Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Hardparts (2006-2013)
  • 1 Post By Enki
 Old 12-30-2013, 10:22 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Default First Gen EFR Intake
For those do-it-yourselfers, this is the parts list I used to make the intake for my EFR 6758:
Parts from Silicone Intakes:
1x 3.5 inch to 2.5 inch 90 degree reducer
1x 3.5 inch by 1 foot long 45 degree mandrel bend pipe (to be trimmed)
1x 3.5 inch silicone coupler
Assorted t-bolt clamps
Parts from Treadstone Performance:
1x 3.5 inch MAF housing; specifically the one labeled as follows:
DENSO MAF, Mass Air Meter Pipe, Subaru, Scion, Mazda, Toyota, Lexus
DENSO MAF, Mass Air Meter Adapter Flange, Subaru, Scion, Mazda Speed 6, Toyota, Lexus.
For best fitment, trim at least 2 inches off of each side of the 45 degree mandrel bend pipe; I went with 3 inches removed off the side that the MAF housing connects to.
Unfortunately, I don't have a TIG setup yet so I took everything to my local race car shop and had the support bracket and additional connections welded on, and the trimmed edges re-bead rolled.
Note that to fit the huge air filter I had to shave the inner lip out of the filter itself with a home made fillet knife.
The result is as follows (large images ahead, click link below image for big):
http://www.mazdaspeedforum.org/forum/foru...224_141438.jpg
http://www.mazdaspeedforum.org/forum/foru...224_141444.jpg
http://www.mazdaspeedforum.org/forum/foru...224_141450.jpg
I'll edit this post tomorrow with the outer diameter measurements of the EBCS vent tube and valve cover breather tube (which was re-used from a piece of discarded AC line).
btstarcher (12-30-2013), Code Monkey (12-30-2013), littleloogy (12-30-2013), sidekick (12-30-2013)
 Old 12-30-2013, 11:09 PM   #2
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Holy airfilter. Lol. Good shit.
The Following 2 Users Say Thank You to sidekick For This Useful Post:
btstarcher (12-30-2013), Enki (12-30-2013)
 Old 12-30-2013, 11:19 PM   #3
Enki's Avatar
Groans: 189
With the JBR air filter on there, I couldn't hear anything but the turbo whoosh. Now I can hear everything, including the EFR diverter valve.
Alpha (12-31-2013)
 Old 12-30-2013, 11:27 PM   #4
sidekick's Avatar
Groans: 47
What was your reasoning for running such a large filter? Just to make sure you're not constricting the intake side at all? Just curious. That is awesome though.
 Old 12-30-2013, 11:30 PM   #5
Enki's Avatar
Groans: 189
Basically I just said to myself:
Originally Posted by Enki's Demented Brain
I wonder how big of a filter I can stuff in here...
And then I went and bought the (second?) largest 3.5" filter K&N makes from Amazon, because none of the local car parts shops sell ridiculous shit like this.
Mauro_Penguin likes this.
Mauro_Penguin (12-31-2013), sidekick (12-30-2013)
 Old 12-30-2013, 11:35 PM   #6
sidekick's Avatar
Groans: 47
Trust me, I completely understand.
Enki (12-30-2013)
 Old 12-30-2013, 11:56 PM   #7
Zabbin123's Avatar
Posts: 114   (View Stats)
Zabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond reputeZabbin123 has a reputation beyond repute
Good ish man! Go NATOR AZ!
Yup...
Lots o' Stuff
Zabbin123 is offline   Reply With Quote
The Following User Says Thank You to Zabbin123 For This Useful Post:
Enki (12-31-2013)
 Old 12-31-2013, 09:46 PM   #8
glockman25's Avatar
Posts: 335   (View Stats)
glockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the world
Groaned at 8 Times in 5 Posts
That is the biggest air filter I have ever seen what the part number
2010 Liquid Silver Metallic
JBR- SRI/TIP(powerpath intake)- RMM-TMM-PMM(88 DURO)- RSB(medium setting)
Swift springs/SenSen/ SPC camber arms (ACDELCO)
ETS TMIC-AUTOTECH INTERNALS
XS POWER TURBO MANIFOLD-EBAY M2 DP-MAGNAFLOW CBE
NGK LTR7IX-11
COBB AP-CURRENTLY BEING PERM'D
glockman25 is offline   Reply With Quote
The Following User Says Thank You to glockman25 For This Useful Post:
Enki (12-31-2013)
 Old 12-31-2013, 10:04 PM   #9
Enki's Avatar
Groans: 189
K&N RE-0920 AKA the "Elephant butt plug"
6.2 x 6.2 x 10.8
Amazon.com: K&N RE-0920 High Performance Universal Air Filter: AutomotiveAmazon.com: K&N RE-0920 High Performance Universal Air Filter: Automotive
 Old 01-06-2014, 07:26 AM   #10
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
so the reducer coupling was long enough so that you went from the reducer to the 45 and it cleared all the hoses and engine? also how much was the maf housing? i have found them on ebay w/ straightener for $95 shipped.
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 01-06-2014, 09:19 AM   #11
Enki's Avatar
Groans: 189
Yes, it's a perfect fit. The price for the housing can be found on Treadstone; I don't recall the exact price.
Cobb FMIC with Sure intake Or CORKSPORT FMIC for Ram-Air Intake BloodyAnt101 2010 MS3 - Turbo Induction 31 12-11-2012 04:44 PM
Cold air intake vs short ram intake knarfies MazdaSpeed 3/6 - Turbo Induction 3 04-27-2010 04:15 PM
Page generated in 0.36197 seconds with 24 queries
