Like Tree3Likes
  • 1 Post By Justin@Freektune
  • 1 Post By mituc
 Old 04-27-2016, 06:16 PM   #1
ABOSWORTH's Avatar
Posts: 467   (View Stats)
Default Got a tune almost 2 years ago..
I noticed a little bit of hesitation tonight when going WOT. I've never noticed this until tonight so I'm thinking I might have just gotten some shitty gas. Rob rfinkle2 did my tune and I tried to email him but I guess the email is no longer valid so I'm posting this here. Please move if you feel it's necessary. Can someone take a look at these logs? One is in 4th and 5th gear and the other is a 3rd gear log. Noticed a little bit of hesitation around 4-5k RPM. The only thing I have changed power wise since the tune was a CBE, which I did a couple of months ago. I know I need to clean my intake valves as I have 60k and I haven't done it yet. I don't even want to know what they look like! I do notice a bit of black smoke from the exhaust when going WOT but don't notice any oil consumption (running Rotella and change religiously every 3500 miles).
Current Mods
 Old 04-27-2016, 07:42 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Don't see anything in the log except maybe you need to clean your MAF. Your AFRs bounce around a bit causing fuel to fluctuate....
How many miles on your plugs? Checked the gap lately?
ABOSWORTH (04-27-2016)
 Old 04-27-2016, 07:52 PM   #3
ABOSWORTH's Avatar
Probably have about 20-30k on the plugs. Haven't gapped them since I installed them when I got the tune in June of 2014.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Current Mods
 Old 04-27-2016, 08:02 PM   #4
sheston's Avatar
Clean the MAF and look into new plugs... just my thoughts
 Old 04-28-2016, 07:35 AM   #5
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Thats a good amount of miles on the plugs. I would get a new set and gap them to .028" which will more than likely take care of the hesitation you are feeling
In the 3rd gear wot log, starting at cell 45 you can see afr blip lean, and then cells 54 and up you see the same. That is a classic sign of a misfire typically caused by plugs
ABOSWORTH likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
ABOSWORTH (04-29-2016), KiwiFlavor (04-28-2016), macdiesel (05-01-2016), mudawg (04-28-2016)
 Old 04-28-2016, 05:10 PM   #6
ABOSWORTH's Avatar
I ordered new plugs today and will have them tomorrow. I'm just going to baby it until I put the new ones in tomorrow. I feel like an idiot, I totally forgot that the plugs are only good for like 10k. I usually put about 10k a year on my car so I'm going to just start changing them every year.
Thanks for the info guys.
Current Mods
 Old 04-29-2016, 06:10 AM   #7
No problem at all man. Once you have them in, post up a couple more logs or email them to me, and I can make sure you are good to go!
My email is Justin@freektune.com
PTE 6062
633HP/523TQ
 Old 04-29-2016, 06:48 PM   #8
ABOSWORTH's Avatar
I ordered some more Denso ITV22 plugs but they didn't come in today like they were supposed to so I stopped at Advance and got some Autolite 1 step colder plugs. I did some WOT pulls and the hesitation is totally gone. What did you mean by the AFR lean blip? The 12 reading? I'm still seeing that in the fresh log from tonight, though in a different cell. Anyway, the car feels much better now but looking at the plugs, I'm wondering if maybe I shouldn't be running 1 step colder. I'm seeing some white on the plugs. Isn't that indicative of the heat range being too low?
Current Mods
 Old 05-01-2016, 02:01 AM   #9
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Change the plugs every year or every 15k miles tops on modified cars. I change mine every year in March/April. Just to make an idea about the rate they wear at, my plugs are always gapped at 0.65mm/0.26". When I change them they're at 0.8mm/0.32". They'd still be good for a car that is not or just lightly modified but not really good for throwing high boost at them.
When the gap is too big the boost wave would have the same effect on the spark like wind on a candle.
dumbone95 likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
iamareios (05-02-2016)
local tune or inet tune RACER_X Gen2 MS3 General Discussion 19 11-13-2014 02:05 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Page generated in 0.30313 seconds with 24 queries
