Like Tree104Likes
 Old 03-28-2014, 01:45 PM   #1
pfp22972's Avatar
Posts: 820   (View Stats)
pfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the world
Originally Posted by pfp22972 View Post
There is a section in the AP, under options to reset to the default logs parameters. If you haven't added or removed an check marks on what it logs you should be fine. I went ahead and reset them just to be safe.
Sent from somewhere...but not here.
My bad. It's actually in the Monitor section. Scroll down to Reset Log List.
2010 Celestial Blue Speed 3
- FREEKTUNED -
Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC
CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals
JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete
Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's
pfp22972 is offline   Reply With Quote
 Old 03-29-2014, 05:40 PM   #2
Scott4957's Avatar
Posts: 171   (View Stats)
Scott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the world
This is great stuff. The tune has held me back on several of my cars, not knowing who to go to, having to be done in person. The etune option for this car and the great results people are getting is exciting. I love to do all the mechanical work, but don't have the time or the balls to do the tune from scratch. I will be watching freektune threads closely!
Scott4957 is offline   Reply With Quote
The Following User Says Thank You to Scott4957 For This Useful Post:
OverBoosted (03-29-2014)
 Old 03-30-2014, 09:17 AM   #3
pfp22972's Avatar
I thought I would provide an update on my Freektune for those still on the fence. I received my supplementary update last night. There is a significant improvement over the initial base map. The power increase is very noticeable from idle all the way to red line. Boost is also quite a bit stronger now. But, beyond the power increase, I am so impressed with how much more driveable my car is now. If I want to cruise around town it is very easy. If I want to jump on the power and get moving quickly, it is right there when I need it.
I thought I was doing a good job tuning on my own. Now, I realize my work was decent at best.
Justin's work has transformed my car. It is easy to see why people have said his tunes are the best money they have spent on their car.
- FREEKTUNED -
The Following 3 Users Say Thank You to pfp22972 For This Useful Post:
Justin@Freektune (03-30-2014), OverBoosted (03-30-2014), purpledrank (03-30-2014)
 Old 03-30-2014, 10:06 AM   #4
El Beaner's Avatar
Posts: 4,262   (View Stats)
My initial map for my + tune is leaps and bounds better than the Cobb ots crap. I flashed it yesterday and am putting the requested milage on the car (well more cause wife wanted to go shopping so I'll have probably close to 100 miles before I can do some logs).
I have noticed in the few little good pulls I've done boost is pretty good and strong. Can't wait to do my logs and send them in.
Justin@Freektune likes this.
SOLD 2012 LSM Tech - 11/17/17
The Following 3 Users Say Thank You to El Beaner For This Useful Post:
Justin@Freektune (03-30-2014), OverBoosted (03-30-2014), pfp22972 (03-30-2014)
 Old 03-31-2014, 07:56 PM   #5
purpledrank's Avatar
Posts: 52   (View Stats)
purpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant futurepurpledrank has a brilliant future
I have also received my base OTS+ map and it's a night and day difference from Cobb's OTS. The car maintains excellent driveability while having plenty of power when you want it. The power band is silky smooth and boost hits like a champ. Note all of this is without the supplemental revision and it's hard to believe it could be even better.
For those of you that are on the fence about the OTS+ tune, please do yourself a favor and buy it. You will not be disappointed.
2009 Mazdaspeed 3
Cobb SRI//HTP TIP//CXRacing FMIC//HKS SSQV 4//AT Internals//M2 Catless Downpipe//Straight Piped//ITV22's//JBR RMM//Raceland Coilovers//CPE Tow Plate
Freektune OTS+
purpledrank is offline   Reply With Quote
The Following 5 Users Say Thank You to purpledrank For This Useful Post:
Awal (05-07-2015), El Beaner (03-31-2014), Justin@Freektune (03-31-2014), OverBoosted (03-31-2014), pfp22972 (03-31-2014)
 Old 03-30-2014, 10:09 PM   #6
El Beaner's Avatar
Alright, did my requested logs about an hour ago and sent them in. Can't wait for the update and see how that is.
The Following 2 Users Say Thank You to El Beaner For This Useful Post:
 Old 03-31-2014, 07:57 PM   #7
OverBoosted's Avatar
Posts: 1,608   (View Stats)
That's exactly how mine is as well. It gets even better though just wait haha
Tapatalked
The Following 2 Users Say Thank You to OverBoosted For This Useful Post:
 Old 03-31-2014, 08:10 PM   #8
El Beaner's Avatar
Tapatalked
I can't wait lol. I keep checking my email like every hour hoping for an email haha
The Following User Says Thank You to El Beaner For This Useful Post:
 Old 03-31-2014, 08:19 PM   #9
pfp22972's Avatar
Lol! You don't want to rush Freektune awesomeness!
