 Old 06-06-2015, 08:00 PM   #1
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Default Load based vs inertia based dynos
I just spent some time reading the differences between dynojet and mustang dynos. As I understand it dynojets are inertia based and measure acceleration. Mustang dynos apply a load more to simulate real world conditions.
Based off what I read tuning on a dynojet could cause problems in real world driving.
I'm no expert just trying to understand the differences and why @Justin@Freektune; recommends using a dynojet to measure our cars.
Here is one of the articles I read. http://www.zerotohundred.com/newforu...rtia-dyno.html
 Old 06-08-2015, 04:24 PM   #2
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
To be honest, I am not a fan of roller dynos at all. There are too many additional variables ranging from wheel slip to tire pressure that can impact both the output and consistency of the curve.
IMHO, hub dynos are the most consistent in a majority of environments. They are load based and factor out complications associated with rotational mass. But results are inflated 6-8% since all work is evaluated without a 20 lb wheel attached. So for that reason enthusiasts tend to dislike them.
To be fair, most of us looking at the numbers don't care about bragging rights. We just want reliability in the measurements taken at baseline vs. modded.
09 CWP MS3 GT
Ownership & Build Thread
The Following 3 Users Say Thank You to Design For This Useful Post:
ALPINEST4RS (06-18-2015), Awal (06-08-2015), MD1032 (06-10-2015)
 Old 06-10-2015, 07:47 AM   #3
JgamB's Avatar
Posts: 2,566   (View Stats)
I spose it doesn't much matter as long as it shows gains while you're hunting MBT on Eth/Meth/PI etc. If you can return to the same dyno for future upgrades, it should give you a decent indication if you spent your money wisely.
I prefer to go get trap speeds and use weight/velocity/distance/DA and use a calculator with 10% DTL.
Design (06-10-2015)
Load based mystery EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 25 01-05-2013 12:32 AM
AP 2.10 maps: boost vs load based ericm979 MazdaSpeed 3/6 - ECU Computer Tuning 21 07-29-2012 02:22 PM
Load Based Map abiezerf MazdaSpeed 3/6 - ECU Computer Tuning 2 05-21-2012 03:10 AM
Load Based Map abiezerf MazdaSpeed 3/6 - ECU Computer Tuning 0 03-02-2012 01:11 PM
Load based throttle closing djuosnteisn 2010 MS3 - ECU Computer Tuning 8 11-29-2010 03:51 PM
Page generated in 0.24691 seconds with 22 queries
