Mazdaspeed Forums
-   Damond Motorsports (http://www.mazdaspeedforum.org/forum/forum/f661/)
-   -   Oil Pressure Sensor Adapters (http://www.mazdaspeedforum.org/forum/forum/f661/oil-pressure-sensor-adapters-141030/)
Matt@DamondMotorsports 03-22-2013 07:05 PM
The Damond Motorsports Oil Pressure Sensor Adapter allows an aftermarket oil pressure sensor to be connected into your oil system, with very little modification.
Our OPS adapter connects into the factory oil sensor connection, located on the oil filter housing, and adds a “T” to connect the factory sensor and connect an additional aftermarket sensor. This way, there is no need for a sandwich plate, which can minimize the size of oil filter you can run. Also, the OPS adapter works with the cartridge style filter housings, used on many 4 cylinder Mazdas.
The Damond Motorsports OPS adapter comes with all the fittings you need to connect either a 1/8” NPT or 1/4” NPT oil pressure sensor, and enough hose to locate the sensors where you would like. We also include a bung, as to close off the additional connection, if, for some reason, the aftermarket sensor would need to be removed.
http://damondmotorsports.com/collect...sensor-adapter
Price: $29 free US shipping
http://cdn.shopify.com/s/files/1/042...g?v=1399085469
Page generated in 0.19475 seconds with 11 queries
