Like Tree12Likes
 Old 03-18-2014, 09:16 AM   #121
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
At idle and low load, the venturi setup will actually push exhaust gas back up into the VC. For this reason, you have to run a CV on the venturi pipe.
That's odd. There is a lot of vacuum from the venturing setup at idle. The check valve is needed to prevent pressure from coming from the exhaust.
Pickles Tune in progress
 Old 03-18-2014, 09:27 AM   #122
Realgib3's Avatar
Posts: 2,443   (View Stats)
Yeah back pressure, however small it is even with a 3" exhaust, will push back up the venturi pipe at low exhaust speeds. I wasn't able to test it with my cutout open, but I would suspect that to be the only way you wouldn't have this happen, if you truly had zero back pressure after the venturi pipe.
 Old 03-18-2014, 10:29 AM   #123
Voltwings's Avatar
Posts: 3,713   (View Stats)
I had HTP make me a custom intake with 2 breather nipples to use with my Perm plate. Its been a while, but let me see if i can remember what i did.
Plate outlet 1: Routed like a standard OCC.
Block > PCV > Can > CV > IM
Plate outlet 2: Routed to the intake to pull a vacuum on the crankcase at WOT
Block > CV > Can > intake
This route was on a check valve so it only placed vacuum on the crankcase at WOT conditions. For daily driving the IM still pulled on the crankcase like the stock design.
The second port on my intake was just routed to the VC like stock. I figured this helped with DD conditions as far as engine seals and just overall engine health was concerned. I Designed this setup so there was always some type of pull on the Crankcase.
DJ's original perm design worked great, but since i was in the market for a 4" and i like to tinker, i figured id give it a shot. Id say it worked fine, but i really have no quantitative proof either way. In theory i dont see why it wouldnt work.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 4 Users Say Thank You to Voltwings For This Useful Post:
jtday (04-07-2014), Matt@DamondMotorsports (03-25-2014), Realgib3 (03-19-2014), redboat (03-19-2014)
 Old 05-19-2014, 04:52 PM   #124
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Thanks again Matt, found the thread you mentioned, I'll be readin (:
 Old 05-19-2014, 05:11 PM   #125
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Ignore Kevin.
"Exclusivity" - CP-enis
Demodded.
The Seals
breakfstincluded (05-19-2014)
 Old 05-19-2014, 06:02 PM   #126
Thanks again to Tokay too, fuel trims bug the shit out of me when something is off.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/occ-crankcase-pressure-testing-diaries-141095/
Crank Case Ventilation fully explained. (Turbocharged edition.) This thread Refback 06-18-2014 11:19 AM
oil catch This thread Refback 06-13-2014 06:24 AM
The Project Pad ? View topic - Darin's 80tq...484whp... This thread Refback 06-05-2014 09:35 AM
Crankcase Ventilation Options - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-26-2014 07:21 AM
$5 OCC with Gatorade bottle - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-15-2014 06:56 PM
PCV and Excessive crank case pressure This thread Refback 12-31-2013 04:53 PM
oil catch can - Mazda 3 Quebec This thread Refback 11-19-2013 05:32 AM
Oil catch can et l'hiver - Mazda 3 Quebec This thread Refback 11-06-2013 03:31 PM
Need Help 1UZ TT not running smooth - Lextreme: Lexus-Toyota V8 Forum This thread Refback 10-18-2013 04:50 AM
Crank Case Ventilation fully explained. (Turbocharged edition.) - Page 4 Post #1 Pingback 06-21-2013 02:33 PM
Pressure testing a silicone TIP? Todd98SE MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 03-13-2013 03:07 PM
Crankcase relief jpshotya 2010 MS3 - Engine, Transmission & Driveline 3 10-18-2012 05:40 AM
Gen 1 MS3/6 Build/Diaries Haltech MazdaSpeed 3/6 - Build Diaries 6 04-07-2011 12:47 AM
GenPu Build Diaries Haltech 2010 MS3 - Build Diaries 1 03-21-2011 04:31 AM
Negative Crankcase Pressure kore2000 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-16-2010 07:56 AM
Page generated in 0.28136 seconds with 25 queries
