Like Tree104Likes
 Old 03-21-2014, 12:10 PM   #1
El Beaner's Avatar
Posts: 4,262   (View Stats)
Neutral  :  -1 score
Default Has anyone tried the OTS plus map(s)?
Well since I won't be doing a DP/TP for a while(probably tax/bonus time next year) I wanted to look into getting a better map than the COBB OTS POS they have.
Just wanted to see how much of a difference it made(and I know there has to be a difference cause it's got to be better than the COBB OTS tunes).
SOLD 2012 LSM Tech - 11/17/17
The Following 2 Users Say Thank You to El Beaner For This Useful Post:
Easter Bunny (03-24-2014), Justin@Freektune (03-21-2014)
 Old 03-21-2014, 12:12 PM   #2
atvfreek's Avatar
Posts: 7,787   (View Stats)
There are a bunch of people on these right now. You get a base map for your mods, then a supplemental revision in which I am able to get 80% or so of the power of a full tune in those revisions, plus the maf cal is dialed in.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 9 Users Say Thank You to atvfreek For This Useful Post:
Atticaz (12-31-2015), Easter Bunny (03-24-2014), El Beaner (03-21-2014), himurax13 (08-20-2014), ItsNox (03-21-2014), Mauro_Penguin (03-24-2014), MTLspeed6 (03-23-2014), trancehead (03-21-2014), white'swhiteMPS (03-24-2014)
 Old 03-21-2014, 12:15 PM   #3
El Beaner's Avatar
That's why I'm looking at Freektune OTS vs Stratified OTS - I like the idea of the revision to make it just that little bit better.
Are there any Dyno/VDyno comparisons posted yet?
The Following User Says Thank You to El Beaner For This Useful Post:
Elvisrosales88 (03-21-2014)
 Old 03-21-2014, 12:19 PM   #4
SpeedEngineer's Avatar
Posts: 1,589   (View Stats)
dyno differences between these two maps will be very minimal if not the same - both are great tuners and are offering a solution to have a drive-able car that you can have a little fun on with whatever supporting mods you have
Freek does offer a revision with along with a sudo custom map for whatever mods you have
Lex offers an ots map that will support your mods with the idea that you get a pro-tune from him which he will then discount the money paid for the ots map
Both are amazing but you shouldn't worry about dyno numbers with an ots map
They will be better and safer than the COBB ots as it will be more tailored to you
LOL MS3 likes this.
2010 MS3 GenPu Blue Mica
4 GAL E85 CORN BY THE FREEK
SpeedEngineer is offline   Reply With Quote
The Following 5 Users Say Thank You to SpeedEngineer For This Useful Post:
Easter Bunny (03-24-2014), himurax13 (08-20-2014), Justin@Freektune (03-21-2014), Lex (03-30-2014), obsidian76 (03-26-2014)
 Old 03-21-2014, 12:21 PM   #5
Justin@Freektune's Avatar
Posts: 954   (View Stats)
This is quite a bit more than what your average OTS map would be. Seeing several datalogs and having that supplemental revision picks up quite a bit of power. I will gather a couple VD's up
SpankyCuervo and Atticaz like this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 10 Users Say Thank You to Justin@Freektune For This Useful Post:
altaprecision (04-05-2014), Awal (05-07-2015), bigwavedave33 (03-27-2014), Easter Bunny (03-24-2014), El Beaner (03-21-2014), impossible (04-26-2014), ItsNox (03-21-2014), maisonvi (03-21-2014), OverBoosted (03-21-2014), SpeedEngineer (03-21-2014)
 Old 03-21-2014, 12:25 PM   #6
Well i think that answers his question right there your sudo OTS maps where you revise it per what that particular car is doing is an awesome solution
The Following 2 Users Say Thank You to SpeedEngineer For This Useful Post:
Atticaz (12-31-2015), Justin@Freektune (03-21-2014)
 Old 03-21-2014, 12:31 PM   #7
I'm really glad I decided to go with the supplemental revision, and monitoring datalogs too, because two people with gen1's had bad primary o2 sensors, and didn't even know it and one had a bad ebcs and wasn't hitting any boost. Straight up one revision and out into the wild would have never seen that
Atticaz likes this.
