Like Tree14Likes
 Old 12-04-2014, 05:27 PM   #1
Name is longer than yours
Posts: 209   (View Stats)
Default We're working on MS6 stuff.
I myself have owned two MS6's, and @Farhan@DM; has had his for like 900 years, that being said we came to the Mazdaspeed world via the MS6.
We haven't forgotten about this car, and we're working to better the 6 platform with DM products.
I'll be sure to make more formal threads pertaining to the specific parts, in due time, but for now I just wanted to show y'all the RMM we have in the works for the 6.
The Following 36 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
atvfreek (12-04-2014), blackmicamps6 (12-09-2014), Bob-o (12-11-2014), Boostin'likeAboss (12-09-2014), Captain KR (12-09-2014), Code Monkey (12-04-2014), dsb_chicago (12-12-2014), Easter Bunny (12-05-2014), ESA (12-05-2014), Farhan@DM (12-05-2014), fretburnr (12-15-2014), Hammology (12-06-2014), Hargarbl (12-05-2014), ItsNox (12-11-2014), John@RPM (12-05-2014), kish89 (12-05-2014), lnumbp (12-10-2014), Mazdazilla6 (12-09-2014), MD1032 (05-13-2015), memin (12-05-2014), Micha (12-05-2014), Mr. T (12-09-2014), ms3blackmica (03-20-2015), mxlplx71 (12-04-2014), Nliiitend1 (12-05-2014), Rich990 (12-12-2014), rymanmazda (12-04-2014), silvapain (12-09-2014), speed23 (12-04-2014), SpeedRebirth (12-06-2014), stanley0910 (12-05-2014), the public enemy (12-09-2014), TiGraySpeed6 (12-05-2014), trancehead (12-05-2014), WetzMS3 (12-05-2014), zer010gic (12-05-2014)
 Old 12-05-2014, 06:08 AM   #2
Micha's Avatar
Posts: 3,436   (View Stats)
And it helps there is an extra 6 parked in front of Farhans garage that will put motor mounts to work for sure.
I am slow again.
I modded it a little.
The Following 5 Users Say Thank You to Micha For This Useful Post:
Hammology (12-06-2014), Koke382 (12-10-2014), Matt@DamondMotorsports (12-05-2014), Nliiitend1 (12-05-2014), WetzMS3 (12-05-2014)
 Old 12-05-2014, 06:24 AM   #3
stanley0910's Avatar
Posts: 364   (View Stats)
stanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the world
Yay! @Matt@DamondMotorsports; is my hero!
Need more parts.
stanley0910 is offline   Reply With Quote
The Following 2 Users Say Thank You to stanley0910 For This Useful Post:
Matt@DamondMotorsports (12-05-2014), Micha (12-05-2014)
 Old 12-05-2014, 08:42 AM   #4
zer010gic's Avatar
Posts: 401   (View Stats)
zer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the world
Want to make us really happy. We need a good FMIC kit that does not require cutting the crash bar or a replacement crash bar for mounting a FMIC.
Autotech Internals | ETS TMIC | Cobb AP | JBR Tru-3.5" Wide Path Aluminum | JBR RMM | JBR TMM | JBR PMM | JBR Short Shift Plate | Fidanza Flywheel | TWM Weighted Shift Knob | Hawk HPS 5.0 Pads | Techna-Fit Brake Lines | RedLine Fluids and Unicorn Blood | NGK 1 Step Colder | Damond OCC | TurboSmart Duel Port | CP-e SafeSeals | JBR TIG | JBR TBG | Damond EGR Delete
Miltuned!!!
Ready to Install
ATP Downpipe
zer010gic is offline   Reply With Quote
The Following 8 Users Say Thank You to zer010gic For This Useful Post:
Boostin'likeAboss (12-09-2014), ESA (12-09-2014), igve2shtz (12-16-2014), ItsNox (12-11-2014), Matt@DamondMotorsports (12-05-2014), Micha (12-06-2014), Mr. T (12-09-2014), ms6mil (12-05-2014)
 Old 12-05-2014, 11:22 AM   #5
Are you thinking about making a diff mount as well?
