Like Tree120Likes
 Old 05-19-2016, 06:21 PM   #1
Name is longer than yours
Posts: 209   (View Stats)
Default We've been working on sumtin... manifold
So here's a glimpse of what we've been working on, and plan on making a kit for on the MS3 and MS6 platforms.
More info and data coming thoon...
The Following 54 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
08cosmic3 (05-19-2016), 5doorsoffury (05-21-2016), Bleupit80 (05-20-2016), Boost_creep (05-20-2016), broda (05-20-2016), Code Monkey (05-19-2016), CWP_MS3 (05-20-2016), Dano (05-23-2016), davychronic (05-31-2016), dsb_chicago (05-25-2016), faeker (05-19-2016), Faez0rbeamz (05-23-2016), FittedMazda (05-21-2016), Funkster777 (05-27-2016), g00s3y (05-24-2016), Gerbilo (05-19-2016), Hush (05-19-2016), iamareios (05-20-2016), impossible (05-31-2016), InkedInspector (05-20-2016), Jeremy M (05-27-2016), Jh8909 (05-19-2016), JSmith (06-05-2016), Kellerspeed3 (05-24-2016), KiwiFlavor (05-20-2016), macdiesel (05-28-2016), Mauro_Penguin (05-20-2016), Mazdazilla6 (05-19-2016), MD1032 (05-25-2016), Micha (05-23-2016), mituc (08-08-2016), monkey.bones.007 (05-20-2016), MS3Shadow (05-19-2016), mxlplx71 (05-19-2016), nindoja (05-20-2016), Nliiitend1 (05-20-2016), PapaBruno (08-11-2016), Polish_Eagle (05-20-2016), Poohster (05-20-2016), qkrthnu2 (05-26-2016), rob ms6gt (05-21-2016), ryguy 3 (05-21-2016), Shwa (05-19-2016), silvapain (05-20-2016), SpeedRebirth (05-20-2016), Thepedigree13 (05-19-2016), thrisnospork (05-20-2016), TiGraySpeed6 (05-19-2016), Tomas (06-30-2016), wes3id (05-19-2016), WetzMS3 (05-19-2016), Wholegrain (05-24-2016), Ziggyboy (05-25-2016), [R]usty (05-24-2016)
 Old 05-19-2016, 06:27 PM   #2
wes3id's Avatar
Posts: 611   (View Stats)
I'm intrigued!!!
wes3id is offline   Reply With Quote
The Following User Says Thank You to wes3id For This Useful Post:
 Old 05-19-2016, 06:35 PM   #3
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
I understand the PI aspect.. But why the plastic mani from the ST?
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
The Following User Says Thank You to derek13p For This Useful Post:
 Old 05-19-2016, 06:38 PM   #4
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Don't question it just be happy.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 13 Users Say Thank You to Mazdazilla6 For This Useful Post:
AwAfrican (05-20-2016), CWP_MS3 (05-20-2016), derek13p (05-19-2016), Gerbilo (05-19-2016), impossible (05-31-2016), KiwiFlavor (05-20-2016), MD1032 (05-25-2016), Micha (05-23-2016), PhillyCheese (05-23-2016), SpeedRebirth (05-20-2016), Thepedigree13 (05-19-2016), Vansquish (05-24-2016), WetzMS3 (05-20-2016)
 Old 05-19-2016, 07:11 PM   #5
Shwa's Avatar
Posts: 322   (View Stats)
I don't know anything about their manifolds so just a couple quick questions
They have the vtcs too? Or are the codes still going to be a thing?
How much does one of the st manis go for second hand?
Will the kits include a way of routing fmic piping or is it something you can easily grab?
Interesting for sure!
The Following User Says Thank You to Shwa For This Useful Post:
 Old 05-19-2016, 07:13 PM   #6
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
Oh snap, that appears to be an even bigger #nipslip
¿dónde está @WetzMS3;?
WetzMS3 likes this.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
The Following User Says Thank You to Gerbilo For This Useful Post:
 Old 05-19-2016, 07:20 PM   #7
#tittyslip .
Full frontal to come. You guys know the DM guys like to tease but always deliver.
nindoja and Mazdazilla6 like this.
The Following 6 Users Say Thank You to WetzMS3 For This Useful Post:
Gerbilo (05-19-2016), impossible (05-31-2016), KiwiFlavor (05-20-2016), Mauro_Penguin (05-20-2016), Mazdazilla6 (05-20-2016), Micha (05-23-2016)
 Old 05-19-2016, 07:29 PM   #8
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
I have no immediate plans for PI so my question here would be this; will there be an option to plug the PI holes on the adapter?
WetzMS3 and MS3Shadow like this.
