Like Tree51Likes
 Old 03-16-2014, 05:44 PM   #41
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
christ I can't believe after all of these years you STILL need to port the IWG on the ATP hotside.
'08 CWP MS3 w/ T3 3071r
The Following 7 Users Say Thank You to 802MS3 For This Useful Post:
bstover17 (03-16-2014), Code Monkey (03-16-2014), Easter Bunny (03-16-2014), Justin@Freektune (03-17-2014), Last_Loser (03-19-2014), Mauro_Penguin (03-17-2014), Micha (10-21-2014)
 Old 03-16-2014, 06:05 PM   #42
Here is a pic. Tomorrow I will load the dyno files and grab a better one on one comparison
It is very interesting to compare the response of this turbo versus the GTX2867. You can see that below 4100 RPM or so the larger turbo lags behind the smaller one in terms of response. Beyond that the larger turbo pulls ahead.
Depending on how the powerband is used and car is driven you can clearly see which is the better choice. The maximum torque reached by both is close in terms of absolute numbers but where the torque is made and how far it is carried in the powerband is what sets them apart.
Thanks for the comparisons!
The Following 10 Users Say Thank You to Lex For This Useful Post:
cld12pk2go (03-18-2014), Fail_6 (03-17-2014), Hammology (03-22-2014), ItsNox (03-27-2014), Justin@Freektune (03-17-2014), Last_Loser (03-19-2014), Mauro_Penguin (03-17-2014), Pointless (06-18-2014), SarcasticOne (03-16-2014), YABBAMZR (03-17-2014)
 Old 03-16-2014, 06:29 PM   #43
darkstar5440's Avatar
Posts: 477   (View Stats)
darkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the world
That's cuz ATP don't give a fuck
OMWTFYB
darkstar5440 is offline   Reply With Quote
The Following 5 Users Say Thank You to darkstar5440 For This Useful Post:
Boosted Beluga (03-16-2014), bstover17 (03-17-2014), Justin@Freektune (03-17-2014), sidekick (03-17-2014), taf0422 (03-16-2014)
 Old 03-17-2014, 05:46 AM   #44
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Default Freekbuilt 3076 500hp
The gtx2867, gt2871, and BNR are probably the best fit for these cars out of the box. They truly are great turbos and the spool on them is fantastic. The 3076 still spools fast on the street but you can see the difference in lag.
The top end of this gtx3076 is truly awesome though. Once you get put in your seat. This thing pulls HARD up top.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 9 Users Say Thank You to Justin@Freektune For This Useful Post:
Boosted Beluga (03-17-2014), Easter Bunny (03-17-2014), Hammology (03-22-2014), Last_Loser (03-19-2014), maisonvi (03-17-2014), sidekick (06-19-2014), Sterling (03-17-2014), taf0422 (03-17-2014), YABBAMZR (03-17-2014)
 Old 03-17-2014, 05:56 AM   #45
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
What A/R comes on the GTX 3076? Edge's site doesn't say
 Old 03-17-2014, 06:22 AM   #46
It's .63 A/R great for spool which is a double edge sword. I can get it to spool so fast it surge which is 20psi before 3200 rpms. Soooo auto x this is not the turbo. Bit on the street it's fun and at the quarter it should also do really good. Probably a low 11 turbo with ATP trim and Mazda flange
PTE 6062
633HP/523TQ
Boosted Beluga (03-17-2014), Easter Bunny (03-17-2014), Last_Loser (03-19-2014), maisonvi (03-17-2014), Mauro_Penguin (03-17-2014), Mazdazilla6 (03-17-2014), Micha (10-21-2014), mxlplx71 (03-17-2014), Sterling (03-17-2014)
 Old 03-17-2014, 08:19 AM   #47
Boost_creep's Avatar
Posts: 829   (View Stats)
Well this came out of nowhere. Lol. Nice work buddy!
Did you happen to notice if the "crescent" shaped obstruction was present in your IWG passage? My 3071 I got recently from ATP looks like it's been revised from the previous versions. Just wondering if yours was too.
www.dizzytuning.com
www.facebook.com/dizzytuning
 Old 03-17-2014, 10:56 AM   #48
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Do you think it would be possible to cut down that surge (20 at 3200) with (more) porting on the intake mani and head?
