Like Tree13Likes
 Old 06-21-2015, 06:31 PM   #1
JgamB's Avatar
Posts: 2,566   (View Stats)
Default In-tank Methanol Tuning
I spoke briefly with @Justin@Freektune; about in-tank methanol, and it appears it's an overlooked means of getting E85 performance by visiting Home Depot instead of trying to find a station with Corn.
There are some upsides to it:
No meth kit needed, so no plumbing, wiring, failsafes, nozzles, etc. to worry about. No additional tank to keep full or mount somewhere you might be uncomfortable with for safety.
2 Gallons of Meth will give you the knock protection of ~3 gallons of E85, so you can get that sweet spark advance and give up just a little bit less specific gravity (fuel overhead) with a higher gasoline concentration.
And of course the downsides:
It's being consumed all of the time, unlike a MAF/MAP based controller that is only using methanol when you demand it with your right foot.
It's comparatively expensive.
You aren't getting *extra* fueling like a meth kit can provide, but if you're not looking for 400hp or more it isn't going to matter.
Justin stated he's got a couple/few cars that have been running like this for quite some time, and used to do it himself for a couple of years. If you don't want to install a meth kit, and you can't get E85 readily but want more power, this could be a viable alternative. I'm just tossing it out there because it looks like a solid alternative to get some alcohol in your combustion chamber with minimal fuss and great results.
The Following 17 Users Say Thank You to JgamB For This Useful Post:
Addikted To Boost (06-21-2015), Agent_Orange (06-21-2015), aromig (06-22-2015), Awal (06-24-2015), brandon3212 (06-22-2015), Gunslinger (07-30-2015), Hammology (06-22-2015), Hush (06-22-2015), ItsNox (06-22-2015), Justin@Freektune (06-21-2015), Mauro_Penguin (06-22-2015), MBalik (07-22-2015), MD1032 (06-23-2015), ms6mil (06-21-2015), RJTSi (06-21-2015), speed23 (10-14-2015), WetzMS3 (06-22-2015)
 Old 06-21-2015, 06:37 PM   #2
JgamB's Avatar
I should add that local speed shops often carry VP race fuels - meth here is $5 per gallon by the gallon, or $3.80 per gallon for a 45 gal drum. I didn't ask if it was M1, 3, or 5.
Awal (06-24-2015)
 Old 06-21-2015, 06:47 PM   #3
RJTSi's Avatar
Posts: 205   (View Stats)
RJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond repute
Thanks for the info dude. Looks like this would be pointless for me since I have 2 E85 stations within a mile of my front door. I'm also looking for the added fuel headroom that meth gives since I'm about to run out of injector DC with the Corksubishi 18g
True Red 2008.5 SPEED3 Sport...RIP
VRM 2006 Mazdaspeed6....Corksport TD05H-18g, Rambo 3.5" intake, Circuit Werks catless DP, AP E85 tuned, CX Racing FMIC piping w/ TR8, 3 port EBCS, 3-bar Map, heavy Shift weight, Shifter bushings, Autotech internals, RMM, Hawk Pads, SS clutch and brake lines
RJTSi is offline   Reply With Quote
The Following 2 Users Say Thank You to RJTSi For This Useful Post:
Awal (06-24-2015), JgamB (06-21-2015)
 Old 06-21-2015, 07:03 PM   #4
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I highly suggest if you're putting it intank to go with an m3 or m5 mix as they have an added hydrocarbon and will make more power than straight meth. M5 is generally considered the better variant when using it intank. I use 1 gallon of straight m1, but don't really "tune" for it. I would not suggest using m3 or m5 in a wmi system. Not good for the pump.
2013 CWP and Stock
The Following 5 Users Say Thank You to NCspecV81 For This Useful Post:
aromig (06-22-2015), Awal (06-24-2015), ItsNox (06-22-2015), JgamB (06-21-2015), ms6mil (06-21-2015)
 Old 06-22-2015, 01:35 PM   #5
speedboost's Avatar
Posts: 13   (View Stats)
speedboost is a glorious beacon of lightspeedboost is a glorious beacon of lightspeedboost is a glorious beacon of lightspeedboost is a glorious beacon of lightspeedboost is a glorious beacon of light
Neutral  +1 score
I just finished tune last week with Stratified - 94 pump & only 1 gallon meth in tank gave me e85 type results.