PTE 6062
633HP/523TQ
The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post:
Atticaz (12-31-2015), AwAfrican (05-14-2015), El Beaner (03-21-2014), ESA (04-01-2014), Haltech (04-23-2014), OverBoosted (03-21-2014), SpeedEngineer (03-21-2014)
 Old 03-21-2014, 12:35 PM   #8
This is a stage2 OTS-plus I just finished
PTE 6062
633HP/523TQ
Atticaz (12-31-2015), djrich26 (07-23-2015)
 Old 03-21-2014, 12:50 PM   #9
El Beaner's Avatar
Ok that settles it. I'll be going FreekTune OTS. Looking on your site, pretuning checks say to change plugs after 15k miles so gonna have to do this next week since I have to pick up some plugs(have 26K miles on the car now).
Atticaz likes this.
 Old 03-21-2014, 01:16 PM   #10
Sounds good sir. Just let me know when you are ready to go.
PTE 6062
633HP/523TQ
El Beaner (03-21-2014), OverBoosted (03-21-2014)
 Old 03-21-2014, 02:21 PM   #11
El Beaner's Avatar
Would you recommend stock heat range plugs or go one step colder for your tunes?
 Old 03-21-2014, 02:51 PM   #12
Stock heat range is perfectly fine and runs best in most k04 cars
PTE 6062
633HP/523TQ
 Old 03-21-2014, 02:58 PM   #13
Even for an e85 tune? Just to verify
 Old 03-21-2014, 03:02 PM   #14
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I put my step colders in right before tuning, and they were covered in black soot with less than 100 miles on them.
I'm back to stock heat, and I'm going to stay with stock heat during my ethanol tune.
The Following 3 Users Say Thank You to Cheapspeed For This Useful Post:
Justin@Freektune (03-21-2014), OverBoosted (03-21-2014), SpeedEngineer (03-21-2014)
 Old 03-21-2014, 03:20 PM   #15
squilliam's Avatar
Posts: 266   (View Stats)
squilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the world
could i get a 50/50 e85 ots plus map?
2009 CWP MS3: CP-E FMIC / CP-E RMM / Cobb SRI / Cobb TIP / Cobb AP V3/ HKS BOV / PTP HPFP Internals / UR V1 Catted DP / UR Racepipe / Cobb SS Catback Exhaust / Swift Spec-R Lowering Springs w/Koni Yellow
squilliam is offline   Reply With Quote
The Following User Says Thank You to squilliam For This Useful Post:
 Old 03-21-2014, 03:33 PM   #16
El Beaner's Avatar
Nope, on his site it clearly states OTS maps are 91/93 octane only maps. For E85, you're probably better off with a full tune
 Old 03-21-2014, 04:55 PM   #17
Unfortunately We can't dial that in within two maps so a full tune would be needed.
PTE 6062
633HP/523TQ
 Old 03-21-2014, 06:13 PM   #18
OverBoosted's Avatar
Posts: 1,608   (View Stats)
I was considering this but after this thread I will be placing my order in the next day or two. Cant wait.
The Following 2 Users Say Thank You to OverBoosted For This Useful Post:
jtday (03-21-2014), Justin@Freektune (03-21-2014)
 Old 03-22-2014, 11:27 AM   #19
Any idea when the OTS + tunes will be available? Want to make sure I get in the next round .
 Old 03-22-2014, 12:31 PM   #20
I will be putting more in stock Monday. Just need the weekend to get caught up
PTE 6062
633HP/523TQ
El Beaner (03-22-2014), OverBoosted (03-22-2014)
 Old 03-22-2014, 12:34 PM   #21
Sounds good. I'll be signing up on Monday.
Justin@Freektune (03-22-2014)
 Old 03-23-2014, 11:53 AM   #22
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
Are these maps going to be locked? I know the stratified OTS and OTS+ maps are locked. Im wondering because if I had a code unchecked and come inspection time I were to uncheck the code and legalize the car for an afternoon would this be a possible option. Or would it be easier to have a map that would be good for an inspection and just flash/reflash when the inspection is finished?
2012 black mica. Totaled 10/31/14.
