 Old 10-14-2016, 10:43 PM   #1
MS3VT23's Avatar
Posts: 1   (View Stats)
MS3VT23 is an unknown quantity at this point
Default Planning for FreekTune
I have a 2012 speed 3 with a few basic bolt ons and am planning for a freektune. A 3 inch jbr intake, egr delete, hpfp internals, atp catless downpipe, forge bpv, JBR 88A motor mount, grimmspeed ebcs and Cobb access port. My future plans are a cat back exhaust, bnr s4, fmic, pcv plate, 3 bar map sensor, injector seals and possibly race headers. I plan on purchasing a dyno tune from freektune. I'm wondering if anyone could share knowledge if these mods should be suitable for a s4. Any other things I should do in preparation for this build?
MS3VT23 is offline   Reply With Quote
 Old 10-15-2016, 08:24 PM   #2
mrboostman's Avatar
Posts: 101   (View Stats)
mrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to all
All of those mods look fine for an s4. I have a freektune and really like it. If you have access to e85 you should use a blend for more power. I am using 4 gallons of e85 per tank
2008 MS3 GT, Fully Bolted, Cobb AP V3, TR8 FMIC, JBR Piping, JBR 3.5 Wide Path, Autotech Internals, CPE Stage 2 Rear Motor Mount, CNT Catless DP, CNT Cat Back, 51R Battery Box, Cobb Short Shifter, Enkei RPF1's, Koni Yellows, GTX3076R, Freektuned.
mrboostman is offline   Reply With Quote
 Old 10-17-2016, 09:34 AM   #3
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
Make sure you have new plugs gapped to .026-.028 and absolutely no boost leaks.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
FSR Freektune day wolfpack92054 FREEKTUNE 0 01-28-2016 05:46 PM
Freektune or no? Castillo817 2010 MS3 - ECU Computer Tuning 37 02-17-2015 07:04 AM
Freektune jseams 2010 MS3 - ECU Computer Tuning 14 12-02-2013 11:48 PM
Freektune and BT = Better MPG? NCspecV81 2010 MS3 - Big Turbo Builds 34 09-11-2013 11:27 AM
Page generated in 0.23637 seconds with 22 queries
