Like Tree61Likes
 Old 05-11-2016, 12:23 PM   #81
Kevopg's Avatar
Posts: 120   (View Stats)
Kevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to all
Yea I only have "A" he must of not attached it.
Kevopg is offline   Reply With Quote
 Old 05-11-2016, 12:31 PM   #82
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
Are you using gmail? Sometimes the attachment is hidden. So stupid.
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 05-11-2016, 01:05 PM   #83
Kevopg's Avatar
Yea but I spent a couple hours trying to make it pop up. How did you make yours show up?
 Old 05-11-2016, 01:07 PM   #84
Atticaz's Avatar
I actually forgot. It works now. Try forwarding Justin's email to yourself. See if it shows up then. I hate what Google did to gmail.
 Old 05-16-2016, 10:17 AM   #85
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
Pretty much wrapped up my 91 tune on the S4 with Justin. Cali 91 strikes again and we had to dial timing back because of knock. This thing is fun as hell to drive and the boost curve feels so damn smooth compared to the k04. I basically picked up 30hp and 30tq with the S4.
Atticaz likes this.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
 Old 05-16-2016, 10:21 AM   #86
Atticaz's Avatar
307 on an S4? DAMN, 91 Octane!!!!! Shit. That's gotta be a vdyno thing. You gotta have more than that. I have been wanting a S3 and I'm in AZ, with only 91. Hmm.
 Old 05-16-2016, 10:30 AM   #87
iamareios's Avatar
Yeah the 91 gas out here is just so damn unpredictable station to station so its best to play it on the safer side. I travel a lot. I'm everywhere and i cant necessarily fill up at the same shell gas station that i know has "good" gas. Oh well. Onto my E85 toon! Knock wont stand a chance!
Atticaz likes this.
 Old 05-16-2016, 10:33 AM   #88
Atticaz's Avatar
Default From OTS + to Full FREEKTUNE
I'm in the same boat. I drive a lot. I don't have E85 in my near future. I just like to fill up and go. I not looking to be he fastest, also. Hmm. I may just go S4 then, after this post.
How was the S4 install?
 Old 05-16-2016, 10:44 AM   #89
iamareios's Avatar
The s4 is fully spooled by 3900rpm according to my logs. I'd say the s3 is a tad bit quicker. But not by much. Both turbos flow much better than the k04 and you can definitely feel it. They keep on making power all the way to redline where the k04 falls flat. The install was a piece of cake. If you remove the EGR valve, you wont have to remove the exhaust manifold which saves a ton of time. Also if you already have a down pipe installed, that helps too as removing the stock down pipe is a PITA. It can be done in a day but over a weekend is best to give you time. No fab of coolant lines or oil lines was necessary. Honestly the only sticking point i had was because i bought the turbo used, it didn't come with new down pipe studs and nuts. THAT was a b*tch extracting them and reusing them! GO FOR IT!
Atticaz likes this.
The Following 2 Users Say Thank You to iamareios For This Useful Post:
Atticaz (05-16-2016), Jakeypoo (05-20-2016)
 Old 05-16-2016, 10:46 AM   #90
Atticaz's Avatar
All great info. Thanks!
 Old 05-16-2016, 10:11 PM   #91
ryguy 3's Avatar
Posts: 353   (View Stats)
That does seem kinda low, I hope that's an issue with v dyno since I have an S4 on the way. Lol
Here's my stock turbo on an E85 flash tune.
 Old 05-17-2016, 07:53 AM   #92
iamareios's Avatar
Attachment 225369
Thats pretty much what i had on the k04 with a e33 blend. I'm happy with the 310 on shitty 91. Of course if it was 93, it could have been an extra 10-20hp. I'm looking forward to starting my e33 tune soon.
 Old 05-17-2016, 07:57 AM   #93
ryguy 3's Avatar
Yeah I guess it would be nice to have that on pump gas, you still on the stock block?
 Old 05-17-2016, 08:13 AM   #94
PurplFox's Avatar
Posts: 352   (View Stats)
PurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the world
Look at both your vd's
one is in 3rd gear the other in 4th, and almost an 1 inch difference in tire height. Hard to compare.
Atticaz likes this.
