Like Tree11Likes
  • 9 Post By rfinkle2
  • 1 Post By Goodrich27
  • 1 Post By Farhan@DM
 Old 10-09-2014, 08:51 AM   #1
Neutral  +1 score
Default Review... Damond Motorsports Methanol Injection TB Spacer
Wanted to write a quick review up for a couple of the guys I have a lot of respect for and have always been big supporters of the Mazdspeed community.
Damond Motorsport’s guys are all Mazdaspeed owners and drivers and it is really cool to see such nice, useful and well-designed mods for our cars come out of these grassroots shops, imo.
Obviously, the pics are of a methanol injection throttle body spacer, and just as obvious is the spacer’s overall quality.
I like a few things about this particular plate, the overall size of the plate is very compact…, # of possible nozzle angles/ combinations and its versatility are killer, imo.
I’ve had a similar design on my car now for a while, and really think that these plates may benefit everyone from the k04 guys spraying relatively small amounts of meth to the guys making tons of HP…
What you get is a streamlined nozzle mounting solution that keeps your cold piping from becoming swiss cheese in what I think is an ideal place to spray…
Nozzle orifice depth is perfect, and the fan angle is in no way interrupted like some of the deep bungs and silicone mounts available.
Another very well designed, made and useful mod to come to our platform from Damond Motorsports.
The Following 32 Users Say Thank You to rfinkle2 For This Useful Post:
aromig (10-09-2014), BigO (10-09-2014), Chuthor (10-09-2014), CrawlingMS3 (10-09-2014), dawgincustoms (10-09-2014), dsb_chicago (10-11-2014), Farhan@DM (10-09-2014), Goodrich27 (10-09-2014), Gr8Speed (10-09-2014), Hammology (10-09-2014), Hush (10-09-2014), ibcrusn (10-10-2014), jdmage_mx5 (10-09-2014), Jtaylor (10-09-2014), Justin@Freektune (10-09-2014), Kyle Undefined (10-09-2014), LumberJack (10-09-2014), magicka (10-10-2014), MATT DAMOND (10-09-2014), Matt@DamondMotorsports (10-09-2014), Mauro_Penguin (10-09-2014), Micha (10-11-2014), Miltron (10-09-2014), ms6mil (10-09-2014), Nliiitend1 (10-09-2014), Shampu (10-09-2014), Sinerspeed (10-09-2014), SpeedRebirth (10-09-2014), taf0422 (10-25-2014), The Nut (10-09-2014), txmedic512 (10-09-2014), WetzMS3 (10-09-2014)
 Old 10-09-2014, 12:00 PM   #2
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Would love to have this as apart of my meth setup
Sent whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
The Following 3 Users Say Thank You to Goodrich27 For This Useful Post:
Farhan@DM (10-09-2014), rfinkle2 (10-09-2014), Sinerspeed (10-09-2014)
 Old 10-09-2014, 12:04 PM   #3
BlackFlag's Avatar
Posts: 596   (View Stats)
BlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the world
Will def keep this in mind for down the road. Looks like quality!
Slow for now...
Cobb ApV3///Cobb SRI+TIP///JBR Solid Shift Bushings///JBR 88 RMM///JBR SSP///
JBR Shift Knob///Cobb EBCM///MSR 045 18x8 +35///Nitto Nt05 235/40/18///CS Batt Box///CS Catted DP///ITV22's///Autotech Internals///TR8 FMIC///Koni FSD's/// CS springs
Freek Tuning Meow
BlackFlag is offline   Reply With Quote
The Following User Says Thank You to BlackFlag For This Useful Post:
 Old 10-09-2014, 12:07 PM   #4
If you guys were interested, there is a thread for a pre-sale here:
Damond Motorsports TB Meth Injection spacer
Farhan@DM (10-12-2014), Mauro_Penguin (10-09-2014), WetzMS3 (10-09-2014)
 Old 10-09-2014, 12:11 PM   #5
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
So quick question, if you have say...a JBR TB TIG....should you uninstall it when installing this spacer? I realize it does not do a whole lot especially with the coolant bypass but just curious about the proper way to go about the installation.
