 Old 10-01-2017, 08:49 PM   #1
tec_41's Avatar
Posts: 128   (View Stats)
tec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond repute
Groaned at 7 Times in 2 Posts
Default BNR s3 Freektune Dyno (video)
Hit up the local Dyno Days event and threw the ol' girl on the rollers. I've now learned how much effect heatsoak has with the stock TMIC setup. 306hp/358tq on the first run, and it dropped significant power each run after. I know it had a little more on the first pull, but it was sitting idling for a while.
I'm very happy with Justin's work and will not be using anyone else for future tunes. Just 93 octane here, but would like to add some corn down the road.
2011 MS3 Velocity Red Mica
BNR S3 - - - CS Catless Downpipe - - - JBR SRI/TIP - - - Cobb 3-Port EBCS
CS 3.5bar MAP - - - JBR Thermal IM Gasket - - - CNT Catback- - -Ebay Test Pipe
JBR 88 Duro RMM - - - JBR Tru Torsion 1.25" RSB - - - Swift Springs - - - Cobb Shifter Weight
CS Adjustable Shocks/Struts - - - Damond EGR Delete - - - Autotech Internals
FREEKTUNED
tec_41 is offline   Reply With Quote
 Old 10-02-2017, 06:52 AM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
Looks good! Any logs or dyno sheets you can post too?
The Following User Says Thank You to speed23 For This Useful Post:
tec_41 (10-03-2017)
 Old 10-02-2017, 07:09 AM   #3
GroceryGtr's Avatar
Posts: 472   (View Stats)
so unrelated, but what rims are those? They look great.
The Following User Says Thank You to GroceryGtr For This Useful Post:
tec_41 (10-03-2017)
 Old 10-02-2017, 07:50 AM   #4
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Looks like xxr 530 wheels
2018 Audi RS3
2007 Acura TSX 6MT
tec_41 (10-03-2017)
 Old 10-02-2017, 08:20 AM   #5
tec_41's Avatar
Thanks! Yeah, they're cheap-o XXR 530's in Chromium Black.
And here's the sheet
FREEKTUNED
 Old 10-02-2017, 08:38 AM   #6
Yatta's Avatar
Posts: 1,862   (View Stats)
funny thing about heat soak... it really only hurts you this much when you are doing back to back dyno or 1/4 runs ‘hot’ for on road use? constant air-flow fixes much of it... my 2 cents...
tec_41 (10-02-2017)
 Old 10-02-2017, 11:31 AM   #7
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Good run. Not bad for 93. I’d like to see what kind of torque she puts down with some corn in her tank.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following User Says Thank You to JakeMS3 For This Useful Post:
tec_41 (10-02-2017)
 Old 10-02-2017, 12:23 PM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You need to put a fan on top of the intercooler on the hotside. Otherwise you heat soak big time. When I did that, it kept all 3 pulls within 1hp of each other every time I put my car on the rollers.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
tec_41 (10-02-2017)
 Old 11-03-2017, 03:34 AM   #9
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Did you log the run or have a log of a similar pull o the street?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
BigJim FREEKTUNE dyno results BigJimMs3 2010 MS3 - Dyno Sheets/Discussions 43 04-20-2012 01:18 PM
MS3BAMF hitting the dyno (freektune) ms3bamf 2010 MS3 - Dyno Sheets/Discussions 10 04-02-2012 12:07 PM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Page generated in 0.32887 seconds with 28 queries