Johnasaurus is offline   Reply With Quote
 Old 03-23-2014, 12:49 PM   #23
mrshoulders's Avatar
Posts: 652   (View Stats)
mrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the world
Groaned at 86 Times in 51 Posts
why get a ots tune instead of a custom one?
2010 Speed3 w/tech
Bolted E85 FREEKTUNE
mrshoulders is offline   Reply With Quote
 Old 03-23-2014, 01:53 PM   #24
SHADY1's Avatar
Posts: 60   (View Stats)
SHADY1 has disabled reputation
Groaned at 7 Times in 5 Posts
Yea, seen the comment about ebcs. I just installed this upgrade and was running well prior 20 psi, now I can not hold boost above ~16psi. Now I did read on this site that if you add this upgrade you should cut WGDC by 50%, work your way back up until you hit boost targets.
So I have stepped the WGDC back up some and sturggled betwee ~14 and ~16 psi. I will leak check, however after that I may need some help.
(Autotech, Turbo BacK 3" High Flow Cat, Injen CAI, Corksport TIH, Cobb FMIC, TurboXS Hybrid BOV, K04 with billet /port and polished, Cobb 3 port EBCS, AP V3,)
strickly a
Shady1Blk Mica / Carbon Fiber MS3GT
[COLOR="White"]AP / CS 3" Turbo Back / Autoteck HPFP / CS BPV /GA V3 / GT3071R / Cobb FMIC / JBR TRU 3.0 SRI / HTP 3" TIH / CP Low End / Massive Auto Keyed Crank / ARP Main & Head studs / DO Meth 1200cc Full SS quad Inj/ AEM Fail Safe / Cobb 3 Port / H & R Lowering Spring / Magan Racing Camber Arms/ Damond MS Catch Can / Sure Shift Linkage / Sure Hard Mounts / SPEC LW Fly Wheel / SPEC ST3+ Clutch / JBR Trans and Motor Mounts / JBR Balancer Delete Kit / Denso 1sg cooler plugs / Freaktune - (24PSI 450whp, 470 ft-lb)
SHADY1 is offline   Reply With Quote
 Old 03-23-2014, 02:06 PM   #25
El Beaner's Avatar
Mainly for those of us not wanting a full tune yet and want something a lot better than the Cobb ots tunes at a fraction of the price of a full tune.
I'll be buying my tune this coming week, my plugs should be here Monday
Justin@Freektune likes this.
 Old 03-23-2014, 02:13 PM   #26
Neutral  :  -1 score
I have changed my mind about going big turbo and really building this car. Other projects that need my attention. This seems like a happy medium between just a cobb map thats been modified by the user and a full blown tune. Something with a more reliability, safety, power at a good cost.
The Following 3 Users Say Thank You to Johnasaurus For This Useful Post:
El Beaner (03-23-2014), Justin@Freektune (03-23-2014), OverBoosted (03-23-2014)
 Old 03-23-2014, 02:36 PM   #27
That's exactly why I opted to offer this. There are people that don't want or need a full tune. Better than an OTS map with much better boost control, dialed in maf and a few freeky touches
Unless you have egr delete as well as a dp. You should have no issue with emissions testing.
But yes all my maps are locked now. Too many people started using my maps to make maps for other people
GunGuru727 likes this.
PTE 6062
633HP/523TQ
Last edited by Justin@Freektune; 03-23-2014 at 02:36 PM. Reason: MSF Database - Automerged Doublepost
alexryan (03-27-2014), Johnasaurus (03-23-2014), OverBoosted (03-23-2014), SpeedEngineer (03-23-2014)
 Old 03-23-2014, 02:40 PM   #28
SHADY1's Avatar
Ok, I leak checked finding that my BOV (TurboXS hybrid) has leak between hard mount flange and BOV body! meaning the BOV is crap and the EBCS has a small leak at the #2 barb fitting connection at the valve body.
Im sure these affect the tune however system supports 20psi prior to leaking. I believe I will need new BOV, Fix leak at EBCS and tune support.
strickly a
The Following User Says Thank You to SHADY1 For This Useful Post:
 Old 03-23-2014, 05:00 PM   #29
SHADY1's Avatar
Ok, found 3 bolts on Bov that mounts housing to flange loose. Tighend and this fixed BOV leak. Got one turn on EBCS port #2 and this fixed that leak. Guess I will attempt tuning again.
