Like Tree13Likes
 Old 06-26-2015, 11:10 PM   #1
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
I run 1 step colder without issue at all and I'm only intake / tip / dp / internals, just saying
sent via tapafail!
nice, glad they worked out for you.
Considering all the slight differences all of us MS3/MS6/CX-7 owners come up against it hardly surprises me that there are people with minor-mid-max bolt-ons who have had good results with stock HR to one step colder HR. In the end I guess most of us are just going to have to try it to know for sure.
I'm certainly not trying to lead anyone in the wrong direction regarding heat ranges on Sp plugs, just trying to see if others can chime in as well to add to the info resource.
AwAfrican likes this.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
 Old 06-27-2015, 08:23 AM   #2
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I bought a VP jug and the dern lip isn't square with the seal under the lid so it leaks. I'm going to have to sand it down and square it. So disappointed.
2013 CWP and Stock
Awal (06-27-2015)
 Old 06-27-2015, 07:25 PM   #3
Awal's Avatar
Good to know, at their prices, shit shouldn't be leaking. Have you since compared it to another new one to see if they're all the same?
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-27-2015, 07:28 PM   #4
NCspecV81's Avatar
nope. I'm gonna file this one down and find another solution if I need more jugs.
2013 CWP and Stock
Awal (06-27-2015)
 Old 06-27-2015, 09:14 PM   #5
AwAfrican's Avatar
Posts: 1,038   (View Stats)
Edit: posted in wrong thread *face palm* well I guess that's what happens when you spend 12hrs working on cars during the day
sent via tapafail!
2013 Black MS3
 Old 07-21-2015, 12:03 PM   #6
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
What AFR are you guys targeting? I run a 2 gallon mix. I'm finally getting around to dialing in a new methanol tune tonight…been probably over a month since I last ran it. Last run I did with this proportion, I didn't vdyno my tune, but it made a significant difference And at $4 a gallon I can't afford not to do it.
2007 Mazdaspeed3 GT
Awal (07-21-2015), Tifosi42 (07-21-2015)
 Old 07-21-2015, 08:06 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
I run 2 gallons per tank and I target 12.1 AFR. I also spray with a D07 nozzle
MD1032 (07-21-2015)
 Old 07-21-2015, 11:46 PM   #8
Awal's Avatar
Ok, I would say I've been running about a max of 2 liters (approx 1/2 a gallon) per tank (of 91 w/ up to 10% eth) and I went from having occasional non WOT KR peaks of 4.5 to the occasional non WOT peak of 1.9-2.5 KR. During WOT I am never going over .5 KR and I used to hit 1-1.5 KR sometimes at WOT.
I know the occasional high peaks here and there under partial throttle aren't really much to worry about, but I have DEFINITELY noticed a pretty significant difference in KR all around since I've been adding a bit of meth in tank for the last few weeks.
Again, I'm not tuning for it, as I have a few more mods to do before I start my custom tune, but so far, @ $5 cdn (2l of meth) per tank of gas, I'm happy with the results:cost ratio.
Next step I thought I might try is the OTS 93 oct map (the rest of the map staying the same) to see if the in tank meth I've been adding will meet the 93 Oct requirements.
Regardless, I have seen a benefit in reduced KR, and considering a full tank lasts me 2-3 weeks, $5 ain't shit.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
The Following User Says Thank You to Awal For This Useful Post:
acousticdefbot (07-22-2015)
 Old 07-22-2015, 02:32 AM   #9
acousticdefbot's Avatar
Posts: 319   (View Stats)
Originally Posted by Awal View Post
a full tank lasts me 2-3 weeks...
Awal likes this.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
 Old 07-22-2015, 12:55 PM   #10
Awal's Avatar
Originally Posted by acousticdefbot View Post
Because 3minute commute, equals just about 17k Kms since September 2013
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 07-22-2015, 05:42 AM   #11
MD1032's Avatar
Groans: 143
Yeah, that's one thing I've noticed with Methanol, it pretty much eliminates 95% of the KR you usually see. I haven't yet seen any LSPI events with Methanol either (granted I've probably only used it for about 1000 miles total), just tip-in/part throttle knock which is generally understood around here to not be real. It's great being able to just floor it when your BATs are 180°F and not see a single count of KR.