Need more parts.
 Old 12-05-2014, 11:50 AM   #6
Damn you 6 guys are needy!!!!!!!!!!!!!!!!!!!
The Following 6 Users Say Thank You to WetzMS3 For This Useful Post:
ABolewski (12-06-2014), ItsNox (12-11-2014), Matt@DamondMotorsports (12-05-2014), Micha (12-06-2014), stanley0910 (12-06-2014), xfeejayx (12-05-2014)
 Old 12-06-2014, 11:54 AM   #7
Micha's Avatar
I used to say that too.... until I bought a speed 6.
WetzMS3 likes this.
I am slow again.
The Following 8 Users Say Thank You to Micha For This Useful Post:
ABolewski (12-06-2014), ItsNox (12-11-2014), Koke382 (12-10-2014), mxlplx71 (12-06-2014), Rich990 (12-12-2014), stanley0910 (12-06-2014), the public enemy (12-09-2014), WetzMS3 (12-06-2014)
 Old 12-06-2014, 02:32 PM   #8
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Hey Matt-
If I could make one suggestion, it's to maybe run the mount a little narrower so you can space the poly away from the mounting points. Otherwise the poly gets pretty chewed up. I guess functionally it doesn't make a huge difference but it always kind of annoyed me.
That's why I liked the CP-E because the mount is narrower and the spacers are the only points that make contact with the car mounts. This probably cuts down on NVH a bit since there is a little more isolation form the rubber and keeps the sides from getting torn up.
Not coincidentally, this is like the stocker.
I could see how this would add to cost since their rubber is formed to the mount though, vs just having poly bushings and spacer. I guess if you don't run the poly to the ends then the poly mounts can maybe walk out though... hmm.. Maybe a narrower mount, narrower bushings and then some sleeves/spacers to hold it together.
Anyways, just points of consideration.
WetzMS3 and Farhan@DM like this.
MINI H1 6.0 - CAR LED TAILS
The Following 8 Users Say Thank You to dale_gribble For This Useful Post:
dagrimey1 (12-12-2014), Easter Bunny (12-09-2014), Farhan@DM (12-06-2014), Matt@DamondMotorsports (12-10-2014), Micha (12-07-2014), Rich990 (12-12-2014), TiGraySpeed6 (12-11-2014), WetzMS3 (12-06-2014)
 Old 12-06-2014, 03:56 PM   #9
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Bushings in the rear don't touch the body. The stock tangs/hooks hold them in place, like they should. Thank you so much for the constructive feedback.
Beta parts are outbound.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
Matt@DamondMotorsports (12-10-2014), SpeedRebirth (12-06-2014)
 Old 12-09-2014, 01:32 AM   #10
Mr. T's Avatar
Posts: 659   (View Stats)
Mr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the world
Speed6 parts? Y'all just want me to open my wallet, don't you...
Alpine White/coral red 135i (N54)
24 psi, e70, catless downpipes, midpipes, axleback. FMIC and piping, synapse bov. G5 ISO board, e85 backend flash, stage 1 lpfp, turbo inlets, Federal 595 RSR-R tires.
Mr. T is offline   Reply With Quote
The Following User Says Thank You to Mr. T For This Useful Post:
 Old 12-09-2014, 11:32 AM   #11
blackmicamps6's Avatar
Posts: 2,744   (View Stats)
blackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the world
Groans: 127
Groaned at 24 Times in 17 Posts
I wish i could create multiple accounts on here just to thank you more times. fuck yes gentlemen... fuck yes.
