Like Tree37Likes
 Old 06-03-2014, 05:52 PM   #81
macdiesel's Avatar
Posts: 825   (View Stats)
Quality control on washers is probably on the low side. Washers don't really need to exact to get the job done.
Sent from my iPad using my stinky fingers
 Old 06-03-2014, 05:56 PM   #82
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Well i guess in this case they did lol
macdiesel likes this.
 Old 06-03-2014, 05:57 PM   #83
macdiesel's Avatar
Yeah, right. Looks like I'm off to the hardware store for some 12mm washers.
The Following 2 Users Say Thank You to macdiesel For This Useful Post:
blackms3_71 (06-03-2014), blam1 (06-04-2014)
 Old 06-03-2014, 05:59 PM   #84
Just to be clear u can use thicker washers then 12mm or 7/16 right? Bc i have some that a little thicker but will still let the nut thread on correctly
 Old 06-03-2014, 06:00 PM   #85
Nano91's Avatar
Posts: 286   (View Stats)
Yes, just put it in a position where the damond washer is the one making contact with the bushing
 Old 06-03-2014, 06:01 PM   #86
macdiesel's Avatar
Should work as long as a few threads are poking out when tightening the bolt
 Old 06-03-2014, 06:30 PM   #87
Damond washer?
Here is the set i have right now.. Is it okay to stack washers?
Last edited by blackms3_71; 06-03-2014 at 06:30 PM. Reason: MSF Database - Automerged Doublepost
Nano91 (06-03-2014)
 Old 06-03-2014, 06:31 PM   #88
Nano91's Avatar
Damond washer?
I ment provided
Damond washer?
Yes, I also stacked them except I didn't use locking washer. Should be fine I will check how my nut looks tomorrow make sure all is intact. After my drive it all seemed to be fine.
blackms3_71 likes this.
Last edited by Nano91; 06-03-2014 at 06:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-03-2014, 06:43 PM   #89
Thanks for the help. I also looked online and the faa says its okay to do on planes so must be ok to do on cars lol
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
Easter Bunny (06-04-2014), Nano91 (06-03-2014)
 Old 06-03-2014, 07:57 PM   #90
YoursTruly's Avatar
Posts: 325   (View Stats)
I stacked two 12mm washers on the allen side of the bolt. This allowed the supplied nut and washer to tighten down on the metal sleeves without running into the bolt shoulder. I torqued it to 55 ft-lbs and the clunk is gone!! The bushings hardly look deformed, so very little stress is put on them axially. Unless a better solution is found or the clunk returns, I am leaving this setup alone.
2010 MS3 "Maiko" - Sold
The Following 3 Users Say Thank You to YoursTruly For This Useful Post:
blam1 (06-04-2014), grazamataz (06-03-2014), JgamB (06-03-2014)
 Old 06-03-2014, 07:59 PM   #91
Chuthor's Avatar
Posts: 435   (View Stats)
Chuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the world
No clunking here yet. Spent the day trying
Sent from my XT1060 using Tapatalk
2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC
Chuthor is offline   Reply With Quote
 Old 06-03-2014, 08:06 PM   #92
Well good to see that it just seems to be a washer thickness issue and is being resolved. Now lets hear some more reviews!!
Farhan@DM (06-03-2014), YoursTruly (06-03-2014)
 Old 06-03-2014, 08:50 PM   #93
morbiddk's Avatar
Posts: 31   (View Stats)
morbiddk is a splendid one to beholdmorbiddk is a splendid one to beholdmorbiddk is a splendid one to beholdmorbiddk is a splendid one to beholdmorbiddk is a splendid one to beholdmorbiddk is a splendid one to beholdmorbiddk is a splendid one to beholdmorbiddk is a splendid one to behold
Alright, as promised, review as of today with maybe 20 miles on the new RMM.
A little background... I had originally purchased and installed the JBR 88 and ran that for about 300 miles before going back to the stock w/ CS Inserts. The vibes made it race car worthy but the resonating noise as a result of the vibes was next to umbearable. The CS Inserts were fine, next to no vibes at all but just felt too soft and then I saw DM's RMM and had to have it. I am still running the stock PMM and TMM.