Well last night I got through 7 revisions and still didn't get any knock whatsoever. I'm basically running the E37 map posted here at this point, which I wasn't able to do before with the stock IC on the same mix. I'm probably going to try slowly leaning out further from 11.6 (already up from the 11.0 I was using on 93) and then if I still don't see knock, possibly target higher loads/boost. Currently running 2.30/20 tapering to 1.80/17.5.
Oh, and 3rd gear logs are now useless for vdyno. Getting some wheelspin finally...that's progress.
2007 Mazdaspeed3 GT
Awal (07-22-2015), Tifosi42 (07-22-2015)
 Old 07-22-2015, 04:09 PM   #12
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
Curious if 2L of meth will allow use of a 93 octane map. Around here 91 is very common and a few places carry 94 at obscene prices.
2010 Mazdaspeed3 Tech
JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings
Cobb Accessport v3 / XLE BPV / Cobb Knob
Damond Motorsports License Plate Tow Mount / EGR Delete
Ultimate Racing Test Pipe
Autotech Fuel Pump Internals
CP-E XFlex Stage2 RMM
Stratified Stage 3 93oct OTS+
AnubisFSU is offline   Reply With Quote
The Following User Says Thank You to AnubisFSU For This Useful Post:
Awal (07-22-2015)
 Old 07-22-2015, 09:26 PM   #13
Awal's Avatar
So am I my friend, so am I. I just need to find a bit of spare time to transfer my WGDC values from my 91 map to the 93.
We actually have 94 octane here at every Chevron, but unfortunately they 'pride' themselves on it being guaranteed 100% ethanol free. Before I had my AP I had been running Chevron 94 octane since the car was new, once I got the AP though, I decided to run a tank of 91 octane, which has up to 10% ethanol, and I found I got just as good or better performance from my MS3 in every way, even without any mods or ecu flashes.
Petro Canada and Husky used to carry 94 octane out here in BC about 5 years a go or so, those were the good old days for forced induction vehicles.
Canada needs to get over the whole 'ethanol is durty' complex.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 07-22-2015, 09:59 PM   #14
AnubisFSU's Avatar
I bought 2 gallons of methyl hydrate from Canadian tire, 2L currently in the tank with some shell 91. Running a stage 2 91 Oct map until I grab a couple logs. I'll hopefully have some results with a 93 map after this weekend. Huskey here still carries 94 Oct but it doesn't specify how much ethonal content it contains.
 Old 07-24-2015, 06:13 PM   #15
AnubisFSU's Avatar
Finally found a safe place to get a 4th gear log, boosted air temp 110F - 120F. Going to flash a 93 version of this map.
 Old 07-25-2015, 12:13 AM   #16
AnubisFSU's Avatar
Managed to get a good 4th gear log with a 93 octane map, currently have shell 91 with half a gallon of methyl hydrate in the tank. everything looks safe.
 Old 07-25-2015, 12:16 AM   #17
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
You know there is calculators on teh interwebs, so you don't have to guess lol
Built motor
GTX3071
Meth
6th Port
 Old 07-25-2015, 12:59 AM   #18
AnubisFSU's Avatar
For serious? I did search for a calculator quickly but nothing turned up. Guess I'll take another look.
 Old 07-25-2015, 01:30 AM   #19
Hammology's Avatar
Groans: 36
Your welcome: Octane Mix Calculator - Wallace Racing
Built motor
GTX3071
Meth
6th Port
The Following User Says Thank You to Hammology For This Useful Post:
AnubisFSU (07-25-2015)
 Old 09-09-2015, 11:39 PM   #20
Tifosi42's Avatar
Posts: 179   (View Stats)
@MD1032; @Awal; @AnubisFSU;
Any updates on the in tank methanol? Since the closest E85 station is an hour and a half drive and no WMI for autox I am looking to get a 2 gallon in tank methanol tune along with a straight 93 tune once I acquire a downpipe. I have been running one gallon of VP M1 in tank just for knock protection (not tuned for it) with great success at the drag strip and at autox as well. Just curious how it has been working out for you guys and if you are seeing typical E85 mix results.