Cobb AP
JBR Tru-3.0
CNT Catted DP "Gutted"
CNT Catback
JBR 88 RMM DM PMM and TMM
3 port, Turbosmart dual port
FReaktune E33
PurplFox is offline   Reply With Quote
The Following User Says Thank You to PurplFox For This Useful Post:
iamareios (05-17-2016)
 Old 05-17-2016, 09:13 AM   #95
iamareios's Avatar
Yeah and i don't plan on building until i need to. The engine is running strong at 84k miles. I was around 272hp at a similar psi on the k04.
Atticaz likes this.
 Old 05-17-2016, 09:19 AM   #96
Atticaz's Avatar
That's about where I am now on my K0snore. Mine is at 143k and still running strong.
 Old 05-18-2016, 04:56 PM   #97
iamareios's Avatar
Welp. Thats how you do it. E33 base map!
 Old 05-18-2016, 05:13 PM   #98
Atticaz's Avatar
Nice man. Good numbers. What's up with the log numbers? I have a v2 also and my pedal position always reads 99 when I'm at WOT. And my open loop reads as .16, where your reads 0. Just found that odd and made me curious and to the difference.
I cont wait to be in the 300's.
 Old 05-18-2016, 06:51 PM   #99
iamareios's Avatar
Log numbers? As in 1,2,3 like what i posted above? Meh i have ocd and delete the logs in my AP after each revision lol so they always start from 1 for Justin.
 Old 05-18-2016, 09:30 PM   #100
Atticaz's Avatar
I do that too. But for me. I was meaning how your pedal position never goes to 99 and your LTFTs read 0, while mine read .16.
 Old 05-18-2016, 09:40 PM   #101
iamareios's Avatar
Gen 2, Gen 1 difference?
 Old 05-18-2016, 09:44 PM   #102
Atticaz's Avatar
That's probably it.
 Old 05-20-2016, 03:22 PM   #103
iamareios's Avatar
Revision C e33 blend
Are you convinced with e85 yet? Lol
Sent from my SM-G935T using Tapatalk
 Old 05-20-2016, 03:24 PM   #104
Atticaz's Avatar
Yep. Gonna wait til I get my S3 for E tho.
 Old 05-20-2016, 03:29 PM   #105
ryguy 3's Avatar
How many miles does your car have?
 Old 05-20-2016, 03:30 PM   #106
Atticaz's Avatar
143+k and running like new.
 Old 05-20-2016, 03:30 PM   #107
iamareios's Avatar
I just passed 84k
Atticaz likes this.
 Old 05-20-2016, 03:31 PM   #108
Atticaz's Avatar
I just passed 84k
It's all about how you treat her. I bought mine at 93k.
iamareios likes this.
 Old 05-25-2016, 07:25 AM   #109
Tifosi42's Avatar
Posts: 179   (View Stats)
I just finished my pump 93 tune with Freektune, it took 5 revisions from the OTS and I have to say there definitely is a difference in power from the OTS to being fully Freeked. The car pulls hard and strong with no drivability issues whatsoever which is important as my car is daily driven. I would definitely recommend going from Freek OTS to a full tune once your at a point in your mod process where you won't be adding more go fast parts. Now for the in tank methanol tune!
Atticaz likes this.
BNR S3 - FREEKTUNED on E33
Tifosi42 is offline   Reply With Quote
 Old 06-08-2016, 03:42 PM   #110
Atticaz's Avatar
When my tune was completed, BAT's were about 120 max. Car was doing great, feeling great, running great. Then it heated up to 117 outside!!! KR started getting crazy when BAT's reached 140-150. One day it hit 5.96 and held for the last half of my 4th gear wot pull. It spiked, but then started dropping. It had dropped to 1.4 by the time I let off.
I have not seen it that high ever and never again since then. But, I was still getting wacky KR numbers in the 2's very frequently in part throttle and as high as 2.5, with 140+ BAT's.
I was told by a local Nator member to pop a gallon of E85 in and see what happens. So I did. KR disappeared. There were only few blips of .3's and .7's here and there. After 25 or so miles of testing her out; easing into the power, I got brave. I reverted my tune to an earlier revision, that had more boost and blasted out 3 pulls with High BATS... two 4th gear and one 3rd. one blip of .3 in all three runs!! Fuck you 91 Oct!!
I did a morning wot pull the next day. I was VERY PLEASED. the car has been a joy to drive. E is magical. Now I want the E85 tune. You guys weren't kidding.
