Like Tree104Likes
 Old 03-24-2014, 11:26 AM   #41
SpeedEngineer's Avatar
Posts: 1,589   (View Stats)
Originally Posted by SHADY1 View Post
No luck needed! I have done this many times and Cobb is happy for the extra business.
Maybe freektune is not, but as stated before to many providers to be talking crap!!!
Lol wut?
2010 MS3 GenPu Blue Mica
4 GAL E85 CORN BY THE FREEK
SpeedEngineer is offline   Reply With Quote
The Following 2 Users Say Thank You to SpeedEngineer For This Useful Post:
chaser27 (03-28-2014), OverBoosted (03-24-2014)
The Following User Says NO Thank You to SpeedEngineer For This Un-useful Post:
Wildcard (04-01-2014)
 Old 03-24-2014, 11:28 AM   #42
OverBoosted's Avatar
Posts: 1,608   (View Stats)
I'm so confused about this. I don't even see where you ask if he can resolve this for you.
Tapatalked
SpeedEngineer (03-24-2014)
 Old 03-24-2014, 11:30 AM   #43
Tapatalked
All he does is beg Justin to "help" and to look at his logs to what I assume is resolve it for free lol
El Beaner (03-24-2014), OverBoosted (03-24-2014)
 Old 03-24-2014, 11:58 AM   #44
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Originally Posted by swsmailman View Post
I'm debating going with either a full tune or just a OTS tube from Freek. I need something besides this Cobb OTS tube I got, I get into boost way to quick with the new DP. Won't be able to do a FMIC for a while, but may get a ETS TMIC depending on if I can sell some things, decisions decisions.
Even my OTS map will fix your boost control issues unless its something hardware related that cannot be tuned out
More than likely just going to go the full custom one now since I have everything pretty much except for a upgraded IC, then when I get one later on I will just do a revise. No point in spending the money for an OTS when I know I am going to get a custom one hopefully this year.
HHum?? a poor job trolling for a paid service???? Really!!! To many tuning services to be talking crap. Or at least I was under the assumption that Freektune was in the business of selling this type of servce. Now if you have little experience in tuning the EBCS in I understand. Free was never the question since freektune is a business!! The question was do you have experience in this upgrade tuning and do you believe you can help if I purchase the service?
Best of luck!
I can tune any setup on your car including an ebcs. For purchase details please visit my website Freektune - Welcome
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post:
altaprecision (04-05-2014), Awal (05-07-2015), El Beaner (03-24-2014), Johnasaurus (03-25-2014), obsidian76 (03-26-2014), OverBoosted (03-24-2014), swsmailman (03-24-2014)
 Old 03-26-2014, 08:37 PM   #45
pfp22972's Avatar
Posts: 820   (View Stats)
pfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the world
Well since I won't be doing a DP/TP for a while(probably tax/bonus time next year) I wanted to look into getting a better map than the COBB OTS POS they have.
Just wanted to see how much of a difference it made(and I know there has to be a difference cause it's got to be better than the COBB OTS tunes).
Just wanted to let you know I received my base map tonight from Justin. I flashed it and drove around for a while. I am by no means an expert so I will do my best to describe his map.
First, what I was using. I was using the CS stage 2 map with various tweaks. I was following Bucker's guide in most areas. Per Cobb's guide, I conservatively set my boost targets to 18psi based on my mods. I used SnailD's aggressive DBW tables and a 9 percent reduction of basically OTS APP tables. This all made for a boost happy car that hit pretty hard around 3500 rpm.
This tune feels very different to me since I was used to such quick pedal response and early boost.
I have to say I really like the base map Justin gave me. It feels much easier to drive around town. Low end, out of boost, power feels stronger. The pedal requires more pressure, and feels a bit more like stock. The boost comes on strong later in the pedal position, feels different, and actually sounds different. Perhaps Justin has done some timing improvements or he's adding load based tuning which was not present in my previous map.
