| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Aug 2015
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hello, I am a new mazdaspeed 6 owner and I'm looking to pick up a Cobb accesport with a few other supporting mods. Is I would like to have you tune the car for me. Now and as I progress with it. So what should my next step be ? |
| Not Ranked : 0 score Try purchasing a tune through his website.
(Thread Starter) | Not Ranked : 0 score That's the plan, but I don't know what to purchase or how he's going to set it up. He should probably know my plans and then he can sell me the right stuff. |
![]() Join Date: Apr 2014 Location: san diego CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score He tunes for what you have, not what you're going to have in the future. Unless you plan on buying everything in one go and installing it very soon.
__________________ 2008 ms3 |AT HPFP | Corksport SRI/TIP | JBR 70d RMM | Ebay catless test pipe | Corksport Catback exhaust |
(Thread Starter) | Not Ranked : 0 score Yes @chriswillrise; I am ordering my first set of parts now and when they come in, I am going to install them all at the same time. Then the car is going to stay that way until I learn more and spend the winter planning the next step. I have emailed him already tho, so I'll see what happens there. |
![]() Join Date: Oct 2011 Location: Tijeras, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Justin is great. However, just starting the mod process you should stick with the basics and use the Cobb standard tunes. Then decide over the winter what you want to do and if you are doing something that requires a special tune (likely), then get Justin involved after you have installed the new mods.
__________________ Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa MS3 Mods Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP Corksport TMIC CP-E full HPFP with warranty All Freektuned with two tunes, one for 15psi and another at 20psi |
(Thread Starter) | Not Ranked : 0 score OK @patABQ; I just assumed that running the OTS Cobb tune would be a negative. Especially since I'll be relying heavily on the tune to give me the stability and sqeak out all the power possible with the first set of mods I'm going to install. If Justin's recommendation is to run the standard Cobb tune until I have the big turbo ready to go in then that's what I will do I suppose. I've just gathered that these cars can be real picky and I don't want to upset the balance. |
![]() Join Date: Nov 2012 Location: Leominster Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,003
| Not Ranked : 0 score Buy the accessport from his website, freektune.com and get an ots+ map from him for now. |
| The Following User Says Thank You to brandonnicholson For This Useful Post: | Justin@Freektune (08-25-2015) |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Step one get accessport. Step two install mods, and hpfp internals better be on that list. Step three order tune, during which time you are required to tell Justin what mods you have. Step four flash said tune and smile everyday
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
| Not Ranked : 0 score It really depends on the mods. But, do what brandonnicholson suggests and everyone is happy.
![]() Join Date: Dec 2014 Location: Orlando Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score whats the big difference between the the $200 Freektune and the $50 Stratified tune since they both tune for your current mods?
__________________ Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds |
$200 Freektune - multiple revisions to dial in the tune. $50 Freektune - base map + 1 revision.
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
The $200 tune is a full custom tune I offer a $75 tune which is similar to the flash tune, but you also get a revision to dial in the tune a step further.
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
| Not Ranked : 0 score Ok cool might check you out when im certain i dont have Compression problems.
| Not Ranked : 0 score Jump on it with Justin. But you have to have the "ass mods". Sorry - had to do it. "then as you ass mods we can discuss what the best map options for you are. "
| The Following 2 Users Say Thank You to patABQ For This Useful Post: | Easter Bunny (08-25-2015), Justin@Freektune (08-25-2015) |
| Not Ranked : 0 score If you order the AP through me, I will put a base map on there for the mods you will have on there when you add the AP. That is my OTS plus map, and then you get a revision to dial it in a little further. That comes free with the AP purchase, then as you add mods we can discuss what the best map options for you are.
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway Last edited by Justin@Freektune; 08-25-2015 at 09:17 AM. |
| The Following User Says Thank You to Justin@Freektune For This Useful Post: | Easter Bunny (08-25-2015) |
| Freektune or no? | Castillo817 | 2010 MS3 - ECU Computer Tuning | 37 | 02-17-2015 07:04 AM |
| Freektune | jseams | 2010 MS3 - ECU Computer Tuning | 14 | 12-02-2013 11:48 PM |
| Freektune and BT = Better MPG? | NCspecV81 | 2010 MS3 - Big Turbo Builds | 34 | 09-11-2013 11:27 AM |
