Like Tree104Likes
 Old 12-22-2015, 05:49 AM   #361
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
Originally Posted by PurplFox View Post
Yep next Payday THat will be the plan. Quite happy with the 290/310.
We have almost identical mods and an ots map from the same dude... how are you getting 290whp?
Not trying to be a douchebag I just wanna know how you're setting up Vdyno
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
Last edited by robbspeed; 12-22-2015 at 05:53 AM. Reason: MSF Database - Automerged Doublepost
robbspeed is offline   Reply With Quote
 Old 12-22-2015, 06:54 AM   #362
PurplFox's Avatar
Posts: 352   (View Stats)
PurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the world
this was the base, ill pull another log and post it up for the post revision
Edit, adjusted for smoothing3 and added VD
Cobb AP
JBR Tru-3.0
CNT Catted DP "Gutted"
CNT Catback
JBR 88 RMM DM PMM and TMM
3 port, Turbosmart dual port
FReaktune E33
PurplFox is offline   Reply With Quote
The Following 2 Users Say Thank You to PurplFox For This Useful Post:
Atticaz (12-31-2015), robbspeed (12-22-2015)
 Old 12-22-2015, 06:59 AM   #363
robbspeed's Avatar
Groans: 50
Thats right around where I was. Do you have to use that SAE correction thing for weather and barometric pressure?
Totaled/ R.I.P.
 Old 12-22-2015, 07:03 AM   #364
PurplFox's Avatar
I Choose to, it only makes a difference when the temps are way out there. right now we are seeing temps close to the sae standard. but come summer it will help show a more accurate result IMO.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
The Following User Says Thank You to PurplFox For This Useful Post:
 Old 12-22-2015, 07:05 AM   #365
robbspeed's Avatar
Groans: 50
I just started using Vdyno so I wanted to make sure I was doing it right. My peak torque was 3500 rpm but peak hp was the same rpm as yours.
Totaled/ R.I.P.
 Old 12-22-2015, 07:23 AM   #366
robbspeed's Avatar
Groans: 50
Can u post the logs you used. I wanna compare mine to them. I can post mine if you want.
Totaled/ R.I.P.
 Old 12-22-2015, 07:26 AM   #367
PurplFox's Avatar
Here you go.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-22-2015, 07:34 AM   #368
Jakeypoo's Avatar
Posts: 226   (View Stats)
Jakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond repute
How in the world can you pull off a 3rd gear pull with a Freaktune and not spin the tires? I was almost traction limited in third with the base tune and had to go to 4th gear logs after first revision on 93.
Now with E30 OTS+ I have an even bigger problem with being unable to wipe the stupid grin off my face. I got mad love for the Freaktune.
2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25.
Jakeypoo is offline   Reply With Quote
 Old 12-22-2015, 08:03 AM   #369
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Depends on boost taper and tire/suspension.
 Old 12-22-2015, 08:49 AM   #370
robbspeed's Avatar
Groans: 50
Here you go.
datalog 14 was my base map and data log 15 was my revision. Log 20 was with the revision but it was a lot warmer out. I'm hitting similar load as you, flowing a similar amount of air as you and hitting the same boost as you yet its not translating to similar vdyno's. WTF
Maybe i need a 3" intake and 3" catback?
Totaled/ R.I.P.
 Old 12-22-2015, 09:04 AM   #371
PurplFox's Avatar
I think part of it may be the extra data you are collecting. Follow freaks guide, i think only pulling the default parameters.
RPM,Boost, Throttle Position, HPFP, Speed, Act AFR, MAF, Spk adv, wasgate, BAT, Load, LT,ST,MafV, iat, IVA.
I've heard that VD can be finiky
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-22-2015, 09:38 AM   #372
robbspeed's Avatar
Groans: 50
Im pretty sure it was logging the default parameters. The only thing I added was accelerator position.
Totaled/ R.I.P.
Last edited by robbspeed; 12-22-2015 at 09:40 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-22-2015, 09:44 AM   #373
robbspeed's Avatar
Groans: 50
Do you have the v2 or v3? Im just wondering if they log different parameters by default.
Totaled/ R.I.P.