Received the RMM in the mail and first thing I thought was holy crap this thing is heavy. That said its a beautiful piece of engineering, at looks good to although I was concerned to find a shoulder bolt but I held out and had faith. Had the mount sitting on my desk for about 4 days before I got a chance to install it, needless to say I was itching something fierce. Having no instructions I came back to the forum to see if anyone had any tips or pointers on torque requirements and say 40-45tq on the shoulder bolt and I felt much more at ease.
Install went just as any previous RMM installs, with the exception of the shoulder bolt not being able to torque down. Got it as tight as I could and the bolt still easily spun. Reinstalled the bolt about 3 times all with the same result. After closer inspection it appeared approximately 1mm of the shoulder of the bolt was extending out past the end of the bushing and the provided washer did not clear the shoulder but instead while tightening down the should would start to dig in and deform the washer and it was starting to look like LatinKraze's and ear28's. As concerning as this was I recall reading those who had similar issues and resulted in clunking but without any anticipated damage to occur as a result, I decided to stick with it. Clunking was anticipated and clunking I had occasionally during initial acceleration, occasionally around turns while accelerating, and constantly when reversing. This was also accompanied by vibes through the frame, but I had to admit the resonance as noticed with the JBR was not present, so far so good clunking aside. After seeing others using various washers and lock washers to resolve this I decided to start digging and found a couple washers of my own but that would have to wait for tomorrow to fix.
Install Day 2- Before attempting my own washers today I checked in to the thread again and saw that 7/16's washer should do the truth, this is when I found that the washers I was dug up were only 3/8 and wouldn't do any better than the provided one, so ran over to Lowe's and picked up a pack of 7/16's. I lostened the bolts for the mount to allow for movement and to add the new washer to the shoulder bolt. When I removed the supplied washer and nut and placed my own 7/16 washer in place I found that it fit perfectly over the extending part of the shoulder and allowing the provided washer to mount flush. I began tightening everything down and noticed that the 7/16 had slipped off the edge of the soulder and was presenting me with the same situation as with the provided washer, not being able to torque down the nut as needed. 2 attempts later I found that I had to slowly and carefully tighten the nut down to ensure the 7/16 washer remained in place. I was able to get everything torqued down to specifications including the 45tq on the shoulder bolt.
After finishing I took her for a test drive. Vibes definitely still present but clunking completely gone and still no adverse resonance like with the JBR. Wondering if the vibes will settle as the bushings break in, but what I've felt and noticed thus far I would definitely be ok if they don't.
Installed: Cobb AP v2 // Autotech Internals // Corksport Stage II SRI // CX Racing FMIC // ATP Catless Downpipe // DM RMM // Corksport SSP // JBR TBG & Collant Bypass // SU Shift Bushings // JBR Armor Mud Flaps
On The Bench (pending install): Grimspeed EBCS
Coming Soon (in no particular order):
JBR Intake TIG // HTP 3.5" Intake System // DM PMM // DM v1 Oil Catch Can // Corksport BPV // (?) Short Shifter // (?) Catted Downpipe
morbiddk is offline   Reply With Quote
The Following 2 Users Say Thank You to morbiddk For This Useful Post:
Farhan@DM (06-03-2014), grazamataz (06-03-2014)
 Old 06-03-2014, 09:13 PM   #94
grazamataz's Avatar
Posts: 221   (View Stats)
grazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the worldgrazamataz is the leader of the world
Definitely gonna try this on Thursday. No time tomorrow unfortunately.
phone
2012 CWP Mazdaspeed 3
Idontknowwhat SRI (on it when I bought the car) // Corksport TIP // Corksport test pipe // Corksport HPFP internals // Damond Motorsports RMM // Cobb AP // JBR solid shifter bushings // Stratified S-OTS+ E85 Tune
much car wow
so turbo
grazamataz is offline   Reply With Quote
 Old 06-03-2014, 10:48 PM   #95
JgamB's Avatar
Posts: 2,566   (View Stats)
Not sure my results are applicable due to being a complete beta part - but I have no clunking, and the only vibes I get are throttle tip in from 1st / reverse or lugging 2nd gear when rolling out from a very low speed. I was under the car recently to check my bushings and nut/bolt, and everything is looking good and still feeling great.
