Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Hardparts (2006-2013)
  • 1 Post By slowwwms3
 Old 12-13-2018, 07:05 AM   #1
slowwwms3's Avatar
Posts: 19   (View Stats)
slowwwms3 will become famous soon enoughslowwwms3 will become famous soon enough
Default Slave cylinder pipe line change?
Anyone know how to do this? Procedure and steps? 09 speed3
slowwwms3 is offline   Reply With Quote
 Old 12-13-2018, 07:30 AM   #2
Posts: 2,237   (View Stats)
the slave end is special, i'm not aware of anything aftermarket that could fit there.
You would either need your old end and custom make a union with a new aftermarket line but there is also a flex hose so....The easiest remain to get the correct part from Mazda or get it used
 Old 12-13-2018, 07:32 AM   #3
slowwwms3's Avatar
Oh I know, I ordered the line and slave from edge autosports, OEM, i’m just asking if anyone knows HOW to change that hard line, the slave is easy, just a little nervous about changing that line since the new slave is an updated design and doesnt fit the stock pipe line that’s on the car from factory.
 Old 12-13-2018, 07:57 AM   #4
is it a 6 ? i replaced the slave on my 2007 3 after an ACT clutch install but i didn't bother with the hard line...there is just a clip that secure it there.
The other end is a screwed fitting so it work like any other fitting.
The slave end is sealed by an o ring. So you make sure it is clean, you oil it a bit, you push it there and put back the clip.
The part that could be a a little more challenging is to bleed it.
Personally, i would remove the old slave from the trans but leave it piped. I would install the new one and try to do as much as possible to reduce the time the master is leaking to avoid emptying the tank. (Or you could get a friend to hold the hose end in the air blocking it with his finger until you install everything else...)
To bleed
open the bleeder untill you see oil comming out.
close the bleeder
have the same friend to pump the clutch
Have him to hold it down
open the bleeder
Close the bleeder
release the pedal
start again untill at least 2 time you don't see air going out or until the pedal feel good.
Take a look at oil level each time to make sure you don't run out of oil...
 Old 12-13-2018, 08:40 AM   #5
slowwwms3's Avatar
To bleed
close the bleeder
open the bleeder
Close the bleeder
release the pedal
I heard the newer style slaves aren’t compatible with the stock line
Also I have a pneumatic bleeder (:
Last edited by slowwwms3; 12-13-2018 at 08:40 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-02-2019, 05:41 PM   #6
davros's Avatar
Posts: 1,021   (View Stats)
davros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the world
old thread... but.. is this true??
new style slaves? as in this one? WAGNER SC143568 or is that an old style
2009 Metro Gray Mica Mazdaspeed 3
Cobb AP - HTP INTAKE - HKS BPV - GrimmSpeed EBCS - Autotech HPFP - ATP catless DP - JBR EGR full delete - Damon RMM PMM TMM- TR8/CX Piping - Damon Catch Can - FREEKTUNED
davros is offline   Reply With Quote
 Old 03-02-2019, 06:05 PM   #7
slowwwms3's Avatar
I believe it is, I did do the replacement a few months back but the newer slave wont work with the old line. The line is so easy to replace though its like a foot long and has a staple type clamp to clamp it to the line that goes to the master cylinder, if you’re gonna get the new slave get the line as well, takes an extra 2 minutes I promise
davros likes this.
The Following User Says Thank You to slowwwms3 For This Useful Post:
davros (03-02-2019)
 Old 03-02-2019, 06:10 PM   #8
davros's Avatar
in that case maybe i'll just get the oem one from edge ... fuck, i need a beater car lol
 Old 03-02-2019, 06:32 PM   #9
slowwwms3's Avatar
That’s what I did man easy change
davros likes this.
 Old 03-02-2019, 10:23 PM   #10
davros's Avatar
cylinder and pipe on its way... driving the wife's corolla for a few...
Slave Cylinder Line Clip MSpeedRon MazdaSpeed 3 - How-To's 2 08-15-2018 04:42 PM
Bad Slave Cylinder boostdmazda3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 01-10-2014 12:33 PM
Slave Cylinder line clip is blowing off??? WhoDakAttack MazdaSpeed 3 - Engine, Transmission & Driveline 1 06-13-2012 03:25 PM
Slave cylinder line placement on the car MSFer87 MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-20-2011 11:53 AM
Page generated in 0.31325 seconds with 22 queries