 Old 12-22-2015, 09:48 AM   #374
PurplFox's Avatar
what size tire and gear are you using, and what is your weight of you and extras in car. those valves can have a big shift in results
V3
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
Last edited by PurplFox; 12-22-2015 at 09:49 AM. Reason: didnt want to double post
 Old 12-22-2015, 10:04 AM   #375
robbspeed's Avatar
Groans: 50
V3
I was in 3rd gear for log 14 and 15. Log 20 was 4th gear.
Stock size is the info I put in. 225/ 40 r18
I used the predetermined weight for a gen 2 speed3 so like, 3270 lbs plus my weight which is 160 lbs.
Totaled/ R.I.P.
 Old 12-22-2015, 10:48 AM   #376
PurplFox's Avatar
looks like i might just have a freaky motor. i know i need to clean the valves. hopefully mid January i can finish the phonlic gaskets and knock it all out at once.
Just sent payment for Corn, its so much fun to drive. cant wait to see what more will do!
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-22-2015, 11:01 AM   #377
robbspeed's Avatar
Groans: 50
How many miles do you have on your motor?
Totaled/ R.I.P.
 Old 12-22-2015, 11:02 AM   #378
Cheapspeed's Avatar
Gear has a huge effect on vdyno numbers. My 3rd gears all hit about 30whp lower than 4th gear logs.
 Old 12-22-2015, 11:04 AM   #379
PurplFox's Avatar
Ive got just a hair over 80,000 miles.
Gear makes a big difference when doing logs
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-22-2015, 11:16 AM   #380
robbspeed's Avatar
Groans: 50
I've done 3rd and 4th gear logs.
I guess I'll just try again when it's not raining. I'll log only the critical parameters and do 3rd and 4th gear.
Totaled/ R.I.P.
 Old 12-22-2015, 07:40 PM   #381
robbspeed's Avatar
Groans: 50
Ok @PurplFox;, I have one more question and I'll leave you alone forever. What size wheels and tires are you using? When I put in the stock dimensions it gives me 25.08 but on yours it says 25.61
25.61 gives me completely different numbers. I'm just trying to see if I'm doing anything wrong.
Totaled/ R.I.P.
 Old 12-23-2015, 05:43 AM   #382
PurplFox's Avatar
I run a gen two tire 225/40r18
Something I've noticed, save a screen shot of a graph and reload the same and see if it comes out the same. i have seen different results on the same log
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-23-2015, 05:48 AM   #383
robbspeed's Avatar
Groans: 50
Hang on, hang on. I thought something was weird. I run the same size tire but when I put 225/40 r18 in, it gives me 25.01 instead of 25.61 like your says. When I manually enter a tire size of 25.61 I get about another 10 whp and that puts me at 285 whp.
So is my vdyno tire size selector thing fucked up or is yours?
Totaled/ R.I.P.
 Old 12-23-2015, 06:11 AM   #384
PurplFox's Avatar
you have to remember that the 25.61 is stock for a 215 45 tire. stock on a gen one. i run a gen pu tire so it computes differently i guess
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-23-2015, 06:18 AM   #385
AwAfrican's Avatar
Posts: 1,038   (View Stats)
Make sure you guys have CF=1.01 as well. I'm not looking at previous posts to see if you have just doing a quick browse on my phone.
Sent via tapafail.
2013 Black MS3
 Old 12-23-2015, 06:21 AM   #386
robbspeed's Avatar
Groans: 50
Well then you need to re enter the your tire size correctly to get a proper reading because you're no longer running a gen one tire
Totaled/ R.I.P.
The Following User Says Thank You to robbspeed For This Useful Post:
AwAfrican (12-23-2015)
 Old 12-23-2015, 06:26 AM   #387
AwAfrican's Avatar
And don't forget, just because you have the same mods does NOT mean you will make the same power, each car is slightly different in the way it responds. Plus the maps may nto be identical, I know justin played around with my timing during revisions, not to mention the log air temp, tire slip etc. Will be different. While yes you need to correct tire size the only way to truely get similar dyno results would be to go on the same dyno one after another. Someone please correct me if I'm wrong.
Edit: even altitude will effect results
Sent via tapafail.
Cheapspeed likes this.
2013 Black MS3
The Following User Says Thank You to AwAfrican For This Useful Post:
robbspeed (12-23-2015)
 Old 12-23-2015, 06:45 AM   #388
robbspeed's Avatar
Groans: 50
Sent via tapafail.
