Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Hardparts (2006-2013)
Like Tree84Likes
 Old 08-16-2015, 08:20 PM   #1
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Default Turbo_Steve's Custom SHEET METAL INTAKE MANIFOLD Design / Build Thread
Over the past couple years I have pondered and played with the idea of making my own custom sheet metal intake manifold for the mazdaspeed 3/6.
I will save the blab talk and just say that after many hours of design time & a couple 3d printed prototypes I have finally come up with a design that I feel worthy of building.
A simple manifold flange featuring single port runners & set up to use off the shelf extruded tubing.
Plenty of room in the flange to add injectors.
Only parts needed to be machined are 4 velocity stacks, head flange & throttle body flange. Everything else can be sourced from Ross Machine Racing.
Be patient as this will be a while before I have a finished product. I am very near to having parts machined and ordering up everything.
Only thing to figure out yet is some minor plumbing / port placement.
Pictures of rendered components below.
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following 27 Users Say Thank You to Turbo_Steve For This Useful Post:
Awal (08-27-2015), cbmms3 (08-16-2015), Code Monkey (08-16-2015), cshunter (08-16-2015), daniely (08-17-2015), Easter Bunny (08-17-2015), HawkeyeGeoff (08-20-2015), Hush (08-17-2015), ItsNox (08-17-2015), Jackis (08-25-2015), Justin@Freektune (08-20-2015), Koke382 (08-17-2015), macdiesel (10-23-2015), maisonvi (08-17-2015), Mauro_Penguin (08-16-2015), Mazdazilla6 (10-13-2015), ms3blackmica (09-03-2015), MS3Shadow (08-16-2015), ms6mil (08-16-2015), MSpeedDemon3 (10-25-2015), rob ms6gt (08-19-2015), SpeedRebirth (08-17-2015), taf0422 (08-20-2015), Tokay444 (08-17-2015), WetzMS3 (08-17-2015), Yatta (08-17-2015), zenit (08-18-2015)
 Old 08-16-2015, 10:51 PM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
TMIC support? Runner alignment straight on or arched so there's no sharp kink in flow pattern?
Easter Bunny (08-17-2015), Mauro_Penguin (08-18-2015)
 Old 08-17-2015, 06:41 AM   #3
littleloogy's Avatar
Posts: 4,005   (View Stats)
Neutral  +1 score
I don't know if I'm half asleep or still high from last night, but this IM looks like an Imperial Walker.
I want one.
Sent from my iPhone 6
The Following 37 Users Say Thank You to littleloogy For This Useful Post:
2eatV8everyday (08-18-2015), amoosenamedhank (09-11-2015), ArmanRus (08-17-2015), Awal (08-27-2015), biscuit003 (08-17-2015), blakjak0271 (08-17-2015), brandon3212 (08-21-2015), chaser27 (09-11-2015), Code Monkey (08-17-2015), Djohns (08-20-2015), Dommo14 (08-20-2015), Dralphy (08-18-2015), Easter Bunny (08-17-2015), g00s3y (08-18-2015), Jackis (08-25-2015), jthough1 (08-17-2015), Koke382 (08-17-2015), lnumbp (08-25-2015), macdiesel (10-23-2015), magicka (08-18-2015), Mauro_Penguin (08-18-2015), monkey.bones.007 (08-18-2015), mxlplx71 (08-17-2015), NCspecV81 (08-21-2015), NoRegrets (09-11-2015), rob ms6gt (08-19-2015), sho (09-11-2015), speedfreak44 (08-18-2015), taf0422 (08-20-2015), TRBLSM (08-17-2015), Turbo_Steve (08-17-2015), udntknw (08-20-2015), WetzMS3 (08-17-2015), white'swhiteMPS (10-14-2015), Yatta (08-17-2015), Zdraveca (08-20-2015), zenit (08-18-2015)
 Old 08-17-2015, 06:58 AM   #4
Now that you say it I tend to agree.
littleloogy (08-17-2015), Mauro_Penguin (08-18-2015)
 Old 08-17-2015, 07:04 AM   #5
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Lmao! Naw I was thinking the same thing. Looks good though man good luck can't wait to see this. Will this be a little easier on the wallet vs JMF manifolds?