In short, whatever he's doing, I really like it. Power feels quite different but stronger throughout the rpm range. This map doesn't seem to make a lot of noise like my previous map but feels quicker even though this is his base map. I am very impressed. I cannot wait to gather his requested logs and see what he comes up with.
Also, his excellent work has convinced me to go ahead and get a full e-tune.
Thank you Justin!
Justin@Freektune likes this.
2010 Celestial Blue Speed 3
- FREEKTUNED -
Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC
CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals
JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete
Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's
pfp22972 is offline   Reply With Quote
The Following 7 Users Say Thank You to pfp22972 For This Useful Post:
Awal (05-07-2015), BeeZaa (07-09-2014), El Beaner (03-26-2014), Justin@Freektune (03-26-2014), OverBoosted (03-26-2014), R_Squared (08-17-2014), SarcasticOne (03-26-2014)
 Old 03-27-2014, 07:41 AM   #46
LOL MS3's Avatar
Posts: 67   (View Stats)
LOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond repute
While the OTS+ is a great option for some, getting the full tune support is the best option. If you're going tune, you might as well get it done right the first time. For my ST, the difference between the first revision, and the map I have now (4th revision) is noticeably different. I personally have never been a believer of running an OTS map, mainly because we all drive differently in different environments and different climates, so running an OTS map is the lazy way out. Way too much at stake when it comes to tuning to try to save $75.
If I were you guys, I'd wait an extra week or two, save the extra pennies and just get the full support. Justin will grow with the car, and you will fall back in love with your car, like the first time you drove it off the lot.
You MS3 chaps have a lot to gain from a simple tune, unlike my little 2.0. Get the full e-tune support, you'll be happy you did.
Sent while street racing
'13 Focus ST
Current Modifications:
Freektune 93 oct|Boomba BOV|Res and Mufler Delete|CXR FMIC - Installed by Relentless Customs
- @lolms3
LOL MS3 is offline   Reply With Quote
The Following 4 Users Say Thank You to LOL MS3 For This Useful Post:
Justin@Freektune (03-27-2014), Nel Mazdaspeed (08-19-2014), SpeedEngineer (03-27-2014), TRBLSM (05-03-2015)
 Old 03-27-2014, 08:02 AM   #47
pfp22972's Avatar
I don't believe Justin sells these as "OTS" maps. The + signifies that it is beyond a cookie cutter standard tune. He tailors each sale to your specific vehicle, given your mods. He then has you run some logs and dials everything in for you. Not quite a full tune but much more than a standard OTS tune, reflected in the lower price. Comparing the base map he sent me to a standard OTS show considerable improvement. He supplementary revision should be even better.
Like you say, however, a full tune gets full potential out of your car and your mods. That is why I decided to go ahead and get the full tune. The few conversations I've had with Justin let me know I can trust him to take care of my car.
BTW, how do you like your ST? They are really growing on me.
Sent from somewhere...but not here.
- FREEKTUNED -
The Following User Says Thank You to pfp22972 For This Useful Post:
 Old 03-27-2014, 08:06 AM   #48
LOL MS3's Avatar
Justin definitely takes the OTS maps a step further, which why freektune is so amazing. But still..... Full tuning support is the only way to go. I know in the ST community, not many people know or knew about freektune prior to a few weeks ago. I had been reading up on him and had been in talks with Justin for a little before I pulled the trigger. I'm so happy I did.
I love my ST. Everything about it is great, EXCEPT the awful exhaust note. I personally love the MS3 sound so the ST leaves me wanting more in that area. That, and the tiny k03 is starting to be a pain in the ass. Overall though it's a great car. Of course it's all subjective because I think the MS3 is a great car, lol.
'13 Focus ST
- @lolms3
The Following User Says Thank You to LOL MS3 For This Useful Post:
 Old 03-27-2014, 08:09 AM   #49
Great feedback, and converstion guys!