I just added air bags to the rear springs, so my weight transfer (or lack thereof) has just added to the flat and tight feel of the car and shift linkage. The whole package is feeling really good - now to find some streetable tires capable of handling the power...
 Old 06-03-2014, 11:25 PM   #96
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Yup, this is nothing more than a tolerance stackup issue. Washers for this time around ended up being a different size. Like I said, .070" causing this.
Wetz is doing testing on a new setup, but the result was instant and thoroughly successful. Give me a few days to feel all warm and fuzzy, then I'll send out a care package to anyone that wants one with new nut and washers so you don't have to guess.
Pull the bolt, put an additional 12mm, 7/16, or 1/2 in washer under the head, put it all back on invluding the 10mm washer. TORQUE TO 25 ft-lbs. Please do not use hardware that wasn't provided or recommended, especially lock washers or a regular bolt.
allo80 and WetzMS3 like this.
The Following 12 Users Say Thank You to Farhan@DM For This Useful Post:
blam1 (06-04-2014), dark_matter (06-06-2014), Dimenus (06-04-2014), ear28 (06-05-2014), Easter Bunny (06-04-2014), grazamataz (06-04-2014), JgamB (06-04-2014), jharris243 (06-04-2014), LatinKraze (06-04-2014), mazdaspeedmyk (06-04-2014), mdl3v8 (06-13-2014), WetzMS3 (06-04-2014)
 Old 06-04-2014, 12:09 AM   #97
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Crap 25 lbs? I just got to 40 lbs and the head of the bolt started to strip. Can we order a new bolt?
Sent from Stockish Pu
Pickles Tune in progress
 Old 06-04-2014, 12:56 AM   #98
mazdaspeedmyk's Avatar
Posts: 124   (View Stats)
Is it 25ft lbs or 45ft lbs?
The Following User Says Thank You to mazdaspeedmyk For This Useful Post:
himurax13 (06-04-2014)
 Old 06-04-2014, 12:57 AM   #99
Nano91's Avatar
New spec is 25lbs with the washer added
The Following 3 Users Say Thank You to Nano91 For This Useful Post:
Farhan@DM (06-04-2014), himurax13 (06-05-2014), mazdaspeedmyk (06-04-2014)
 Old 06-04-2014, 02:54 AM   #100
Whats wrong with using lock washers? I will not use it and go with a normal one but just wondering
 Old 06-04-2014, 07:34 AM   #101
grazamataz's Avatar
@Farhan@DM; I'm in for one of those care packages, I will pm you my home address (different address from where you shipped the mount)
phone
much car wow
so turbo
 Old 06-04-2014, 07:42 AM   #102
I can say that after about 75-100 miles so far, the issue is resolved. After a test drive to duplicate the clunk a few times with @Farhan@DM in the car, we added the correct washer and it really was an instant change. Idle vibrations were less right away, then we repeated the test drive to try to duplicate the clunk, without being able to produce a clunk at all.
The mount feels just as solid as it did two days ago, but now has less vibrations and no clunk. An improvement I could have survived without, but appreciate none the less.
I will monitor and be in touch with Farhan over the next few days.
Farhan@DM likes this.
The Following 8 Users Say Thank You to WetzMS3 For This Useful Post:
Easter Bunny (06-04-2014), Farhan@DM (06-04-2014), grazamataz (06-04-2014), JgamB (06-04-2014), mazdaspeedmyk (06-04-2014), mdl3v8 (06-04-2014), naoandlater (06-05-2014), SarcasticOne (06-05-2014)
 Old 06-04-2014, 09:00 AM   #103
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Lock washers turn into regular washers once they're flat. They don't actually lock anything. Just learned this for myself a few days ago lol.
-06 MS6
-Corn fed 07 MS3 - Sold
Farhan@DM (06-04-2014), Hush (06-04-2014), WetzMS3 (06-04-2014)
 Old 06-04-2014, 09:42 AM   #104
squilliam's Avatar
Posts: 266   (View Stats)
squilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the world
I would like a care package.