BNR S3 - FREEKTUNED on E33
Tifosi42 is offline   Reply With Quote
The Following User Says Thank You to Tifosi42 For This Useful Post:
Awal (09-10-2015)
 Old 09-10-2015, 05:37 AM   #21
MD1032's Avatar
Groans: 143
I've been running it intermittently for 2-3 months now. I use it whenever I get the chance. I would definitely say I'm getting low E85 mix (3-4 gal) or better results. The only problem with running methanol is that when you switch back to 93, the car knocks all over the place and the power sucks balls. The whole car just runs way better with methanol.
I haven't even used all of my knock headroom and I'm running 100% WGDC in the top end with timing at 18.0° @ 6000, 20.0° @ 6500 RPM. I have logs under those conditions on the dyno where BATs climb into the 140-160°F range with zero KR, and that's with AFR's in the 12's and high 11's (can't remember what I was targeting at that time exactly). I always tell people, besides the power, the best thing about methanol is that you can just floor it whenever you want...no worrying about heatsoak or BATs.
Do yourself a favor and pay the little extra for the methanol map. You probably won't even use the 93 map except in an emergency once you feel what the methanol can do.
Awal likes this.
2007 Mazdaspeed3 GT
The Following 3 Users Say Thank You to MD1032 For This Useful Post:
Awal (09-10-2015), JgamB (09-10-2015), Tifosi42 (09-10-2015)
 Old 09-10-2015, 03:23 PM   #22
Tifosi42's Avatar
I can definitely attest to the not worrying about KR with methanol in the tank. I did an autox run in July with a starting BAT of 172 F and there was no knock at all, I couldn't believe it. I will be definitely be getting both maps just because I probably won't run methanol in the winter time. Thanks for the input and the update @MD1032;
Awal (09-10-2015)
 Old 09-10-2015, 07:46 PM   #23
sheston's Avatar
I've been running Meth @ 2 gallons per tank for at least a year and a half. No knock problems (running 28 psi at low rpms on the K04) and live in Texas, so 2 of the worst heat sources. Like @MD1032; said, I get more protection with 2 gallons of Meth than I did with 4.5 gallons of E
Awal likes this.
The Following 2 Users Say Thank You to sheston For This Useful Post:
Awal (09-10-2015), Tifosi42 (09-11-2015)
 Old 09-11-2015, 12:30 AM   #24
Hammology's Avatar
Groans: 36
28psi on a K04?
Built motor
GTX3071
Meth
6th Port
 Old 09-11-2015, 11:26 AM   #25
Awal's Avatar
28psi on a K04?
Must have one of the K04s made out of unicorn horns and fairy wings But more likely it's just tuned really well. I was hoping to get to at least 20 on the K04 but my 1st one ate it's self at 17 psi.
Originally Posted by speed23 View Post
Are you guys modifying fuel gravity table in atr for only 1 or maybe 2 gallon of meth added? I run a pretty rich 93 oct tune so assume that I should fine leaving it alone (but adding a little timing to make use of the added octane)
Yes, the people running 2 gallons or more need to modify the FG table to get the full benefits of running that much in tank meth. I know there's some info around here somewhere on it, but because I wasn't using that much it's not something I did.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
speed23 (09-11-2015)
 Old 09-11-2015, 02:21 PM   #26
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
28psi on a K04?
Sweet zombie Jesus, man.
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
The Following User Says Thank You to aromig For This Useful Post:
Awal (09-12-2015)
 Old 09-10-2015, 11:42 PM   #27
Awal's Avatar
I've suffered a 11k mile premature K04 failure setback, and prior to the 'catastrophic failure' of my K04, at 2l (1/2 a gallon) of meth per tank my KR went way down and it made a substantial difference with our shit gas.
Again, that was not for the sake of tuning, I just added a bit during the peak of summer to help the shitty gas we get up here aid in POT/WOT knock prevention. And it did so wonderfully.
