Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Hardparts (2006-2013)
 Old 12-20-2017, 02:41 PM   #1
limited's Avatar
Posts: 2   (View Stats)
limited is an unknown quantity at this point
Default Variable Swirl Sensor Switch Lever
I'm trying to fix a CEL on my stock '08 MS3. The small gray plastic lever that lives on the VTCS rod broke off and no longer activates the switch indicating the butterfly valves are closed. Mazda wants an arm and a leg to replace the entire intake manifold.
Since the VTCS is a common mod, does anyone have this lever laying around they would be willing to part with?
I know about the relay hack, but would like to keep the car as close to stock as possible.
limited is offline   Reply With Quote
 Old 12-20-2017, 11:05 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Move the plunger and you dont need the lever. IIrc there is a how to on here somewhere.
Vansquish (12-21-2017)
 Old 12-21-2017, 06:10 AM   #3
GroceryGtr's Avatar
Posts: 472   (View Stats)
there is, but its pretty simple. Unscrew the 2 bolts move it forward and use the rearmost bolthole in the frontmost mounting location. You'll now only have 1 bolt holding it, but thats plenty. ill look for the thread, if I find it i'll update my post.
The other option is to get an AP and just turn it off.
Edit: Found it. See post #10 .
Now what..P2006
The Following User Says Thank You to GroceryGtr For This Useful Post:
 Old 12-21-2017, 09:07 AM   #4
limited's Avatar
Wow thank you, awesome find!
Ford Ranger and Bronco rumors swirl yet again Haltech Automotive News 0 11-09-2015 04:20 PM
Swirl Valve linkage Pic,does anyone know if vegaslightsss CX-7 > Turbo Induction & ECU Tuning 3 01-25-2015 07:05 AM
07 CX7 swirl valve questions vegaslightsss CX-7 > Turbo Induction & ECU Tuning 1 01-22-2015 06:30 PM
hood release lever help autoracer88 Gen2 MS3 General Discussion 8 06-22-2014 06:09 PM
MS3 OEM Shift Lever Knob Available dkapetansky MazdaSpeed 3 - Engine, Transmission & Driveline 5 08-30-2012 06:56 PM
Page generated in 0.24781 seconds with 22 queries