2009 CWP MS3: CP-E FMIC / CP-E RMM / Cobb SRI / Cobb TIP / Cobb AP V3/ HKS BOV / PTP HPFP Internals / UR V1 Catted DP / UR Racepipe / Cobb SS Catback Exhaust / Swift Spec-R Lowering Springs w/Koni Yellow
squilliam is offline   Reply With Quote
 Old 06-04-2014, 09:48 AM   #105
mdl3v8's Avatar
Posts: 410   (View Stats)
mdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the world
I'm going to need the care package, possibly a new shoulder bolt since mine is pretty stripped out.
Sent from my Samsung GALAXY S III
3" JBR TIP + 3.5" Treadstone MAF Housing | GTX2867R | CP-E catted DP | COBB CBE | Autotech Internals | CXRacing Piping + TR8 | DevilsOwn Meth Kit | Forge BPV | JBR Shifter Bushings | DM RMM | JBR PMM | JBR RSB | Moog Front/Rear Endlinks | Koni Yellows
mdl3v8 is offline   Reply With Quote
 Old 06-04-2014, 10:05 AM   #106
Well installed the mount. So far no clunk but i do have more vibs then i did with my old mount but i will give it some time to break in and then see how it feels
 Old 06-04-2014, 10:07 AM   #107
morbiddk's Avatar
@Farhan@DM I'll gladly take a care package just so I've got a good and supported install. It would go to the same address as the mount was shipped. Thanks.
 Old 06-04-2014, 10:12 AM   #108
dark_matter's Avatar
Posts: 193   (View Stats)
@Farhan@DM; I will take the care package as well.
@blackms3_71; I have increased idle speed from 700rpm to 750rpm, and it have significantly reduced idle vibrations.
Sent from my Republic Wireless Moto X using Tapatalk
RIP: くろ ひめ BlackMica SPEED3
dark_matter is offline   Reply With Quote
 Old 06-04-2014, 10:46 AM   #109
[R]usty's Avatar
Posts: 2,204   (View Stats)
@Farhan@DM;
Please send me a care package as well. Thanks!
2010 Mazdaspeed3 w/tech
 Old 06-04-2014, 10:50 AM   #110
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
@Farhan@DM;
Thank you good sir!
 Old 06-04-2014, 10:51 AM   #111
Nano91's Avatar
Same here In for the proper care
Package repair
 Old 06-04-2014, 10:53 AM   #112
My idle is 850, i also get more decl vibes too. Anyone get that? Maybe just needs to break in? Also i will take a care package too @Farhan@DM;
 Old 06-04-2014, 10:54 AM   #113
Nano91's Avatar
Today I felt those decel vibe
 Old 06-04-2014, 11:12 AM   #114
jharris243's Avatar
Posts: 214   (View Stats)
jharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the worldjharris243 is the leader of the world
I'll take one of them fancy care packages as well.
I put about 70 miles on the mount after adding the washer to the nut side and no more clunk. Vibes are still more prevalent than before. I'll wait for the proper washer and nut to torque to spec and see if there's a difference. Could just be the bushings breaking in too.
Sent from my Nexus 4 using Tapatalk
2012 CWP MS3: Corksport SRI/TIP | MD RMM, OCC | AT Internals | Cobb AP v3 | JBR 70d side mounts, SSP, shifter bushings | CP-E FMIC | CNT catted DP | UR Resonated CBE | Tints 20% and 5%
jharris243 is offline   Reply With Quote
 Old 06-04-2014, 12:00 PM   #115
@Farhan@DM; I sent a PM, but just in case it's buried under all the ones you've been receiving recently, I'll take a nuts and bolts care package. Thanks. Right thumb!
 Old 06-04-2014, 12:23 PM   #116
I agree prob is the bushing. I will give it 1000 miles to see if it improves if not back to the old mount lol
I noticed it the very first decal and its kinda heavy too i didnt like that but its also a new mount so lets see what happening during break in
Last edited by blackms3_71; 06-04-2014 at 12:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-04-2014, 12:27 PM   #117
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
@Farhan@DM; I will also take a care package.
Gracias!
2012 Velocity Red Mica
 Old 06-04-2014, 12:40 PM   #118
 Old 06-04-2014, 06:16 PM   #119
macdiesel's Avatar
@Farhan@DM; I will take a care package as well.