Able to get 19* timing and hold boost at 18.5psi to 6500 on K04. Very happy with results!
We don't have e85 stations in province Alberta so I was looking for alternative fuel too.
Home Depot way cheaper than VP fuels around here.
Meth is thought of as being corrosive but in amounts around 10% it is safe in tank.
People have been using for years as octane booster. Took me a while of searching to find other mazdaspeeds using but they are out there - and it works!
From what I've read it sounds like 1 amount of meth = 2 amount e85 by volume, so you only need half as much.
DaltonP801 likes this.
Cobb SRI, TIP, DP // AT internals // Denzo itv22 // AP V3 // Stratified
speedboost is offline   Reply With Quote
The Following 3 Users Say Thank You to speedboost For This Useful Post:
Awal (06-24-2015), speed23 (06-22-2015), tparker14 (08-29-2015)
 Old 06-22-2015, 03:58 PM   #6
AwAfrican's Avatar
Posts: 1,038   (View Stats)
What are you using for meth?
2013 Black MS3
 Old 06-22-2015, 04:13 PM   #7
speedboost's Avatar
good ol' Home Depot - Methyl Hydrate 99.9%
walmart & rona have but around here seems cheapest spot.
About the half cost M1 for me
The Following User Says Thank You to speedboost For This Useful Post:
Awal (06-24-2015)
 Old 06-22-2015, 05:38 PM   #8
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
Where in Alberta are you? Fury on Sherwood park freeway has m1 for something $1.35/litre is what it works out to
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
The Following User Says Thank You to justinsane87 For This Useful Post:
speed23 (05-01-2018)
 Old 12-18-2015, 05:20 PM   #9
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
I am thinking of running 1 gallon of methanol in tank. What should I change my fuel gravity and injector scalar to? Injector scalar is currently at 1.00, and fuel gravity is at 0.74
Sorry if that's already been answered
Thanks!
 Old 06-22-2015, 04:29 PM   #10
AwAfrican's Avatar
Well dam this may be a viable option! I'm in Ontario so not much e85 either. I'm not pushing enough yet to even warrant e85 or meth just yet but its nice to know that down the road this is an option. Especially if Justin has already tuned a couple of cars this way.
2013 Black MS3
The Following User Says Thank You to AwAfrican For This Useful Post:
Awal (06-24-2015)
 Old 06-22-2015, 04:42 PM   #11
RJTSi's Avatar
Does using in tank meth avoid the injector headroom reduction that comes with e85?
The Following User Says Thank You to RJTSi For This Useful Post:
Awal (06-24-2015)
 Old 06-22-2015, 05:47 PM   #12
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
No.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
Awal (06-24-2015), Mauro_Penguin (06-25-2015), phate (06-23-2015), RJTSi (06-22-2015), WetzMS3 (06-23-2015)
 Old 06-22-2015, 05:47 PM   #13
AwAfrican's Avatar
How do injectors / fuel pump hold up to meth in the fuel tank?
2013 Black MS3
 Old 06-22-2015, 06:04 PM   #14
Justin@Freektune's Avatar
Posts: 954   (View Stats)
They hold up perfectly fine. 10% meth in gasoline vs. 10% ethanol is very common across the world. So going a little beyond that has shown no ill signs. I ran 2 gallons of meth per tank on top of my meth injection for quite a while. The only thing it's starts to hurt is your wallet if you are running vp fuels. A gallon of vp m1 can cost anywhere from 7-10 bucks a gallon where I live.
Awal likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post:
AwAfrican (06-22-2015), Awal (06-24-2015), Hammology (06-22-2015), JgamB (06-22-2015), Tifosi42 (07-23-2015), WetzMS3 (06-23-2015), xfeejayx (06-23-2015)
 Old 06-22-2015, 06:18 PM   #15
sheston's Avatar
Posts: 1,847   (View Stats)
@Justin@Freektune; and @JgamB; where do you get the 2 gallons of Meth equals 3 gallons of E85? I've been using it for over a year now, and it seems more like @speedboost; has experience, I run 2 gallons of Meth instead of 4.5 gallons E85 and think I get better results.
@speedboost; You should post a Vdyno. Are you built?
