Mazdaspeed 3/6 MZR Gen1/2 Parts Fabrication Forums (2006-2013)
> Mazdaspeed 3/6 Electronics (2006-2013)
 Old 02-02-2015, 10:57 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Default Raspi B v2
Per Hackaday:
Introducing the Raspberry Pi 2 | Hackaday
TLDR: Quad core, 1 gig ram, same capabilities/form factor as B+. Once they hit Amazon I'll order a couple to play with. Also will be able to run Windows 10 (Per microsoft) AND modern variants of Android.
FTMFW.
breakfstincluded (02-02-2015), mr.speedy3 (02-05-2015), Roddiy (02-03-2015)
 Old 02-02-2015, 11:20 PM   #2
kolosok17's Avatar
Posts: 1,104   (View Stats)
kolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the world
Groans: 47
I am very excited to see what folks can do with this one! I am thinking of picking one up and building a NAS out of it.
2012 CWP Non-Tech MS3
JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats,
COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC,
Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker
kolosok17 is offline   Reply With Quote
 Old 02-02-2015, 11:28 PM   #3
Enki's Avatar
Groans: 189
You'd be better off using this as a single disk NAS:
Banana Pi - A Highend Single-Board Computer: Banana Pi
Has an integrated SATA port.
I can think of a ton of uses for the v2 though.
kolosok17 (02-03-2015)
 Old 02-03-2015, 06:24 PM   #4
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
And I barely even booted my Rasberry Pi B+ and toyed with it
I'll grab one of these too, just because hahah
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
Enki (02-03-2015)
 Old 02-03-2015, 06:46 PM   #5
dale_gribble's Avatar
Posts: 4,720   (View Stats)
We've already got this guy planned for some embedded projects. It is a lot more capable than previous pi's and lightyears past Gumstix. This guy should be able to handle some decent video processing.
There is an Israeli company offering a really nice quad core snapdragon 1.7 ghz in an industrial package (-20 to +60) with Linux and Android distros. Lot pricier, but basically deployable as is.
MINI H1 6.0 - CAR LED TAILS
Roddiy (02-04-2015)
 Old 02-03-2015, 08:50 PM   #6
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Encoding or decoding? If encoding, what codecs? Right now I use a whole lot of cores from a dual socket opteron box to do x264 with Handbrake, but they are kind of weak compared to the intels.
'08 CWP MS3 w/ T3 3071r
 Old 02-03-2015, 09:09 PM   #7
Enki's Avatar
Groans: 189
The regular b version does realtime playback AND recording to a network share at the same time without issue...all encoded in raw h264.
I don't recall what settings I used, but it was probably 2.5 mb/sec for this test video, and auto chroma was enabled:
802MS3 (02-04-2015), Roddiy (02-04-2015)
 Old 02-04-2015, 06:22 AM   #8
rabble rabble
802MS3's Avatar
Groans: 221
Interesting. So a good candidate for a PVR.
I've been considering picking up one of these cubox-i systems: CuBox-i -Mini Computer, XBMC player, Android TV Box | Specifications
I've also have a gigabyte BRIX that I built. Its the most recent celeron version but it has some extra power for deinterlacing compared to the celeron version of the NUC. It also has WiFi/BT built in. Using it for Kodi and a news/SNES/genesis/N64 emulator with dualshock 3 controllers.
 Old 02-04-2015, 08:31 AM   #9
Enki's Avatar
Groans: 189
I have a vesa mount B that I mounted to the back of a 7" monitor (had to custom make spacers from aluminum tube but that was easy), and also hooked up a 12v D size battery pack that ran both the pi and the monitor...until the monitor died out and had to be replaced. I also have a Pi camera that has no IR filter on it. Gonna see what I can get it to do at some point, would be pretty awesome to be able to go dark while driving.
 Old 02-04-2015, 01:11 PM   #10
Roddiy's Avatar
Groans: 279
Forum Home - NUI Group Community Forums
You're welcome.
2010 LSM Speed3
#BakeryTuned
 Old 02-04-2015, 01:20 PM   #11
Enki's Avatar
Groans: 189
Originally Posted by Roddiy View Post
So, what am I supposed to be finding here?
 Old 02-04-2015, 01:43 PM   #12
Roddiy's Avatar
Groans: 279
Anything relating infrared, optics, software recognition, processing etc etc etc.
I used it to make a big ass IR-based touchscreen table years ago, but the technology and the software is highly adaptable to whatever you'd like to make using a camera without an IR filter and a RPI
2010 LSM Speed3
#BakeryTuned
 Old 02-04-2015, 01:46 PM   #13
Enki's Avatar
Groans: 189
Application is more for driving under IR; bigass LED array combined with no IR filter raspi camera (which I already have) = driving around in the dark but able to see just fine.
 Old 02-04-2015, 02:11 PM   #14
Roddiy's Avatar
Groans: 279
Ah I misunderstood.
Go build your batmobile, and post updates when you do, cause that's tits.
2010 LSM Speed3
#BakeryTuned
Enki (02-04-2015)
 Old 02-04-2015, 03:20 PM   #15
Enki's Avatar
Groans: 189
I still need to do the IR night camera test. I'll post that up when I get around to it.
 Old 02-05-2015, 10:43 AM   #16
rabble rabble
802MS3's Avatar
Groans: 221
Review: Intel?s Broadwell mini PC is a next-generation Ultrabook in a box | Ars Technica
 Old 02-05-2015, 10:57 AM   #17
Enki's Avatar
Groans: 189
At well over 10x the cost... Probably be fine for a carputer setup, but won't be able to do what I need for camera shit.
 Old 02-05-2015, 06:24 PM   #18
rabble rabble
802MS3's Avatar
Groans: 221
ah I was just treating this thread as one for bad ass ultra small computers. the NUCs are sweet, especially with DDR3-1866 and a SATA or PCIE SSD.
 Old 02-05-2015, 06:51 PM   #19
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Win, I'll be picking up a few to beef up my home server... I currently run the B model as a NAS/SSH server/Torrent box... more speed teh betters
 Old 02-06-2015, 04:17 PM   #20
Enki's Avatar
Groans: 189
Benchmarks!
Benchmarking The Raspberry Pi 2 | Hackaday
Roddiy (02-06-2015)
 Old 03-06-2015, 09:16 PM   #21
Enki's Avatar
Groans: 189
My two came in today; with only autologin and auto run of raspivid, I go from power applied to camera streaming in 16 seconds. Not a whole lot of optimization being done to the boot process.
Good shit, and WAY more acceptable than 45 seconds to boot to the same place.
 Old 03-10-2015, 04:45 PM   #22
mr.speedy3's Avatar
Just ordered mine... Going toove my server to the new one, and make a PVR out of my old one. Maybe a camera. Haven't decided.
tapatalkin
Page generated in 0.39723 seconds with 24 queries