 Old 06-04-2014, 06:28 PM   #120
Faez0rbeamz's Avatar
Posts: 83   (View Stats)
Faez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the worldFaez0rbeamz is the leader of the world
Hello there! I know I'm a little late to this thread, but being that I've had this RMM installed on my car possibly the longest (or close to - just shy of 5k miles with it on) I thought I'd throw my two cents in here.
I want to say first a few things in order to be as fair as possible. I am a total newb to car innards and workings, I didn't know what a RMM was before owning my Speed. I also have a proto-type, and therefore I believe I may have slightly different nuts, bolts, washers than everyone else (the bushings and body/material/shape is the same though). Lastly, Farhan himself installed the RMM on my car (in a parking lot) - so my discussion of how easy it was is void, but it only took 10 minutes tops for him to get it on there without the aid of any special tools/selection of tools.
That day we immediately set out to the East Coast for Epic Nator Meet...within that weekend we drove about 1.5k miles, and had 5 different people drive my car at some point (to be fair, one was Farhan and another was Matt ...perhaps the two making the product do not count) yet all of us felt no note worthy vibration yet all commented on how seated an stiff the engine felt.
I have a Fidanza flywheel on my Speed so there is noticeable chatter at idle when I do not have my clutch engaged, and most of the vibrations are here and slightly into my climb out of 1st to 2nd. This is only slightly more noticeable when I happen to have the A/C on - but only in the sense that I'm trying to pay attention to it in order to write this review. Honestly it's basically the same with and without the A/C on and I hardly ever drive with that shiz on so if you're like me, you really won't GaF.
I'm a newb. I learned to drive stick on this car, in the winter, in Chicago - my driving skills are not the most forgiving or the best. I'll be the first to tell you. The beauty of this RMM is how much better it makes my shifting FEEL. I used to struggle with 1st and 2nd, and granted I'm still not perfect, but my transitions into and out of these gears are 110% better with the DM RMM. ESPECIALLY with the fact that, I CAN'T REV MATCH - so what do I do when I down shift from 6th to 4th to hoon? I basically slap that shit into gear and let it go - and as we know that makes the engine want to travel. This mount holds tight and takes the abuse (I am not recommending everyone drive like an idiot as I do, but you should know your DM RMM will rise to the challenge).
The DM RMM has remained strong, secure and quiet/almost completely vibeless over 5k miles, and I do not doubt that it will remain that way for many more. What I can't tell you in technical speak, I can tell you in experience - Farhan and DM will take care of you and the minor clunking issue that you're experiencing. It's unfortunate that something as minor would happen upon a great product's release but if that's the only issue marring your experience, let Farhan and DM send you a care package when they are comfortable doing so - give it another go and I am pretty sure you will not be disappointed.
OhMerGerd Phey Edition Blue Ken Maisonville Steel Shift Knob!!!
Cosmo <3 - '08 Cosmic Blue Mica Speed3. <3 Cobb V3 AP <3 CorkSport Intake & TIP <3 CX Racing FMIC <3 Forge V1 BPV <3 Fidanza Flywheel <3 AT Internals <3 Damond Motorsports RMM & PMM <3 Ultimate Racing Test Pipe <3 Bilstein Shocks & Struts <3 Cobb Lowering Springs <3 Whiteline Sway Bars <3 Phate Tuned <3
Faez0rbeamz is offline   Reply With Quote
The Following 3 Users Say Thank You to Faez0rbeamz For This Useful Post:
Chuthor (06-04-2014), grazamataz (06-04-2014), naoandlater (06-05-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/rmm-testing-review-diaries-171335/
Transformation! - Mazda 3 Quebec This thread Refback 05-17-2015 05:47 PM
OCC and crankcase pressure testing diaries Matt@DamondMotorsports Damond Motorsports 125 05-19-2014 06:02 PM
Video: Zenvo responds to Top Gear review after its car catches fire during testing Haltech Automotive News 1 02-21-2014 11:45 AM
Gen 1 MS3/6 Build/Diaries Haltech MazdaSpeed 3/6 - Build Diaries 6 04-07-2011 12:47 AM
GenPu Build Diaries Haltech 2010 MS3 - Build Diaries 1 03-21-2011 04:31 AM
Page generated in 0.60739 seconds with 41 queries