 Old 06-22-2015, 07:55 PM   #16
There is no 2 gallons meth equals 3 gallons e85 equation haha
I have just seen similar results with a 2 gallon meth mix compared to small e85 mixes. I think Jason was just stating that a little meth in tank goes a long way for knock protection
PTE 6062
633HP/523TQ
Awal (06-24-2015), JgamB (06-22-2015), Mauro_Penguin (06-25-2015), WetzMS3 (06-23-2015)
 Old 06-22-2015, 07:34 PM   #17
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
The only thing that stops me from doing this is the price. Meth isn't cheap around here. I wish they sold methyl hydrate in Home Depot here like they do in Canada.
Built motor
GTX3071
Meth
6th Port
 Old 06-22-2015, 08:32 PM   #18
NCspecV81's Avatar
@Hammology; I'm not sure about CA, but in NC some tireshops keep methanol for farmers' tractors. Methanol is used in combination with a water mix to "fill" tires to provide additional weight/traction. I know a few places where I live that carries pure methanol in the generic, "off brand" variety for such tire filling.
I may give it a whirl once all my VP runs out...bwhahah whenever that is.
2013 CWP and Stock
 Old 06-22-2015, 08:34 PM   #19
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
Methanol has a higher heat of vaporization than E so you get good in cylinder cooling along with what others have said (knock protection and potentially more power through spark advance)
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
The Following User Says Thank You to mize13 For This Useful Post:
 Old 06-22-2015, 09:01 PM   #20
Tokay444's Avatar
Groans: 793
If you can't find methyl hydrate at your home dept, look for denatured alcohol.
It's ethanol with a small percentage of methanol to make it poisonous to drink.
Demodded.
The Seals
The Following 8 Users Say Thank You to Tokay444 For This Useful Post:
3starmagnum (06-27-2015), chaser27 (09-11-2015), Hammology (06-22-2015), JgamB (06-22-2015), Mauro_Penguin (06-25-2015), NCspecV81 (06-22-2015), Putin 2.3T (06-23-2015), WetzMS3 (06-23-2015)
 Old 06-23-2015, 12:07 AM   #21
IMASA's Avatar
Posts: 209   (View Stats)
There's always air brake anti-freeze which is supposed to be 99% methanol and 1% rust inhibitor. It's about half the price of methyl hydrate where I'm located.
 Old 07-22-2015, 10:36 PM   #22
MBalik's Avatar
Posts: 500   (View Stats)
MBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the world
Would this actually work or is it best to stick to the other stuff?
Sent from my SGH-I747M using Tapatalk
2013 White Pearl Pu
Back to stock.... for now
MBalik is offline   Reply With Quote
 Old 06-23-2015, 07:26 AM   #23
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Damn, Justin, you're a double meth head? Thought you looked a little crazy eyed.
Look for threads by Phate for more info on this, also. He did some bench testing for what happens to a couple seals/components in different concentrations. He's got the math for meth/ETH DISI equivalent, but not sure he posted that.
Between Justin and Clint, I think they've proven this works wonders for an in tank solution with minimal side effect with low concentrations.
-Wetz
QFT
The Following 5 Users Say Thank You to xfeejayx For This Useful Post:
AwAfrican (06-23-2015), Hammology (06-23-2015), JgamB (06-23-2015), Justin@Freektune (06-23-2015), Mauro_Penguin (06-25-2015)
 Old 06-23-2015, 05:30 PM   #24
JgamB's Avatar
Clint's tests showed some significant swelling of the seals at high concentrations, but this looks like a safe bet if you're just chasing MBT.
I've seen quite a few people complain they can't get corn and wish they could, don't want to screw with a meth kit, etc. Figured this might help awareness as it's not specifically listed on Justin's (or any other tuner's site) to my knowledge.
Awal and Axela_EN like this.
The Following 4 Users Say Thank You to JgamB For This Useful Post:
Awal (06-24-2015), Justin@Freektune (06-23-2015), Mauro_Penguin (06-25-2015), xfeejayx (06-23-2015)
 Old 06-24-2015, 12:30 AM   #25
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
Going to try it tomorrow if I get the chance, HD or Lordco Bound, HD 1st. I was thinking about just dropping in 2l (roughly 1/2 gal) and hoping it lets me run 91 Canadian octane with no KR over .5 on a 93 oct map..
will report back with results.
long version of subbed.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
The Following User Says Thank You to Awal For This Useful Post:
JgamB (06-24-2015)
 Old 06-24-2015, 08:51 PM   #26
Awal's Avatar
I think one of the big reasons our 94 octane gasoline in BC (or at least the Vancouver area) fails so hard is because Chevron uses 0% ethanol in the 94.