In all honesty, Justin responds with tune updates faster than most part suppliers respond to email questions. Pretty impressive dude.
- FREEKTUNED -
 Old 03-31-2014, 08:41 PM   #10
El Beaner's Avatar
Oh not rushing him, just checking like a kid waiting for Christmas morning.
Awal (05-07-2015), Justin@Freektune (03-31-2014)
 Old 03-31-2014, 08:48 PM   #11
pfp22972's Avatar
No doubt. I got all excited when I saw his email. I acted all cool in my reply but I ran to my pc and loaded the map into my AP then to my car. I did a few miles aroubd the neighborhood and proceeded to have the stupidest smile on my face.
- FREEKTUNED -
The Following 4 Users Say Thank You to pfp22972 For This Useful Post:
Awal (05-07-2015), Donut (04-29-2014), Justin@Freektune (03-31-2014), OverBoosted (03-31-2014)
 Old 03-31-2014, 08:49 PM   #12
Justin@Freektune's Avatar
Posts: 954   (View Stats)
You should have mail sir
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
El Beaner (03-31-2014), OverBoosted (03-31-2014), pfp22972 (03-31-2014)
 Old 03-31-2014, 09:00 PM   #13
MTLspeed6's Avatar
Posts: 110   (View Stats)
MTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the worldMTLspeed6 is the leader of the world
How close to the full etune are you able.to get with 1 revision. I feel like if.u can get close to 75-80% of what the full etune would give( in terms of power/delivery), i will definately purchase an OTS+ map. My mods in sig + upcomming hpfp and tmic.
COBB AP | COBB SRI | PG TIP | Autotech HPFP | Corksport TMIC | AWR RMM | SURE TP | 3inch single exit straight pipe exhaust | H&R springs FREEKtuned Videos of the whip : 1. https://www.youtube.com/watch?v=JnWmorhXPKo 2 https://www.youtube.com/watch?v=5JXhI4bFC44
MTLspeed6 is offline   Reply With Quote
 Old 04-01-2014, 10:08 AM   #14
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Yall bitches better get that e85 FREEKTUNE later because you dont know what you are missing!
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
The Following 4 Users Say Thank You to Zdraveca For This Useful Post:
El Beaner (04-01-2014), Justin@Freektune (04-01-2014), OverBoosted (04-01-2014), SpeedEngineer (04-01-2014)
 Old 04-01-2014, 10:12 AM   #15
El Beaner's Avatar
If/when I get a DP/TP and get a full tune, I'll most likely get an E85 tune to have as well. That way I can run e85 around town(since there is a station really close to me) and still have the ability to run a 93 map for when I travel.
With a baby on the way, I don't want to(and probably won't be able to) reserve cargo space for gas jugs ala @SpeedEngineer style
OverBoosted (04-01-2014), SpeedEngineer (04-02-2014)
 Old 04-01-2014, 10:17 AM   #16
Zdraveca's Avatar
Groans: 145
no need to do that. he just doesn't have e85 close enough and we have 2 stations in LE
@atvfreek; will you be offering evo x tunes soon? we got a local guy here that needs some FreekTune treatment because he's too slow to hang with us cool guys
GT2876r
E85 FREEKTUNE
Last edited by Zdraveca; 04-01-2014 at 10:17 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Zdraveca For This Useful Post:
 Old 04-01-2014, 10:18 AM   #17
El Beaner's Avatar
I know the Valero on 380/1385 - where is the other one?
 Old 04-01-2014, 10:22 AM   #18
Zdraveca's Avatar
Groans: 145
https://www.google.com/maps/place/Va...d4a0f26bdf906c
GT2876r
E85 FREEKTUNE
 Old 04-01-2014, 10:11 AM   #19
Yea that is a known side effect of the OTS +. Justin is like a speed drug dealer. Once you get a taste, you're hooked lol.
 Old 04-01-2014, 10:29 AM   #20
MadOzodi's Avatar
Posts: 686   (View Stats)
Sommuma...it's pretty damn cool to see how far the tuning has come since we were chompin at the bit for the release of the AP for the Gen1.
I've got more vacation time than I know what to do with this year. I believe a road trip to visit my niece in New Hampster is in order!
07 COSMIC BLUE MS3 GT
MadOzodi is offline   Reply With Quote
 Old 04-01-2014, 10:51 PM   #21
El Beaner's Avatar
Well, just sent off Revision B logs to Justin. Hoping all looks good and nothing scary. Saw a little KR but nothing I would say too scary.