Mods: stock
The Following 7 Users Say Thank You to faeker For This Useful Post:
broda (05-20-2016), Mauro_Penguin (05-20-2016), Micha (05-23-2016), MS3Shadow (05-19-2016), Shwa (05-19-2016), Thepedigree13 (05-19-2016), WetzMS3 (05-19-2016)
 Old 05-20-2016, 05:36 AM   #9
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Always interested in better flow balance between cylinders...
Mazdazilla6 likes this.
340hp / 371tq
The Following 5 Users Say Thank You to TiGraySpeed6 For This Useful Post:
KiwiFlavor (05-20-2016), Mazdazilla6 (05-20-2016), Vansquish (05-24-2016), Voltwings (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 05:39 AM   #10
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
So when can i buy this RS manifold??
 Old 05-20-2016, 05:55 AM   #11
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
We've got something for your application.
WetzMS3 likes this.
The Following 10 Users Say Thank You to Farhan@DM For This Useful Post:
broda (05-20-2016), faeker (05-24-2016), impossible (05-31-2016), Mauro_Penguin (05-20-2016), Mazdazilla6 (05-20-2016), Micha (05-23-2016), monkey.bones.007 (05-20-2016), sharksinspace (05-20-2016), Thepedigree13 (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 06:08 AM   #12
WetzMS3 and PapaBruno like this.
The Following 12 Users Say Thank You to Code Monkey For This Useful Post:
BigBoostMS3 (05-31-2016), Farhan@DM (05-23-2016), impossible (05-31-2016), JSmith (05-23-2016), KiwiFlavor (05-20-2016), Mauro_Penguin (05-20-2016), MD1032 (05-25-2016), Micha (05-23-2016), qtrmile beast (05-23-2016), Vansquish (05-24-2016), Voltwings (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 06:09 AM   #13
KiwiFlavor's Avatar
This is better than @WetzMS3; wet teaser pic!
monkey.bones.007 (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 01:16 PM   #14
Nicely done .
No VTCS in the ST manifold. Also given the price of the manifold new ... well if it fits this is a win for the community.
OverBoosted and WetzMS3 like this.
The Following 10 Users Say Thank You to Lex For This Useful Post:
broda (05-21-2016), Farhan@DM (05-20-2016), impossible (05-31-2016), Mauro_Penguin (05-20-2016), Mazdazilla6 (05-20-2016), MD1032 (05-25-2016), Micha (05-23-2016), nindoja (05-20-2016), SpeedRebirth (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 01:48 PM   #15
Gerbilo's Avatar
With the TB being right at the bottom on the FoST manifold and air flowing straight upwards, I'd imagine it flows more evenly across all cylinders since there is no "sharp bend" like ours has to cyl 4. Curious to see how it all got piped up. Also time to show this to a friend with a FoST so he can say it's crazy, which means that you folks are doing it right. #tittyslip .
Freektune 93
Cobb Accessport V3
The Following 4 Users Say Thank You to Gerbilo For This Useful Post:
Micha (05-23-2016), MS3Shadow (05-20-2016), SofaKingAwesome (05-24-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 01:54 PM   #16
alexwlwsn's Avatar
Posts: 47   (View Stats)
alexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant future
IIRC in reading other forums the ST manifold flows nearly as well as a JMF and costs less than $100. Boy do I hope this becomes available soon.
OverBoosted likes this.
2008.5 CWP MazdaSpeed3
Purple Drank Tuned
ATP GT3076R @ 26 psi
369.5whp & 348wtq.. yawn
alexwlwsn is offline   Reply With Quote
The Following 3 Users Say Thank You to alexwlwsn For This Useful Post:
markos213 (05-24-2016), rocknrolla47 (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 02:15 PM   #17
nindoja's Avatar
Posts: 2,395   (View Stats)
An OEM part flowing nearly as well as a $1k aftermarket piece? You must be crazy sir, absolutely crazy.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
The Following 6 Users Say Thank You to nindoja For This Useful Post:
InkedInspector (05-25-2016), Mauro_Penguin (05-20-2016), Mazdazilla6 (05-20-2016), Micha (05-23-2016), MS3Shadow (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 02:28 PM   #18
alexwlwsn's Avatar
Looks like it was tested by SP63
Stock Intake Manifold Flow Data
Purple Drank Tuned
The Following 8 Users Say Thank You to alexwlwsn For This Useful Post:
ericrapp0507@gmail.com (05-23-2016), g00s3y (05-24-2016), Gerbilo (05-20-2016), InkedInspector (05-25-2016), KiwiFlavor (05-20-2016), Micha (05-23-2016), mxlplx71 (05-21-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 02:45 PM   #19
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
This shit is bananas b-a-n-a-n-a-s!
so excited may kmart ship my pants
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
The Following 3 Users Say Thank You to MazdaspeedKills For This Useful Post:
KiwiFlavor (05-20-2016), nindoja (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 02:49 PM   #20
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
We all know plastic is really light. Less weight = better acceleration and less understeer since it's positioned in front of the front axles. The CPE mani weighs like 40lbs according to their own site. This plastic mani can't weigh more than 5 ?