It looks like I have been wasting money on Chevron 94 octane in my MS3 ever since I bought it new. I tried my 1st full tank of Chevron 91 (up to 10% ethanol, which I assume means NO LESS than 9.9% ethanol considering how much $ they save by using it in the 1st place) and I did notice that I actually got about an average of 1-1.5 mpg better, city and HWY. I noticed no loss in power, and no excessive knock/KR when I hooked up my AP about 1/2 way through the tank.
Been on a bunch of different OTS and modified OTS tunes since then, and a full tank of 94, which I noticed sucked quite a bit for KR, but then again I switched up maps quite a bit.
I'm back on full 91, just put in 1/2 a gallon of methanol from HD and topped it up with 17 liters of 89.. lol totally not scientific, I know, I just wanted to get something in to the tank on top of the methanol to mix it in a little better.. Going to run through the tank and do as many logs as I can. Next tank I'll put in a full gallon of meth when I fill up, which should be roughly 7% of my tank. Not sure how big our fuel tanks are on paper, but I have fit 65 litres (when pretty much bone dry) numerous times.
I'm not putting in the meth to tune on it, I plan on going to WMI and will tune for that, but I am seeing if I can mitigate/eliminate an occasional knock spike (1-3, sometimes, rarely, 4-5) that I get around 4500-5000 rpm at POT. I know knock sensors can occasionally be triggered by vibrations, and I'm a little bit suspicious of the PMM. Gonna try swapping out the PMM some time in the future if the occasional KR continues..
Chevron should have a sign that says "CONTAINS 0% WIN" for their 94 octane. No wonder people loved Husky and Petro Can 94 so much back when we had it, theirs had ethanol in it..
Sorry, that was a super ramble..
TL;DR (I put in .5 gallon of meth to a tank, will report back with any findings)
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-24-2015, 10:57 PM   #27
IMASA's Avatar
If you're in Vancouver, make the trek to Arcade station in West Vancouver. They have E85. I run about a 25% E85 mix, about 10L per tank. I bring 30L in jerry cans and 1 trip lasts 4 tanks of fuel.
The Following User Says Thank You to IMASA For This Useful Post:
Awal (06-25-2015)
 Old 06-25-2015, 12:53 AM   #28
Awal's Avatar
Yup, I'm familiar with that e85 pump, if I was in the heart of Vancouver I would have already done it. I'm just in the process of getting all the j-cans possible, then buying a few others then I'm gonna make a trip down there and fill up as many as I can fit. I will store it in a several 5 gal or one 50 gal drum at work and use our shop fluid pump to tap it as needed.
For now tho, $20 of meth for 1-3 tanks of study was easy/convenient, and worth giving it a go..
Been keeping an eye out for e85 pumps as well , would love one in Langley or even Surrey.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-24-2015, 09:20 PM   #29
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
In tank methanol has really intrigued me lately, since I don't really want to do meth kit or anything like that but I'm drooling for its cooling properties. E85 is also not readily available around me, closest station with it is like 45 mins away from me. So this sounds like a legitimate alternative to lower my BAT and prevent knocks. I'm curious to see what is the long term result of this
TAPPPPPin
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
 Old 06-24-2015, 09:38 PM   #30
Awal's Avatar
In tank won't lower your BATs, WMI will (or better ICs, or external H20 IC misting).
When u use Water/Math or Meth injection, in a Throttle Body spacer or in the TB end of the IC cold pipe, you are essentially creating a boost/MAF voltage (starts working at X amount of boost, or starts working at X MAF voltage[g/s of air]) controlled chemical intercooler.
Via the tank, you are using meth as an octane booster, nothing more. Especially since this is a Direct Injection application the fuel never has an opportunity to be in the intake side of the motor.
Doesn't mean it doesn't work to allow your car to run more power, just does it in a very different way.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
The Following 3 Users Say Thank You to Awal For This Useful Post:
aromig (06-24-2015), GARRETHEXTREME (06-24-2015), TRBLSM (12-11-2016)
 Old 06-24-2015, 10:10 PM   #31
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
Purpledrank tuned my car for intank meth and I love it. For me the biggest setback is measuring out the methanol into a gas can to put it in the car. Storing it and transporting it can also be a hassle, but the gains are well worth it. Best gas I can get where I live is 91 but its really more like 89, no ethanol anywhere either. For people in a similar situation this may be the best option for you.