2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna
FreekTuned
blackmicamps6 is offline   Reply With Quote
The Following 3 Users Say Thank You to blackmicamps6 For This Useful Post:
Farhan@DM (12-09-2014), Matt@DamondMotorsports (12-10-2014), WetzMS3 (12-09-2014)
 Old 12-09-2014, 11:48 AM   #12
RMM, really, wtf? We are way past this point. This is what I want for Christmas 2015:
A super efficient dual- or triple-flow radiator with one fan + a FMIC. All inlets/outlets on the radiator are in the same location as stock. The IC cold pipe would probably have to drop down and be routed under the radiator/IC bracket as most people have a condenser in front but you get the idea. On my race car I could run a thicker core as the condenser is gone.
The Following 9 Users Say Thank You to Code Monkey For This Useful Post:
bam88 (12-12-2014), Boostin'likeAboss (12-09-2014), cocoanton (03-02-2015), dagrimey1 (12-12-2014), ItsNox (12-11-2014), Matt@DamondMotorsports (12-10-2014), ms6mil (12-09-2014), Rich990 (12-12-2014), the public enemy (12-09-2014)
 Old 12-09-2014, 11:54 AM   #13
AlsMS6's Avatar
Posts: 96   (View Stats)
AlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant futureAlsMS6 has a brilliant future
^^Word
AlsMS6 is offline   Reply With Quote
The Following 3 Users Say Thank You to AlsMS6 For This Useful Post:
ESA (12-09-2014), Farhan@DM (12-09-2014), Matt@DamondMotorsports (12-10-2014)
 Old 12-09-2014, 12:44 PM   #14
BrownBear
Farhan@DM's Avatar
So many parts to make.
If you only knew how many things we have in motion right now...
The Following 10 Users Say Thank You to Farhan@DM For This Useful Post:
dsb_chicago (12-12-2014), ESA (12-09-2014), Koke382 (12-10-2014), Matt@DamondMotorsports (12-10-2014), Mazdazilla6 (12-12-2014), Micha (12-09-2014), Mr. T (12-12-2014), SpeedRebirth (12-09-2014), TiGraySpeed6 (12-11-2014), ttgeoff (12-15-2014)
 Old 12-09-2014, 12:58 PM   #15
Yes, I am in for a very good FMIC solution from just a crash bar up to full system. This is severely lacking in our space right now. The CP-E system and Corksport both had too many compromises to be meaningful systems and the hack/slash universal solutions were just that.
 Old 12-09-2014, 01:11 PM   #16
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I find your anal beads next to car parts, on a dirty table, unsanitary and disturbing...
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 8 Users Say Thank You to CWP_MS3 For This Useful Post:
dagrimey1 (12-12-2014), dale_gribble (12-09-2014), Deldran (12-12-2014), Easter Bunny (12-10-2014), ItsNox (12-11-2014), Koke382 (12-10-2014), Matt@DamondMotorsports (12-10-2014), Micha (02-15-2015)
 Old 12-09-2014, 08:48 PM   #17
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
Diff mounts and fmic please, there are already 5 different companies putting out great mounts right now
You would kill it with an affordable, hassle free fmic kit
08 cwp ms3
The Following 6 Users Say Thank You to Boostin'likeAboss For This Useful Post:
Easter Bunny (12-10-2014), ItsNox (12-11-2014), Matt@DamondMotorsports (12-10-2014), Micha (12-09-2014), mxlplx71 (12-12-2014), the public enemy (12-10-2014)
 Old 12-09-2014, 09:21 PM   #18
That sort of thing isn't my bag baby. It's not mine.
CWP_MS3 (12-10-2014)
 Old 12-09-2014, 10:41 PM   #19
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
YOU RANG?
Farhan@DM likes this.
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following 4 Users Say Thank You to Captain KR For This Useful Post:
Easter Bunny (12-10-2014), Farhan@DM (12-10-2014), Matt@DamondMotorsports (12-10-2014), Micha (12-09-2014)
 Old 12-10-2014, 05:59 AM   #20
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Shall we shag now, or shag later?
