  • 1 Post By iamareios
 Old 06-20-2016, 07:40 PM   #1
BrandonM's Avatar
Posts: 65   (View Stats)
BrandonM is a name known to allBrandonM is a name known to allBrandonM is a name known to allBrandonM is a name known to allBrandonM is a name known to allBrandonM is a name known to all
Default Email Response Question
Hello,
Just had a quick question, typically how long does it take between sending back logs and a new map revision. This isn't a complaint at all, I'm honestly just asking because I'm not sure if my e-mails are going through correctly or not. After placing my order I was amazed how fast I received my map, but I sent datalogs back about a week ago and haven't gotten a response.
If it hasn't been done yet that is totally fine, just wanted to make sure they are being received correctly. I sent a question a few weeks ago (a few days before I bought the tune), but never received a response to that as well, I just figured it was because I had bought a tune so the question didn't need to be answered, but I'm starting to think it may be my email (I am using yahoo which I know some domains have issues with).
Again, not a complaint at all, I know Freektune is fantastic, the first map I received blew me away as far as how on point it was in the first place. Just wanted to ask instead of waiting longer just to find out my email is screwy hahaha.
Thank you!
Brandon
2006 Titanium Gray Metallic Mazdaspeed 6 GT ~144k Miles
AP V3 with Freektune, BNR S2, Autotech Internals, Catless ebay dp, Cobb TIP+SF, HKS BOV, JBR RMM, CPE xFlex Rear Diff Mount, JBR EBCS, Bosch 3 Bar Map Sensor
BrandonM is offline   Reply With Quote
 Old 06-20-2016, 07:55 PM   #2
Omega's Avatar
Posts: 441   (View Stats)
I typically receive mine every 3-4 business days. Depends on how busy he is of course and if he has any events that week.
2006 Super Clean BCM MS6
 Old 06-21-2016, 08:30 PM   #3
BrandonM's Avatar
Thanks! Actually just got mine today hahaha, should have just been more patient. So pumped to go out and try it.
 Old 06-22-2016, 04:54 PM   #4
MaleJadeLy's Avatar
Posts: 60   (View Stats)
MaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to beholdMaleJadeLy is a splendid one to behold
I heard he tries to stay within 1-3 business days but it's probably a busy time of the year so I've been receiving mine closer to 3-5 business days...patience has been killing me over the past couple weeks
MaleJadeLy is offline   Reply With Quote
 Old 06-22-2016, 10:44 PM   #5
ryguy 3's Avatar
Posts: 353   (View Stats)
Yeah I'm also waiting for my base map for my S4, it's been 4 days since I finished the install and the wait is agonizing!
 Old 06-23-2016, 11:12 AM   #6
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Neutral  :  -1 score
At this point I would expect a longer than usual wait before you hear back from him. I've been getting my maps back from him in 5-6 business days. He is very busy so patience is required...when you want the best! Its worth the wait.
I'm close to my last revision but had to stop due to a sudden freak out of my trims. Might have developed a minor boost leak. And due to KR above 18psi had to turn it down. Totally cool with that as my car is about to tick over 100K!
Even at 18psi I am MORE than happy with the power curve and how hard it hits. I actually never go WOT other than when doing logs for the tune. LOL.
 Old 06-24-2016, 11:51 AM   #7
vaibe's Avatar
Posts: 44   (View Stats)
vaibe has a spectacular aura aboutvaibe has a spectacular aura about
I sent a general email and haven't received a response at all. I noticed that he took off the custom tune from the website so he's probably super booked.
Can anyone recommend something in the meantime while Justin is catching up? Should I just load Cobb maps for now?
vaibe is offline   Reply With Quote
 Old 07-01-2016, 12:09 PM   #8
BrandonM's Avatar
Cobb maps are useable (definitely not near where a custom tune is though). Really depends on what mods you have though, some would require a custom tune.
For sure, his tunes are on point, completely worth the wait, and he's got great feedback. Just got my 3rd revision back, can't wait to drive it. I'm real slow at sending logs back so I can't even say anything hahaha.
 Old 07-04-2016, 08:30 AM   #9
lescano88's Avatar
Posts: 40   (View Stats)
lescano88 is a jewel in the roughlescano88 is a jewel in the roughlescano88 is a jewel in the rough
I've been waiting for 18 days now since I sent my logs. Not sure what's goin on but it cant be that bad to not respond. At least a "sorry, still working on it".
