Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Hardparts (2006-2013)
Like Tree11Likes
 Old 02-12-2016, 12:06 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Default Enkiworks Tallboy shifter bushings for TWM Full Replacement shifter (GenWon)
When I first installed the TWM full replacement shifter, I wasn't terribly thrilled with how much tension there was against the shift cables. Shit was next to impossible to install due to this, and I'm pretty certain over time it was going to hurt the shifter cables due to the pressure on them. To give you an idea of what I mean, this is what the base plate looks like with the cables mounted to the base but the base not bolted down:
As you can see, bolting this thing down would be detrimental to the cables; previously, I fucked around and drilled out a stack of washers to go under the TWM shifter bushings that came with it, and that actually improved the shifter feel a noticeable amount.
Not satisfied with that, I took the next logical step: I had my gunsmith make me some huge ass shifter bushings. Here's a comparison:
Those with a keen eye will notice that the bolt hole on the spacers is offset; I had this done like this to allow for more solid contact with the bolt, which is 6mm in diameter, rather than going the easy route that TWM did and having the bushing drilled out to 8mm. Since the TWM base plate uses oval holes for the bushing to rest in, there's no harm in going this route. The only thing I'd change about this setup is using studs instead of bolts to make the actual installation a little less annoying, but that's about it.
This is what it looks like with the base plate sitting on the 15mm bushings:
And the 20mm:
And installed:
Unfortunately, I'll have to wait until the transmission is back in the car before I'll know if I'll need to modify the cover plate, as going all the way over has it contacting the plastic boot bracket, which might prevent shifting to 5th/6th:
The Following 11 Users Say Thank You to Enki For This Useful Post:
breakfstincluded (05-19-2016), cshunter (02-18-2016), Kellerspeed3 (02-12-2016), macdiesel (02-12-2016), Mauro_Penguin (02-12-2016), sh4d0w (02-12-2016), Shwaykid (02-12-2016), SofaKingAwesome (02-12-2016), Tomas (02-18-2016), Vansquish (02-12-2016), WetzMS3 (02-12-2016)
 Old 02-12-2016, 12:32 PM   #2
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Good stuff!
Enki (02-12-2016), Vansquish (02-12-2016)
 Old 02-12-2016, 12:58 PM   #3
Shwaykid's Avatar
Posts: 646   (View Stats)
If you have another set, and want another test car let me know. (I.E. I want a set...)
I definitely remember the struggle getting the cables in place. IIRC, I put the cables in first, then used used a screwdriver to pry the mounting holes until they were lined up.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
 Old 02-12-2016, 01:03 PM   #4
Enki's Avatar
Groans: 189
I'm not using my 15mm set at the moment, so I can send those to you for short term testing if you like. If they work out for you, and you want me to get you a set made to your specs I can do that. I might need the 15mm ones back if I can't make the 20mm ones work, however.
Edit: I'll need to get some more washers and drill them out before shipping.
 Old 02-12-2016, 01:06 PM   #5
Shwaykid's Avatar
Sounds good man. I'll PM you my addy.
2008 Mazdaspeed3 GT
 Old 02-12-2016, 01:06 PM   #6
COCKSTRONG
Groans: 890
Can vouch for @Shwaykid; if you do end up looking for a tester.
Enki (02-12-2016), Shwaykid (02-12-2016)
 Old 02-12-2016, 01:22 PM   #7
I need something that will lock out the 6th.
 Old 02-12-2016, 02:59 PM   #8
Enki's Avatar
Groans: 189
@Shwaykid;
Shipped, they will be there Tuesday.
Conditions:
1. You can hang on to them for 3 months (~end of May).
2. No money needed unless you want to keep them longer than 3 months, in which case, we can discuss how much you want to donate to me. If they don't turn out good, just ship them back and we will call it square.
3. At some point, be as hard on these as you feel comfortable. Need to know how firm they are (specifically the longer bolts) when being abusive.
4. Nudes.
Easter Bunny (02-18-2016), SofaKingAwesome (02-12-2016)
 Old 02-12-2016, 03:04 PM   #9
Shwaykid's Avatar
@Shwaykid;
Conditions:
4. Nudes.
Cool. Weather is just starting to get good in Central Texas. Now I have a good reason to do the Devil's Backbone, for science
2008 Mazdaspeed3 GT
The Following 2 Users Say Thank You to Shwaykid For This Useful Post:
Easter Bunny (02-18-2016), Enki (02-12-2016)
 Old 02-12-2016, 03:11 PM   #10
Enki's Avatar
Groans: 189
There's always science to be had.
 Old 02-16-2016, 01:26 PM   #11
Shwaykid's Avatar
Got 'em
They'll most likely go on tomorrow after work.
