Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Hardparts (2006-2013)
  • 1 Post By zenit
 Old 12-24-2017, 12:31 PM   #1
BACKYARDKUSTOMZ's Avatar
Posts: 51   (View Stats)
BACKYARDKUSTOMZ has a spectacular aura aboutBACKYARDKUSTOMZ has a spectacular aura about
Default Turbo clipping
Had anyone ever had their turbo rebuilt, turbo wheel clipped and rebalanced? How did you like the results?
CP-E SRI & TIP, JBR boost tubes, GFB hybrid BPV/BOV Accessport V3
BACKYARDKUSTOMZ is offline   Reply With Quote
 Old 12-24-2017, 04:25 PM   #2
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Yes, not worth it unless your competing in a turbo limited class.
Otherwise, get a bigger turbo.
BACKYARDKUSTOMZ likes this.
-feejay
-wetzel
BACKYARDKUSTOMZ (12-24-2017)
 Old 01-29-2018, 08:54 PM   #3
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
joined in 09, with 47 posts.......
I'm gonna have to read them posts..
 Old 01-30-2018, 06:24 AM   #4
GroceryGtr's Avatar
Posts: 472   (View Stats)
1. Generally you clip a turbo that has a 'too small' turbine housing(to increase flow at higher RPMs), in our case we have a 'too small turbo'(which is technically another reason people clip, but it doesnt apply here and is too difficult to explain without a book explanation of exhaust flow and engine rmp ramp up)
2. Our K04 compressor is already easily maxed out, so the high rpm flow wont help much. A good candidate would still have usable boost in the upper RPMs, ours just putters out and creates a valve bbq.
3. Add to that the CHRA is a crappy design anyways.
That being said if you upgraded the thrust bearing, bored out the compressor side and used a bigger wheel I could see clipping being of use. I know a few guys many years ago played with modifying the stocker. I got half way down that road end of last year and decided it just wasnt worth the investment when for 100-200 more I could get a proper sized BNR or CS turbo. Only way it would make sense in my book is if you have a buddy that can do the labor for free(clip, bore, balance). Then you'd only be in it for about $150 for the new comp wheel and rebuilt parts.
Los Angeles: 2014 Porsche Panamera Turbo S is a 911 Turbo for the family man Haltech Automotive News 0 11-21-2013 10:20 AM
Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] Haltech Automotive News 0 05-03-2013 07:50 AM
Geneva 2009: Fioravanti LF1 design a study for cost-cutting and clipping apexes Haltech Automotive News 0 03-03-2009 09:50 AM
Page generated in 0.25101 seconds with 23 queries