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 3 Users Say Thank You to SpeedRebirth For This Useful Post:
Micha (05-23-2016), Voltwings (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 02:55 PM   #21
 Old 05-20-2016, 03:07 PM   #22
Yatta's Avatar
Posts: 1,862   (View Stats)
make it fit a TMIC and take my money.
The Following 9 Users Say Thank You to Yatta For This Useful Post:
InkedInspector (05-25-2016), Jester2552 (05-31-2016), KiwiFlavor (05-20-2016), MD1032 (05-25-2016), MS3Shadow (05-20-2016), sharksinspace (05-20-2016), Thepedigree13 (05-20-2016), Voltwings (05-20-2016), vortk355 (05-24-2016)
 Old 05-20-2016, 03:31 PM   #23
+1 to make it fit with a TMIC.
sent from my Nexus 6P
The Following 7 Users Say Thank You to MS3Shadow For This Useful Post:
InkedInspector (05-25-2016), markos213 (05-24-2016), sharksinspace (05-20-2016), Thepedigree13 (05-20-2016), Thor Hammer (05-24-2016), vortk355 (05-24-2016), Yatta (05-23-2016)
 Old 05-20-2016, 03:34 PM   #24
Voltwings's Avatar
Posts: 3,713   (View Stats)
i'm still wanting to use my TMIC as well, but I imagine its nothing just a 180* intercooler pipe and some couplers cant fix.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 05-20-2016, 03:36 PM   #25
derek13p's Avatar
Groans: 38
Less heat soak too, and the flow imbalance is a lot lower from the looks.
But I cant powdercoat it
06 MS6 & 06 MS6
Daily driven
The Following 7 Users Say Thank You to derek13p For This Useful Post:
impossible (05-31-2016), InkedInspector (05-25-2016), Micha (05-23-2016), MS3Shadow (05-20-2016), SofaKingAwesome (05-24-2016), Thepedigree13 (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 04:01 PM   #26
Will this be offered in red?? I want it to go with the color scheme in my engine bay.
WetzMS3 likes this.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Micha (05-23-2016), snailD (05-26-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 04:07 PM   #27
wes3id's Avatar
What about the "top Secret" hush hush thing under the BMW cover and coke boxes????
 Old 05-20-2016, 04:08 PM   #28
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
The Following 8 Users Say Thank You to Mazdazilla6 For This Useful Post:
InkedInspector (05-25-2016), KiwiFlavor (05-20-2016), Micha (05-23-2016), MS3Shadow (05-20-2016), Nliiitend1 (05-27-2016), TiGraySpeed6 (05-20-2016), wes3id (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-20-2016, 04:10 PM   #29
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Balanced flow. The ST intake manifold goes straight down with 1&4 and 2&3 runners being equal length, instead of the drastically-sharp bend that air needs to make with the stock intake on our engines.
The Following 10 Users Say Thank You to silvapain For This Useful Post:
Gerbilo (05-20-2016), InkedInspector (05-25-2016), KiwiFlavor (05-20-2016), Mauro_Penguin (05-20-2016), Mazdazilla6 (05-20-2016), Micha (05-23-2016), MS3Shadow (05-20-2016), SofaKingAwesome (05-24-2016), TiGraySpeed6 (05-20-2016), WetzMS3 (05-20-2016)
 Old 05-23-2016, 10:26 AM   #30
865ms3's Avatar
Posts: 2,602   (View Stats)
I need this like meow. I'll ditch my v1 jmf and go this route for my pi setup.
Options are good. Thanks guys!
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
The Following 6 Users Say Thank You to 865ms3 For This Useful Post:
AwAfrican (05-23-2016), InkedInspector (05-25-2016), Mazdazilla6 (05-23-2016), MD1032 (05-25-2016), Thepedigree13 (05-23-2016), WetzMS3 (05-23-2016)
 Old 05-23-2016, 01:41 PM   #31
BrownBear
Farhan@DM's Avatar
About that track testing...
The Following 16 Users Say Thank You to Farhan@DM For This Useful Post:
alexwlwsn (05-27-2016), AwAfrican (05-23-2016), Gerbilo (05-23-2016), Hush (05-23-2016), InkedInspector (05-25-2016), Mazdazilla6 (05-23-2016), MD1032 (05-25-2016), Micha (05-23-2016), mxlplx71 (05-23-2016), Nliiitend1 (05-27-2016), PapaBruno (08-11-2016), snailD (05-26-2016), SpeedRebirth (05-23-2016), Thepedigree13 (05-23-2016), wes3id (05-23-2016), WetzMS3 (05-23-2016)
 Old 05-23-2016, 01:50 PM   #32
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Not bad, not bad at all. Subbed for outcome.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following User Says Thank You to JakeMS3 For This Useful Post:
MD1032 (05-25-2016)
 Old 05-23-2016, 03:46 PM   #33
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
 Old 05-23-2016, 04:15 PM   #34
Yatta's Avatar
Tamiya Color Spray for Polycarbonate
...impervious to fuel and oils... tuff stuff and many colors
darkcherry and WetzMS3 like this.
