| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Oct 2013 Location: Vermont
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
__________________ 2012 Speed3 - Velocity Red Mica Current Mods JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Don't see anything in the log except maybe you need to clean your MAF. Your AFRs bounce around a bit causing fuel to fluctuate.... How many miles on your plugs? Checked the gap lately?
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | ABOSWORTH (04-27-2016) |
Sent from my SAMSUNG-SM-G935A using Tapatalk
__________________ 2012 Speed3 - Velocity Red Mica Current Mods JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob | |
| Not Ranked : 0 score Clean the MAF and look into new plugs... just my thoughts
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
| Not Ranked : 0 score Thats a good amount of miles on the plugs. I would get a new set and gap them to .028" which will more than likely take care of the hesitation you are feeling In the 3rd gear wot log, starting at cell 45 you can see afr blip lean, and then cells 54 and up you see the same. That is a classic sign of a misfire typically caused by plugs
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway |
| The Following 4 Users Say Thank You to Justin@Freektune For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score I ordered new plugs today and will have them tomorrow. I'm just going to baby it until I put the new ones in tomorrow. I feel like an idiot, I totally forgot that the plugs are only good for like 10k. I usually put about 10k a year on my car so I'm going to just start changing them every year. Thanks for the info guys.
My email is Justin@freektune.com
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
| The Following User Says Thank You to Justin@Freektune For This Useful Post: | ABOSWORTH (04-29-2016) |
(Thread Starter) | Not Ranked : 0 score I ordered some more Denso ITV22 plugs but they didn't come in today like they were supposed to so I stopped at Advance and got some Autolite 1 step colder plugs. I did some WOT pulls and the hesitation is totally gone. What did you mean by the AFR lean blip? The 12 reading? I'm still seeing that in the fresh log from tonight, though in a different cell. Anyway, the car feels much better now but looking at the plugs, I'm wondering if maybe I shouldn't be running 1 step colder. I'm seeing some white on the plugs. Isn't that indicative of the heat range being too low?
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score Change the plugs every year or every 15k miles tops on modified cars. I change mine every year in March/April. Just to make an idea about the rate they wear at, my plugs are always gapped at 0.65mm/0.26". When I change them they're at 0.8mm/0.32". They'd still be good for a car that is not or just lightly modified but not really good for throwing high boost at them. When the gap is too big the boost wave would have the same effect on the spark like wind on a candle.
| The Following User Says Thank You to mituc For This Useful Post: | iamareios (05-02-2016) |
| local tune or inet tune | RACER_X | Gen2 MS3 General Discussion | 19 | 11-13-2014 02:05 PM |
| cobb ap: is safe tune quicker than stage 0 tune? | Fusion_MS3 | 2010 MS3 - ECU Computer Tuning | 14 | 12-16-2012 02:27 AM |
| Problem. Without meth tune is great. On Meth tune shits the bed. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 16 | 09-06-2011 06:58 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