I didn't tune for it as I'm about to start supplying E85 from our shop, just making sure I have all the red tape covered b4 doing so.
ATM I'm back to stock (engine wise) and I'm still throwing a liter into the tank to help with octane as I'm only running 91 (w/ up to 10% ethanol) because I found 94 oct w/ 0% ethanol (guaranteed) didn't perform as well as 91 w/ up to 10% eth without any meth added.
I'll have more info/data one I've finished dealing with the Mazda Warranty BS and get my engine mods back on and i start proper tuning..
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 09-11-2015, 06:29 AM   #28
Tifosi42's Avatar
Has anyone done a UOA besides @NCspecV81; (with incredible amounts of meth)? I was curious if anyone has seen any excessive wear metals with the two gallons of in tank methanol. I run Rotella T6 @ 5k mile change intervals myself but have not done a UOA as of yet. Also, are the any other issues that one may have encountered due to the two gallons in tank besides excessive grinning from extra hp/tq?
 Old 09-11-2015, 07:03 AM   #29
MD1032's Avatar
Groans: 143
No.
Mazdaspeed 3/6 UOA Results
2007 Mazdaspeed3 GT
 Old 09-11-2015, 09:47 AM   #30
speed23's Avatar
Posts: 1,480   (View Stats)
 Old 10-18-2015, 05:17 PM   #31
MD1032's Avatar
Groans: 143
Sorry for the late reply here. I'm using @sheston;'s values (thanks again man!) for my 2 gallon mix and they work well enough with my car. The car will not run correctly without changing these values.
Fuel gravity = 0.7482 kg/m^3
Injector scalar = 1.08
I hope to see more people using this in the future. I really wish we had a dyno verified timing map for this mix, but the E85 ones phate posted are probably in the ballpark.
2007 Mazdaspeed3 GT
SoyBean (06-28-2018), speed23 (10-18-2015)
 Old 09-11-2015, 08:26 PM   #32
sheston's Avatar
Well, maybe only 27.5, and it does fall like a rock after 4 - 4.5 k
How else am I going to destroy it and convince the wifey that I need a BT?
Don't get to use it much, but pulled a new corvette on the way home. I wish I could have seen the look on his face as I pulled by him (at illegal speeds)
Awal likes this.
aromig (09-12-2015), Awal (09-12-2015)
 Old 09-12-2015, 01:33 AM   #33
Awal's Avatar
I'll be tty soon..
I want to run my K04 pretty hard, but I don't mind if it tapers safely.. I don't want anything near yer peak PSI, I just want to be able to turn it up with a Corksport 3.5 SRI/TIP, CS TMIC w/ stock shroud, CS 80mm catless TBE wit 1 resonator, and all supporting mods (HPFP internals, EBC, 3 bar MAP, AP V3, CS BPV). Using WMI or tuning for intank Meth or e85 (just convincing my partner at the shop it's work stocking) for the end tune..
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 09-28-2015, 09:33 PM   #34
chance91's Avatar
Posts: 56   (View Stats)
chance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond reputechance91 has a reputation beyond repute
Good discussion. Reminds me of Toluene that was very popular a while back, though It got expensive. Toluene is about 114 octane vs methanol's 100 or so.
Some notes, Methanol/Toluene are sold as paint thinners/detergents, and likely remove some lubricant properties from the fuel (noted some people mentioned this) ATF or other lube would be a good idea to add into the mix to keep things happy. Also, here is a bit of info on the subject. Porsche/Audi people have been doing this for over 30 years. Also, some of these chems are used in making of illegal substances, so buying large amounts might get you flagged if you look suspicious, I recall buying a few 5 gallon buckets of toluene and getting my ID scanned.