Awal likes this.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
The Following User Says Thank You to superman For This Useful Post:
Awal (06-24-2015)
 Old 06-24-2015, 10:32 PM   #32
maddocx240's Avatar
Posts: 823   (View Stats)
There was a thread on this in fuel section that died out. I was contemplating trying this out. Gonna see how if home depot carries it out here by me. But I do have 2 e85 stations not far from me too.
The Following User Says Thank You to maddocx240 For This Useful Post:
Awal (06-24-2015)
 Old 06-24-2015, 10:35 PM   #33
Awal's Avatar
LOL, yeah, when putting it in tank one of the 1st things I thought is why don't they sell this shit in no spill/drip containers.. I will fab up a nice in-tank funnel tomorrow at work that will minimize this issue, but yeah it can be a bit of a sloppy job with paper funnels ..
If you happen to be filling up when yer not on your last bar of fuel and you are tuned for it, then yeah, I could see measuring out the right amount being a bitch and a half. In those situations, just try to use a 1l or 1qt container to help the process, but remember, this is not about being within an oz or several ml to get it close to what you want, unless you are tuning it for a VERY specific ratio, just try to meet your min desired ratio then add a splash (50 mls to an oz) to be safe...
Luckily with the OEM hatchback Mazda mesh cargo net, I can carry around a ton of shit without anything sliding around or spilling, so that helps with carrying around a few different sized bottles/funnels along with some gallon jugs of meth.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-25-2015, 02:11 PM   #34
insain's Avatar
Posts: 15   (View Stats)
insain has a spectacular aura aboutinsain has a spectacular aura about
I'm in the same situation as well. I picked up a cp-e intercooler and colder plugs to see if my knock would go down during WOT, but with the crappy 94 Chevron I had no luck . I'm thinking of making the trips to Arcade Station or dumping methyl hydrate in the tank for th the time being.
insain is offline   Reply With Quote
The Following User Says Thank You to insain For This Useful Post:
Awal (07-21-2015)
 Old 06-25-2015, 08:29 PM   #35
Awal's Avatar
I've read and heard from quite a few people who had a bad experience going to colder plugs with only minor bolt-on mods, most switched back to stock heat range right away.
I will look for a VP fuels jerrycan. I have like 4-5 different designs and they all suck if you need to use them on a regular basis.
Derp, I'm just going to make up a cap that screws onto the top of the 1 gallon jugs with a better filler nozzle that pulls the pour point out another 2-3" and see how that works..
With stuff that is so thin like meth/brake clean/solvents all of the containers I see daily in the shop drip until they are about 1/2 full or less.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-25-2015, 08:01 PM   #36
sheston's Avatar
I agree with @Awal; the only thing wrong with Meth in tank is the dripping. I really hate the new child proof gas cans. Makes you have to use a funnel
 Old 06-25-2015, 08:10 PM   #37
I would invest in a vp race fuel can. It will make your life a whole lot easier
PTE 6062
633HP/523TQ
aromig (06-26-2015), Awal (06-25-2015), xfeejayx (06-26-2015)
 Old 06-25-2015, 08:02 PM   #38
AwAfrican's Avatar
Yay for Ontario petro 94 with e
sent via tapafail!
2013 Black MS3
Awal (07-21-2015)
 Old 06-25-2015, 08:14 PM   #39
sheston's Avatar
I've got 2 normal 5 gallon tanks and one JP race fuel, with the filler neck and valve. Use the VP to fill up a 2 gallon POS....
Get 15 gallons at a wack, works pretty good for me. @Justin@Freektune; Does VP make a 2 gallon fuel can? I didn't see it where I shop
 Old 06-26-2015, 07:45 AM   #40
AwAfrican's Avatar
I run 1 step colder without issue at all and I'm only intake / tip / dp / internals, just saying
sent via tapafail!
2013 Black MS3
Awal (06-26-2015)
Poor gas mileage from 260-280 miles on a tank down to 200-220 miles per tank? Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 08-27-2011 07:59 PM
AEM Methanol Kit Questions AntiStock MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 8 12-28-2010 05:20 PM
Page generated in 0.64867 seconds with 40 queries
