 Old 03-14-2016, 12:38 AM   #1
Polish_Eagle's Avatar
Posts: 408   (View Stats)
Default Oil Drain Line Flange #2 Interest
Not sure how many people missed the previous order for the oil drain line flange, but I definitely want/need one. Therefore, I'm creating this interest thread to see if we can get enough people to make another batch. Here's the thread for the original: Oil Drain Line Flange pre-buy
@Farhan@DM; @pwdunmore; @wwpms6;
Here's the list:
1. Polish_Eagle
 Old 03-14-2016, 10:12 AM   #2
pwdunmore's Avatar
Posts: 368   (View Stats)
Here's the list: @wwpms6;
1. Polish_Eagle
2. pwdunmore
My car thread:
 Old 03-15-2016, 08:59 PM   #3
wwpms6's Avatar
Posts: 26   (View Stats)
wwpms6 will become famous soon enoughwwpms6 will become famous soon enough
me
1. Polish_Eagle
2. pwdunmore
3. wwpms6
wwpms6 is offline   Reply With Quote
 Old 04-15-2016, 12:26 PM   #4
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
would this line benefit people with stock turbos? I am not precisely sure what issue this resolves, but from the number of people interested in the first run, this seems like something I probably will also want, once I understand the direct benefit if there is any
like the oil restrictor bolt stops the turbo smoking by blowing oil past the seals right? so then what does this return line fix? or is this more of an issue down the line with the stock line getting dirty and flowing worse and worse with time?
I tried to search but seems like more and more of my searches are winding up in a giant mess of irrelevant info, in threads that have nothing to do with the subject at hand(not sure what i am doing wrong, same search logic never failed me on google)
maybe I just suck at life, but maybe it would benefit others besides me to also re-list the benefits of this flange for others in a thread trying to drum up further interest...
just a suggestion, or at least a link to a thread that explains the issue if you wish to save urself the typing would be something quite helpful
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 04-16-2016, 08:23 AM   #5
Fonsi's Avatar
Posts: 236   (View Stats)
Fonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond repute
I'm in .... taking 2 of these.
1. Polish_Eagle
2. pwdunmore
3. wwpms6
4. Fonsi (2x)
2012 Mazdaspeed 3
CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts
Fonsi is offline   Reply With Quote
 Old 04-18-2016, 01:09 PM   #6
Gribbs1469's Avatar
Posts: 112   (View Stats)
Gribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to all
Mark me for one! hopefully this can be done soon!
1. Polish_Eagle
2. pwdunmore
3. wwpms6
4. Fonsi
5. Fonsi
6. Gribbs1469
2007 MS6 FMIC, Garrett turbo, 3" Magna Flow TBE, 4" Intake, HP Fuel pump, COBB AP V3
Gribbs1469 is offline   Reply With Quote
 Old 04-19-2016, 09:00 AM   #7
I don't need this anymore as I bought everything from eBay
1. pwdunmore
2. wwpms6
3. Fonsi
4. Fonsi
5. Gribbs1469
 Old 04-19-2016, 09:14 AM   #8
Gribbs1469's Avatar
Thanks
 Old 04-19-2016, 09:31 AM   #9
Gribbs1469's Avatar
So doesn't look like we will ever be getting this part? How many people do we need to they will make another run?
 Old 04-19-2016, 10:37 AM   #10
pwdunmore's Avatar
1. wwpms6
2. Fonsi
3. Fonsi
4. Gribbs1469
Decided to go with a BNR S4 so I can use my stock drain again.
My car thread:
 Old 04-19-2016, 10:40 AM   #11
Gribbs1469's Avatar
Dam! another on bites the dust!
 Old 04-30-2016, 03:53 PM   #12
speedtoz's Avatar
Posts: 453   (View Stats)
speedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the world
I would be in. If they do a second run. I got a spare block.
^^^My fail boats^^^
2006 mazdaspeed 6: fujita CAI, PG TIP, Turbosmart dual BOV, ITV22, Corksprt TBE, Cobb AP, SURE front/rear diff mounts(FTW), whiteline RSB
1978 280z(s30): currently needs some love....and going turbo o.0
1990 300zx: 850cc injectors, 300degree fuel rail, aeromotive FPR, garrett gt 28's twin turbo upgrade(@19psi), stillen IC's, CZP's 3in dp and mid pipe, Selin dual intakes, GTR R32 brakes, Nismo clutch, HKS hi-power exhaust, megan coil-overs, SPL full titanium suspension parts, z1 boost tubes, 2 AEM AFR's, AEM boost guage
RWHP:???? RWTRQ: 475@4500 rpm. needs new clutch(blown).
2008 350z HR: Greddy dual Ti-C, Carbonetics LSD, Nismo diff, GTM TP's, Stillen CAI's
(waiting on full metal CSC and carbonetic clutch and light wieght flywheel, then it's TT time!) currently on hold due to needing new clutch and flywheel/metal csc and master. wanting skyline manifold.
speedtoz is offline   Reply With Quote
 Old 12-17-2016, 02:00 PM   #13
rob ms6gt's Avatar
Posts: 416   (View Stats)
I just posted mine in the for sale section, BNIB
@wwpms6
@speedtoz
@Gribbs1469
@Fonsi;
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
The Following User Says Thank You to rob ms6gt For This Useful Post:
speedtoz (12-17-2016)
 Old 12-17-2016, 02:18 PM   #14
speedtoz's Avatar
@wwpms6
@speedtoz
@Gribbs1469
;@Fonsi
I'll take . I don't think I can get into the fs section
^^^My fail boats^^^
Oil Drain Line Flange pre-buy Matt@DamondMotorsports Damond Motorsports 48 03-14-2016 12:38 AM
MS6 Oil Drain Line Flange Farhan@DM Damond Motorsports 58 02-12-2016 12:00 AM
bt oil drain line for MS6 ryein7 MazdaSpeed 3/6 - Turbo Induction 17 03-14-2012 10:42 AM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Page generated in 0.32863 seconds with 27 queries
