 Old 07-12-2018, 08:49 AM   #1
nebolskeetskeet's Avatar
Posts: 45   (View Stats)
nebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of light
Default Cobb EBCS and not custom tuned
I recent purchased a MS6 (mods in my signature), and noticed that it has a Cobb EBCS. The seller told me that he is only running a OTS Cobb Stage 3 map (modified to remove VTCS codes).
I am having rich at idle issues, and was wondering if this could be a culprit.
Thanks!
2006 Black Mica MS6 - COBB AP V2, OTS 93 Stage 3 Tune, BNR S3, Relentless IM, CX Racing FMIC, AEM CAI, Cobb EBCS, Autotech HPFP Internals, Magnaflow Cat-Back, ATP Catted DP
(GONE) - 2008 Black Mica MS3
nebolskeetskeet is offline   Reply With Quote
The Following User Says NO Thank You to nebolskeetskeet For This Un-useful Post:
mituc (08-01-2018)
 Old 07-13-2018, 08:28 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
No
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Vansquish (07-13-2018)
 Old 07-13-2018, 06:08 PM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
If you have an s4 and your running a ots map kiss that motor goodbye. It’s a matter of time before she lets loose.
2010 black mica speed3
Soon:built motor
 Old 07-13-2018, 07:48 PM   #4
shaneski's Avatar
Posts: 505   (View Stats)
OP join date is 2011...7 years to research shit that will answer the questions 100 times over....then to top it off, posts in the wrong area of the forum to ask the obvious.
 Old 07-13-2018, 11:06 PM   #5
I used to drive a gen 1 ms3, but never had the money/time to mod and tune. I really think I f’ed up in buying this car, but really wanted to get into ms6.
I posted here because I wanted to know from a pro tuner if this was compounding to my issues. All I could find doing research is that a custom tune is needed for the ebcs, and not what happens if you don’t run a custom tune.
 Old 07-15-2018, 10:55 AM   #6
shamie's Avatar
Posts: 952   (View Stats)
non stock turbo = custom tune
 Old 08-01-2018, 12:24 AM   #7
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
If not running a custom tune from the tuner that has this section then why would you post here and not in a general ECU tuning section under the MS6 section on this forum?
The rich at idle errors are usually caused by MAF calibrations. No matter where you have a leak in your intake, at idle you're pretty much under vacuum so the engine would pull unmetered air rather than loosing metered air. So probably the previous owner also had a different (larger) intake and the tune you now have on the car has the MAF cal for that intake, not for the smaller intake you have now.
Usually this code appears when the difference between the target AFR and actual AFR is larger than 25% which is beyond the self-adjusting capabilities of the ECU logic, and also indicate a problem.
Another cause for the rich condition may be faulty HPFP o-rings which favour fuel-oil mixing. In such cases though there is going to be so much fuel in the oil that the oil level (or whatever you can call the resulted fluid) will be way beyond the MAX mark on the dipstick. So check that as well.
So nothing to do with the Cobb EBCS or Freektune. Please post in the right section next time.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
nebolskeetskeet (08-01-2018), Orimar (08-01-2018)
 Old 08-01-2018, 09:36 AM   #8
You are right, I should have posted in the tuning section and apologize. Are we able to move this thread?
I also appreciate your input, I have been doing a lot of research lately and what you say makes total sense. I am not getting any crazy amounts of gas in my oil so I think that the leaking o-ring wasn't the culprit. I recently replaced my radiator, thermostat, MAF, PCV valve, and corrected some incorrect routing of lines on my EBCS and I have not thrown the P2188 code in 200 miles and counting.
However, I am noticing that my LTFTs are negative when cruising, so I suspect a MAF cal is needed. Like I said, I am kinda new to the tuning game and want to make sure the car is running safely.
Thanks again for the help. Next time I will post in the appropriate forum.
 Old 08-01-2018, 10:28 AM   #9
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
You would be much better off spending your money on a custom tune. Go to the Freektune website and purchase a custom tune. It will be the best money you've ever spent!
Are you really running an OTS tune with a BNRS3???
Also, fuel trims in the +/- 8-10% range are normal. Nothing to worry about.
 Old 08-01-2018, 12:21 PM   #10
That was my plan, and kind of the reason why I posted on the Freektune section at first.
Yes, the previous owner told me that he was running Cobb's OTS Stage 3 tune. I am truly ashamed that I did not do the right research before committing to the car. So, right now I am on a mission to ensure the car is in the best working order before getting an e-tune.
Depending on the bin, my LTFTs are between -10% to -20% while driving. Idle is around -5%.
 Old 08-01-2018, 12:49 PM   #11
Fstrnyou's Avatar
If your intake system (from MAF to head) is without a doubt leak free, a proper MAFcal is needed.
Other rides:
History:
 Old 08-01-2018, 01:23 PM   #12
Derekst's Avatar
Posts: 1   (View Stats)
Derekst has a little shameless behaviour in the past
Default Harness help missing plug
I just swapped another motor due to my old
Block blowing a hole out the back I installed everything there is just one plug for my
Cooling fan that i can’t seem to find. Its a single pin plug with a red lock tab on it
Any help please !
File Type: jpeg 7D229F3E-274F-4EBB-A2F6-8A4979933AE7.jpeg (2.23 MB, 4 views)
File Type: jpeg CA61B92F-19F7-4A66-94A5-56670DB19857.jpeg (1.98 MB, 3 views)
Derekst is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Derekst For This Un-useful Post:
mituc (08-01-2018), Thor Hammer (08-01-2018)
 Old 08-01-2018, 01:43 PM   #13
Any help please !
Thread jack..
When changing out my radiator I can across two plugs with red lock tabs: one on the throttle body, and the other connected to a sensor on the hood latch.
 Old 08-01-2018, 03:32 PM   #14
Groans: 211
Any help please !
That connector goes straight to your battery. Just cut if off and splice it in.
Seriously, start your own thread noob.
Cobb EBCS m249saw 2010 MS3 - Turbo Induction 70 07-22-2012 09:17 PM
Page generated in 0.38376 seconds with 28 queries