Rich Tuned
330WHP and 363TQ
dale_gribble (12-10-2014)
 Old 12-10-2014, 08:33 AM   #21
the public enemy's Avatar
Posts: 1,133   (View Stats)
the public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the world
Definitely subscribed for FMIC solutions. @Code Monkey; nailed it that'd be a wonderful setup over current options. It'd be even better if it came with ducting to channel the air directly through the two units and maximize airflow through them. My $.02.
I'd be interested to see what kind of bracing could be designed to help out in the twisties as well.
Subscribing and paying more attention in this area.
2006 Mazdaspeed6 GT Pearl Whitewater
"A life lived at half throttle is a life half lived."
Pulling like a freight train whilst sounding like a tractor.
the public enemy is offline   Reply With Quote
The Following 5 Users Say Thank You to the public enemy For This Useful Post:
Code Monkey (12-10-2014), dagrimey1 (12-12-2014), jtms6 (05-15-2015), Matt@DamondMotorsports (12-10-2014), Micha (12-12-2014)
 Old 12-10-2014, 08:38 AM   #22
SpecialK's Avatar
Posts: 830   (View Stats)
SpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the world
And subbed in hopes of awesome shit
2006 Mazdaspeed 6 Zoom Zoom Boom Feb/2014 - fixed 3/30/2014
Motor:
2012 Block / V2 AP / Autotech HPFP / HTP 3" intake / AEM dryflow filter / Fidanza Flywheel / NGK 6510 Step Colder Plugs / TurboSmart BPV / Catless M2 DP / JBR SSP / CPE RMM
Suspension:
Poly SwayBar Bushings / CP-e Rear Diff Mount / BC Coilovers / 245/40/18 on 18x8" RX8 Wheels
Visual:
25% Tint On All Windows / 25% Tint Side Markers / Front Grill Plasti-Dipped Black / Stockers Plasti-Dipped Black / Black Mad M on Trunk / De-Badged / Heavy Shift Knob
Fluids:
Motocraft gold in gearbox / Redline in TC and diff / Oil - Rotella T6 /
SpecialK is offline   Reply With Quote
 Old 12-11-2014, 05:34 PM   #23
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
If ya need anybody to beta test Matt....
Front engine mount?
FMIC is always a crowd favorite
Front upper control arms with adjustable camber (!!!!)
Rear sway bar would be way cool
and of course rear diff mounts
340hp / 371tq
Matt@DamondMotorsports (12-12-2014)
 Old 12-11-2014, 05:42 PM   #24
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
And CASTER!!!!
Yep. A bigger option would be welcome. 26mm bar with at least two holes
-06 MS6
-Corn fed 07 MS3 - Sold
fretburnr (12-15-2014), Matt@DamondMotorsports (12-12-2014), Micha (12-12-2014), TiGraySpeed6 (12-11-2014)
 Old 12-11-2014, 06:21 PM   #25
ItsNox's Avatar
Posts: 3,076   (View Stats)
Front & rear diff mounts please! Dont make me buy from the penis eater!!
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
The Following 4 Users Say Thank You to ItsNox For This Useful Post:
Boostin'likeAboss (12-11-2014), DingoDave (11-13-2015), Matt@DamondMotorsports (12-12-2014), Micha (12-12-2014)
 Old 12-11-2014, 08:10 PM   #26
The CP-E piece is decent but the turbine tech front diff mount is never in stock / slightly over priced in my opinion
a true short shift kit would be sick too
and I'm just not gonna buy any sure product ever, fill the voids bro!
another single exit catback would be pretty legit too, CP-E's is great but if you can beat it on price (probably wouldn't be that hard to) I'm sure quite a few would sell, cp-e seems to have trouble stocking parts at times and corksports catback is heavy / expensive / is corksport.