2006 MS6 Sport
BNR S4,Grimmspeed 3port EBCS, Bosch 3 bar map,Autotech HPFP internals-AP V3/FreekTuned-COBB SF Intake,TIP,BPV
Mishimoto FMIC,TMM,PMM,RDM,RMM,Corksport Rear chassis brace,CPE DP w/Highflow Cat,Corksport CBE, safe injector seals-NGK 6510
JBR EGR Block Off Kit,JBR BPV Hose,Redefined Performance PCV Plate,OCC S2,Odyssey PC680MJ Battery,SU Short Shifter,JBR solid shift bushings/weight,Eibach Pro-Kit Springs,Koni Sport Adjustable Shocks,SPC Camber Adjustable Ball Joints
Michelin Pilot Super Sports 225/40ZR18(summer)/Continental Extreme Contact DWS 215/45zr18(winter)
TRS mini projector retrofit w/h1 Morimoto 55w,60mm STRI boost guage
2013 Mitsubishi Outlander Sport SE
Stock
lescano88 is offline   Reply With Quote
 Old 07-04-2016, 08:53 AM   #10
wes3id's Avatar
Posts: 611   (View Stats)
sometimes emails don't go through. i was using yahoo to contact him and had many problems with them being not delivered, so i switched to my other hotmail address. if it has been 18 days, i would try a different email and reference your order #.
wes3id is offline   Reply With Quote
 Old 07-04-2016, 09:02 AM   #11
ryguy 3's Avatar
You gotta blow him up to keep your email on his radar.
 Old 07-04-2016, 10:44 AM   #12
lescano88's Avatar
sometimes emails don't go through. i was using yahoo to contact him and had many problems with them being not delivered, so i switched to my other hotmail address. if it has been 18 days, i would try a different email and reference your order #."
Not sure if that's the issue. We communicated through the same gmail in the past and for him to send me my initial map. I will try another email though.
"You gotta blow him up to keep your email on his radar.
I have sent him various emails. I understand his emails get jammed. Perhaps I should send waves of bump emails throughout the day.
I bought the car freektuned about a year ago and loved the reliability and power compared to other cars with similar mods which was the major reason I decided to freektune after turbo swap.
2006 MS6 Sport
Stock
 Old 07-04-2016, 10:54 AM   #13
wes3id's Avatar
every email you send bumps you further down the list, so i would not send a bunch. Just send one asking whats going on and indicate that it's been 18 days.....then wait another 3-4 business days for a response. You could also shoot him a message on instagram, might be quicker
 Old 07-04-2016, 10:59 AM   #14
lescano88's Avatar
I have him on Facebook but don't want to call them out on Facebook. He doesn't have messenger. I don't have an Instagram. Never did and trying really hard not to open one. Facebook is bad enough. lol
@wes3id are from jersey?
2006 MS6 Sport
Stock
Last edited by lescano88; 07-04-2016 at 10:59 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-04-2016, 11:04 AM   #15
wes3id's Avatar
no, why?
 Old 07-04-2016, 11:05 AM   #16
lescano88's Avatar
Your location shows Lodi. There a Lodi in jersey.
2006 MS6 Sport
Stock
 Old 07-04-2016, 11:07 AM   #17
wes3id's Avatar
oh, nope..Lodi Ohio
 Old 07-04-2016, 11:16 AM   #18
wes3id's Avatar
@lescano88; i just messaged justin on instagram for you
 Old 07-04-2016, 02:45 PM   #19
lescano88's Avatar
[@wes3id Thanks, I appreciate it a lot.
2006 MS6 Sport
Stock
 Old 07-05-2016, 09:46 AM   #20
lescano88's Avatar
Update: I received my revision today. I had send waves of bump emails then started a new email to him. Finally got his attention.
2006 MS6 Sport
Stock
 Old 07-06-2016, 12:27 PM   #21
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
You will quickly learn doing that doesn't help. I know I did haha. Just be patient. It seemed right when I couldn't wait any longer for a response, I would get one.
Atticaz likes this.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
 Old 07-07-2016, 02:20 PM   #22
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Bump emails move you further down the list.
First in, first out. If you send a bump, bottom of the list chump.
MS3Shadow (07-07-2016), WetzMS3 (07-07-2016)
 Old 07-07-2016, 02:34 PM   #23
tec_41's Avatar
Posts: 128   (View Stats)
tec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond reputetec_41 has a reputation beyond repute
Groaned at 7 Times in 2 Posts
I'm also working with Justin on a tune. So...go ahead and keep bumping, speeds up the responses to my messages
I'm sure he had holiday plans just like the rest of us.
2011 MS3 Velocity Red Mica
BNR S3 - - - CS Catless Downpipe - - - JBR SRI/TIP - - - Cobb 3-Port EBCS
CS 3.5bar MAP - - - JBR Thermal IM Gasket - - - CNT Catback- - -Ebay Test Pipe
JBR 88 Duro RMM - - - JBR Tru Torsion 1.25" RSB - - - Swift Springs - - - Cobb Shifter Weight
CS Adjustable Shocks/Struts - - - Damond EGR Delete - - - Autotech Internals
FREEKTUNED
tec_41 is offline   Reply With Quote
Page generated in 0.41949 seconds with 30 queries
