Degree Fitting.
Micha (01-29-2016)
 Old 01-27-2016, 12:52 PM   #40
Just giving away part numbers that he could sell at a markup.
HawkeyeGeoff (01-28-2016), Micha (01-29-2016)
MS6 -- possible oil drain line solution? Code Monkey Mazdaspeed3/6 General Discussion 15 01-29-2015 07:50 PM
bt oil drain line for MS6 ryein7 MazdaSpeed 3/6 - Turbo Induction 17 03-14-2012 10:42 AM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Page generated in 0.67807 seconds with 33 queries