Are numbers should be close because we have similar mods and a similar tune and our logs look very similar. Yet he was showing about 15-20 whp over me. I believe 10-15 whp of that is do to him using an incorrect tire size because when I use the size he is using I get within a few whp of him.
All im saying is he needs to change his tire size to what I'm using.
Totaled/ R.I.P.
 Old 12-23-2015, 06:49 AM   #389
AwAfrican's Avatar
@robbspeed; I believe you are correct, within 15whp of each other on vdyno to me is an acceptable error.and that would correct it
Sent via tapafail.
2013 Black MS3
 Old 12-23-2015, 06:53 AM   #390
PurplFox's Avatar
i input my tire size, Ive saved my profile so that i can just select it. VD is more for showing change more than hard numbers.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-23-2015, 07:04 AM   #391
robbspeed's Avatar
Groans: 50
When the right info is entered and a correction factor of 1.01 is used, vdyno comes extremely close to actual dynojet numbers.
I'm just glad we got this figured out.
Totaled/ R.I.P.
 Old 12-23-2015, 07:28 AM   #392
Jakeypoo's Avatar
Even tires with the same size. 225/45 18 can have different diameters. Look up your tires on tirerack and check the diameter.
Also graph time vs. speed from your run. Flat spots indicate wheel spin.
The Following 2 Users Say Thank You to Jakeypoo For This Useful Post:
AwAfrican (12-23-2015), robbspeed (12-23-2015)
 Old 12-23-2015, 07:49 AM   #393
Justin@Freektune's Avatar
Posts: 954   (View Stats)
10hp difference in VD of all things is negligible. You can even hop on a dyno one day, then hop on a different day and see 10hp difference.
I also use smoothing 6. (the highest smoothing on VD) That rules out any bumps or anomalies. Sure the numbers may be lower with that smoothing, but its most accurate when comparing one revision to another
All logs when using VD also need to be on the same day, same road, same direction, and same start point or results will vary
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
 Old 12-23-2015, 09:00 AM   #394
PurplFox's Avatar
Sweet, Time to fill up for e33 mix. this is going to get fun. of course Quick turnaround is awesome.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-28-2015, 11:20 AM   #395
Tifosi42's Avatar
Posts: 179   (View Stats)
Just purchased an OTS+ map to go along with my Damond full egr delete and CPE catless downpipe I will be installing this week. I am excited to see the results compared to where I am right now. This OTS+ map will be holding me over until May when I go for a full Freektune plus a full tune on 2 gallons of in tank methanol.
BNR S3 - FREEKTUNED on E33
Tifosi42 is offline   Reply With Quote
The Following User Says Thank You to Tifosi42 For This Useful Post:
Justin@Freektune (12-28-2015)
 Old 12-29-2015, 09:59 AM   #396
Tifosi42's Avatar
I received my first map already after ordering it on Sunday night which is about a day and a half turnaround time (pretty awesome). I'll be installing the new parts on Thursday and loading the new map. I am already liking this single revision stuff, since he is asking for different datalogs to dial maf cal, etc. Really looking forward to the results.
The Following 2 Users Say Thank You to Tifosi42 For This Useful Post:
Justin@Freektune (12-31-2015), robbspeed (12-29-2015)
 Old 12-30-2015, 10:48 AM   #397
PurplFox's Avatar
@Justin@Freektune; Inbox when you have a chance
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 12-31-2015, 07:30 PM   #398
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
This is a stage2 OTS-plus I just finished
I'm Sold. I got my Catted DP on the way. I will be ordering as soon as I am able. Baby on the way is making me have to "budget". UGH, I hate that word.
robbspeed likes this.
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 12-31-2015, 07:32 PM   #399
You won't be disappointed with the tune. Also weird that you replied to a year old post lol.
sent from my Nexus 6P
Atticaz (12-31-2015), robbspeed (12-31-2015)
 Old 12-31-2015, 07:32 PM   #400
AwAfrican's Avatar
Should have thought about that before you got yourself a baby lmao
Sent via tapafail.
Atticaz likes this.
2013 Black MS3
Page generated in 0.60780 seconds with 28 queries
