Like Tree11Likes
 Old 02-11-2016, 10:57 PM   #1
Name is longer than yours
Posts: 209   (View Stats)
Default Oil Drain Line Flange pre-buy
Okay, you guys asked for this, and now you are getting antsy, so we want to get these out ASAP. As a good favor to the MS6 community from DM, let us present our Oil Drain Line Flange.
https://damondmotorsports.com/collec...l-drain-flange
This is for the flange that mates to the block and the -10AN 90 ORB fitting that goes into the flange. Depending on how well these do, we may offer a full line and fitting kit, but for now we want to get the most crucial components out, so you can run with it from there.
Price is going to be $95 Free US shipping. That includes the flange, and this ridiculously expensive fitting. We’ll also be offering the flange and fitting separately for $35 and $60 respectively. Note: we grind the washer down on the fitting, as to clear access for the bolts.
Pre-buy is open now, and closes in 1 week, so order ASAP. We’re doing a first round of 20 of these, if there’s more than that many people in the pre-buy, we’ll be getting more. Estimated delivery is 2.5 weeks. I’d say “2 weeks” but then you guys would never get this kit.
The Following 13 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Code Monkey (02-12-2016), DingoDave (02-13-2016), dsb_chicago (02-16-2016), Farhan@DM (02-12-2016), fivefingerdeathpunch (02-12-2016), g00s3y (02-17-2016), Mauro_Penguin (02-12-2016), Mazdazilla6 (02-11-2016), ms6mil (02-13-2016), rob ms6gt (02-13-2016), SIXual Panda (03-02-2016), Sleepin6 (02-12-2016), WetzMS3 (02-12-2016)
 Old 02-11-2016, 11:24 PM   #2
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
First. Ordered.
Does it include the bolts?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Matt@DamondMotorsports (02-11-2016)
 Old 02-11-2016, 11:34 PM   #3
First. Ordered.
It does. You can re-use the stock ones, but we include allen bolts.
 Old 02-12-2016, 12:07 AM   #4
MSP611's Avatar
Posts: 2,291   (View Stats)
What u mean by shave down the washer??
What kinda gasket is used between block and new flange? Stock type?
Just ordered mine as well!!
Sent from my Nexus 7 using Tapatalk
In progress:
 Old 02-12-2016, 12:27 AM   #5
littleloogy's Avatar
Posts: 4,005   (View Stats)
If you look closely at the last pic, you can see the washer between the mounting plate and the 90 degree fitting is shaved to allow the Bolts to line up properly. It's common to shave washers especially in a trial run. I am sure if these become popular Damond Motorsports will custom make their own washer.
Sent from a Galaxy far, far away...
 Old 02-12-2016, 03:56 AM   #6
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
Just place my order
season_of_ages is offline   Reply With Quote
 Old 02-12-2016, 05:53 AM   #7
Ordered.
 Old 02-12-2016, 06:43 AM   #8
wes3id's Avatar
Posts: 611   (View Stats)
ordered
wes3id is offline   Reply With Quote
 Old 02-12-2016, 06:48 AM   #9
Stock gasket.
 Old 02-12-2016, 09:19 AM   #10
Omega's Avatar
Posts: 441   (View Stats)
Ordered
2006 Super Clean BCM MS6
 Old 02-12-2016, 09:38 AM   #11
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Ordered
MSP611 likes this.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 02-12-2016, 11:49 AM   #12
MSP611's Avatar
Ordered
not tryna hijack thread or anything but breh ur car looks dope in ur sig... i was thinkin of gettin a professional photoshoot done with my car when its done
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
ms6mil (02-12-2016)
 Old 02-13-2016, 09:13 AM   #13
rob ms6gt's Avatar
Posts: 416   (View Stats)
Any way to get more than a week on this? I'll buy just the flange if I have to, but I'd like to wait till I can afford the whole thing. If 20 are not sold this week will they be no longer available?
Sorry, poor.
edit: Ordered. Fuck it. Made it happen.
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
 Old 02-13-2016, 04:56 PM   #14
DingoDave's Avatar
Posts: 764   (View Stats)
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
Ordered!
2013 Black Mica Mazdaspeed 3 - Current daily
2006 WWP Mazdaspeed 6 - Soon to be daily
2006 BCM Mazdaspeed 6 - Project
Tuned with by
DingoDave is offline   Reply With Quote
 Old 02-15-2016, 06:22 AM   #15
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Sorry, poor.
Glad you were able to get it.
For anyone else in a similar situation, your best bet is to buy the flange now, and buy the fitting when you're ready. You can buy the fitting yourself, and modify it. It's an available P/N from XRP (currently on amazon for ~$60), and taking the washer diameter down is nothing to be afraid of.
We'd rather not delay release, as there are people with builds coming up very soon that would be upset.
MSP611 likes this.
The Following 3 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (02-15-2016), MSP611 (02-15-2016), rob ms6gt (02-15-2016)
 Old 02-15-2016, 06:36 AM   #16
MSP611's Avatar
Thts wat im talkin about....
season_of_ages likes this.
In progress:
The Following 3 Users Say Thank You to MSP611 For This Useful Post:
Code Monkey (02-15-2016), DingoDave (02-15-2016), WetzMS3 (02-15-2016)
 Old 02-15-2016, 08:27 AM   #17
wes3id's Avatar
I bought this flange and the 90* adaptor. i will be installing a BNR s3 soon and am wanting to go ahead and do the return line at the same time. can anyone give me a parts list i will need to build the return line for the BNR so i can get it ordered? also does anybody know the exact size hose that goes from the bottom of the turbo to the TC?