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following 4 Users Say Thank You to JakeMS3 For This Useful Post:
littleloogy (08-17-2015), Mauro_Penguin (08-18-2015), MS3Shadow (08-17-2015), PlatinumPuma (04-08-2016)
 Old 08-17-2015, 08:07 AM   #6
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
This has the potential to be a great manifold, if the runners follow the same angle as the head runners.
Koke382 likes this.
"Exclusivity" - CP-enis
Demodded.
The Seals
Enki (08-17-2015), Jackis (08-25-2015), Mauro_Penguin (08-18-2015), Turbo_Steve (08-17-2015)
 Old 08-17-2015, 08:13 AM   #7
Tokay444's Avatar
Groans: 793
The shape of the head side ports should also match the port shape of the head.
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
Enki (08-17-2015), Jackis (08-25-2015), littleloogy (08-17-2015), Mauro_Penguin (08-18-2015), MS3Shadow (08-17-2015), Turbo_Steve (08-17-2015), Yatta (08-17-2015)
 Old 08-17-2015, 08:30 AM   #8
Yatta's Avatar
Posts: 1,862   (View Stats)
If you are going to design one, why not a dual plenum to even up flow?
Building a dual plenum/dual intake, a few questions. - Turbobricks Forums
http://www.jenvey.co.uk/products/turbo-plenum
Putin 2.3T likes this.
Last edited by Yatta; 08-18-2015 at 09:12 AM. Reason: Another link with some DIY parts.
leo766 (03-31-2016)
 Old 08-17-2015, 07:02 PM   #9
No TMIC mounting. As of right now the runners are a straight 90 degrees alignment with the plenum. I actually thought of having the runners angle towards the inlet side a few degrees for flow improvement and also to provided added clearance by the power steering pump on the genwon & Speed 6. It would be just a matter of cutting the tubing on an angle as I have left enough clearance in my velocity stack & head flange. I will have to wait till I get all the parts in my hand to see how fitment is.
Soon to come.
The Following 3 Users Say Thank You to Turbo_Steve For This Useful Post:
Easter Bunny (08-17-2015), Mauro_Penguin (08-18-2015), torquemaniac (08-18-2015)
 Old 08-17-2015, 07:15 PM   #10
I agree but from a design aspect / keeping costs down so far this is the best option I have come up with.
I think that comparing this design to the oem manifold, having the runners come in straight is still better than having them curve up like the oem mani.
The major improvement is the relocated throttle body & the tapered plenum. Also I think the runners I have selected being larger than oem, but smaller than JMF should allow this manifold to perform very well up to 7,000 rpms but still promote more mid range power.
I still am undecided about overall runner length right now as well.
Soon to come.
 Old 08-17-2015, 07:34 PM   #11
Tokay444's Avatar
Groans: 793
The majority of the manifold wouldn't need to change.
Just making the flange a wedge with the correct angle would do the trick.
Demodded.
The Seals
Mauro_Penguin (08-18-2015), Turbo_Steve (08-18-2015), WetzMS3 (08-18-2015)
 Old 08-18-2015, 06:55 AM   #12
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
@Turbo_Steve; we should be friends.
Let me know if you need help with anything. I'm not too far away.
@WetzMS3;
Mauro_Penguin and WetzMS3 like this.
The Following 6 Users Say Thank You to zenit For This Useful Post:
Easter Bunny (08-18-2015), Mauro_Penguin (08-18-2015), monkey.bones.007 (08-18-2015), naoandlater (08-18-2015), Turbo_Steve (08-18-2015), WetzMS3 (08-18-2015)
 Old 08-18-2015, 08:00 AM   #13
@WetzMS3;
Haha, I almost tagged you as I was creeping in here yesterday. We definitely need to be more friendly with @Turbo_Steve;.
