  • 1 Post By g00s3y
 Old 07-12-2014, 09:25 AM   #1
oOfactoryOo's Avatar
Posts: 107   (View Stats)
oOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond repute
Groaned at 6 Times in 1 Post
Default HPFP squeaking noise
Hey Justin. I am absolutely loving the tune. The car drives fantastic, and has the power right where I need it
https://www.youtube.com/watch?v=ZPKubctncp8
Apparently this squeaking noise is the HPFP. Peeps are saying that adjusting the HPFP demand can fix this. It happens on cold starts, and kicks in right around 1700 RPM. Do you have any experience with this issue? Can I fix it myself?
2013 CWP MS3 with Tech package
Cobb V3 // JBR 88RMM // Corksport SRI with TIP // Autotech Internals // UR Test Pipe
oOfactoryOo is offline   Reply With Quote
 Old 07-12-2014, 12:50 PM   #2
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
Hmm... I have been hearing this recently too... Keeping an eye on this thread to find out the outcome.
 Old 07-12-2014, 12:54 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
My Autotechs squeaked from the day I installed them. No harm ever came from it.
skeeter149 (07-12-2014)
 Old 07-12-2014, 01:07 PM   #4
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
I have like a chip at start up
 Old 07-12-2014, 01:11 PM   #5
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Cold Start Squeak on Throttle Tip in
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
PapaBruno (07-20-2014)
 Old 07-14-2014, 01:59 AM   #6
JayBeeL's Avatar
Posts: 34   (View Stats)
JayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to behold
Well I was just wondering myself...after reading all the threads done about this noise I feel WAY better... I definitely don't feel like the car or the logs are problematic but I was actually gonna get the car in for a checkup because of this...
JayBeeL is offline   Reply With Quote
 Old 07-20-2014, 12:48 PM   #7
kevdog's Avatar
Posts: 2,449   (View Stats)
kevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the world
My car makes the same exact noise. No problems here.
gtx3076 and shit
kevdog is offline   Reply With Quote
 Old 07-20-2014, 11:46 PM   #8
PapaBruno's Avatar
Posts: 942   (View Stats)
Mine makes it too. I just figured it was associated with the fuel pump being cold.
 Old 07-21-2014, 07:25 AM   #9
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
The bird chirp is from the relief valve....mine has been doing this forever on cold starts. I've been told if its ONLY on cold starts its nothing to worry about.
Silver 2007 Speed3 GT
 Old 07-21-2014, 09:41 AM   #10
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You can stop it from happening by lowering the commanded fuel pressure in those low rpm/low load situations in the HPFP tables. I've lowered mine to 1520psi, haven't heard anything, and still works properly.
PapaBruno likes this.
 Old 07-22-2014, 08:36 AM   #11
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
If you accelerate slowly, no boost, does it always kick in at the same RPM? If so, is it constant as revs increase? I'm having a weird squeal under those conditions, but it kicks in at 3200rpm when the engine is cold.
Sounds awful, squeals at any RPM above that with the same frequency. I can't tell if it's a mechanical sound or if it's air leaking from somewhere, but this sounds similar, so I'm curious if the sound continues as you accelerate slowly.
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
 Old 07-22-2014, 07:30 PM   #12
TIS
No, it only happens as the car drops in RPM at idle, on a cold start. My car starts at around 2100 RPM, then as it hits 1700 on the way down it makes the noise. If you watch the video, you can see that there is absolutely no revving going on. And then I do not hear it again until the next cold start........
 Old 02-20-2015, 08:27 AM   #13
tparker14's Avatar
Posts: 180   (View Stats)
tparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond repute
Anyone come across this noise?
https://www.youtube.com/watch?v=dSlZtgqpZQA
It happens during colds start (-15°C) or so. At first I was thinking fuel pump but sounds like it's coming from dash.
tparker14 is offline   Reply With Quote
 Old 02-20-2015, 09:22 AM   #14
razerer's Avatar
Posts: 168   (View Stats)
razerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond repute
Groaned at 8 Times in 4 Posts
Mine made a slight whine when my relief valve was on the verge of turning into a disaster. Worth a look in my option. When I replaced the RV my whine went away
Stupid app doesn't wanna play videos for some reason so I can't hear if it's the same noise
Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM
Cobb SoCal tuned
razerer is offline   Reply With Quote
 Old 02-20-2015, 09:37 AM   #15
tparker14's Avatar
It's not really a whine, it literally sounds like a duck quacking. Quite funny when people are walking by. But I'll take a look at the RV just to be safe
 Old 02-20-2015, 01:29 PM   #16
PapaBruno's Avatar
Someone say duck call?
https://www.youtube.com/watch?v=3pbUMXZvfi8
I get a quick squeek/chirp sound from what I believe are my HPFP internals, but usually only on cold starts when it's around 60 or below outside. But I think we've all deduced that it can be fixed with a couple map adjustments.
This is something I've not heard. Spencer seems to have a good theory.
 Old 02-20-2015, 10:53 AM   #17
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Mine does it too when it's really cold outside.
 Old 02-20-2015, 12:01 PM   #18
SpencerC's Avatar
Posts: 2,159   (View Stats)
It sounds to me like your spray nozzle pump for the window cleaner.
Weird squeaking noise? Ray Danger 2020 2010 MS3 - Suspension & Brakes 45 08-10-2015 08:12 AM
squeaking/creaking noise when cold mrkdspd MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 01-11-2015 06:48 AM
HPFP Releif Valve Noise [R]usty 2010 MS3 - Engine, Transmission & Driveline 11 10-25-2013 01:35 PM
What is this squeaking noise?! nycMS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 08-26-2013 11:41 PM
Squeaking noise when going over small bumps dread MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 01-12-2010 04:57 AM
Page generated in 0.40085 seconds with 34 queries