Kozmic is the only one right now developing a PTE flanged DP, that might be worth looking into as well
08 cwp ms3
The Following 4 Users Say Thank You to Boostin'likeAboss For This Useful Post:
ItsNox (12-17-2014), Matt@DamondMotorsports (12-12-2014), Micha (12-12-2014), stanley0910 (12-18-2014)
 Old 12-12-2014, 06:36 AM   #27
Micha's Avatar
@Boostin'likeAboss;... guess where the only Kozmic Precision flanged DP equipped MS6 is parked right now?
LOL.
I am slow again.
Boostin'likeAboss (12-12-2014)
 Old 12-12-2014, 06:41 AM   #28
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
In 4 FMIC, but only if it's pretty.. none of this piping over the valve cover crap, i wanna see my baybeh!
acemanz is offline   Reply With Quote
 Old 12-12-2014, 11:23 AM   #29
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I can't believe this hasn't been mentioned yet but we need one of these
PS a crashbar that can accommodate a real core (TR8+) would be lovely. It's not hard to make a FMIC kit, any joe shmoe can do it, but we really need a crashbar that isn't $500.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
dagrimey1 (12-12-2014), Matt@DamondMotorsports (12-12-2014), ms6mil (12-12-2014)
 Old 12-12-2014, 11:44 AM   #30
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
^ RHD versions as well for the MPS please.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 12-12-2014, 11:48 AM   #31
BrownBear
Farhan@DM's Avatar
Please help me understand why.
Deldran (12-12-2014), Matt@DamondMotorsports (12-12-2014)
 Old 12-12-2014, 11:59 AM   #32
^ If anything, I want an full replacement extender with a short-shifter like the discontinued Corksport's (pictures here), or, if it is just an SSP, please make it bolt on both sides so it does not come loose mid-session at the track.
 Old 12-12-2014, 12:04 PM   #33
1. Adjustability
2. I can watch the stock plastic flex if I shift hard enough
3. Durability (I've seen some stock shifters with stupid amounts of play in them due to wear)
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 12-12-2014, 02:04 PM   #34
BrownBear
Farhan@DM's Avatar
1. Adjustability
1. Please elaborate. Adjustability of what?
2. Do you see it flex mid shift, or after you've hit the gate? (I hope you're not driving and looking at your shifter at the same time)
3. Where are they wearing?
I'd like clarity on these issues because I don't have any issues in my 6, so I'd like to know what might come, and so that I know what problems may need addressing if we do go forward with this.
 Old 12-12-2014, 02:16 PM   #35
dagrimey1's Avatar
Posts: 1,246   (View Stats)
@SBMS316; please elaborate on the needs on the short shifter for our platform.
For one thing is the plastic guide that prevents you from going into reverse wears thin and give you that not so smooth shift to 2nd gear. If you own a 6 or any first Gen 1 3 I'm pretty sure you know that feeling.
@Farhan@DM;
"I'd like clarity on these issues because I don't have any issues in my 6, so I'd like to know what might come, and so that I know what problems may need addressing if we do go forward with this."
How many miles on that car must be an 07, that was cryogenically frozen.
 Old 12-12-2014, 02:30 PM   #36
BrownBear
Farhan@DM's Avatar
@Farhan@DM;
Late 07, ~117k miles on it. I do have that wear from the lockout. That I will absolutely agree with. You surely don't want a full replacement just for that.
The Following User Says Thank You to Farhan@DM For This Useful Post:
 Old 12-12-2014, 02:36 PM   #37
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
My 6 has 150k on. No shifter issues
Damond Built Speed 6
 Old 12-12-2014, 02:40 PM   #38
acemanz's Avatar
1. Adjustability?
2. all plastic flexes... >.>
3. Replace them like any other wear item?
 Old 12-12-2014, 02:41 PM   #39
I was just gonna say my old one didn't, but there you go. lol
 Old 12-12-2014, 02:43 PM   #40
dagrimey1's Avatar
Mine is not really an issue it just not as smooth as those Damn PU's.
Page generated in 0.59991 seconds with 44 queries