***Log names contain the starting BAT numbers. The VD is from the morning run.
Side not: Yesterday, when I got home, I noticed my coolant reservoir was bubbling like crazy. I'm pretty sure its the high temps and the crack in my reservoir that's doing it. I have new reservoir coming and used JB Plastic Weld to, hopefully, hold it over. waiting for it to cure. Fingers crossed that the head gasket isn't toast.
I have no smoke, care has full power (evident by VD, below) and cylinders are dry.
The Following 2 Users Say Thank You to Atticaz For This Useful Post:
robbspeed (06-08-2016), Tifosi42 (06-08-2016)
 Old 06-08-2016, 04:15 PM   #111
Omega's Avatar
Posts: 441   (View Stats)
Lol now you finally see why I kept trying to convince you!
Atticaz likes this.
2006 Super Clean BCM MS6
 Old 06-08-2016, 04:19 PM   #112
Atticaz's Avatar
I'm shedding my noobish ways. Curious form when I get this tune... How exactly do you go about filling up, to make sure you have the correct mix?
If the tank is about empty to put the 4 gals of E85 in first, correct? And what if you are almost empty but have a 1/4 or 1/2 tank? How will I know how much to mix, without having to go full-on math wiz?
 Old 06-08-2016, 04:33 PM   #113
PurplFox's Avatar
An e time will net you much closer to 300 without fear of knock I cant wait to finish my 93 just to get back on the e
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
Atticaz (06-08-2016)
 Old 06-08-2016, 04:33 PM   #114
Omega's Avatar
There's fuel mix cheat sheets on the forum. You'll have to know how many gallons you can fit typically you just fill up when you're low. Start experimenting now with regular and write down how many gallons you can put in at different intervals.... Don't ever expect to top off on an e85 tune but you can get real close
 Old 06-08-2016, 04:47 PM   #115
Atticaz's Avatar
Got 'em. Fuel mix cheat sheets
 Old 06-09-2016, 04:07 AM   #116
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Groaned at 16 Times in 7 Posts
Default touch up tune
Hey guys question currently running e50 mix withe the ets top mount pushing about 360whp
Will a tr8 fmic with a rich up tune give me more power or should I just stay where I am?
Mazd1222 is offline   Reply With Quote
 Old 06-09-2016, 06:24 AM   #117
PurplFox's Avatar
That would depend on if your having issues with heat soak.
lot of info left out to make that decision
Atticaz likes this.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 06-14-2016, 08:47 AM   #118
iamareios's Avatar
Hell yeah man! Glad you jumped on board the E train haha! I just finished up my e33 tune with Justin and the car roasts tires gears 1-3. We had to switch to 4th gear logs which is difficult to do here in san diego at speeds of 105+ Fortunely i have 4 stations near me with E85 and i recently picked up a 5gal gas can to load up on so i always have it on me. My 91 tune is so damn conservative compared to my e85 tune. I'm addicting to E! I'm thinking of picking up a new exahust manifold and waiting on details about damond motorsports intake manifold adapter plate.
Atticaz likes this.
 Old 06-14-2016, 09:09 AM   #119
Atticaz's Avatar
I'd love to see your final revision vdyno pull, if you have one.
I'm excited for my E33 tune. I need to do a few repairs first though.
 Old 06-14-2016, 02:58 PM   #120
McD_nasty's Avatar
Posts: 369   (View Stats)
McD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the worldMcD_nasty is the leader of the world
I'm moving back to Cali starting Friday. I feel like I'll have to do like an 91+e40 blend just get the same power I have with a 93 tune. But I'm in the same boat..can't wait to get some .
Atticaz likes this.
#BaseCrew.
McD_nasty is offline   Reply With Quote
Freektune or no? Castillo817 2010 MS3 - ECU Computer Tuning 37 02-17-2015 07:04 AM
Freektune jseams 2010 MS3 - ECU Computer Tuning 14 12-02-2013 11:48 PM
Freektune and BT = Better MPG? NCspecV81 2010 MS3 - Big Turbo Builds 34 09-11-2013 11:27 AM
My Freektune atvfreek 2010 MS3 - Dyno Sheets/Discussions 12 02-19-2012 08:01 AM
Page generated in 0.58809 seconds with 29 queries