PTE 6062
633HP/523TQ
 Old 03-27-2014, 08:46 AM   #50
pfp22972's Avatar
I'm all about helping people. If I can help someone by sharing my experiences, I will. In your case, if I can help you sell what I believe to be a great product, I sure will.
LOL MS3 and Justin@Freektune like this.
- FREEKTUNED -
 Old 03-27-2014, 09:20 AM   #51
pfp22972's Avatar
I haven't heard any ST's other than stock in video reviews. It's interesting to note that the base map Justin gave me has changed how much deceleration drone I had inside the car. With my previous map it was really getting on my nerves. So much so that I added a second resonator. It's much more tolerable.
- FREEKTUNED -
 Old 03-27-2014, 09:30 AM   #52
LOL MS3's Avatar
Heres my ST
Just a res delete.
'13 Focus ST
- @lolms3
The Following 2 Users Say Thank You to LOL MS3 For This Useful Post:
Justin@Freektune (03-27-2014), OverBoosted (03-27-2014)
 Old 03-27-2014, 09:53 AM   #53
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Holy loud BOV.
The Following 3 Users Say Thank You to Cheapspeed For This Useful Post:
Awal (05-07-2015), OverBoosted (03-27-2014), Qwik6 (03-31-2014)
 Old 03-27-2014, 10:02 AM   #54
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Sounds like a big rig or a bus lol. Nice car.
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
The Following User Says Thank You to Playaj For This Useful Post:
 Old 03-27-2014, 10:25 AM   #55
JPPatterson's Avatar
Posts: 118   (View Stats)
JPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond reputeJPPatterson has a reputation beyond repute
I'm currently on my 3rd map of a full tune from Justin and it's great. My car has limited mods (see below, it's pretty light compared to a lot of the peeps around here) and it's infinitely better than the OTS Cobb map. The Cobb maps felt twitchy and choppy. The car feels more powerful, smoother and I think I'm getting better gas mileage too which wasn't really a concern... Regardless, Justin has been great.
And that ST sounds great. A guy that works for me has one that's bone stock and it's so quiet, sounds like he's driving a Prius. Okay, maybe not a Prius but it's quiet and especially compared to my MS3! Definitely cool cars though, good luck with it.
JP
2012 Mazdaspeed 3
CP-E Stage 2 RMM, Autotech Internals, Cobb Accessport V3, Corksport SRI w/tip, JBR Solid Shifter Bushings, JBR Short Throw Plate, JBR Cylindrical Shift Knob, Corksport Catted Downpipe, Corksport Cat Back Exhaust, NGK Plugs, Corksport TMM Insert, AEM V2 Meth Injection, TSW Nurburgring 18x8.5 Wheels
FreekTuned
To Be Installed: Rally Armor Mud Flags (Mazdaru Style)
JPPatterson is offline   Reply With Quote
The Following 3 Users Say Thank You to JPPatterson For This Useful Post:
B4RK3R (08-31-2015), Justin@Freektune (03-27-2014), OverBoosted (03-27-2014)
 Old 03-27-2014, 12:05 PM   #56
El Beaner's Avatar
Posts: 4,262   (View Stats)
Darnit, went to go order my OTS+ tune so I'd have it ready for when I changed the plugs Saturday, and he's sold out right now
SOLD 2012 LSM Tech - 11/17/17
 Old 03-27-2014, 12:16 PM   #57
El Beaner's Avatar
Holy loud BOV.
I was going to say the same thing, wow. I thought my CS witha metal TIP was loud lol
 Old 03-27-2014, 01:00 PM   #58
LOL MS3's Avatar
It's a very unique sound. In person, as with everything else, it sounds much better.
'13 Focus ST
- @lolms3
 Old 03-27-2014, 07:41 PM   #59
Finished up my OTS + and I must say that its awesome. I thought I was doing a decent job tweaking my cobb OTS map myself, but this is sooo much better. Best money spent so far. Only 1 downside though...I am going to HAVE to get a full tune with an e85 map now.
atvfreek (03-27-2014)
 Old 03-27-2014, 07:48 PM   #60
LOL MS3's Avatar
Told ya!