Could you spool it that fast with a larger hotside and a 4 port?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 03-17-2014, 12:54 PM   #49
The compressor is relatively large compared to the smaller .63 hotside and this is why you can get into some surge trouble with this turbo. You will generate enough boost and more flow than the motor can take to put you on the far left side of the map via the small exhaust hotside.
If you increase the flow through the motor you will reduce surge and if you increase the flow through the exhaust hotside you will spool slower again avoiding surge. Or you can use a smaller compressor.
802MS3 (03-17-2014), Boosted Beluga (03-17-2014), Mazdazilla6 (03-17-2014)
 Old 03-17-2014, 01:50 PM   #50
maisonvi's Avatar
Groans: 75
By increase flow though the motor you mean on the intake side? I assume his intake manifold is ported as I know his head is ported. Is this what you are saying would help? ie: it would be worse without these items?
 Old 03-17-2014, 02:49 PM   #51
The intake manifold itself I don't think is the issue. The colder temps and the very free flowing exhaust is what can make it surge. So instead of running 100% wgdc at 3k, I just run 50 which does the trick on my car. That makes the turbo spool just enough slower that there is no surge.
On the 2867 I could run full tilt down low and have 20+ psi by 2900 rpms and it would just roll the tires off. Lol.
This turbo seems to want to spin the tires less (although winter and roads suck) but has a lot more punch up top. Still a great turbo to dd on, you just need to pay a little closer to your rpms and the gear you're in before roll racing
YABBAMZR likes this.
PTE 6062
633HP/523TQ
The Following 8 Users Say Thank You to Justin@Freektune For This Useful Post:
Boosted Beluga (03-17-2014), Easter Bunny (03-17-2014), ItsNox (03-27-2014), Last_Loser (03-19-2014), maisonvi (03-17-2014), sidekick (03-18-2014), taf0422 (03-17-2014), YABBAMZR (03-17-2014)
 Old 03-17-2014, 03:23 PM   #52
maisonvi's Avatar
Groans: 75
Yeah Im having terrible wheel spin issues with the winter roads and still running 205 winter tires as I try and tune here. Cant wait to get something sticky on the corners and see what happens.
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
Micha (10-21-2014), taf0422 (03-17-2014)
 Old 03-17-2014, 03:27 PM   #53
You aren't alone my friend
OMWTFYB
The Following 3 Users Say Thank You to darkstar5440 For This Useful Post:
Justin@Freektune (03-17-2014), maisonvi (03-17-2014), taf0422 (03-17-2014)
 Old 03-17-2014, 06:20 PM   #54
Matt H.'s Avatar
Posts: 137   (View Stats)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
How well are you putting IDC in check with the D14 nozzle? Is the three inch intake still in place?
Matt H. is offline   Reply With Quote
 Old 03-18-2014, 04:31 AM   #55
IDC at 27psi is just under 100 and 30psi is just over 100. I am running a Cpe maf housing now and still running the HTP 3" TIP. I hit maf cut twice on the sure maf housing which was good for just about 500hp.
In shop temp is a pretty consistent 69* throughout the winter so on the street in the colder weather right now the car is making about 500 at 27psi.
Boost_creep likes this.
PTE 6062
633HP/523TQ
The Following 5 Users Say Thank You to Justin@Freektune For This Useful Post:
Boosted Beluga (03-18-2014), Boost_creep (03-18-2014), Easter Bunny (03-18-2014), Last_Loser (03-19-2014), Micha (10-21-2014)
 Old 03-18-2014, 08:23 AM   #56
That cresent was clearly there and needed to be removed. Once it was removed boost control was perfect.
PTE 6062
633HP/523TQ
The Following 6 Users Say Thank You to Justin@Freektune For This Useful Post:
Boosted Beluga (03-18-2014), Boost_creep (03-18-2014), Easter Bunny (03-18-2014), ItsNox (03-27-2014), Last_Loser (03-19-2014), Micha (10-21-2014)
 Old 03-18-2014, 08:59 AM   #57
Nice!
