Like Tree4Likes
  • 1 Post By byzantines2000
  • 1 Post By WAMBUSHHHH!
  • 1 Post By Justin@Freektune
  • 1 Post By Thor Hammer
 Old 12-06-2015, 01:54 PM   #1
byzantines2000's Avatar
Posts: 18   (View Stats)
byzantines2000 will become famous soon enoughbyzantines2000 will become famous soon enough
Default preferred bcs?
I snapped the nipple off the stock bcs during a short ram intake insall because it made me feel manly and grew my chest hair out a lot, but now I need to buy a new one. Ive been reading that I'll need a tune with the new bcs and I was wondering what you guys prefer in terms of dealing with the solenoids, (easier to work with, faster, etc)
my mods are lame and its kind of shitty that i need to make this my next mod already but i dont think i much of a choice.
mods are AP, sri, inlet pipe, and hpfp upgrade I was hoping to get a freektune as they get a lot of positive reviews.
Justin@Freektune likes this.
byzantines2000 is offline   Reply With Quote
The Following 2 Users Say Thank You to byzantines2000 For This Useful Post:
Code Monkey (09-23-2018), Justin@Freektune (12-09-2015)
 Old 12-06-2015, 01:58 PM   #2
Based on your post it sounds like you dont already have a tuning solution. If that's the case it may be best to go VIP and try to buy a used stock one.
 Old 12-06-2015, 02:01 PM   #3
I was thinking about buying a OEM one, but the plastic nipples are weak and I would rather just get something that I can keep.
 Old 12-06-2015, 03:04 PM   #4
Most of the plug and play ones use the same solenoid so just look for the best price.
 Old 12-06-2015, 03:23 PM   #5
Do the cobb stage ots maps play well with them? I was under the impression that I would need a tune to control boosting.
 Old 12-06-2015, 05:03 PM   #6
I have no idea other than it needs a tune since it works differently than the stock one.
 Old 12-06-2015, 05:31 PM   #7
btstarcher's Avatar
Posts: 4,852   (View Stats)
I would just get an OEM one at this point. Mine has lasted 290k miles without issue; just be more careful.
SnailTune in progress
The Following 5 Users Say Thank You to btstarcher For This Useful Post:
Boost_creep (12-06-2015), macdiesel (12-06-2015), robbspeed (12-06-2015), Vansquish (12-06-2015), WAMBUSHHHH! (12-08-2015)
 Old 12-08-2015, 02:10 PM   #8
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
As added advice that was given to me way back when I started to mod...if you're having issues with getting the hose off of the solenoid, make a small incision vertically on the hose to help loosen it and it should slide right off. The hose itself is long enough to give up an inch or two and I think some even come with replacement hosing soo its easier to cut and just be done with it rather than have to buy an entire BCS unit because you hulk handed it.
btstarcher likes this.
 Old 12-08-2015, 02:33 PM   #9
Yeah, I'll have to remember that. I just ended up buying a new stock one as I have been reading that I won't be able to do much more in terms of downpipe/exhausts yet. I want to get orders to europe and I think I'll stick with mods that can probably pass a emissions test.
I'll just nab a tune from someone and call her a day.
 Old 12-09-2015, 04:17 AM   #10
jhise's Avatar
Posts: 25   (View Stats)
jhise is just really nicejhise is just really nicejhise is just really nicejhise is just really nicejhise is just really nice
when i bought my ms6. the ebcs was missing. After some searching i found that the stratfield ebcs will work without a tune. I ran one for almost a year without a tune and no issues.
jhise is offline   Reply With Quote
 Old 12-09-2015, 04:57 AM   #11
Justin@Freektune's Avatar
Posts: 954   (View Stats)
On a stock turbo I recommend running a bcs in two port mode. When running in 3 port mode you have to disconnect a hose on the bottom of the wastegate actuator and cap it off. That cap is prone to cracking and deteriorating over time. When that happens. The turbo has zero boost control and will over boost. So it's a liability in my eyes.
That being said, any of the 3 ports that vendors sell can be run in two port mode and function just like stock.
Bryce@Freektune likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Bryce@Freektune (12-10-2015), Easter Bunny (12-10-2015), neganox (12-09-2015), robbspeed (12-09-2015)
 Old 09-20-2018, 01:20 PM   #12
Ds_06_Speed6's Avatar
Posts: 38   (View Stats)
Ds_06_Speed6 will become famous soon enoughDs_06_Speed6 will become famous soon enough
I know this shits old as fuck, but didnt feel like making a new thread.
My question is in regards to running 3 port on the stock turbo. On my current tune with you, I have the Grimmspeed in 2 port mode, Im about to put in a Gaurdian Angel V3 which will protect against overboost. Since I will be running the GA V3, would you tune me for 3 port on the stock turbo?
06 Speed6
AP V3| CS TIP/SRI |CS 50/50 BPV |CS Test Pipe |CS FP internals|CS high pressure SS fuel line |CPE EGR delete |CPE TMIC |JBR Boost Tubes |JBR Trilogy race mounts |JBR short shift kit |Grimmspeed EBCS |GA V3|Custom FREEK tune
Ds_06_Speed6 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Ds_06_Speed6 For This Un-useful Post:
Mauro_Penguin (09-25-2018), zenit (09-20-2018)
 Old 09-21-2018, 10:25 AM   #13
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Doubt he will reply to your request here. Best to find the email thread from your original correspondence when you did the tune and contact him that way.
Fstrnyou likes this.
 Old 12-01-2018, 01:02 AM   #14
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I have a Grimmspeed in my 3MPS BK (Mazdaspeed3 gen1) and a Cobb in my CX7. They both have similar turbos (GTX3071R gen1 on the 3 and GTX2867R gen2 on the CX7). To be honest I did not feel any difference tuning them, even though the LEC/BEC tables are a few percents off when I compare them and of course the WGDC tables look different because the cars have different power goals, different intakes and exhausts.
As far as I know all these aftermarket EBCSs (CS, Cobb, Grimmspeed, JBR, Stratified, whatever) are based on two electro-valves so you can say that some of the above are pretty much the same EBCS.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
GMAC will be Saab's preferred lender Haltech Automotive News 0 03-15-2010 10:10 PM
Page generated in 0.35194 seconds with 28 queries