'13 Focus ST
- @lolms3
 Old 03-27-2014, 08:32 PM   #61
pfp22972's Avatar
That BOV sounds louder than the exhaust in the video. The exhaust sounds good despite being quiet. I think once you get the DP and do the muffler delete you have planned it will sound pretty darn good.
Sweet. I should have my logs done and sent to Justin in the morning to update my base map. I can't wait for the changes he makes. I went ahead and decided to go with the full tune after enjoying just the base map. That, plus the full e-tune is on sale right now. Can't beat his excellent work for such a low price.
- FREEKTUNED -
Last edited by pfp22972; 03-27-2014 at 08:32 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to pfp22972 For This Useful Post:
atvfreek (03-27-2014), OverBoosted (03-27-2014)
 Old 03-27-2014, 08:37 PM   #62
I wish I had the extra funds for the full tune right now, but I have a few more parts I want to get before I do the full tune so I can wait. I'm just glad I have a safe, reliable, and powerful tune right now.
The Following 2 Users Say Thank You to OverBoosted For This Useful Post:
atvfreek (03-27-2014), purpledrank (03-28-2014)
 Old 03-27-2014, 08:45 PM   #63
pfp22972's Avatar
That was the most important factor for me in going with a Freektune. I was playing so much with my tune that I began to worry if it was becoming detrimental. Putting my tune in much more knowledgeable hands puts my mind at ease.
- FREEKTUNED -
atvfreek (03-27-2014), OverBoosted (03-28-2014)
 Old 03-27-2014, 08:48 PM   #64
atvfreek's Avatar
Posts: 7,787   (View Stats)
Were you able to get your purchase in today?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 03-27-2014, 09:37 PM   #65
El Beaner's Avatar
I just put the order in like 10min ago
LOL MS3 likes this.
The Following 3 Users Say Thank You to El Beaner For This Useful Post:
Justin@Freektune (03-28-2014), OverBoosted (03-27-2014), pfp22972 (03-27-2014)
 Old 03-28-2014, 06:20 AM   #66
scapone4's Avatar
Posts: 179   (View Stats)
scapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud of
So does the + option go towards a full tune similar to what stratified does with their + option?
scapone4 is offline   Reply With Quote
 Old 03-28-2014, 09:16 AM   #67
Exactly! I was messing with it so much that it started to worry me, but now I'm good. Oh and it has a hell of a lot more power now.
 Old 03-28-2014, 09:36 AM   #68
pfp22972's Avatar
That's great to hear. Just finished my logs. Headed home to send them to Justin and wait for some awesomeness.
- FREEKTUNED -
 Old 03-28-2014, 11:54 AM   #69
purpledrank's Avatar
Posts: 52   (View Stats)
purpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant future
I just purchased the OTS+ tune a few minutes ago. I'm currently running the Cobb Stage 2 OTS v231 map. I will report back when I'm tuned and compare the two.
2009 Mazdaspeed 3
Cobb SRI//HTP TIP//CXRacing FMIC//HKS SSQV 4//AT Internals//M2 Catless Downpipe//Straight Piped//ITV22's//JBR RMM//Raceland Coilovers//CPE Tow Plate
Freektune OTS+
purpledrank is offline   Reply With Quote
The Following 2 Users Say Thank You to purpledrank For This Useful Post:
El Beaner (03-28-2014), OverBoosted (03-28-2014)
 Old 03-28-2014, 12:14 PM   #70
El Beaner's Avatar
Woohoo got my map - just have to wait until tomorrow to swap the plugs out and then put the required milage on the car.
Quick question, what are the default logging parameters for the datalogs? What items should I be logging?
Here is an example datalog from a previous one I've done. More or less than that info? (this is not a log on the Freektune OTS map)
 Old 03-28-2014, 12:16 PM   #71
pfp22972's Avatar
There is a section in the AP, under options to reset to the default logs parameters. If you haven't added or removed an check marks on what it logs you should be fine. I went ahead and reset them just to be safe.