The Following 8 Users Say Thank You to Yatta For This Useful Post:
AwAfrican (05-23-2016), impossible (05-31-2016), KiwiFlavor (05-23-2016), Liquidsilver (05-24-2016), Mazdazilla6 (05-23-2016), Micha (05-23-2016), PapaBruno (08-11-2016), WetzMS3 (05-23-2016)
 Old 05-23-2016, 06:00 PM   #35
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
Default yep
this is interesting. someone had their thinking cap on over there !
Hope to see this come to market
WetzMS3 and AwAfrican like this.
ericrapp0507@gmail.com is offline   Reply With Quote
The Following User Says Thank You to ericrapp0507@gmail.com For This Useful Post:
 Old 05-23-2016, 08:15 PM   #36
Lol I was totally kidding but that's pretty damn cool!
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Micha (05-23-2016), Yatta (05-24-2016)
 Old 05-23-2016, 08:25 PM   #37
Micha's Avatar
Posts: 3,436   (View Stats)
http://youtu.be/ARODwLK91QI
Worst video recorder ever. Must be retarded.
I am slow again.
I modded it a little.
The Following 9 Users Say Thank You to Micha For This Useful Post:
impossible (05-31-2016), InkedInspector (05-25-2016), Mazdazilla6 (05-23-2016), monkey.bones.007 (05-24-2016), MS3Shadow (05-23-2016), Nliiitend1 (05-27-2016), SofaKingAwesome (05-24-2016), WetzMS3 (05-23-2016), xfeejayx (05-24-2016)
 Old 05-24-2016, 06:18 AM   #38
LittleredMPS's Avatar
Posts: 214   (View Stats)
LittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the world
Damn. Now this has potential. Really want this to happen.
Time for some BT action...Bring it!!!
LittleredMPS is offline   Reply With Quote
 Old 05-24-2016, 01:45 PM   #39
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
Focus ST Intake Manifold flow bench tested:
Runner 1) 331 CFM
Runner 2) 336 CFM
Runner 3) 329 CFM
Runner 4) 337 CFM
Total) 1333 CFM
~2% flow imbalance
Mazdaspeed Intake Manifold:
Runner 1) 199
Runner 2) 235
Runner 3) 233
Runner 4) 192
Total) 859 CFM
~20% flow imbalance
Will the Focus ST plastic manifold go bang under boost?:
Realistically, probably not. It was pressure tested to 27 PSI on an ST head, which turned out to be the static float point of the stock intake valves (point at which the head leaks boost into the cylinder):
https://www.youtube.com/embed/0A00YmHuooA
Later on,it was pressure tested to 110 PSI on its own (sitting in a big bang proof enclosure) which only resulted in blowing couplers.
https://www.youtube.com/embed/_uZGSsZH7YE
Edit: Food for thought:
TL;DR: Can't argue with hard data, that plastic manifold is legit.
2008 Gen1 MS3
Self tuned on E85
The Following 11 Users Say Thank You to Spectrix For This Useful Post:
AwAfrican (05-24-2016), derek13p (05-24-2016), Funkster777 (05-27-2016), InkedInspector (05-25-2016), JgamB (05-31-2016), MS3Shadow (05-24-2016), SofaKingAwesome (05-24-2016), SpeedRebirth (05-24-2016), Tomas (06-30-2016), wes3id (05-24-2016), WetzMS3 (05-24-2016)
 Old 05-24-2016, 01:51 PM   #40
There are a lot of similarities between the ST and DISI ... like the throttle body bolt pattern and sizing .
Also this really opens up the ability to run under-engine intercooler piping.
There are also advantages to plastic:
- heat rejection
- weight
- cost
The Following 11 Users Say Thank You to Lex For This Useful Post:
Gerbilo (05-24-2016), impossible (05-31-2016), InkedInspector (05-25-2016), KCi (05-26-2016), Mauro_Penguin (05-28-2016), Mazdazilla6 (05-24-2016), MD1032 (05-25-2016), MS3Shadow (05-24-2016), SpeedRebirth (05-24-2016), Vansquish (05-24-2016), WetzMS3 (05-24-2016)
MS6 - LCD display not working, stereo not working Kalandoss MazdaSpeed 3/6 - Car Audio & Electronics 1 05-20-2015 11:24 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Page generated in 0.61799 seconds with 48 queries