I was pleasantly surprised when I noticed it wasn't there in my GTX3071R. I remember cld12pk porting his, and knew they must had revised it.
www.dizzytuning.com
The Following User Says Thank You to Boost_creep For This Useful Post:
 Old 03-18-2014, 04:45 PM   #58
Matt H.'s Avatar
I know most of us are working with some kind of budget in most of the stuff we do to are cars and you are no exception as you have gradually worked your way into where your car is now. I just keep thinking about what the flow numbers would have been on the head if you would have flowed it!!! It looks like a nice 45-50 HP gain at very similar boost comparing the 28 to the 3076. Large hot side doing work. You took a small hit in spool but with the small A/R the overall power gains both in torque and HP you can't beat that. Hell even with a K04 most roll racing starts at 3800 rpm or higher!!! Your build is a lot of inspiration my man.
The Following 4 Users Say Thank You to Matt H. For This Useful Post:
802MS3 (03-18-2014), Boosted Beluga (03-18-2014), Justin@Freektune (03-18-2014), YABBAMZR (03-18-2014)
 Old 03-18-2014, 05:13 PM   #59
Thanks man. I've always been the type to see what you can make on a budget. So it just shows you don't need a 20k build to make silly power and keep it reliable
BooSTed_Hatch likes this.
PTE 6062
633HP/523TQ
The Following 13 Users Say Thank You to Justin@Freektune For This Useful Post:
Boosted Beluga (03-18-2014), BooSTed_Hatch (05-20-2014), cshunter (07-31-2014), darkcherry (07-01-2014), Funkster777 (03-21-2014), killer-ms3 (04-09-2014), Last_Loser (03-19-2014), Mauro_Penguin (03-21-2014), Micha (10-21-2014), msantana101 (03-19-2014), sidekick (06-19-2014), thepatient77 (10-21-2014), YABBAMZR (03-18-2014)
 Old 03-19-2014, 07:01 PM   #60
Last_Loser's Avatar
Posts: 739   (View Stats)
Last_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the world
Does this mean I may tickle 450 without meth? Also debating on pulling the trigger on the JMF mani not sure yet
Under Construction
Last_Loser is offline   Reply With Quote
 Old 03-21-2014, 03:38 PM   #61
Twinturbo6's Avatar
Posts: 125   (View Stats)
Twinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond repute
Groaned at 29 Times in 10 Posts
If your going JMF intake mani, does that mean your selling your ported mani? ( can you hit me up? )
Sorry if this is against any rules.. I don't mean to offend, admin please just erase if it is...
Twinturbo6 is offline   Reply With Quote
 Old 03-21-2014, 04:53 PM   #62
PM me after the epic easy coast meet. Not doing any changes to my car until after then.
PTE 6062
633HP/523TQ
taf0422 (03-21-2014)
 Old 03-21-2014, 06:50 PM   #63
alfre127's Avatar
Posts: 291   (View Stats)
alfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond repute
went to the dyno the other day i think i am regretting going 10.6.1, timing is at 10 up top and spraying 2 medium size nozzles with m5 100% meth and 91oct and still have knock up-top, gonna change spark plugs and see if its that or the fact that i re used my injector seals, sorry for the tread jack.
GTX3076 EWG // Tial Waste Gate // Sure 3.25 Big Mouth // // JBR Side Motor Mounts // JBR, SS Kit, Corksport RMM Inserts // Cobb Pipping with TRL8 // CNT DP // CNT Cat back // DNP Mani // Autotech HPFP // Rota G-force 18x8.5 // Eibach Pro Kit Springs // Cobb AP, // Auto meter boost and vacuum gauges // AEM A/F gauge // AEM Meth Stage 2 kit // Hella Horns // PTP injector seals // PNP IM // TIGS // EGR Delete // ACT 6 Puck Sprung/Streetlite // Superskaterex 74MM TB //
alfre127 is offline   Reply With Quote
 Old 03-21-2014, 07:23 PM   #64
Unfortunately that is the issue with higher compression and a boosted engine. You need very high octane to push things along.
What size nozzles are you running? Have you tried m1 methanol rather than m5? Also what Afr are you targeting?
On my car with the d14 and 93 I get no kr even at 30psi
PTE 6062
633HP/523TQ
Mauro_Penguin (03-22-2014), taf0422 (03-21-2014)
 Old 03-22-2014, 01:01 AM   #65
JgamB's Avatar
Posts: 2,566   (View Stats)
Justin have you considered the diesel gearbox to take better advantage of the peak power?
