 Old 10-22-2015, 09:45 PM   #1
Flawless's Avatar
Posts: 190   (View Stats)
Flawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond repute
Default Mustang Dyno, Freek e44 tune
Hey all, got a real dyno done today, curve seemed a little off so I wanted to post it. Mustang dyno numbers read 263/333 (and it was a fight to get it up there, BATs were really bad, but those numbers came out at 105F).
Curve seems to have a nose dive in it at 4k rpm and idk why. I've posted my best dyno lines and my ap log for the relevant rpms from the same run. They all had this dive though.
Is this something that I need a retune for? Those numbers seem a little low for my mods . . . even on a mustang dyno.
Korn Killer
2012 Black Mica MS3 || Cobb SRI || Cobb TIP || Freek E44 tune || Cobb FMIC || Autotech Internals || JBR SSP || JBR RSB || JBR Trilogy Mounts (RMM, PMM, TMM) || Koni Yellows || H&R Sport Springs || UR Test Pipe || UR Downpipe || GFB BPV || JBR Solid Shifter Bushings || RPF1 17x9 +45 245/40/17 RE71Rs
Flawless is offline   Reply With Quote
 Old 10-23-2015, 02:13 PM   #2
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Can you post the vdyno of the same log too just for comparison. Mine dives down too but not that hard. Could be error on part of the loading of the dyno too
The line up:
 Old 10-23-2015, 02:30 PM   #3
Flawless's Avatar
The vdyno comes out completely retarded, like 500whp, it starts really high, kinda slopes gradually down to 400whp at 4krpm and then slowly back up to 500whp at 7krpm.
Korn Killer
 Old 10-23-2015, 04:35 PM   #4
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
What gear was the dyno pull done in? Did you enter the correct gear in vdyno?
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
The Following User Says Thank You to gdawg25 For This Useful Post:
speedfreak44 (10-23-2015)
 Old 10-23-2015, 04:38 PM   #5
I feel like the dyno was not setup correctly...and on that note your vdyno isnt either. Post the log file not a screenshot and let someone run it and post the correct vdyno
The line up:
The Following User Says Thank You to speedfreak44 For This Useful Post:
speed23 (10-23-2015)
 Old 10-23-2015, 04:56 PM   #6
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
Assuming that Log was on the dyno, and the temp being at 105 the fan did a GREAT job at keeping your bats down, where you spraying iced water?
Mustangs Dynos are known to read on low side too
 Old 10-23-2015, 05:16 PM   #7
Flawless's Avatar
Well it was 50F out . .. so I'm not super impressed by the bats. And I'm not effin kidding about the vdyno, what I posted was the REAL dyno, here's the vdyno from that info. Reading kids, reading.
Korn Killer
 Old 10-23-2015, 06:00 PM   #8
Cyclops's Avatar
Posts: 290   (View Stats)
Cyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the world
Dyno pulls don't register correctly with VD
2008.5 Mazdaspeed 3 GT True Red
BNR S3. HTP Full 3.5" Intake. Self Ported Intake Mani. CorkSport Catless DP. UR Test Pipe. CXRacing Piping w/ TR8. GFB Respons BPV. Autotech HPFP. Stratified 3 Port EBCS. Stratified Guardian Angel. 3 Bar MAP Sensor w/ PnP Harness.
Cyclops is offline   Reply With Quote
 Old 10-23-2015, 06:04 PM   #9
Cevaes_64's Avatar
Thanks for this, I trimmed mine from when i dynoed and i had like 600 plus on VD, 200 more than real dyno
The Following User Says Thank You to Cevaes_64 For This Useful Post:
Cyclops (10-23-2015)
 Old 10-23-2015, 06:15 PM   #10
Flawless's Avatar
That's what I assumed, cuz resistance is off. Hence why I didn't even bother to post it to begin with
Korn Killer
 Old 10-23-2015, 06:22 PM   #11
Clutch is slipping?
 Old 10-23-2015, 06:47 PM   #12
Flawless's Avatar
Clutch is slipping?
Seems really unlikely, it doesn't slip in 6th at all, no smell, no noticeable loss ever.
Korn Killer
323whp with a FrEeK TuNe! pwned 2010 MS3 - Dyno Sheets/Discussions 37 06-21-2013 05:55 PM
My fully bolted pre-flash, no tune dyno on a mustang gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 40 05-31-2009 10:02 PM
Page generated in 0.32295 seconds with 25 queries
