| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
| Not Ranked : 0 score What we need now is for someone that will design a failsafe with hooks into the car to automatically reduce boost/ignition in a meth flow cutout condition. I imagine it wouldn't be rocket science to create something that would measure meth flow and in the event of a failure, send something to the EBCS that could instantly and automatically force boost cut. Since we don't have a standalone system, we really can't get a signal INTO the ECM to do anything so I think ignition is out (unless aftermarket ignition). I can't imagine it would be too crazy to intercept ECM _> EBCS signal and inject a different signal to EBCS to pull boost in meth flow cut conditions. Who wants to make some $$$?
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: |
Dano mentioned his was not particularly reliable, but maybe Faeker's idea would be a good substitute. Thanks Faeker. btw. And @dale_gribble; I hope that I didn't come off jerky in response to your post above. I'm just not a fan of water in the mix. IMO, it may be worth experimentation for long, sustained periods of wot operation since it is said that h20 has a greater effect on cooling egt's vs. bat's, but for street use and an octane bump, 100% meth is best. If h20 works for you, that is awesome too. | |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
| Not Ranked : 0 score Water has an octane of infinity...........
| The Following User Says Thank You to Easter Bunny For This Useful Post: | rfinkle2 (09-08-2014) |
(Thread Starter) | Not Ranked : 0 score That may be true, but it is not a fuel. In my experience, a high concentration of water eats up nozzle size, lessens the charge cooling effect of the methanol and only carries with it relative safety and cost savings vs. running 100% meth. I have tried every variation of h20 to meth, creeped every forum imagineable in terms of meth injection results and 98% of the people running meth kits will tell you that 100% meth is the best performer when looking for the octane bump needed for running aggressive ignition advance. |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
As seen in the wiring diagram, the meth controller taps into the EBCS signal. If it detects a low or high flow condition, it opens the wastegate and dumps boost. I actually caught a log of a high flow condition. It was pretty smooth when it happened, too. It wasn't like running into a brick wall or anything. It also has some added flexibility in that you can tie in other failsafes, as well. For instance, if the ECU has map switching capabilities, it can trigger that and change maps on the fly based on the condition. @rfinkle2; My apologies if I'm cluttering things up. I can delete this if you find it irrelevant to the original purpose of your thread.
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges | |
| The Following 6 Users Say Thank You to skeurton For This Useful Post: | faeker (09-03-2014), Mauro_Penguin (09-04-2014), Mistersix (09-08-2014), resilientone (01-06-2016), rfinkle2 (10-07-2014), torquemaniac (10-02-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f699/methanol-injection-info-176351/ | ||||
| Port Injection WMI, help | This thread | Pingback | 04-06-2015 01:17 PM | |
| w/m injection questions | This thread | Refback | 03-20-2015 12:03 PM | |
| Best way to take meth | This thread | Pingback | 03-20-2015 11:43 AM | |
| Meth failsafe solenoid placement | This thread | Pingback | 03-20-2015 07:29 AM | |
| methanol injection MAF failsafe | bigmike | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 12 | 07-25-2015 11:00 AM |
| Methanol Direct Injection | phate | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 290 | 10-01-2014 09:34 PM |
| Pre-turbo methanol injection | KoukiS14 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 26 | 10-19-2009 04:20 PM |
