Like Tree3Likes
  • 2 Post By Rob@Freektune
  • 1 Post By rfinkle2
 Old 06-17-2014, 04:31 PM   #1
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Default 93 Tune, LTFT's Getting Worse
@Justin@Freektune; @Rob@Freektune; If I understand how the e-mail works now, I probably just bumped myself back down the list when I sent some 93 Freektune MAF logs.
I'm probably about to finish the ethanol tune, but I run the 93 tune most of the time. My LTFT's have been getting progressively worse and just want to know if I should be concerned because they were at +17.00 within an rpm range I spend most of my time in cruising on the highway so I can't really avoid it.
My notes in the email said that I probably had about 2 gallons of ethanol in my tank when I switched back to my 93 map, but up until now my trims have been around +15. So basically they've been getting progressively worse over the past few months.
Just not sure if it's a big deal or not, I was reading +,-25 will throw a CEL. I'd fix it myself but dem damn locked maps.
If it's not an issue I have no problem waiting 'til my e-mail makes it back to the top of the list, thanks guys.
Rob@Freektune (06-20-2014)
 Old 06-17-2014, 04:42 PM   #2
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Were your LTFTs on point before? What have you changed? Cleaned your MAF? Sounds like a pretty decent vacuum leak... Or you fixed a boost leak after your tune.
I'd say it would be nice if they could unlock specific tables like your MAF cal for issues like this, but that table seems to touch EVERYTHING in the form of Load calculations...
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following User Says Thank You to chaser27 For This Useful Post:
Cheapspeed (06-17-2014)
 Old 06-17-2014, 08:50 PM   #3
Cheapspeed's Avatar
After doing some reading I did like you mentioned, tightened everything up. Nothing seemed loose, but for shits I loosened and shifted a few clamps around and retightened.
Went for a drive, and crazy high +'s were gone, I was back down to something more reasonable. +4, +8. I didn't log, but just watched as I did a 2nd gear slow to redline.
So weird, since my trims were fine right before I flashed back to 93...maybe the heat? It's just recently been skirting the 100's here. Maybe things have just loosened up.
It's making me wonder about my last batch of Ethanol logs since I switch between the 93 and E40 maps pretty frequently but I definitely noticed my 93 map had worse trims. Car seems to be holding boost fine (20psi).
chaser27 (06-17-2014)
 Old 06-17-2014, 05:00 PM   #4
Cheapspeed's Avatar
My eth trims are fine, but anytime I switch to 93 my trims are out of whack again.
When we finalized the 93 tune a few months ago I noticed it was jumping to a high number and its has gotten worse as weather has gotten hotter but I didn't pay it much mind until recently. We only did 1 MAF cal on the 93 tune, and 2 on the ethanol tune so maybe we didn't get it dialed in?
They just weren't as bad then so I didn't try to address it.
MAF has been cleaned very recently, and I have a new filter on. I could double check my clamps, but I would suspect my ethanol trims would be bad too if that were the case?
 Old 06-20-2014, 05:46 AM   #5
Rob@Freektune's Avatar
Posts: 11   (View Stats)
Rob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond reputeRob@Freektune has a reputation beyond repute
I need to check this account more often. My apologies for the delay.
If you need some maf cal work, send whatever it is you need looked @ to rfinkle2.atr@comcast.net and mention this thread in the subject line please.
Send whatever it is you want me to see and the map that created it please.
Again, apologies for the delay.
Micha and PapaBruno like this.
Rob@Freektune is offline   Reply With Quote
The Following 5 Users Say Thank You to Rob@Freektune For This Useful Post:
Cheapspeed (06-20-2014), HawkeyeGeoff (06-20-2014), lobitoPU (06-20-2014), Micha (06-22-2014), XxSmarTz (07-01-2014)
 Old 06-26-2014, 08:26 PM   #6
Cheapspeed's Avatar
I'm going to bump this and say I'm seeing a pattern of whacky high + FT's after going from my ethanol tune to my 93 map. I'm planning on doing a boost leak test this weekend but after switching a few times between maps, the first 30 miles or so switching back to 93 from E, I get +15 to+17 at light throttle and -0.16 to -13 at idle.