2008 Mazdaspeed3 GT
The Following 3 Users Say Thank You to Shwaykid For This Useful Post:
Easter Bunny (02-18-2016), Enki (02-16-2016), SofaKingAwesome (02-16-2016)
 Old 02-17-2016, 08:58 PM   #12
Shwaykid's Avatar
@Enki; And in today they did go.
Just got back from the initial test drive. And I must say, I'm sold. The tension or tightness I had felt in between gears is gone. The shifter WANTS to change gear now. Further testing will see if that they also fixed my 1st gear lockout I get every once in awhile. 6th gear felt a little extra 'notchy' but I'm pretty sure I can fine tune that away with the adjustment cable.
I really liked the additional height. I have the TWM Type R knob, so it's nothing tall or bulbous. That extra 15mm made all the difference. It feels like a more natural shifting position. Especially going into 5th; I didn't feel like I was reaching.
Bonus, my cup holder and center console got a much needed Simple Green cleaning... That was kinda gross.
TL;DR - How much $$?
Cheapspeed likes this.
2008 Mazdaspeed3 GT
Cheapspeed (02-29-2016), Enki (02-17-2016)
 Old 02-17-2016, 09:56 PM   #13
Enki's Avatar
Groans: 189
For the set you have, a $30 - $35 donation will suffice (half my cost for both + ~$5 shipping). I'll send you my PayPal through PM should you want to go forward with that.
Oh, and there's one last thing I'd like you to check for me: clearances between the boot bracket and shifter rod in 5th and 6th gear? Keep in mind I'm running 5mm taller bushings than you are (and they should improve feel further) and some clearance information would be beneficial to the both of us.
You can probably make do by pulling the cupholder section out while leaving the boot and bracket in and taking pictures with a cell phone camera or something of the sort; I'd do this myself, but I don't have a transmission installed so I can't really tell where 5th and 6th would be.
I don't think people would mind having to mod the boot bracket (I don't), but knowing that it is necessary would be beneficial, I think.
Shwaykid likes this.
 Old 02-17-2016, 10:42 PM   #14
Enki's Avatar
Groans: 189
This just in, gunsmith says he's down to make more.
 Old 02-18-2016, 03:07 AM   #15
markos213's Avatar
Posts: 166   (View Stats)
markos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond repute
I'm in pm me donation info I would love to give this a try.
markos213 is offline   Reply With Quote
 Old 02-18-2016, 10:03 AM   #16
Enki's Avatar
Groans: 189
Further kits will be premade and sold properly via the forums.
Easter Bunny (02-18-2016), impossible (05-21-2016), markos213 (02-18-2016), SofaKingAwesome (02-25-2016)
 Old 02-19-2016, 09:59 PM   #17
bryantyper's Avatar
Posts: 56   (View Stats)
bryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud ofbryantyper has much to be proud of
Same
bryantyper is offline   Reply With Quote
 Old 02-25-2016, 09:27 PM   #18
Enki's Avatar
Groans: 189
@Shwaykid; how are they holding up? Still feeling good?
Any chance to take a couple clearance pics?
 Old 02-25-2016, 09:29 PM   #19
Shwaykid's Avatar
Amazing so far. And I Suck... pics this weekend. I promise.
2008 Mazdaspeed3 GT
Easter Bunny (03-01-2016), Enki (02-25-2016)
 Old 02-25-2016, 10:06 PM   #20
Enki's Avatar
Groans: 189
No problem; I don't mind. It's the others that want to buy them that are gonna get upset with you.
markos213 likes this.
Easter Bunny (03-01-2016), Shwaykid (02-26-2016)
 Old 02-26-2016, 07:35 AM   #21
Shwaykid's Avatar
I have had them on for 200 miles now, and I will say, the 1st gear lockout I used to get is pretty much gone.
My issue was rolling to a stop without slipping into 1st before coming to a complete stop. If I rolled to a stop in neutral and then just sat, more often than not, going into first would get ridiculous. A couple times I just took off in 2nd because it would NOT go into 1st.
Now, with dem Tallboys, that doesn't happen anymore. The worst that happens is 1st is a little extra notchy.
Pics will happen this weekend, as well as replacing my junk front sway bar endlinks. Then hopefully a nice little cruise through the twisties.
2008 Mazdaspeed3 GT
Easter Bunny (03-01-2016), Enki (02-26-2016), markos213 (02-26-2016)
 Old 02-27-2016, 11:18 PM   #22
markos213's Avatar
Update??i want some enkieworks tallboys to
The Following User Says Thank You to markos213 For This Useful Post:
Enki (02-27-2016)
 Old 02-28-2016, 10:50 AM   #23
Shwaykid's Avatar
And finally, here they are
I left off my shift boot, so I can take quick pics if you need a different angle:
Neutral:
5th:
6th:
Side angle in 6th:
Under Panel closeup in 5th:
Various Under Panel closeups in 6th:
2008 Mazdaspeed3 GT
Enki (02-28-2016), SofaKingAwesome (02-29-2016)
 Old 02-28-2016, 11:39 AM   #24
Enki's Avatar
Groans: 189
Any idea how close everything is to the plastic retainer on the shift boot?