 Old 08-18-2015, 08:15 AM   #14
ms3andrew's Avatar
Posts: 2   (View Stats)
ms3andrew has a little shameless behaviour in the past
thats dope
2007 mazdaspeed 3
hks blowoff
accesport tuned to e85
ms3andrew is offline   Reply With Quote
The Following User Says NO Thank You to ms3andrew For This Un-useful Post:
Tokay444 (08-18-2015)
 Old 08-18-2015, 08:17 AM   #15
Originally Posted by ms3andrew View Post
thats dope
Sweet intro..
littleloogy likes this.
The Following 6 Users Say Thank You to MS3Shadow For This Useful Post:
chaser27 (09-11-2015), Easter Bunny (08-18-2015), rob ms6gt (08-19-2015), speed3sailor (08-25-2015), Vansquish (08-19-2015), WetzMS3 (08-18-2015)
 Old 08-18-2015, 08:30 AM   #16
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Glad to see you are moving forward with this. I really looked at doing it last year when we talked about it, but I just haven't found the time/ambition. Too many other projects. Hopefully it all goes well!
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
HawkeyeGeoff (08-20-2015), Turbo_Steve (08-18-2015), WetzMS3 (08-18-2015)
 Old 08-18-2015, 09:11 AM   #17
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Subbed for results.
tapatalk, it sucks
 Old 08-18-2015, 10:15 AM   #18
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Will oval velocity stacks work as efficient as circular ones? Could always have a circular stack inside the plenum with tubes that gradually switch to oval before the head. May be minimally affected however and machining costs would probably increase. Also, if our map sensor is in the plenum and these velocity stacks result in increased pressure would it result in a messed up tune? IE would we tune for 24 psi but see 25-26 actually entering the motor? As always ignore me if I am way off base
The line up:
 Old 08-18-2015, 08:57 PM   #19
Thank you for getting the wheels turning in my mind on this.
Here is something I am playing with. I can get a 7 degree angle on the runners fairly easily. I will have to put the injector bungs further back in the runners themselves with this setup but not a big deal.
I will play around with this a bit more and may end up 3d printing a model of this just to check clearances in the car.
Tokay444 likes this.
Soon to come.
The Following 6 Users Say Thank You to Turbo_Steve For This Useful Post:
ArmanRus (08-19-2015), Easter Bunny (08-19-2015), Mauro_Penguin (08-22-2015), Tokay444 (08-19-2015), WetzMS3 (08-19-2015), zenit (08-19-2015)
 Old 08-18-2015, 09:12 PM   #20
I would bet that a traditional round velocity stack would be an improvement over the oval design, but I am trying to make something that is simple to machine and uses off the shelf tubing, etc, etc.
As for the question about messing up the tune. The point of the velocity stacks is to provide a smooth transition from the plenum to the runner for both the intake charge and pressure waves. Ideally a smooth transition will let more air flow through the runner into the head and cylinder thus allowing your engine to flow more air and make more power.
The mas air flow sensor still works just as before and lets the ecu know how much air is going through the motor so that it can send enough fuel.
Soon to come.
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post:
Mauro_Penguin (08-22-2015), speedfreak44 (08-19-2015)
 Old 08-19-2015, 04:41 AM   #21
Yea after my post I thought about the sensors and turbo being pre stack and how it will adjust via the tune. Are there off the shelf oval velocity stacks like you need? I'd assume a round one would be easier to source and a tube transitioning from round to oval wouldn't be difficult to have made for cheaper than a custom velocity stack. Just throwing ideas out there. Love your ingenuity
The line up:
 Old 08-19-2015, 05:23 AM   #22
maisonvi's Avatar
Groans: 75
Steve, if you want to send me any designs of this, I have access to limited flow modeling. (I have a seat of solidworks simulation, but dont use flow often) If you had multiple designs you wanted looked at I might be able to help you chose.
Jackis, Easter Bunny and zenit like this.
The Following 7 Users Say Thank You to maisonvi For This Useful Post:
Easter Bunny (08-19-2015), Mauro_Penguin (08-22-2015), monkey.bones.007 (08-19-2015), MS3Shadow (08-19-2015), Turbo_Steve (08-19-2015), WetzMS3 (08-19-2015), zenit (08-19-2015)
 Old 08-19-2015, 09:59 AM   #23
The stacks I designed are relatively inexpensive to manufacture. Due to other fitment issues, the off the shelf stacks are also a no go.