BUT, then it settles. My trims look fine now. I'm really confused.
I'm talking to Justin now about some logs but I'm going to try and rule out hardware on my part first. Check leakage, oil change, new spark plug in cylinder 3 (low compression) and clean the MAF.
Anyone else get odd trims switching between maps?
Sent from my SAMSUNG-SGH-I777 using Tapatalk
 Old 06-26-2014, 08:44 PM   #7
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Yes, I have had this happen too, I didn't notice the trend until after reading your post though. I have suspected I had a leak somewhere because my trims on e were only a little off but the trims after switching back to 93 were way off, double digit LTFTs and 10.x WOT AFRs, and fuel consumption almost on the same level as on 25% E. But after a few hundred miles the car has settled back into just slightly off and fuel economy came back up a bit.
Bone stock so far
Darth_Nuruodo is offline   Reply With Quote
The Following User Says Thank You to Darth_Nuruodo For This Useful Post:
Cheapspeed (06-27-2014)
 Old 06-27-2014, 05:08 PM   #8
Cheapspeed's Avatar
So I could be stressing over nothing? I swap between the two maps pretty frequently, and thought trims would immediately be changed along with the flash.
I just want to rule out any issues before I call it wraps on the ethanol tune.
 Old 06-28-2014, 08:41 AM   #9
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
If you have an significant amount of E left in the tank it will mess with it too.
Silver 2007 Speed3 GT
 Old 06-28-2014, 08:46 AM   #10
What are the net long term + short term trims?
Justin@Freektune likes this.
chaser27 (07-24-2014), Cheapspeed (06-28-2014), Justin@Freektune (06-28-2014), lilred (06-28-2014)
 Old 06-28-2014, 10:04 AM   #11
Justin@Freektune's Avatar
Posts: 954   (View Stats)
When you are going back to 93, there is going to be ethanol left in your tank. You need to put a full tank or two through it before the trims will be perfect.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Cheapspeed (06-28-2014), HawkeyeGeoff (06-28-2014), lilred (06-28-2014), rfinkle2 (06-28-2014)
 Old 06-28-2014, 10:28 AM   #12
Last_Loser's Avatar
Posts: 739   (View Stats)
Last_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the world
Also when was the last time your secondary o2 was replaced. Thats what is currently holding me up right now and I know everytime my trims go to shit that is usually the culprit.
Under Construction
Last_Loser is offline   Reply With Quote
 Old 06-28-2014, 08:04 PM   #13
Cheapspeed's Avatar
I just replaced the O2 about 2 months ago when I installed my DP. Again, sounds like I just wasn't giving my car enough time to adjust to each map with how frequently I was bouncing between them.
I fill my car up about 3 times a week so about twice on 93, and once with 50/50 usually right before the weekend.
Hopefully this will be helpful for anyone else that flashes frequently between two fuels as often as I do. I was really sure I had a boost/vac leak.
 Old 06-28-2014, 01:36 PM   #14
Cheapspeed's Avatar
I feel like a car hypochondriac. I just assume the worst.
With the miles I put on this car and the tuning it just wouldn't have surprised me if I overlooked something.Thanks for the input guys.
OEM vs. CPE TMIC - worse BAT's? tarnumf MazdaSpeed 3/6 - Turbo Induction 12 11-24-2012 01:15 PM
MAF Cal adjusted LTFT now worse. ms6mil MazdaSpeed 3/6 - ECU Computer Tuning 5 05-18-2012 12:13 PM
High idle LTFT and how to tune it Fobio
Cobb ATR Support
13 02-27-2011 12:00 PM
For top suppliers, bad got even worse in '09 Haltech Automotive News 0 05-23-2010 10:10 PM
Page generated in 0.36170 seconds with 28 queries