Now leak tight and will attempt tuning the EBCS again. Can freaktune possible help?? I have multipe data logs currently and will get a follow-up in the morning. I think maybe I will give it a try.
strickly a
 Old 03-23-2014, 05:56 PM   #30
SHADY1's Avatar
Justine,
freektune can help??? do you have anything to say??
strickly a
 Old 03-23-2014, 07:06 PM   #31
El Beaner's Avatar
Originally Posted by SHADY1 View Post
Justine,
First off, it's Justin not Justine
Second this thread was about seeing who was running ots maps and their impressions of those maps, if you need Tuning help go to the ecu Tuning section for your best bet on help.
The Following 3 Users Say Thank You to El Beaner For This Useful Post:
Cheapspeed (03-23-2014), memin (03-27-2014), OverBoosted (03-23-2014)
 Old 03-23-2014, 07:16 PM   #32
Cheapspeed's Avatar
Plus I know Freek is swamped with paying customers right now. Shady needs to calm the fuck down.
El Beaner (03-23-2014), memin (03-27-2014)
 Old 03-23-2014, 07:19 PM   #33
Dude you're in the wrong thread and if you're looking for a free tune you are poorly mistaken man.
Justine,
You're doing a pooooor job trolling.
Last edited by SpeedEngineer; 03-23-2014 at 07:19 PM. Reason: MSF Database - Automerged Doublepost
Cheapspeed (03-23-2014), El Beaner (03-23-2014)
 Old 03-24-2014, 01:49 AM   #34
swsmailman's Avatar
Posts: 1,118   (View Stats)
I'm debating going with either a full tune or just a OTS tube from Freek. I need something besides this Cobb OTS tube I got, I get into boost way to quick with the new DP. Won't be able to do a FMIC for a while, but may get a ETS TMIC depending on if I can sell some things, decisions decisions.
2013 Liquid Silver MazdaSpeed
 Old 03-24-2014, 05:11 AM   #35
scapone4's Avatar
Posts: 179   (View Stats)
scapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud of
Question,
Like the Stratified OTS Plus, the $$ goes towards a tune if you get a custom tune down the line. Is it the same for the freektune?
scapone4 is offline   Reply With Quote
 Old 03-24-2014, 07:11 AM   #36
El Beaner's Avatar
If the answer to the question below is a yes, then you might want to just go with the OTS at first and see if that solves some issues. If a No, then I'd say go full tune. Personally if I had a DP/TP I'd go full tune to get all the benefits of it. Remember you can always do a fluff tune when you add any parts down the road.
Originally Posted by scapone4 View Post
Question,
 Old 03-24-2014, 08:06 AM   #37
swsmailman's Avatar
More than likely just going to go the full custom one now since I have everything pretty much except for a upgraded IC, then when I get one later on I will just do a revise. No point in spending the money for an OTS when I know I am going to get a custom one hopefully this year.
The Following 3 Users Say Thank You to swsmailman For This Useful Post:
El Beaner (03-24-2014), Justin@Freektune (03-24-2014), OverBoosted (03-24-2014)
 Old 03-24-2014, 11:06 AM   #38
SHADY1's Avatar
HHum?? a poor job trolling for a paid service???? Really!!! To many tuning services to be talking crap. Or at least I was under the assumption that Freektune was in the business of selling this type of servce. Now if you have little experience in tuning the EBCS in I understand. Free was never the question since freektune is a business!! The question was do you have experience in this upgrade tuning and do you believe you can help if I purchase the service?
Best of luck!
strickly a
 Old 03-24-2014, 11:16 AM   #39
Best of luck!
Seems like you're the one that needs the luck my friend
 Old 03-24-2014, 11:24 AM   #40
SHADY1's Avatar
No luck needed! I have done this many times and Cobb is happy for the extra business.
Maybe freektune is not, but as stated before to many providers to be talking crap!!!
strickly a
The Following User Says NO Thank You to SHADY1 For This Un-useful Post:
x09MS3GT (03-24-2014)
Page generated in 0.57716 seconds with 31 queries