I noticed when I roll raced a stock coyote (which I walked comfortably) that the disparity in shift points versus most V8s puts us either at a distinct advantage or disadvantage. Most of them will hit ~64mph in 2nd gear, making a 50 roll our sweet spot and too low of RPM for them, just as a 2nd gear roll leaves us sucking hind tit out of comfortable spool range in 3rd.
My rolls vs a tuned/intake/exhaust 5.0 pretty much confirmed what already made sense on paper. His 2nd gear vs my shallow 3rd gear pull left me sucking wind, while the 50mph roll kept me uncomfortably close for a corn tuned K04.
It seems we'd benefit a great deal from taller gears, and I really can't fathom why Mazda decided to neuter 1st and 2nd instead of stretch out our legs.
Cheapspeed (03-22-2014)
 Old 03-22-2014, 01:47 AM   #66
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
The VW gti has a 1st in between our 1/2
their 2nd/3rd is just shorter than our 3rd/4th
 Old 03-22-2014, 06:03 AM   #67
TBH I would not consider that trans in my car. That gearing is VERY tall.
PTE 6062
633HP/523TQ
 Old 03-22-2014, 06:16 AM   #68
alfre127's Avatar
At the moment i am targeting 11.2 afr at around 1.5 load ,2500rpm, 100% m5 meth with AEM 2 medium size nozzles, pretty sure spark plugs are old. already ordered new itv24's going to swap does make sure they are gap at .024 and add m1.
 Old 03-22-2014, 07:30 AM   #69
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
what did you max out with on the GTX2867?
RichTuned
BlueDmnSpeed is offline   Reply With Quote
 Old 03-22-2014, 07:57 AM   #70
445hp
PTE 6062
633HP/523TQ
 Old 03-22-2014, 08:00 AM   #71
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I don't know anything about the two pieces, but does anyone know if the ST transmission is at all compatible with the MS3? They can hit 60 in 2nd gear...then again I believe they also rev higher as well.
 Old 03-22-2014, 08:02 AM   #72
They def rev higher
 Old 03-22-2014, 08:23 AM   #73
austin102085's Avatar
Posts: 1,195   (View Stats)
Groans: 32
damn this makes me want to get a freek tune...... i think i could deff make 500 with a good tune
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
 Old 03-22-2014, 08:48 AM   #74
445hp
thats pretty much what i am looking to hit before i go nuts with a built block and everything
RichTuned
 Old 03-22-2014, 09:23 AM   #75
Don't forget. I have a ported head and fresh motor. But was able to make 417 on my stock motor. That was maxed the fuck out though on that motor
PTE 6062
633HP/523TQ
Easter Bunny (03-22-2014), killer-ms3 (04-09-2014), maisonvi (03-22-2014), Mauro_Penguin (03-23-2014), mxlplx71 (03-22-2014), SarcasticOne (03-22-2014), taf0422 (03-22-2014), YABBAMZR (03-22-2014)
 Old 03-22-2014, 04:32 PM   #76
Did you ever get a chance to tear down the original motor and examine it?
 Old 03-23-2014, 07:12 AM   #77
Sold it cheap as a core
PTE 6062
633HP/523TQ
Easter Bunny (03-23-2014), Mauro_Penguin (03-24-2014)
 Old 03-26-2014, 02:24 AM   #78
ah so once i get the upgraded rods and pistons in the car that i bought off of Downmented without PnP the head i should be looking at around 375 380?
RichTuned
 Old 06-18-2014, 07:33 PM   #79
JDMCRX's Avatar
Posts: 128   (View Stats)
JDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond repute
Groaned at 18 Times in 6 Posts
Any vids of this car ?
JDMCRX is offline   Reply With Quote
 Old 06-18-2014, 10:35 PM   #80
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Hey, this is my goal! Stop stealing my thunder!!
And please continue my tune.
tapatalkin
Parti's Freekbuilt Goodness Fail_6 MazdaSpeed 3/6 - Big Turbo Builds 514 11-21-2015 09:46 PM
500hp club (corrected) spoonher MazdaSpeed 3/6 - Dyno Sheets/Discussions 90 07-16-2012 04:32 AM
Because 500HP is for pussies Erich MazdaSpeed 3/6 - Dyno Sheets/Discussions 229 02-22-2012 10:33 PM
whos this 500hp reg 3? gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 36 11-09-2009 03:40 PM
Page generated in 0.63132 seconds with 39 queries