Soon to come.
 Old 08-20-2015, 06:53 AM   #24
3d printed runner mockup.
I think the actual runner length I go with is going to be about 1" shorter overall.
Soon to come.
The Following 18 Users Say Thank You to Turbo_Steve For This Useful Post:
ArmanRus (08-20-2015), daafisch (08-20-2015), dan7225 (08-20-2015), Dano (08-20-2015), Easter Bunny (08-20-2015), Enki (08-20-2015), Justin@Freektune (08-20-2015), maisonvi (08-20-2015), Mattyhawk1 (08-20-2015), Mauro_Penguin (08-22-2015), Mazdazilla6 (10-13-2015), neganox (08-20-2015), rob ms6gt (08-24-2015), speedfreak44 (08-20-2015), SpeedRebirth (08-20-2015), WetzMS3 (08-24-2015), Zdraveca (08-20-2015), zenit (08-20-2015)
 Old 08-20-2015, 06:56 AM   #25
zenit's Avatar
Groans: 57
How do you feel above sharing the STL files?
 Old 08-20-2015, 08:16 AM   #26
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Looks awesome man. Looking forward to seeing what you end up with.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
LumberJack (12-31-2015), Turbo_Steve (08-20-2015)
 Old 08-20-2015, 08:53 AM   #27
I will have to think about that one. I have put a lot of hours into this project.
Jackis and Justin@Freektune like this.
Soon to come.
The Following User Says Thank You to Turbo_Steve For This Useful Post:
 Old 08-20-2015, 09:37 AM   #28
Realgib3's Avatar
Posts: 2,443   (View Stats)
I'll give you the best advice I can possibly offer to this thread.
Don't. Share.
The Following 10 Users Say Thank You to Realgib3 For This Useful Post:
2.0t03speed (08-20-2015), chaser27 (09-11-2015), Djohns (08-20-2015), Jackis (08-25-2015), Justin@Freektune (08-20-2015), knocturnal (08-21-2015), lnumbp (08-26-2015), Mauro_Penguin (08-22-2015), MS3Shadow (08-20-2015), TRBLSM (08-24-2015)
 Old 08-20-2015, 10:21 AM   #29
Djohns's Avatar
Posts: 3,944   (View Stats)
So many Illinois peeps in this thread and I haven't met any of you, but it sure seems like I really need to. @monkey.bones.007; you're a Colorado peep now so idk if that counts or not lol.
monkey.bones.007 likes this.
2010 black mica speed3
Soon:built motor
 Old 08-20-2015, 11:38 AM   #30
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Found some welders to help out this effort
monkey.bones.007 and Awal like this.
The Following 10 Users Say Thank You to neganox For This Useful Post:
2.0t03speed (08-20-2015), Awal (08-27-2015), chaser27 (09-11-2015), Code Monkey (08-20-2015), Easter Bunny (08-20-2015), Mauro_Penguin (08-22-2015), meicalnissyen (08-24-2015), rob ms6gt (08-24-2015), WetzMS3 (08-24-2015), Yatta (08-20-2015)
 Old 08-20-2015, 11:46 AM   #31
Djohns's Avatar
If you're looking for a welder I can see if I can talk my brother into helping you out in that department. He went to the best school in the state for welding.
Soon:built motor
 Old 08-20-2015, 09:25 PM   #32
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
If you're looking for a test mule when the time comes. Let me know.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
 Old 08-20-2015, 11:36 PM   #33
Enki's Avatar
Groans: 189
Originally Posted by udntknw View Post
Fixed for you.
File Type: jpg daily-afternoon-randomness-49-photos-417.jpg (73.8 KB, 868 views)
Mauro_Penguin and ItsNox like this.