P.S. thank you for the review. IIRC you were testing the one for JMF also. Any thoughts for comparisons sake or is that a debate better saved for another thread?
Last edited by jdmage_mx5; 10-09-2014 at 12:11 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post:
Mauro_Penguin (10-09-2014), rfinkle2 (10-09-2014)
 Old 10-09-2014, 12:12 PM   #6
If you plan to use the included hardware, you would have to remove the TIG, as the bolts will not fit through both the TB plate and a TIG.
You could always source longer bolts, but personally I wouldn't waste the time.
EDIT: It should work with the TIG as stated a few posts below.
 Old 10-09-2014, 12:46 PM   #7
The design of the MD allows for more nozzle mounting options with a smaller foot print.
They are both well machines parts.
 Old 10-09-2014, 01:03 PM   #8
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Why would it not work with a JBR TIG? It's just 0.062 thick
Surely the bolts must be long enough to thread deep enough even with a thicker gasket?
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 3 Users Say Thank You to SpeedRebirth For This Useful Post:
Mauro_Penguin (10-09-2014), rfinkle2 (10-11-2014), WetzMS3 (10-09-2014)
 Old 10-09-2014, 01:07 PM   #9
My bad, you are likely correct. For some reason in my head I remembered the TIG being thicker than that.
If it's close to OEM gasket thickness it should work fine.
I do stand by the thought that it's unnecessary though.
Farhan@DM (10-09-2014), rfinkle2 (10-11-2014)
 Old 10-09-2014, 01:12 PM   #10
Yatta's Avatar
Posts: 1,862   (View Stats)
This couldn’t come at a better time (for me, as I just purchased a WMI kit) but why not O-ringed to get rid of gaskets?
rfinkle2 (10-10-2014)
 Old 10-09-2014, 01:59 PM   #11
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
That is really cool, I wish I could use it.
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
 Old 10-09-2014, 07:10 PM   #12
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Neutral  +1 score
I tend to prefer captive gaskets over O-rings, especially metal gaskets. They don't fall out during install, they don't pinch, they don't age, and don't compression set (relatively speaking).
Various chemicals, varying temperatures, and installing without having full line of site makes this a non trivial application. Of course, the right o-ring can do the job, but I'm not comfortable releasing an o-ring into an application like this that I haven't vigorously tested.
Additionally, if you're ever in need of a new gasket, the local Mazda dealer has you covered without having to guess material compatibility.
tl;dr: Because I trust the OEM gasket to do the job well.
The Following 15 Users Say Thank You to Farhan@DM For This Useful Post:
Fjager (10-12-2014), Hush (10-09-2014), ibcrusn (10-10-2014), JSmith (10-11-2014), Kyle Undefined (10-10-2014), magicka (10-10-2014), Matt@DamondMotorsports (10-11-2014), Mauro_Penguin (10-09-2014), Micha (10-11-2014), ms6mil (10-09-2014), nindoja (10-09-2014), Nliiitend1 (10-10-2014), rfinkle2 (10-10-2014), WetzMS3 (10-09-2014), Yatta (10-09-2014)
Damond Motorsports TB Meth Injection spacer Farhan@DM Damond Motorsports 84 12-15-2015 12:57 PM
(REVIEW) Damond Motorsports TB Meth Injection spacer BigO Damond Motorsports 17 01-17-2015 05:33 PM
Methanol Direct Injection phate MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 290 10-01-2014 09:34 PM
Damond Motorsports OCC V1 review Justus Damond Motorsports 5 10-15-2013 07:02 PM
Pre-turbo methanol injection KoukiS14 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 26 10-19-2009 04:20 PM
Page generated in 0.36755 seconds with 28 queries