- FREEKTUNED -
The Following 3 Users Say Thank You to pfp22972 For This Useful Post:
El Beaner (03-28-2014), Justin@Freektune (03-28-2014), OverBoosted (03-28-2014)
 Old 03-28-2014, 01:04 PM   #72
El Beaner's Avatar
Ok awesome, I'll switch back to default because I know I messed with it.
The Following 2 Users Say Thank You to El Beaner For This Useful Post:
 Old 03-28-2014, 01:45 PM   #73
pfp22972's Avatar
My bad. It's actually in the Monitor section. Scroll down to Reset Log List.
- FREEKTUNED -
 Old 03-29-2014, 05:40 PM   #74
Scott4957's Avatar
Posts: 171   (View Stats)
Scott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the world
This is great stuff. The tune has held me back on several of my cars, not knowing who to go to, having to be done in person. The etune option for this car and the great results people are getting is exciting. I love to do all the mechanical work, but don't have the time or the balls to do the tune from scratch. I will be watching freektune threads closely!
Scott4957 is offline   Reply With Quote
The Following User Says Thank You to Scott4957 For This Useful Post:
OverBoosted (03-29-2014)
 Old 03-30-2014, 09:17 AM   #75
pfp22972's Avatar
I thought I would provide an update on my Freektune for those still on the fence. I received my supplementary update last night. There is a significant improvement over the initial base map. The power increase is very noticeable from idle all the way to red line. Boost is also quite a bit stronger now. But, beyond the power increase, I am so impressed with how much more driveable my car is now. If I want to cruise around town it is very easy. If I want to jump on the power and get moving quickly, it is right there when I need it.
I thought I was doing a good job tuning on my own. Now, I realize my work was decent at best.
Justin's work has transformed my car. It is easy to see why people have said his tunes are the best money they have spent on their car.
- FREEKTUNED -
Justin@Freektune (03-30-2014), OverBoosted (03-30-2014), purpledrank (03-30-2014)
 Old 03-30-2014, 10:06 AM   #76
El Beaner's Avatar
My initial map for my + tune is leaps and bounds better than the Cobb ots crap. I flashed it yesterday and am putting the requested milage on the car (well more cause wife wanted to go shopping so I'll have probably close to 100 miles before I can do some logs).
I have noticed in the few little good pulls I've done boost is pretty good and strong. Can't wait to do my logs and send them in.
Justin@Freektune (03-30-2014), OverBoosted (03-30-2014), pfp22972 (03-30-2014)
 Old 03-30-2014, 10:09 PM   #77
El Beaner's Avatar
Alright, did my requested logs about an hour ago and sent them in. Can't wait for the update and see how that is.
OverBoosted (03-31-2014), pfp22972 (03-31-2014)
 Old 03-31-2014, 07:56 PM   #78
I have also received my base OTS+ map and it's a night and day difference from Cobb's OTS. The car maintains excellent driveability while having plenty of power when you want it. The power band is silky smooth and boost hits like a champ. Note all of this is without the supplemental revision and it's hard to believe it could be even better.
For those of you that are on the fence about the OTS+ tune, please do yourself a favor and buy it. You will not be disappointed.
2009 Mazdaspeed 3
Freektune OTS+
The Following 5 Users Say Thank You to purpledrank For This Useful Post:
Awal (05-07-2015), El Beaner (03-31-2014), Justin@Freektune (03-31-2014), OverBoosted (03-31-2014), pfp22972 (03-31-2014)
 Old 03-31-2014, 07:57 PM   #79
That's exactly how mine is as well. It gets even better though just wait haha
Tapatalked
 Old 03-31-2014, 08:10 PM   #80
El Beaner's Avatar
Tapatalked
I can't wait lol. I keep checking my email like every hour hoping for an email haha
The Following User Says Thank You to El Beaner For This Useful Post:
Page generated in 0.64000 seconds with 32 queries