The Following 6 Users Say Thank You to Enki For This Useful Post:
Code Monkey (08-21-2015), Dano (08-21-2015), Easter Bunny (08-21-2015), Mauro_Penguin (08-22-2015), udntknw (08-21-2015), WetzMS3 (08-24-2015)
 Old 08-21-2015, 10:39 AM   #34
Can we please hold off on silly cat/animal memes until I abandon this thread for 2 years.
neganox and ItsNox like this.
Soon to come.
The Following 11 Users Say Thank You to Turbo_Steve For This Useful Post:
chaser27 (09-11-2015), Code Monkey (08-21-2015), Enki (08-21-2015), ItsNox (08-24-2015), Mauro_Penguin (08-22-2015), neganox (08-21-2015), speed3sailor (08-25-2015), Tokay444 (08-21-2015), TRBLSM (08-24-2015), udntknw (08-21-2015), WetzMS3 (08-24-2015)
 Old 08-21-2015, 10:45 AM   #35
so stick to serous cat memes for now?
The Following 5 Users Say Thank You to Easter Bunny For This Useful Post:
Dano (08-21-2015), ItsNox (08-24-2015), maisonvi (08-21-2015), Mauro_Penguin (08-22-2015), udntknw (08-21-2015)
 Old 08-21-2015, 02:06 PM   #36
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Aren't those guys employed by HTP and CPE?
Prolly under contract.
Mauro_Penguin likes this.
2013 CWP and Stock
The Following 4 Users Say Thank You to NCspecV81 For This Useful Post:
Code Monkey (08-21-2015), Easter Bunny (08-21-2015), ItsNox (08-24-2015), Mauro_Penguin (08-22-2015)
 Old 08-21-2015, 02:27 PM   #37
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
absolutely
The Following 9 Users Say Thank You to Dano For This Useful Post:
Code Monkey (08-21-2015), DingoDave (09-05-2015), Easter Bunny (08-21-2015), Mauro_Penguin (08-22-2015), rob ms6gt (08-24-2015), TiGraySpeed6 (08-21-2015), udntknw (08-21-2015), WetzMS3 (08-24-2015), zenit (08-21-2015)
 Old 08-21-2015, 04:25 PM   #38
Enki's Avatar
Groans: 189
Hey at least mine was science based.
 Old 08-21-2015, 04:39 PM   #39
knocturnal's Avatar
Posts: 266   (View Stats)
Subbed. This looks interesting. Your mock ups with the XS power manifolds were good so I know you will get this one right. I just hope you source good welders.
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 08-23-2015, 11:26 AM   #40
I reworked the port shape at the head. Came up with a design that is going to flow smoother into both ports from a single runner. I have a 3 printed model of a single runner That I am going to have flow benched. I will flow it both by itself and up against a 1 inch thick plate that will have the exact cutouts of the stock intake ports. This will let me see how the runner flows by itself and how it would flow when merged into dual ports.
Ideally you would port the head to a single runner.
Jackis, Tokay444, ItsNox and 1 others like this.
Soon to come.
chaser27 (09-11-2015), Enki (08-23-2015), Hammology (08-23-2015), Jackis (08-25-2015), knocturnal (08-24-2015), lnumbp (08-26-2015), Mauro_Penguin (08-23-2015), Micha (08-29-2015), monkey.bones.007 (08-23-2015), mxlplx71 (09-22-2015), neganox (08-23-2015), nekret (08-23-2015), RE-ACTIONENGSPEED3 (08-24-2015), rob ms6gt (08-24-2015), Tokay444 (08-23-2015), udntknw (08-23-2015), WetzMS3 (08-24-2015), Yatta (08-24-2015)
Design's Long Term Ownership/Build Thread Design MazdaSpeed 3/6 - Build Diaries 77 08-28-2019 08:15 AM
Intake manifold can someone direct to a thread!!!!!! Briansms3 2010 MS3 - How-To's 10 04-10-2013 08:09 PM
Intake manifold design specs.. Yatta Gen2 MS3 General Discussion 0 03-26-2013 10:28 PM
AutoWerks Sheet Metal Intake Manifold SpeedSixxx MazdaSpeed 6 - Engine, Transmission & Driveline 85 12-17-2009 10:38 AM
Page generated in 0.60204 seconds with 42 queries