Homebrew Octane Boosters
https://en.wikipedia.org/wiki/Octane...mber_.28RON.29
R M R+m/2
toluene 121 107 114
ethanol 108.6 89.7 99.15
methanol 108.7 88.6[ 98.65
E85 gas 102-105 85-87 94-96
Another interesting tidbit:
Toluene at 86% by volume fuelled all the turbo Formula 1 teams in the 1980s, first pioneered by the Honda team. The remaining 14% was a "filler" of n-heptane, to reduce the octane to meet Formula 1 fuel restrictions
chance91 is offline   Reply With Quote
The Following User Says Thank You to chance91 For This Useful Post:
Awal (10-01-2015)
 Old 09-29-2015, 06:33 PM   #35
Ozynigma's Avatar
Posts: 743   (View Stats)
@chande91; something doesn't seem right about your numbers. I've read Meth is much higher than that. I guess I could look it up again. But the hard numbers are that I got more KR protection with 2 gallons of Meth per fillup, than I did with 4.5 gallons of E85. Not sure how your numbers support those findings. Also, I'm not the only one who has had amazing results with Meth
Originally Posted by chance91 View Post
R M R+m/2
toluene 121 107 114
The numbers look pretty right to me.
Meth RON 109
E85 RON 102-105
Adding it to fuel that is say 98RON (in my country), meth will have a much greater effect than E85 and a similar effect to straight ethanol.
 Old 09-29-2015, 06:00 PM   #36
sheston's Avatar
 Old 09-29-2015, 09:13 PM   #37
chance91's Avatar
They are quoted numbers, not my own math, but seem relatively accurate. It doesn't take a significant octane increase to reduce knock. That's the point of 93 or 91 vs 89 or 87 in higher performance cars. Some Audi and Porsche cars will advance timing for use with up to 95 octane (R+M/2 method, US).
Either way, check out the first link I posted, it has the formula for Methanol included if you know your exact mixture amounts.
Just being helpful, obviously Methanol in the tank will increase octane as it is much higher than any other fuel. There are other reasons it might feel better than ethanol, such as energy density, etc.
 Old 09-30-2015, 04:48 AM   #38
0nsp's Avatar
Posts: 143   (View Stats)
0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold
Groaned at 5 Times in 2 Posts
I'm really interested in trying this out because there is no E85 in this province. It seems like people are only using at most 2 gallons of methanol in the tank. However when I run it through the calculator, I get numbers of 3.5 gallons per tank for the equivalent octane of an E35 blend, or 5.35 gallons per task for the equivalent of an E48 blend, which is significantly more than what people have been running. Am I missing something? Is it too corrosive to be running that much in tank meth or has no one yet tried it?
07 BM MS3//
Power//MS CAI/COBB TIP/CP-e DP/CP-e TMIC/TS BPV/Greddy OCC/COBB AP/NGK plugs/Autotech FP
Handling//Hotchkis F+RSB/TRZ RMM + TMM/Enkei RPF1 on Continental Extremecontact DW/solid shifter bushings/custom weighted shift knob/JBR SSP/KW v3 coils
Cosmetic//Tinted tails + windows + side markers/blue led interior/EONON D5102/Heated seats/Speedline tinted+heated mirrors/2tone emblems/painted calipers
0nsp is offline   Reply With Quote
 Old 09-30-2015, 07:14 AM   #39
Justin@Freektune's Avatar
Posts: 954   (View Stats)
I would run up to 2 gallons. That is what I tested in my car, and it performs very well. remember with e85, that is only 85% alcohol, where methanol is 100% alcohol. The Stoich ratio of methanol is also less than it is with ethanol, so when tuning, using 2 gallons of meth seems and adjusting the tables in the tune, it lines up close to with where we would set the tune for a 3 gallon e85 mix
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 6 Users Say Thank You to Justin@Freektune For This Useful Post:
0nsp (09-30-2015), Awal (10-01-2015), MD1032 (09-30-2015), MS3Shadow (09-30-2015), speed23 (09-30-2015), Thepedigree13 (09-30-2015)
 Old 09-30-2015, 06:12 AM   #40
Tifosi42's Avatar
Methanol Direct Injection
0nsp (09-30-2015)
Poor gas mileage from 260-280 miles on a tank down to 200-220 miles per tank? Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 08-27-2011 07:59 PM
AEM Methanol Kit Questions AntiStock MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 8 12-28-2010 05:20 PM
Page generated in 0.64889 seconds with 35 queries