 Old 02-15-2016, 08:41 AM   #18
^ I would use the OEM line on the BNR.
 Old 02-15-2016, 08:45 AM   #19
wes3id's Avatar
What is your reasoning? I think i have a small leak at the block flange as it is a little wet around it. i am installing the kozmic feed line as well, so figured i'd do both and be done with it.
 Old 02-15-2016, 08:57 AM   #20
Probably easier, unless you have the engine out. But if you still want to pursue it, a 45* and a 30* AN fittings worked for my mockup, got them from Treadstone.
 Old 02-15-2016, 09:00 AM   #21
wes3id's Avatar
ya i've read that it is a PITA with the engine and TC in place, but still possible. what flange did you use for the turbo side?
 Old 02-15-2016, 09:06 AM   #22
This one, I don't like the slotted holes as you can get the flange off center so make sure to install it on the turbo while the turbo is out.
wes3id (02-15-2016)
 Old 02-15-2016, 09:11 AM   #23
wes3id's Avatar
Thanks, appreciate it man.
The Following User Says Thank You to wes3id For This Useful Post:
 Old 02-15-2016, 09:31 PM   #24
MSP611's Avatar
Have u found treadstones AN fittings are better priced? Cuz holy fuck these things get expensive.. Just for some e85 nylon braided hose (running from hardlines in rear to my pump and a return line from fpr) and an fittings i spent like $500.. I did buy a few extra just in case I needed diff angles but fuck me $500 for some hose and fittings.
In progress:
 Old 02-15-2016, 09:46 PM   #25
No idea, I bet you can look around and find something a bit cheaper though.
 Old 02-15-2016, 09:54 PM   #26
MSP611's Avatar
Tht was from jegs, summit was similarly priced
In progress:
 Old 02-16-2016, 08:20 AM   #27
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
Finally! ordered
Building it from ground up:
r3d is offline   Reply With Quote
 Old 02-17-2016, 01:04 PM   #28
wes3id's Avatar
Hey man, did you use the paper gasket under that flange? or did you modify the stock metal crush gasket? i plan on using copper spray on whatever gasket works better for extra leak protection.
 Old 02-17-2016, 01:20 PM   #29
This flange has an integrated o-ring, no need for a gasket or copper spray.
 Old 02-17-2016, 01:23 PM   #30
wes3id's Avatar
ya i got it in today and saw the o-ring on it, was just curious if a gasket was still needed. have you had any leak problems with it?
 Old 02-17-2016, 01:40 PM   #31
I only test fitted on a spare engine, have not used the line yet on a running engine.
 Old 02-18-2016, 05:17 AM   #32
rob ms6gt's Avatar
That o-ring is a lifesaver for on car installs tho
ROB MS6GT
The Following User Says Thank You to rob ms6gt For This Useful Post:
Code Monkey (02-18-2016)
 Old 02-18-2016, 02:53 PM   #33
Order while you still can! At 11:59 the pre-buy ends, and the availability to order will cease.
Remember you can always order the $35 flange, and get the fitting elsewhere down the line.
Thanks to everyone who has ordered so far! You'll be receiving a confirmation email when they ship out. We're estimating delivery to your door the first week of March.
wes3id and Code Monkey like this.
 Old 02-18-2016, 05:39 PM   #34
rob ms6gt's Avatar
Not always! Only till about 11:59
ROB MS6GT
Last edited by rob ms6gt; 02-18-2016 at 05:39 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-19-2016, 12:46 PM   #35
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Has any one seen or tried this flange? Its angled at 45o already. Not sure on the clearance for the transfercase though.
track weight 3220
street weight 3370
 Old 02-21-2016, 01:01 PM   #36
Doubt it will clear. I bet it's fine without a fitting but once you put one on it's probably too long.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
qtrmile beast (02-22-2016)
 Old 03-01-2016, 06:06 PM   #37
Aaaaaand.... they shipped!
DingoDave (03-01-2016), Matt@DamondMotorsports (03-01-2016)
 Old 03-01-2016, 06:06 PM   #38
Got all shipped out today!
It was a fun rush, as my UPS guy delivered to me at like 5:45, and I had to be at the post office before 6:30.
Remember to use some oil on the threads of the flange when installing the fitting! For those who ordered the ORB fitting, remember to tighten the jam nut on it when installing into the flange. We also included a couple allen bolts with the flanges.
Any questions when you guys get it, feel free to ask!
wes3id likes this.
The Following 6 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Code Monkey (03-01-2016), DingoDave (03-01-2016), Mazdazilla6 (03-01-2016), rob ms6gt (03-02-2016), wes3id (03-01-2016), WetzMS3 (03-02-2016)
 Old 03-02-2016, 07:59 AM   #39
nindoja's Avatar
Posts: 2,395   (View Stats)
The flange has threads??? Or did you mean oil the bolts?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 03-02-2016, 08:02 AM   #40
BrownBear
Farhan@DM's Avatar
Fitting threads into flange, flange bolts to block.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
nindoja (03-02-2016), WetzMS3 (03-02-2016)
MS6 Oil Drain Line Flange Farhan@DM Damond Motorsports 58 02-12-2016 12:00 AM
bt oil drain line for MS6 ryein7 MazdaSpeed 3/6 - Turbo Induction 17 03-14-2012 10:42 AM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Page generated in 0.56585 seconds with 35 queries