Here was a Vdyno log Zdraveca did for me using my revision A logs. @Justin@Freektune Does this look about right to you? Waiting for him to do a Vdyno of the revision B logs(I don't have a windows PC so no Vdyno software)
 Old 04-02-2014, 12:51 PM   #22
El Beaner's Avatar
Here are Revision B numbers thanks to @Zdraveca
Looks like a slight decrease based on the Vdyno - not sure if that is right.
 Old 04-02-2014, 12:54 PM   #23
pfp22972's Avatar
Looks like a slight increase 5 or so whp/wtq over Rev A which pretty good with just some minor tweaks.
I need to PM Zdraveca to see what specs he's using to create the VD. Mine looks sort of wacky compared to these.
- FREEKTUNED -
 Old 04-02-2014, 01:00 PM   #24
El Beaner's Avatar
Well it looks like I had a slight decrease actually(I was looking at the maps backwards) Wonder why that is. Car feels better now vs A but overall power is lower? I know Vdyno isnot accurate but should have hopefully seen a slight increase over the 2 revisions
 Old 04-03-2014, 09:20 AM   #25
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Did you have someone in the car with you or have the hatch loaded?
On Order:
Coming Soon:
DIY Projects:
 Old 04-03-2014, 09:23 AM   #26
El Beaner's Avatar
No, I figure it was due to higher ambient air temps and quite a bit higher humidty vs the day the first logs were done.
 Old 04-03-2014, 09:29 AM   #27
So glad I no longer have to deal with those Texas summers. Absolutely Horrible.
 Old 04-03-2014, 09:32 AM   #28
El Beaner's Avatar
The heat I can deal wiht, the humidty is what gets you. Dry heat 95 degree day, not too bad. A north Texas 95 degree day can turn into a 105+ heat day when factoring the heat index.
 Old 04-03-2014, 11:42 AM   #29
I was more asking because your occupancy weight in the VD is listed as 380.
On Order:
Coming Soon:
DIY Projects:
 Old 04-03-2014, 01:08 PM   #30
El Beaner's Avatar
lol - nope, that is my fatass - I'm a big guy.
 Old 04-02-2014, 01:02 PM   #31
Probably just the differences in conditions during the logs.
Tapatalked
 Old 04-02-2014, 01:11 PM   #32
El Beaner's Avatar
Tapatalked
That's the only thing I can attribute it to. It was slightly warmer and humidity was higher vs Sunday night.
 Old 04-02-2014, 01:07 PM   #33
pfp22972's Avatar
My logs between the base and the revision are noticeably different as far as peak power is concerned. Each has this odd jump around 3800rpm when i put them in VD compared to most of the VDs I see posted here. Justin said my logs look great though so I'm not concerned. I just figured I didn't have the options set correctly in VD.
- FREEKTUNED -
 Old 04-02-2014, 01:18 PM   #34
That will make a big difference
Tapatalked
 Old 04-02-2014, 01:22 PM   #35
El Beaner's Avatar
Tapatalked
Oh I know, I'm waiting for Summer here when it's 100+ outside and it just kills the power output probably.
OverBoosted (04-02-2014)
 Old 04-02-2014, 07:24 PM   #36
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I had freek put in safe guards for our texas heat.
Justin@Freektune (04-03-2014)
 Old 04-02-2014, 09:40 PM   #37
El Beaner's Avatar
I'mhhoping the ots maps have that in mind.
 Old 04-03-2014, 05:03 AM   #38
That little bump in VD is due to the throttle plate. And the way VD interprets it. If you add accelerator pedal position and re log the VD will be smooth.
All my maps have that incorporated
PTE 6062
633HP/523TQ
El Beaner (04-03-2014), pfp22972 (04-03-2014), purpledrank (04-03-2014)
 Old 04-02-2014, 01:42 PM   #39
pfp22972's Avatar
Ugh...summer. Time to hibernate.
- FREEKTUNED -
 Old 04-03-2014, 08:56 AM   #40
So my second revision arrived last night and I've had a chance to drive around with it for a little while. Very noticeable difference: better boost tables, powerband is even smoother, maf's are dialed in, engine seems to function better all together. The car pulls like a freight train; I have to actively keep myself from speeding or else I'm 20 mph over without even trying.
Awesome work Justin. You will have all my business in the future and I'm looking forward to a full blown e85 tune.
2009 Mazdaspeed 3
Freektune OTS+
The Following 4 Users Say Thank You to purpledrank For This Useful Post:
Atticaz (02-04-2016), El Beaner (04-03-2014), Justin@Freektune (04-03-2014), OverBoosted (04-03-2014)
Page generated in 0.78364 seconds with 30 queries