 Old 02-28-2016, 11:46 AM   #25
Shwaykid's Avatar
I can fit my finger tip in the space
2008 Mazdaspeed3 GT
The Following User Says Thank You to Shwaykid For This Useful Post:
Enki (02-28-2016)
 Old 02-28-2016, 11:53 AM   #26
Enki's Avatar
Groans: 189
So chances are my taller ones will be very close but might not touch.
 Old 02-29-2016, 05:31 AM   #27
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Sounds like you touched on all the same problems I have with my twm. Stiff throws and a far reach to 5th. It took slop out of the shifter when shifting aggressive but when cruising lazy it felt arduous.
Enki (02-29-2016)
 Old 02-29-2016, 06:40 PM   #28
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Hmm... I'm liking this idea.
I'm in for a set @Enki;
Enki (02-29-2016)
 Old 02-29-2016, 10:02 PM   #29
Enki's Avatar
Groans: 189
Just need clearance info before I have more sets made; if there's room, the taller ones are by far better for reducing strain on the shifter cables than the shorter ones.
@Shwaykid; I know I've already asked a lot of you, but could you remove the shifter boot from the plastic rack thingie it mounts to, reinstall that and check clearance with 5th and 6th when you have time? If there's at least 5mm clearance, I'll have a set of the *really* tall fuckers made for you and everyone else that wants them.
markos213 (03-01-2016)
 Old 03-01-2016, 08:28 AM   #30
Shwaykid's Avatar
You talking clearance from the top of the perch to the lip of the shift boot panel, thingy?
2008 Mazdaspeed3 GT
 Old 03-01-2016, 08:53 AM   #31
Shwaykid's Avatar
For science:
2008 Mazdaspeed3 GT
 Old 03-01-2016, 09:55 AM   #32
Enki's Avatar
Groans: 189
That's in 5th/6th?
Looks like there's room for another 5mm lift without the shift arm (the bend in it specifically) hitting the plastics that normally hold the shift boot in place.
Edit:
I'm weary of having 10+ sets of these made if plastics have to be modded.
Edit2:
This is the measurement I was looking for, but with the plastic part of the shift boot present (shift boot fabric/leather removed, just 4 screws):
 Old 03-01-2016, 11:00 AM   #33
Shwaykid's Avatar
Threw the boot assembly back on for a couple quick pics. I don't think it'll fit... could be wrong, but it's basically touching
on to the pics (Most in 6th)
Here's a couple with the boot on:
2008 Mazdaspeed3 GT
Easter Bunny (03-01-2016), Enki (03-01-2016)
 Old 03-01-2016, 11:16 AM   #34
Enki's Avatar
Groans: 189
So just barely touching with the 15mm version, meaning the 20mm version will require a modification to the plastics, which ultimately shouldn't be a big deal.
I'll work on cutting mine up today and see how it impacts the boot and whatnot. Would anyone still be interested in the 20mm version even though a permanent modification is required or do you guys think the 15s are enough?
 Old 03-01-2016, 11:44 AM   #35
Shwaykid's Avatar
I'm definitely good with 15mm. Daily driving is a vast improvement and that's pretty much all I do.
That shift boot assembly is so flimsy and thin, personally, I wouldn't want to modify it.
2008 Mazdaspeed3 GT
Enki (03-01-2016)
 Old 03-01-2016, 11:44 AM   #36
markos213's Avatar
@Enki I'm still in for the 20mm
Enki (03-01-2016)
 Old 03-01-2016, 12:50 PM   #37
silvapain's Avatar
Groans: 136
I'd rather have the 15mm and not modify the boot assembly, but if I have to I have to.
Enki (03-01-2016)
 Old 03-01-2016, 05:35 PM   #38
Enki's Avatar
Groans: 189
5 sets of each size are on the schedule. Unknown ETA.
silvapain (03-05-2016)
 Old 03-02-2016, 03:13 AM   #39
markos213's Avatar
I'm in for 20mm
Enki (03-02-2016)
 Old 03-02-2016, 09:45 AM   #40
Enki's Avatar
Groans: 189
@bryantyper; What size you looking for? I'll add you to the list.
The Following User Says NO Thank You to Enki For This Un-useful Post:
bryantyper (03-04-2016)
Page generated in 0.58915 seconds with 28 queries
