  • 1 Post By Omega
 Old 03-26-2016, 08:27 PM   #1
Me2speed3's Avatar
Posts: 180   (View Stats)
Default ots + or full tune?
I bought my car and only know some of the parts on it, for instance I know Cobb catted dp and cobb sri/tip, autotech hpfp interals, ap V3, and it does have an aftermarket tmic... the last one is the one that bothers me. If I were going to get a tune from you guys, would I have to jump right into the full tune since I don't know which tmic it is or is knowing that it is an aftermarket tmic enough? Will the pressure drop difference between stock and different aftermarkets present a problem unsolveable in the one revision of ots+?
sorry if this has been asked before, but I wasn't able to get any hits through search.
thanks
 Old 03-26-2016, 09:09 PM   #2
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
thanks
Dude you're basically fully bolted, get the full tune fuck ots you will be much better off.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following User Says Thank You to JakeMS3 For This Useful Post:
Me2speed3 (03-26-2016)
 Old 03-28-2016, 05:19 PM   #3
Omega's Avatar
Posts: 441   (View Stats)
full tune, don't look back feels much better.... I had an aftermarket TMIC and went OTS+ w/o issues. Any aftermarket TMIC should flow similarly on a k04 with about the same amount of pressure drop minus a very small variance.
Freek's OTS+ is a basemap + one revision (so it still is meant for your car) but you just won't get any timing adjustment, boost levels I think were slightly lower as well... Just get the full tune, it feels much better IMO.
Me2speed3 likes this.
2006 Super Clean BCM MS6
Freek OTS or full tune Bug2110 2010 MS3 - ECU Computer Tuning 13 05-28-2015 08:26 AM
Tune needed only for full TBE? Speedstick 2010 MS3 - Engine, Transmission & Driveline 28 12-08-2010 08:19 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 06:36 PM
Cp-e Full Control Flash w/o standback & tune? steven88 MazdaSpeed 3 - Engine, Transmission & Driveline 0 07-10-2009 10:32 AM
Cp-e Full Control Flash w/o standback & tune? steven88 MazdaSpeed 3/6 - ECU Computer Tuning 57 07-09-2009 11:53 PM
Page generated in 0.25189 seconds with 22 queries
