Like Tree26Likes
 Old 02-21-2016, 05:57 PM   #1
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Originally Posted by Atticaz View Post
I am digging the size difference! Got her all installed and slumming it with a Cobb Stage 2 OTS, for now. not digging the power loss though. anxiously awaiting my Freektune base map.
From the looks of the sludge shown in the turbo pic, its time for an OCC?
I'll have base map to you tomorrow morning once I'm back at it
Snowing likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Atticaz (02-21-2016)
 Old 02-22-2016, 06:01 PM   #2
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
There's no point to go overkill on intake. You lose low flow resolution (idle, off idle) resulting in a rough idle and for example instead of having 0-4.5v of resolution, you only have 0-4v on MAF sensor. Even Bnr s3 and cs turbo can't outflow 3" intake. 3" is a good size.
just because you have a smaller weiner Dale is no reason to hate on the 3.5 guys.
#girthmatters
ericrapp0507@gmail.com is offline   Reply With Quote
The Following 3 Users Say Thank You to ericrapp0507@gmail.com For This Useful Post:
dale_gribble (02-22-2016), MS3Shadow (02-22-2016), robbspeed (02-22-2016)
 Old 02-20-2016, 08:12 AM   #3
I went to a 3.5in the first time and I don't have rough idle. Later I'll be upgrading the turbo.
sent from my Nexus 6P
 Old 02-22-2016, 07:06 PM   #4
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
Continued over in my Full Tune Thread: From OTS + to Full FREEKTUNE
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 02-20-2016, 08:20 AM   #5
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I ran 3.5" htp for a while and was having idle issues and it kind of stumbled off idle. That cleaned up with 3", plus my maf resolution went from max 4.2v to 4.5v, so it was using more of the table. I was able to dial in afrs a little better.
MINI H1 6.0 - CAR LED TAILS
ericrapp0507@gmail.com (02-22-2016)
 Old 02-20-2016, 08:32 AM   #6
It may be because of the Honeycomb straightener that HTP uses for their intakes.
I had issues using intakes that uses those and I have 3.5in with the two straight fins as the straighter like JBR and Corksport has for their intakes.
 Old 02-22-2016, 06:11 PM   #7
The AEM Mazdaspeed also employed the two fin to reduce turbulence.
The honey comb from HTP is not a design that makes a ton of sense to me.
Is the stock MAF sensor something that should be replaced once the ID is over 3" ?
 Old 02-22-2016, 09:13 PM   #8
Yeah, I have heard that you can special request a HTP intake to have those two fins as a replacement of the honeycombs.
What can you replace it to? I'm still running my stock MAF.
 Old 02-21-2016, 03:40 PM   #9
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Skip the occ and go bnr
The line up:
 Old 02-21-2016, 03:54 PM   #10
Atticaz's Avatar
Wouldn't I still need the OCC?
 Old 02-21-2016, 03:55 PM   #11
An OCC is always a good thing but the crap in the turbo is the turbo leaking as well. Plan for both eventually
Atticaz and Snowing like this.
The line up:
The Following User Says Thank You to speedfreak44 For This Useful Post:
 Old 02-21-2016, 04:01 PM   #12
Snowing's Avatar
Posts: 78   (View Stats)
Snowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud of
Groaned at 3 Times in 1 Post
Just get the bnr also, speedfreak, when will you have Dyno numbers for us??
2012 Mazdaspeed 3
CS SRI + TIP - CS TMIC - CS Catted DP - Autotech HPFP Internals - Denso ITV22
Purple Drank Tune in process
Snowing is offline   Reply With Quote
 Old 02-21-2016, 04:36 PM   #13
Hoping to have it installed tuesday. My work schedule sucks
The line up:
 Old 02-21-2016, 05:57 PM   #14
Atticaz's Avatar
Woo hoo. The Cobb power drain. Sucks. Lol. Thanks man!!
Snowing likes this.
 Old 02-21-2016, 06:04 PM   #15
Snowing's Avatar
Excited to see the difference of the three inch intake...and the full tune!
Atticaz likes this.
2012 Mazdaspeed 3
 Old 02-22-2016, 09:16 PM   #16
Atticaz's Avatar
It's the MAP sensor that need to be upgraded, once you start hitting higher boost pressures, correct?
 Old 02-22-2016, 09:31 PM   #17
Yeah, since the stock one only reads to 22.5psi. I'm going to get the Corksport 3.5 MAP sensor when it's time.
Atticaz likes this.
Justin@Freektune (02-23-2016)
 Old 09-25-2016, 11:35 AM   #18
Speedy955's Avatar
Posts: 43   (View Stats)
Speedy955 is just really niceSpeedy955 is just really niceSpeedy955 is just really niceSpeedy955 is just really niceSpeedy955 is just really nice
I was searching high and low for a v dyno of his base map. I flashed mine and was getting ~230 whp. I know v dyno numbers don't matter much, but that seemed extremely low.
Good to see the revision is where the power comes from.
Speedy955 is offline   Reply With Quote
 Old 09-25-2016, 02:19 PM   #19
Atticaz's Avatar
I was hitting 234whp on my base. In the end you should be around 270ish on the OTS+, in cool weather, depending on your mods. Have patience. I felt the same way. I have since added more mods and went E33 tune and am rockin' 309whp on my last vdyno.
Always chose the same smooth strip of road, start at the same RPM and start at the point in the road, when doing datalog for VD. You'll get the best results. I had to switch my logging road recently, as I have to do all 4th gear logs or roll into the throttle in 3rd, as I always seem to get a bit of slippage, in 3rd, if I stab the gas pedal. Throws off the VD plot.
local tune or inet tune RACER_X Gen2 MS3 General Discussion 19 11-13-2014 02:05 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
WOT-Tune (My experience) akbrazil 2010 MS3 - ECU Computer Tuning 3 07-09-2012 08:09 PM
Page generated in 0.40375 seconds with 28 queries
